A very valid point. Logs below.
At risk of being too verbose, this is what I used for the Steam Log output itself. Ended up being 4000 lines by the time I shut it down. Am willing to re-run with less if desired and post that.
PROTON_LOG=1 \
PRESSURE_VESSEL_SYSTEMD_SCOPE=1 \
STEAM_LINUX_RUNTIME_VERBOSE=1 \
steam 2>&1 | tee steam.log
And the direct proton log output from SC4
Proton: 1647272410 proton-5.13-6d
SteamGameId: 24780
Command: ['/home/cv/.local/share/Steam/steamapps/common/SimCity 4 Deluxe/Apps/SimCity 4.exe', '-w', '-d:DirectX', '-intro:off']
Options: {'forcelgadd'}
depot: 0.20230808.56728
pressure-vessel: 0.20230804.0 scout
scripts: 0.20230804.0
soldier: 0.20230808.56728 soldier 0.20230808.56728
esync: up and running.
30823.189:0028:002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ntdll.dll" at 000000007BC00000: builtin
30823.189:0028:002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernelbase.dll" at 000000007B000000: builtin
30823.190:0028:002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernel32.dll" at 000000007B610000: builtin
30823.191:0028:002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\wineboot.exe" at 0000000000400000: builtin
30823.191:0028:002c:trace:seh:check_bpf_jit_enable enabled 0x31.
30823.193:0028:002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ucrtbase.dll" at 00007F80DB700000: builtin
30823.193:0028:002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\sechost.dll" at 0000000061900000: builtin
30823.193:0028:002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\advapi32.dll" at 00007F80DBD30000: builtin
30823.230:0030:0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ntdll.dll" at 000000007BC00000: builtin
30823.231:0030:0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernelbase.dll" at 000000007B000000: builtin
30823.231:0030:0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernel32.dll" at 000000007B610000: builtin
30823.232:0030:0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\services.exe" at 0000000000400000: builtin
30823.232:0030:0034:trace:seh:install_bpf Seccomp filters already installed.
30823.235:0030:0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ucrtbase.dll" at 00007FA4EFA80000: builtin
30823.235:0030:0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\sechost.dll" at 0000000061900000: builtin
30823.235:0030:0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\advapi32.dll" at 00007FA4EFCA0000: builtin
30823.236:0030:0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\rpcrt4.dll" at 000000006FBC0000: builtin
30823.238:0030:0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\version.dll" at 0000000065780000: builtin
30823.238:0030:0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\setupapi.dll" at 000000006A700000: builtin
30823.239:0030:0034:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\userenv.dll" at 0000000067D00000: builtin
30823.283:003c:0040:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ntdll.dll" at 000000007BC00000: builtin
30823.284:003c:0040:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernelbase.dll" at 000000007B000000: builtin
30823.284:003c:0040:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernel32.dll" at 000000007B610000: builtin
30823.284:003c:0040:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\plugplay.exe" at 0000000000400000: builtin
30823.284:003c:0040:trace:seh:install_bpf Seccomp filters already installed.
30823.287:003c:0040:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ucrtbase.dll" at 00007F89FFE80000: builtin
30823.287:003c:0040:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\sechost.dll" at 0000000061900000: builtin
30823.287:003c:0040:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\advapi32.dll" at 00007F8A000A0000: builtin
30823.287:003c:0040:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\rpcrt4.dll" at 000000006FBC0000: builtin
30823.289:003c:0040:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\version.dll" at 0000000065780000: builtin
30823.289:003c:0040:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\setupapi.dll" at 000000006A700000: builtin
30823.290:003c:0040:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\gdi32.dll" at 00007F89FF860000: builtin
30823.290:003c:0040:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\user32.dll" at 00007F89FFA20000: builtin
30824.582:003c:0040:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ole32.dll" at 0000000065000000: builtin
30824.582:003c:0040:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\imm32.dll" at 000000006BEC0000: builtin
30824.610:0058:005c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ntdll.dll" at 000000007BC00000: builtin
30824.611:0058:005c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernelbase.dll" at 000000007B000000: builtin
30824.611:0058:005c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernel32.dll" at 000000007B610000: builtin
30824.611:0058:005c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\winedevice.exe" at 0000000000400000: builtin
30824.612:0058:005c:trace:seh:install_bpf Seccomp filters already installed.
30824.614:0058:005c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ucrtbase.dll" at 00007FAC75000000: builtin
30824.614:0058:005c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\sechost.dll" at 0000000061900000: builtin
30824.614:0058:005c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\advapi32.dll" at 00007FAC75500000: builtin
30824.616:0058:005c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\msvcrt.dll" at 00007FAC74F00000: builtin
30824.616:0058:005c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ntoskrnl.exe" at 0000000067A00000: builtin
30824.629:0058:005c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\rpcrt4.dll" at 000000006FBC0000: builtin
30824.654:0058:0068:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,0,0xe8f7b0,30,(nil))
30824.660:0058:0064:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\drivers\\winebus.sys" at 00007FAC74EB0000: builtin
30824.661:0058:0064:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\version.dll" at 0000000065780000: builtin
30824.661:0058:0064:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\setupapi.dll" at 000000006A700000: builtin
30824.664:0058:0064:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,0,0xc7ef70,30,(nil))
30824.668:0058:0064:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\hidclass.sys" at 0000000062C40000: builtin
30824.668:0058:0064:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\drivers\\winehid.sys" at 000000006B3C0000: builtin
30824.670:0058:0064:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\hid.dll" at 0000000064B80000: builtin
30824.673:0058:0064:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\gdi32.dll" at 00007FAC74CC0000: builtin
30824.673:0058:0064:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\user32.dll" at 00007FAC74A20000: builtin
30824.905:0058:0064:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ole32.dll" at 0000000065000000: builtin
30824.905:0058:0064:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\imm32.dll" at 000000006BEC0000: builtin
30824.907:0058:0070:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,0,0x11af980,30,(nil))
30824.981:0058:0064:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\drivers\\wineusb.sys" at 00007FAC67A90000: builtin
30825.015:0088:008c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ntdll.dll" at 000000007BC00000: builtin
30825.016:0088:008c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernelbase.dll" at 000000007B000000: builtin
30825.017:0088:008c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernel32.dll" at 000000007B610000: builtin
30825.017:0088:008c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\winedevice.exe" at 0000000000400000: builtin
30825.017:0088:008c:trace:seh:install_bpf Seccomp filters already installed.
30825.019:0088:008c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ucrtbase.dll" at 00007FA584C00000: builtin
30825.020:0088:008c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\sechost.dll" at 0000000061900000: builtin
30825.020:0088:008c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\advapi32.dll" at 00007FA585160000: builtin
30825.021:0088:008c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\msvcrt.dll" at 00007FA584B00000: builtin
30825.021:0088:008c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ntoskrnl.exe" at 0000000067A00000: builtin
30825.034:0088:008c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\rpcrt4.dll" at 000000006FBC0000: builtin
30825.039:0088:0098:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,0,0xe8f7b0,30,(nil))
30825.043:0088:0094:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\drivers\\mountmgr.sys" at 00007FA585120000: builtin
30825.049:0088:0094:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\version.dll" at 0000000065780000: builtin
30825.049:0088:0094:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\setupapi.dll" at 000000006A700000: builtin
30825.115:0088:0098:trace:seh:NtQueryInformationThread (0x64,0,0xe8f750,30,(nil))
30825.254:0088:00a0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\gdi32.dll" at 00007FA5846E0000: builtin
30825.254:0088:00a0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\user32.dll" at 00007FA584420000: builtin
30825.258:0028:002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\gdi32.dll" at 00007F80DAA60000: builtin
30825.259:0028:002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\rpcrt4.dll" at 000000006FBC0000: builtin
30825.261:0028:002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\version.dll" at 0000000065780000: builtin
30825.262:0028:002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\setupapi.dll" at 000000006A700000: builtin
30825.262:0028:002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\user32.dll" at 00007F80DA620000: builtin
30825.262:0028:002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ole32.dll" at 0000000065000000: builtin
30825.262:0028:002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\shcore.dll" at 0000000064940000: builtin
30825.262:0028:002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\shlwapi.dll" at 0000000068A40000: builtin
30825.262:0028:002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\shell32.dll" at 00007F80DAC20000: builtin
30825.489:0088:00a0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ole32.dll" at 0000000065000000: builtin
30825.489:0088:00a0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\imm32.dll" at 000000006BEC0000: builtin
30825.718:0028:002c:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\imm32.dll" at 000000006BEC0000: builtin
30825.721:0020:0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ntdll.dll" at 7BC00000: builtin
30825.723:0020:0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernelbase.dll" at 7B000000: builtin
30825.723:0020:0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernel32.dll" at 7B620000: builtin
30825.726:0020:0024:trace:loaddll:build_module Loaded L"C:\\Program Files (x86)\\Steam\\steam.exe" at 7EFC0000: builtin
30825.729:0020:0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ucrtbase.dll" at 7E520000: builtin
30825.729:0020:0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\sechost.dll" at 61B00000: builtin
30825.729:0020:0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\advapi32.dll" at 7EEE0000: builtin
30825.730:0020:0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\gdi32.dll" at 7E3B0000: builtin
30825.731:0020:0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\rpcrt4.dll" at 6FDC0000: builtin
30825.734:0020:0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\version.dll" at 65980000: builtin
30825.734:0020:0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\setupapi.dll" at 6A900000: builtin
30825.734:0020:0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\user32.dll" at 7E030000: builtin
30825.734:0020:0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ole32.dll" at 65200000: builtin
30825.742:0020:0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\shcore.dll" at 64B40000: builtin
30825.742:0020:0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\shlwapi.dll" at 68C40000: builtin
30825.742:0020:0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\shell32.dll" at 7C430000: builtin
30826.668:0020:0024:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\imm32.dll" at 6C0C0000: builtin
30826.674:00a8:00ac:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ntdll.dll" at 000000007BC00000: builtin
30826.675:00a8:00ac:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernelbase.dll" at 000000007B000000: builtin
30826.675:00a8:00ac:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernel32.dll" at 000000007B610000: builtin
30826.676:00a8:00ac:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\explorer.exe" at 0000000000400000: builtin
30826.676:00a8:00ac:trace:seh:check_bpf_jit_enable enabled 0x31.
30826.678:00a8:00ac:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ucrtbase.dll" at 00007FC404000000: builtin
30826.678:00a8:00ac:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\sechost.dll" at 0000000061900000: builtin
30826.678:00a8:00ac:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\advapi32.dll" at 00007FC404570000: builtin
30826.678:00a8:00ac:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\gdi32.dll" at 00007FC403E30000: builtin
30826.679:00a8:00ac:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\rpcrt4.dll" at 000000006FBC0000: builtin
30826.681:00a8:00ac:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\version.dll" at 0000000065780000: builtin
30826.681:00a8:00ac:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\setupapi.dll" at 000000006A700000: builtin
30826.681:00a8:00ac:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\user32.dll" at 00007FC403A20000: builtin
Setting breakpad minidump AppID = 24780
Steam_SetMinidumpSteamID: Caching Steam ID: 76561198003757397 [API loaded no]
30826.933:00a8:00ac:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ole32.dll" at 0000000065000000: builtin
30826.933:00a8:00ac:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\imm32.dll" at 000000006BEC0000: builtin
30826.938:00a8:00ac:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\winex11.drv" at 00007FC403780000: builtin
WARNING: radv is not a conformant Vulkan implementation, testing use only.
MESA-INTEL: warning: Haswell Vulkan support is incomplete
30829.904:003c:0078:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,12,0x14bfd00,4,(nil))
30830.101:00b4:00b8:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ntdll.dll" at 000000007BC00000: builtin
30830.103:00b4:00b8:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernelbase.dll" at 000000007B000000: builtin
30830.103:00b4:00b8:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernel32.dll" at 000000007B610000: builtin
30830.103:00b4:00b8:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\explorer.exe" at 0000000000400000: builtin
30830.103:00b4:00b8:trace:seh:check_bpf_jit_enable enabled 0x31.
30830.104:00a8:00ac:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\shcore.dll" at 0000000064940000: builtin
30830.104:00a8:00ac:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\shlwapi.dll" at 0000000068A40000: builtin
30830.104:00a8:00ac:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\shell32.dll" at 00007FC401A20000: builtin
30830.106:00b4:00b8:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ucrtbase.dll" at 00007FC11C780000: builtin
30830.106:00b4:00b8:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\sechost.dll" at 0000000061900000: builtin
30830.106:00b4:00b8:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\advapi32.dll" at 00007FC11C9A0000: builtin
30830.107:00b4:00b8:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\gdi32.dll" at 00007FC11C5C0000: builtin
30830.107:00b4:00b8:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\rpcrt4.dll" at 000000006FBC0000: builtin
30830.109:00b4:00b8:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\version.dll" at 0000000065780000: builtin
30830.110:00b4:00b8:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\setupapi.dll" at 000000006A700000: builtin
30830.110:00b4:00b8:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\user32.dll" at 00007FC11C220000: builtin
30830.111:00a8:00ac:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\oleaut32.dll" at 000000006A100000: builtin
30830.111:00a8:00ac:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\actxprxy.dll" at 0000000000DB0000: builtin
30830.113:0020:00a4:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\winex11.drv" at F6160000: builtin
30830.114:0030:0048:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,12,0xe9fd00,4,(nil))
30830.370:00b4:00b8:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ole32.dll" at 0000000065000000: builtin
30830.370:00b4:00b8:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\imm32.dll" at 000000006BEC0000: builtin
30830.373:00b4:00b8:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\winex11.drv" at 00007FC11BF20000: builtin
30830.393:00b4:00b8:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\shcore.dll" at 0000000064940000: builtin
30830.393:00b4:00b8:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\shlwapi.dll" at 0000000068A40000: builtin
30830.393:00b4:00b8:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\shell32.dll" at 00007FC11A220000: builtin
30830.398:00b4:00b8:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\oleaut32.dll" at 000000006A100000: builtin
30830.398:00b4:00b8:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\actxprxy.dll" at 0000000000BA0000: builtin
30830.435:00cc:00d0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ntdll.dll" at 7BC00000: builtin
30830.437:00cc:00d0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernelbase.dll" at 7B000000: builtin
30830.437:00cc:00d0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\kernel32.dll" at 7B620000: builtin
30830.437:00cc:00d0:trace:loaddll:build_module Loaded L"Z:\\home\\chris\\.local\\share\\Steam\\steamapps\\common\\SimCity 4 Deluxe\\Apps\\SimCity 4.exe" at 00400000: native
30830.441:00cc:00d0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ucrtbase.dll" at 7E8A0000: builtin
30830.441:00cc:00d0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\sechost.dll" at 61B00000: builtin
30830.441:00cc:00d0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ADVAPI32.dll" at 7EEB0000: builtin
30830.443:00cc:00d0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\iphlpapi.dll" at 7EE80000: builtin
30830.443:00cc:00d0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ws2_32.dll" at 7EE30000: builtin
30830.443:00cc:00d0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\WSOCK32.dll" at 6C2C0000: builtin
30830.447:00cc:00d0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\rpcrt4.dll" at 6FDC0000: builtin
30830.448:00cc:00d0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\version.dll" at 65980000: builtin
30830.448:00cc:00d0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\setupapi.dll" at 6A900000: builtin
30830.449:00cc:00d0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\gdi32.dll" at 7E4D0000: builtin
30830.449:00cc:00d0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\user32.dll" at 7E630000: builtin
30830.449:00cc:00d0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\mpr.dll" at 6DBC0000: builtin
30830.456:00cc:00d0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\ole32.dll" at 65200000: builtin
30830.457:00cc:00d0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\shcore.dll" at 64B40000: builtin
30830.457:00cc:00d0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\shlwapi.dll" at 68C40000: builtin
30830.457:00cc:00d0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\shell32.dll" at 7DA30000: builtin
30830.457:00cc:00d0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\WININET.dll" at 6B4C0000: builtin
30830.460:00cc:00d0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\DSOUND.dll" at 6D5C0000: builtin
30830.462:00cc:00d0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\msacm32.dll" at 66640000: builtin
30830.462:00cc:00d0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\WINMM.dll" at 639C0000: builtin
30830.463:00cc:00d0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\OPENGL32.dll" at 7A840000: builtin
30830.466:00cc:00d0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\imm32.dll" at 6C0C0000: builtin
30830.467:00cc:00d0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\usp10.dll" at 62800000: builtin
30830.467:00cc:00d0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\comctl32.dll" at 6E8C0000: builtin
30830.467:00cc:00d0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\MSVFW32.dll" at 00320000: builtin
30830.720:00cc:00d0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\winex11.drv" at 7D730000: builtin
30830.732:00cc:00d0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\uxtheme.dll" at 62340000: builtin
30830.732:00cc:00d0:trace:seh:NtSetInformationThread (0xfffffffe,17,(nil),0)
30830.744:00cc:00d0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\psapi.dll" at 6AEC0000: builtin
30830.745:00cc:00d0:trace:loaddll:build_module Loaded L"Z:\\home\\chris\\.local\\share\\Steam\\steamapps\\common\\SimCity 4 Deluxe\\Apps\\dbghelp.dll" at 66400000: builtin
30830.754:00cc:00d0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\lsteamclient.dll" at F5F20000: builtin
30830.755:00cc:00d0:trace:loaddll:build_module Loaded L"C:\\Program Files (x86)\\Steam\\steamclient.dll" at 38000000: native
30830.844:00cc:00d0:trace:loaddll:free_modref Unloaded module L"C:\\Program Files (x86)\\Steam\\steamclient.dll" : native
30830.857:00cc:00d0:trace:loaddll:free_modref Unloaded module L"Z:\\home\\chris\\.local\\share\\Steam\\steamapps\\common\\SimCity 4 Deluxe\\Apps\\dbghelp.dll" : builtin
30830.858:00cc:00d0:trace:loaddll:free_modref Unloaded module L"C:\\windows\\system32\\psapi.dll" : builtin
30830.860:00cc:00d0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\psapi.dll" at 6AEC0000: builtin
30830.860:00cc:00d0:trace:seh:NtQueryInformationThread (0xfffffffe,0,0x31fd34,1c,(nil))
30830.860:00cc:00d0:trace:seh:NtSetInformationThread (0xfffffffe,3,0x31fd48,4)
30831.261:00cc:00d0:trace:seh:NtSetInformationThread (0xfffffffe,3,0x31fd48,4)
30831.268:00cc:00d0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\rasapi32.dll" at 6EAC0000: builtin
30831.271:0088:0098:trace:seh:NtQueryInformationThread (0x88,0,0xe8f750,30,(nil))
30831.437:00cc:00d0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\wined3d.dll" at F3190000: builtin
30831.437:00cc:00d0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\DDRAW.DLL" at 66CC0000: builtin
30831.531:00cc:00d0:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
30831.581:00cc:00d0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\msvcrt.dll" at E5350000: builtin
30831.581:00cc:00d0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\dxvk_config.dll" at 69240000: native
30831.583:00cc:00d0:trace:seh:NtQueryInformationThread (0xd0,0,0x31ece4,1c,(nil))
30831.593:00cc:00d4:trace:seh:NtQueryInformationThread (0xfffffffe,12,0x1aefe30,4,(nil))
30831.665:00cc:00d8:trace:seh:NtQueryInformationThread (0xfffffffe,12,0x1d0fe30,4,(nil))
30831.745:00cc:00dc:trace:seh:NtQueryInformationThread (0xfffffffe,12,0x1aefe30,4,(nil))
30831.890:00cc:00d0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\oleaut32.dll" at 6A300000: builtin
30831.890:00cc:00d0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\mmdevapi.dll" at 70340000: builtin
30831.916:00cc:00d0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\winepulse.drv" at F0E90000: builtin
30831.935:00cc:00d0:trace:loaddll:build_module Loaded L"C:\\windows\\system32\\winealsa.drv" at E3050000: builtin
30831.935:00cc:00d0:trace:loaddll:free_modref Unloaded module L"C:\\windows\\system32\\winealsa.drv" : builtin
30831.949:00cc:00d0:trace:seh:NtSetInformationThread (0xf4,3,0x31f7dc,4)
30831.979:00cc:00d0:trace:seh:NtSetInformationThread (0xfc,3,0x31fba8,4)
30831.980:00cc:00d0:trace:seh:NtSetInformationThread (0x104,3,0x31fc64,4)
30831.990:00cc:00f0:trace:seh:NtQueryInformationThread (0xfffffffe,12,0x36cfec4,4,(nil))
30832.000:00cc:00ec:trace:seh:NtQueryInformationThread (0xfffffffe,12,0x35bfec4,4,(nil))
30832.014:00cc:00e0:trace:seh:NtQueryInformationThread (0xfffffffe,12,0x190fe30,4,(nil))
30832.057:00cc:00d0:trace:loaddll:free_modref Unloaded module L"C:\\windows\\system32\\rasapi32.dll" : builtin
30832.057:00cc:00d0:trace:seh:NtQueryInformationThread (0x104,0,0x31fc54,1c,(nil))
30832.057:00cc:00f4:trace:seh:NtQueryInformationThread (0xfffffffe,12,0x37dfe60,4,(nil))
30832.297:00cc:00d0:trace:loaddll:free_modref Unloaded module L"C:\\windows\\system32\\psapi.dll" : builtin
30832.310:00cc:00d0:trace:seh:NtSetInformationThread (0xf4,3,0x31f7fc,4)
30833.328:003c:0074:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,12,0x12afda0,4,(nil))
30833.328:003c:0054:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,12,0x109fda0,4,(nil))
30833.328:0058:0084:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,12,0x17dfda0,4,(nil))
30833.329:003c:0050:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,12,0xe8fda0,4,(nil))
30833.330:0058:0068:trace:seh:dispatch_exception code=6ba flags=0 addr=000000007B01193E ip=7b01193e tid=0068
30833.330:0058:0068:trace:seh:dispatch_exception rax=000000007b0118f0 rbx=0000000000e8f1a8 rcx=0000000000e8eed0 rdx=0000000000000000
30833.330:0058:0068:trace:seh:dispatch_exception rsi=00000000000000cc rdi=00000000000000be rbp=0000000000000000 rsp=0000000000e8eeb0
30833.330:0058:0068:trace:seh:dispatch_exception r8=0000000000000000 r9=0000000000000000 r10=0000000000ecf508 r11=0000000000e8ecd8
30833.330:0058:0068:trace:seh:dispatch_exception r12=0000000000e8f1a8 r13=000000000005e4c0 r14=0000000000000000 r15=00000000ffba0000
30833.330:0058:0068:trace:seh:call_vectored_handlers calling handler at 0000000067A0D3E0 code=6ba flags=0
30833.330:0058:0068:trace:seh:call_vectored_handlers handler at 0000000067A0D3E0 returned 0
30833.330:0058:0068:trace:seh:call_vectored_handlers calling handler at 000000007B636530 code=6ba flags=0
30833.330:0058:0068:trace:seh:call_vectored_handlers handler at 000000007B636530 returned 0
30833.330:0058:0068:trace:seh:RtlVirtualUnwind type 1 rip 7b01193e rsp e8eeb0
30833.330:0058:0068:trace:seh:dump_unwind_info **** func 118f0-11977
30833.330:0058:0068:trace:seh:dump_unwind_info unwind info at 000000007B0A23A8 flags 0 prolog 0x11 bytes function 000000007B0118F0-000000007B011977
30833.330:0058:0068:trace:seh:dump_unwind_info 0x11: subq $0xc8,%rsp
30833.330:0058:0068:trace:seh:dump_unwind_info 0xa: pushq %rsi
30833.330:0058:0068:trace:seh:dump_unwind_info 0x9: pushq %rdi
30833.330:0058:0068:trace:seh:RtlVirtualUnwind type 1 rip 6fc067b1 rsp e8ef90
30833.330:0058:0068:trace:seh:dump_unwind_info **** func 467a0-467e5
30833.330:0058:0068:trace:seh:dump_unwind_info unwind info at 000000006FC29350 flags 0 prolog 0x4 bytes function 000000006FC067A0-000000006FC067E5
30833.330:0058:0068:trace:seh:dump_unwind_info 0x4: subq $0x28,%rsp
30833.330:0058:0068:trace:seh:RtlVirtualUnwind type 1 rip 6fbc9e54 rsp e8efc0
30833.330:0058:0068:trace:seh:dump_unwind_info **** func 9d60-9e55
30833.330:0058:0068:trace:seh:dump_unwind_info unwind info at 000000006FC27328 flags 0 prolog 0x6 bytes function 000000006FBC9D60-000000006FBC9E55
30833.330:0058:0068:trace:seh:dump_unwind_info 0x6: subq $0x38,%rsp
30833.330:0058:0068:trace:seh:dump_unwind_info 0x2: pushq %rbx
30833.330:0058:0068:trace:seh:dump_unwind_info 0x1: pushq %rsi
30833.330:0058:0068:trace:seh:RtlVirtualUnwind type 1 rip 67a21c9e rsp e8f010
30833.330:0058:0068:trace:seh:dump_unwind_info **** func 21ae0-21d00
30833.330:0058:0068:trace:seh:dump_unwind_info unwind info at 0000000067A33DE4 flags 0 prolog 0xe bytes function 0000000067A21AE0-0000000067A21D00
30833.330:0058:0068:trace:seh:dump_unwind_info 0xe: subq $0x330,%rsp
30833.330:0058:0068:trace:seh:dump_unwind_info 0x7: pushq %rbx
30833.330:0058:0068:trace:seh:dump_unwind_info 0x6: pushq %rsi
30833.330:0058:0068:trace:seh:dump_unwind_info 0x5: pushq %rdi
30833.330:0058:0068:trace:seh:dump_unwind_info 0x4: pushq %r12
30833.330:0058:0068:trace:seh:dump_unwind_info 0x2: pushq %r13
30833.330:0058:0068:trace:seh:call_stack_handlers found wine frame 0000000000E8F080 rsp e8f370 handler 0000000067A215A0
30833.330:0058:0068:trace:seh:call_teb_handler calling TEB handler 0000000067A215A0 (rec=0000000000E8EED0, frame=0000000000E8F080 context=0000000000E8E400, dispatch=0000000000E8E2D0)
30833.330:0058:0068:trace:seh:call_teb_handler handler at 0000000067A215A0 returned 1
30833.330:0058:0068:trace:seh:RtlVirtualUnwind type 1 rip 67a19f95 rsp e8f370
30833.330:0058:0068:trace:seh:dump_unwind_info **** func 19ec0-19fa6
30833.330:0058:0068:trace:seh:dump_unwind_info unwind info at 0000000067A339E0 flags 0 prolog 0x8 bytes function 0000000067A19EC0-0000000067A19FA6
30833.330:0058:0068:trace:seh:dump_unwind_info 0x8: subq $0x160,%rsp
30833.330:0058:0068:trace:seh:dump_unwind_info 0x1: pushq %rbx
30833.330:0058:0068:trace:seh:call_stack_handlers found wine frame 0000000000E8F3A0 rsp e8f4e0 handler 0000000067A22F50
30833.330:0058:0068:trace:seh:call_teb_handler calling TEB handler 0000000067A22F50 (rec=0000000000E8EED0, frame=0000000000E8F3A0 context=0000000000E8E400, dispatch=0000000000E8E2D0)
30833.330:0058:0068:trace:seh:RtlUnwindEx code=6ba flags=2 end_frame=0000000000E8F3A0 target_ip=0000000067A22EE6 rip=000000007bc5fdb2
30833.330:0058:0068:trace:seh:RtlUnwindEx rax=00000000ffba0000 rbx=0000000000e8f080 rcx=0000000000e8dcd0 rdx=0000000067a22ee6
30833.330:0058:0068:trace:seh:RtlUnwindEx rsi=0000000000e8e9d0 rdi=0000000000e8e400 rbp=0000000000e8d780 rsp=0000000000e8d600
30833.330:0058:0068:trace:seh:RtlUnwindEx r8=0000000000e8eed0 r9=0000000067a22f20 r10=0000000000e8e0e0 r11=0000000000025590
30833.330:0058:0068:trace:seh:RtlUnwindEx r12=0000000000e8eed0 r13=0000000000e8dcd0 r14=0000000000e8f3a0 r15=0000000000e8eed0
30833.330:0058:0068:trace:seh:RtlVirtualUnwind type 2 rip 7bc5fdb2 rsp e8d600
30833.330:0058:0068:trace:seh:dump_unwind_info **** func 5fd60-6062e
30833.330:0058:0068:trace:seh:dump_unwind_info unwind info at 000000007BC8A798 flags 0 prolog 0x13 bytes function 000000007BC5FD60-000000007BC6062E
30833.330:0058:0068:trace:seh:dump_unwind_info 0x13: subq $0x658,%rsp
30833.330:0058:0068:trace:seh:dump_unwind_info 0xc: pushq %rbx
30833.330:0058:0068:trace:seh:dump_unwind_info 0xb: pushq %rsi
30833.330:0058:0068:trace:seh:dump_unwind_info 0xa: pushq %rdi
30833.330:0058:0068:trace:seh:dump_unwind_info 0x9: pushq %rbp
30833.330:0058:0068:trace:seh:dump_unwind_info 0x8: pushq %r12
30833.330:0058:0068:trace:seh:dump_unwind_info 0x6: pushq %r13
30833.330:0058:0068:trace:seh:dump_unwind_info 0x4: pushq %r14
30833.330:0058:0068:trace:seh:dump_unwind_info 0x2: pushq %r15
30833.330:0058:0068:trace:seh:RtlVirtualUnwind type 2 rip 7bc6064f rsp e8dca0
30833.330:0058:0068:trace:seh:dump_unwind_info **** func 60630-60658
30833.330:0058:0068:trace:seh:dump_unwind_info unwind info at 000000007BC8A7B0 flags 0 prolog 0x7 bytes function 000000007BC60630-000000007BC60658
30833.330:0058:0068:trace:seh:dump_unwind_info 0x7: subq $0x508,%rsp
30833.330:0058:0068:trace:seh:RtlVirtualUnwind type 2 rip 67a22ee6 rsp e8e1b0
30833.330:0058:0068:trace:seh:dump_unwind_info **** func 22ecc-22ee8
30833.330:0058:0068:trace:seh:dump_unwind_info unwind info at 0000000067A33E90 flags 0 prolog 0x8 bytes function 0000000067A22ECC-0000000067A22EE8
30833.330:0058:0068:trace:seh:dump_unwind_info frame register rbp offset 0x0(%rsp)
30833.330:0058:0068:trace:seh:dump_unwind_info 0x8: subq $0x20,%rsp
30833.330:0058:0068:trace:seh:dump_unwind_info 0x4: leaq 0x0(%rsp),rbp
30833.330:0058:0068:trace:seh:dump_unwind_info 0x1: pushq %rbp
30833.330:0058:0068:trace:seh:RtlVirtualUnwind type 2 rip 67a22f19 rsp e8e1e0
30833.330:0058:0068:trace:seh:dump_unwind_info **** func 22ef0-22f1a
30833.330:0058:0068:trace:seh:dump_unwind_info unwind info at 0000000067A33E9C flags 0 prolog 0x4 bytes function 0000000067A22EF0-0000000067A22F1A
30833.330:0058:0068:trace:seh:RtlVirtualUnwind type 2 rip 67a22fa4 rsp e8e210
30833.330:0058:0068:trace:seh:dump_unwind_info **** func 22f50-22fa5
30833.330:0058:0068:trace:seh:dump_unwind_info unwind info at 0000000067A33EAC flags 0 prolog 0xa bytes function 0000000067A22F50-0000000067A22FA5
30833.330:0058:0068:trace:seh:dump_unwind_info 0xa: subq $0x30,%rsp
30833.330:0058:0068:trace:seh:dump_unwind_info 0x6: pushq %r12
30833.330:0058:0068:trace:seh:dump_unwind_info 0x4: pushq %r13
30833.330:0058:0068:trace:seh:dump_unwind_info 0x2: pushq %r14
30833.330:0058:0068:trace:seh:RtlVirtualUnwind type 2 rip 7bc5f4cf rsp e8e260
30833.330:0058:0068:trace:seh:dump_unwind_info **** func 5f200-5f741
30833.330:0058:0068:trace:seh:dump_unwind_info unwind info at 000000007BC8A758 flags 0 prolog 0x13 bytes function 000000007BC5F200-000000007BC5F741
30833.330:0058:0068:trace:seh:dump_unwind_info 0x13: subq $0x678,%rsp
30833.330:0058:0068:trace:seh:RtlVirtualUnwind type 2 rip 7bc5f81e rsp e8e920
30833.330:0058:0068:trace:seh:dump_unwind_info **** func 5f750-5fa89
30833.330:0058:0068:trace:seh:dump_unwind_info unwind info at 000000007BC8A770 flags 0 prolog 0xe bytes function 000000007BC5F750-000000007BC5FA89
30833.330:0058:0068:trace:seh:dump_unwind_info 0xe: subq $0x50,%rsp
30833.330:0058:0068:trace:seh:dump_unwind_info 0xa: pushq %rbx
30833.330:0058:0068:trace:seh:dump_unwind_info 0x9: pushq %rsi
30833.330:0058:0068:trace:seh:dump_unwind_info 0x8: pushq %rdi
30833.330:0058:0068:trace:seh:dump_unwind_info 0x7: pushq %rbp
30833.330:0058:0068:trace:seh:RtlVirtualUnwind type 2 rip 7bc5dab8 rsp e8e9b0
30833.330:0058:0068:trace:seh:dump_unwind_info **** func 5da50-5dac5
30833.330:0058:0068:trace:seh:dump_unwind_info unwind info at 000000007BC8A6D8 flags 0 prolog 0x7 bytes function 000000007BC5DA50-000000007BC5DAC5
30833.330:0058:0068:trace:seh:dump_unwind_info 0x7: subq $0x4f8,%rsp
30833.330:0058:0068:trace:seh:RtlVirtualUnwind type 2 rip 7b01193e rsp e8eeb0
30833.330:0058:0068:trace:seh:RtlVirtualUnwind type 2 rip 6fc067b1 rsp e8ef90
30833.330:0058:0068:trace:seh:RtlVirtualUnwind type 2 rip 6fbc9e54 rsp e8efc0
30833.331:0058:0068:trace:seh:dump_unwind_info 0x2: pushq %rbx
30833.331:0058:0068:trace:seh:dump_unwind_info 0x1: pushq %rsi
30833.331:0058:0068:trace:seh:RtlVirtualUnwind type 2 rip 67a21c9e rsp e8f010
30833.331:0058:0068:trace:seh:dump_unwind_info **** func 21ae0-21d00
30833.331:0058:0068:trace:seh:dump_unwind_info unwind info at 0000000067A33DE4 flags 0 prolog 0xe bytes function 0000000067A21AE0-0000000067A21D00
30833.331:0058:0068:trace:seh:dump_unwind_info 0xe: subq $0x330,%rsp
30833.331:0058:0068:trace:seh:dump_unwind_info 0x7: pushq %rbx
30833.331:0058:0068:trace:seh:dump_unwind_info 0x6: pushq %rsi
30833.331:0058:0068:trace:seh:dump_unwind_info 0x5: pushq %rdi
30833.331:0058:0068:trace:seh:dump_unwind_info 0x4: pushq %r12
30833.331:0058:0068:trace:seh:dump_unwind_info 0x2: pushq %r13
30833.331:0058:0068:trace:seh:RtlUnwindEx found builtin frame 0000000000E8F080 handler 0000000067A215A0
30833.331:0058:0068:trace:seh:call_teb_unwind_handler calling TEB handler 0000000067A215A0 (rec=0000000000E8EED0, frame=0000000000E8F080 context=0000000000E8DCD0, dispatch=0000000000E8D690)
30833.331:0058:0068:trace:seh:call_teb_unwind_handler handler at 0000000067A215A0 returned 1
30833.331:0058:0068:trace:seh:RtlVirtualUnwind type 2 rip 67a19f95 rsp e8f370
30833.331:0058:0068:trace:seh:dump_unwind_info **** func 19ec0-19fa6
30833.331:0058:0068:trace:seh:dump_unwind_info unwind info at 0000000067A339E0 flags 0 prolog 0x8 bytes function 0000000067A19EC0-0000000067A19FA6
30833.331:0058:0068:trace:seh:dump_unwind_info 0x8: subq $0x160,%rsp
30833.331:0058:0068:trace:seh:dump_unwind_info 0x1: pushq %rbx
30833.331:0058:0068:trace:seh:RtlRestoreContext returning to 67a22ee6 stack e8f370
30833.331:0030:0090:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,12,0x14cfda0,4,(nil))
30833.331:0030:009c:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,12,0x16dfda0,4,(nil))
30833.331:0058:0068:trace:seh:dispatch_exception code=6ba flags=0 addr=000000007B01193E ip=7b01193e tid=0068
30833.331:0058:0068:trace:seh:dispatch_exception rax=000000007b0118f0 rbx=0000000000e8f1a8 rcx=0000000000e8eec0 rdx=0000000000000000
30833.331:0058:0068:trace:seh:dispatch_exception rsi=00000000000000d2 rdi=000000000005a5c0 rbp=0000000000000000 rsp=0000000000e8eea0
30833.331:0058:0068:trace:seh:dispatch_exception r8=0000000000000000 r9=0000000000000000 r10=000000000005c9a8 r11=0000000000e8ef18
30833.331:0058:0068:trace:seh:dispatch_exception r12=0000000000e8f1a8 r13=000000000005e4c0 r14=0000000000000000 r15=00000000ffba0000
30833.331:0058:0068:trace:seh:call_vectored_handlers calling handler at 0000000067A0D3E0 code=6ba flags=0
30833.331:0058:0068:trace:seh:call_vectored_handlers handler at 0000000067A0D3E0 returned 0
30833.331:0058:0068:trace:seh:call_vectored_handlers calling handler at 000000007B636530 code=6ba flags=0
30833.331:0058:0068:trace:seh:call_vectored_handlers handler at 000000007B636530 returned 0
30833.331:0058:0068:trace:seh:RtlVirtualUnwind type 1 rip 7b01193e rsp e8eea0
30833.331:0058:0068:trace:seh:dump_unwind_info **** func 118f0-11977
30833.331:0058:0068:trace:seh:dump_unwind_info unwind info at 000000007B0A23A8 flags 0 prolog 0x11 bytes function 000000007B0118F0-000000007B011977
30833.331:0058:0068:trace:seh:dump_unwind_info 0x11: subq $0xc8,%rsp
30833.331:0058:0068:trace:seh:dump_unwind_info 0xa: pushq %rsi
30833.331:0058:0068:trace:seh:dump_unwind_info 0x9: pushq %rdi
30833.331:0058:0068:trace:seh:RtlVirtualUnwind type 1 rip 6fc067b1 rsp e8ef80
30833.331:0058:0068:trace:seh:dump_unwind_info **** func 467a0-467e5
30833.331:0058:0068:trace:seh:dump_unwind_info unwind info at 000000006FC29350 flags 0 prolog 0x4 bytes function 000000006FC067A0-000000006FC067E5
30833.331:0058:0068:trace:seh:dump_unwind_info 0x4: subq $0x28,%rsp
30833.331:0058:0068:trace:seh:RtlVirtualUnwind type 1 rip 6fbc9ce6 rsp e8efb0
30833.331:0058:0068:trace:seh:dump_unwind_info **** func 9c60-9ce7
30833.331:0058:0068:trace:seh:dump_unwind_info unwind info at 000000006FC27314 flags 0 prolog 0x7 bytes function 000000006FBC9C60-000000006FBC9CE7
30833.331:0058:0068:trace:seh:dump_unwind_info 0x7: subq $0x40,%rsp
30833.331:0058:0068:trace:seh:dump_unwind_info 0x3: pushq %rbx
30833.331:0058:0068:trace:seh:dump_unwind_info 0x2: pushq %rsi
30833.331:0058:0068:trace:seh:dump_unwind_info 0x1: pushq %rdi
30833.331:0058:0068:trace:seh:RtlVirtualUnwind type 1 rip 67a21bdd rsp e8f010
30833.331:0058:0068:trace:seh:call_stack_handlers found wine frame 0000000000E8F080 rsp e8f370 handler 0000000067A215A0
30833.331:0058:0068:trace:seh:call_teb_handler calling TEB handler 0000000067A215A0 (rec=0000000000E8EEC0, frame=0000000000E8F080 context=0000000000E8E3F0, dispatch=0000000000E8E2C0)
30833.331:0058:0068:trace:seh:call_teb_handler handler at 0000000067A215A0 returned 1
30833.331:0058:0068:trace:seh:RtlVirtualUnwind type 1 rip 67a19f95 rsp e8f370
30833.331:0058:0068:trace:seh:call_stack_handlers found wine frame 0000000000E8F3A0 rsp e8f4e0 handler 0000000067A22F50
30833.331:0058:0068:trace:seh:call_teb_handler calling TEB handler 0000000067A22F50 (rec=0000000000E8EEC0, frame=0000000000E8F3A0 context=0000000000E8E3F0, dispatch=0000000000E8E2C0)
30833.331:0058:0068:trace:seh:RtlUnwindEx code=6ba flags=2 end_frame=0000000000E8F3A0 target_ip=0000000067A22EE6 rip=000000007bc5fdb2
30833.331:0058:0068:trace:seh:RtlUnwindEx rax=00000000ffba0000 rbx=0000000000e8f080 rcx=0000000000e8dcc0 rdx=0000000067a22ee6
30833.331:0058:0068:trace:seh:RtlUnwindEx rsi=0000000000e8e9c0 rdi=0000000000e8e3f0 rbp=0000000000e8d770 rsp=0000000000e8d5f0
30833.331:0058:0068:trace:seh:RtlUnwindEx r8=0000000000e8eec0 r9=0000000067a22f20 r10=000000000000000a r11=0000000000000293
30833.331:0058:0068:trace:seh:RtlUnwindEx r12=0000000000e8eec0 r13=0000000000e8dcc0 r14=0000000000e8f3a0 r15=0000000000e8eec0
30833.331:0058:0068:trace:seh:RtlVirtualUnwind type 2 rip 7bc5fdb2 rsp e8d5f0
30833.331:0058:0068:trace:seh:dump_unwind_info **** func 5fd60-6062e
30833.331:0058:0068:trace:seh:dump_unwind_info unwind info at 000000007BC8A798 flags 0 prolog 0x13 bytes function 000000007BC5FD60-000000007BC6062E
30833.331:0058:0068:trace:seh:dump_unwind_info 0x13: subq $0x658,%rsp
30833.331:0058:0068:trace:seh:dump_unwind_info 0xc: pushq %rbx
30833.331:0058:0068:trace:seh:dump_unwind_info 0xb: pushq %rsi
30833.331:0058:0068:trace:seh:dump_unwind_info 0xa: pushq %rdi
30833.331:0058:0068:trace:seh:dump_unwind_info 0x9: pushq %rbp
30833.331:0058:0068:trace:seh:dump_unwind_info 0x8: pushq %r12
30833.331:0058:0068:trace:seh:dump_unwind_info 0x6: pushq %r13
30833.331:0058:0068:trace:seh:dump_unwind_info 0x4: pushq %r14
30833.331:0058:0068:trace:seh:dump_unwind_info 0x2: pushq %r15
30833.331:0058:0068:trace:seh:RtlVirtualUnwind type 2 rip 7bc6064f rsp e8dc90
30833.331:0058:0068:trace:seh:dump_unwind_info **** func 60630-60658
30833.331:0058:0068:trace:seh:dump_unwind_info unwind info at 000000007BC8A7B0 flags 0 prolog 0x7 bytes function 000000007BC60630-000000007BC60658
30833.331:0058:0068:trace:seh:dump_unwind_info 0x7: subq $0x508,%rsp
30833.331:0058:0068:trace:seh:RtlVirtualUnwind type 2 rip 67a22ee6 rsp e8e1a0
30833.331:0058:0068:trace:seh:dump_unwind_info **** func 22ecc-22ee8
30833.331:0058:0068:trace:seh:dump_unwind_info unwind info at 0000000067A33E90 flags 0 prolog 0x8 bytes function 0000000067A22ECC-0000000067A22EE8
30833.331:0058:0068:trace:seh:dump_unwind_info frame register rbp offset 0x0(%rsp)
30833.331:0058:0068:trace:seh:dump_unwind_info 0x8: subq $0x20,%rsp
30833.331:0058:0068:trace:seh:dump_unwind_info 0x4: leaq 0x0(%rsp),rbp
30833.331:0058:0068:trace:seh:dump_unwind_info 0x1: pushq %rbp
30833.331:0058:0068:trace:seh:RtlVirtualUnwind type 2 rip 67a22f19 rsp e8e1d0
30833.331:0058:0068:trace:seh:dump_unwind_info **** func 22ef0-22f1a
30833.331:0058:0068:trace:seh:dump_unwind_info unwind info at 0000000067A33E9C flags 0 prolog 0x4 bytes function 0000000067A22EF0-0000000067A22F1A
30833.331:0058:0068:trace:seh:RtlVirtualUnwind type 2 rip 67a22fa4 rsp e8e200
30833.331:0058:0068:trace:seh:dump_unwind_info **** func 22f50-22fa5
30833.331:0058:0068:trace:seh:dump_unwind_info unwind info at 0000000067A33EAC flags 0 prolog 0xa bytes function 0000000067A22F50-0000000067A22FA5
30833.331:0058:0068:trace:seh:dump_unwind_info 0xa: subq $0x30,%rsp
30833.331:0058:0068:trace:seh:dump_unwind_info 0x6: pushq %r12
30833.331:0058:0068:trace:seh:dump_unwind_info 0x4: pushq %r13
30833.331:0058:0068:trace:seh:dump_unwind_info 0x2: pushq %r14
30833.331:0058:0068:trace:seh:RtlVirtualUnwind type 2 rip 7bc5f4cf rsp e8e250
30833.331:0058:0068:trace:seh:dump_unwind_info **** func 5f200-5f741
30833.331:0058:0068:trace:seh:dump_unwind_info unwind info at 000000007BC8A758 flags 0 prolog 0x13 bytes function 000000007BC5F200-000000007BC5F741
30833.331:0058:0068:trace:seh:dump_unwind_info 0x13: subq $0x678,%rsp
30833.331:0058:0068:trace:seh:RtlVirtualUnwind type 2 rip 7bc5f81e rsp e8e910
30833.331:0058:0068:trace:seh:dump_unwind_info **** func 5f750-5fa89
30833.331:0058:0068:trace:seh:dump_unwind_info unwind info at 000000007BC8A770 flags 0 prolog 0xe bytes function 000000007BC5F750-000000007BC5FA89
30833.331:0058:0068:trace:seh:dump_unwind_info 0xe: subq $0x50,%rsp
30833.331:0058:0068:trace:seh:dump_unwind_info 0xa: pushq %rbx
30833.331:0058:0068:trace:seh:dump_unwind_info 0x9: pushq %rsi
30833.331:0058:0068:trace:seh:dump_unwind_info 0x8: pushq %rdi
30833.331:0058:0068:trace:seh:dump_unwind_info 0x7: pushq %rbp
30833.331:0058:0068:trace:seh:RtlVirtualUnwind type 2 rip 7bc5dab8 rsp e8e9a0
30833.331:0058:0068:trace:seh:dump_unwind_info **** func 5da50-5dac5
30833.331:0058:0068:trace:seh:dump_unwind_info unwind info at 000000007BC8A6D8 flags 0 prolog 0x7 bytes function 000000007BC5DA50-000000007BC5DAC5
30833.331:0058:0068:trace:seh:dump_unwind_info 0x7: subq $0x4f8,%rsp
30833.331:0058:0068:trace:seh:RtlVirtualUnwind type 2 rip 7b01193e rsp e8eea0
30833.331:0058:0068:trace:seh:RtlVirtualUnwind type 2 rip 6fc067b1 rsp e8ef80
30833.331:0058:0068:trace:seh:RtlVirtualUnwind type 2 rip 6fbc9ce6 rsp e8efb0
30833.331:0058:0068:trace:seh:RtlVirtualUnwind type 2 rip 67a21bdd rsp e8f010
30833.331:0058:0068:trace:seh:call_teb_unwind_handler calling TEB handler 0000000067A215A0 (rec=0000000000E8EEC0, frame=0000000000E8F080 context=0000000000E8DCC0, dispatch=0000000000E8D680)
30833.333:0058:0070:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,12,0x11afda0,4,(nil))
30833.333:0058:007c:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,12,0x13bfda0,4,(nil))
30833.333:0058:0080:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,12,0x15cfda0,4,(nil))
30833.335:0058:0068:trace:loaddll:free_modref Unloaded module L"C:\\windows\\system32\\drivers\\winebus.sys" : builtin
30833.337:0058:0068:trace:loaddll:free_modref Unloaded module L"C:\\windows\\system32\\drivers\\wineusb.sys" : builtin
30833.338:0058:0068:trace:loaddll:free_modref Unloaded module L"C:\\windows\\system32\\drivers\\winehid.sys" : builtin
30833.338:0058:0068:trace:loaddll:free_modref Unloaded module L"C:\\windows\\system32\\hidclass.sys" : builtin
30833.340:0058:0068:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,12,0xe8fda0,4,(nil))
30833.432:0030:0044:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,12,0xc8fda0,4,(nil))
30833.437:0030:0060:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,12,0x10afda0,4,(nil))
30833.437:0030:006c:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,12,0x12bfda0,4,(nil))
30833.438:0030:0038:trace:seh:NtQueryInformationThread (0xfffffffffffffffe,12,0xa7fda0,4,(nil))
pid 22052 != 22051, skipping destruction (fork without exec?)
