I’m trying to install mullvad-vpn from the AUR. After about 15 minutes of building, it spits outs the following error and I don’t know how to fix it.
I don’t believe my connection is through a proxy or anything like that.
Installing JavaScript dependencies...
npm ERR! code ETIMEDOUT
npm ERR! syscall connect
npm ERR! errno ETIMEDOUT
npm ERR! network request to https://registry.npmjs.org/yocto-queue/-/yocto-queue-0.1.0.tgz failed, reason: connect ETIMEDOUT 2606:4700::6810:1223:443
npm ERR! network This is a problem related to network connectivity.
npm ERR! network In most cases you are behind a proxy or have bad network settings.
npm ERR! network
npm ERR! network If you are behind a proxy, please make sure that the
npm ERR! network 'proxy' config is set properly. See: 'npm help config'
npm ERR! A complete log of this run can be found in:
npm ERR! /var/tmp/pamac-build-computer/mullvad-vpn/src/npm_cache/_logs/2022-06-02T09_24_45_116Z-debug-0.log
==> ERROR: A failure occurred in prepare().
Aborting...
