Manjari brothers help.I’ve installed 20.1 from a live CD,on a macBookPro(late 2011) as the only OS.Please suggest a cheap mouse(wired or wireless)that will work because i’ve spent a small fortune on mice and none of them works with any consistency.Oh,kernel is 5.9.16-1and i’m an amateur.
Welcome here, @anstzik,
please post
inxi -Fazy
What mice did you test and are they connected via USB or bluetooth?
Kernel 5.9 is EOL. Please fully update your system. Kernel 5.10 is LTS.
I did update to K 5.10.42-1 LTS.Didn’t help.I’m afraid the problem is with both USB 2.0 receptors on the motherboard.Maybe they’re worn-out.I’II check it and let you know,Manjaristi.Thanks anyway.IT’S COMING HOME…
