Hello everybody,
My 8bitdo ultimate controller does not connect to my system anymore. I used to connect it with Bluetooth (it never worked with the dongle). I tried different things like but nothing worked. I know that the system know that the controller is connected but cannot read inputs apparently (lsusb
Bus 001 Device 002: ID 05ac:024f Apple, Inc. Aluminium Keyboard (ANSI)
Bus 001 Device 003: ID 046d:c53f Logitech, Inc. USB Receiver
Bus 001 Device 023: ID 2dc8:3109 8BitDo Ultimate Wireless Controller
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
I also tried to install sudo dkms install -m xpad -v 0.4
, but it did not work.
I also tried pamac build xone-dkms
but it doesn’t work.
I am not sure if I did something wrong with pamac build xone-dkms
command tho.
my system
Kernel: 6.1.71-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=8e0e212d-3399-41b6-9b0f-83f4032ed28f rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_x11 vt: 2
Type: Desktop System: Gigabyte product: B450M DS3H v: N/A
serial: <superuser required>
Mobo: Gigabyte model: B450M DS3H-CF serial: <superuser required>
UEFI: American Megatrends LLC. v: F64 date: 06/08/2023
Device-1: hidpp_battery_0 model: Logitech G304 Lightspeed Wireless Gaming
Mouse serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
System RAM: total: 24 GiB available: 23.39 GiB used: 5.02 GiB (21.5%)
Info: model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen+ gen: 2
level: v3 note: check built: 2018-21 process: GF 12nm family: 0x17 (23)
model-id: 8 stepping: 2 microcode: 0x800820D
L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB desc: 6x512 KiB L3: 16 MiB
desc: 2x8 MiB
Speed (MHz): avg: 1522 high: 1650 min/max: 1550/3200 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1550 2: 1331
3: 1550 4: 1550 5: 1547 6: 1547 7: 1650 8: 1550 9: 1395 10: 1502 11: 1550
12: 1546 bogomips: 76681
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Type: spec_rstack_overflow mitigation: safe RET
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GA106 [GeForce RTX 3060] vendor: Gigabyte driver: nvidia
v: 545.29.06 alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current
(as of 2023-11; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.0
chip-ID: 10de:2503 class-ID: 0300
Display: x11 server: X.Org v: 21.1.10 with: Xwayland v: 23.2.3
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x342mm (23.70x13.46")
s-diag: 692mm (27.26")
Monitor-1: DP-0 res: 2560x1440 dpi: 109 size: 597x336mm (23.5x13.23")
diag: 685mm (26.97") modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 545.29.06
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
memory: 11.72 GiB
API: Vulkan v: 1.3.274 layers: 11 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: nvidia v: 545.29.06
device-ID: 10de:2503 surfaces: xcb,xlib
Device-1: NVIDIA GA106 High Definition Audio vendor: Gigabyte
link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.1 chip-ID: 10de:228e
class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 09:00.3
chip-ID: 1022:1457 class-ID: 0403
API: ALSA v: k6.1.71-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
lanes: 1 port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 2.26 TiB used: 405.54 GiB (17.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B4QFXO7 temp: 36.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37480G
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0102 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT1000BX500SSD1
tech: SSD serial: <filter> fw-rev: 061 scheme: GPT
ID-1: / raw-size: 931.51 GiB size: 915.82 GiB (98.32%)
used: 405.54 GiB (44.3%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:1
label: N/A uuid: 8e0e212d-3399-41b6-9b0f-83f4032ed28f
ID-1: /dev/sda1 maj-min: 8:1 size: 447.13 GiB fs: ntfs label: N/A
uuid: 0A1836E558CB39BF
ID-2: /dev/sdb1 maj-min: 8:17 size: 100 MiB fs: vfat label: N/A
uuid: 0002-DBC1
ID-3: /dev/sdb2 maj-min: 8:18 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/sdb3 maj-min: 8:19 size: 930.74 GiB fs: ntfs label: N/A
uuid: 820A0B7A0A0B6A8D
ID-5: /dev/sdb4 maj-min: 8:20 size: 674 MiB fs: ntfs label: N/A
uuid: 38228E8F228E51B4
Device-1: 1-1:2 info: Apple Aluminium Keyboard (ANSI) type: keyboard,HID
driver: apple,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 05ac:024f class-ID: 0300
Device-2: 1-2:3 info: Logitech USB Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
chip-ID: 046d:c53f class-ID: 0300
Device-3: 1-7:23 info: 8BitDo Ultimate Wireless Controller type: HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 2dc8:3109 class-ID: 0300
serial: <filter>
Hub-4: 4-0:1 info: super-speed hub ports: 4 rev: 3.0
System Temperatures: cpu: 45.9 C mobo: 34.0 C gpu: nvidia temp: 50 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
Processes: 299 Uptime: 32m wakeups: 0 Init: systemd v: 255 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: 1513
pm: pacman pkgs: 1496 libs: 437 tools: pamac,yay pm: flatpak pkgs: 14
pm: snap pkgs: 3 Shell: Zsh v: 5.9 default: Bash v: 5.2.21
running-in: konsole inxi: 3.3.31
so can someone give me advice for fixing it with the 2.4ghz dongle (or bluetooth, but prefer with dongle because my bluetooth is kinda bad)?
if i don’t respond i might be sleeping.
