750ti not working
Hey guys,
Recently I installed Manjaro (Zetar 25.0.3) and am having issues getting my 750ti running, integrated graphics are fine and im writing on the PC right now, as far as i know the GPU is fine as it boots until bios then i get the error (Loadkmap short read) and display cuts off.
System specs:
Celeron G3900 2core2thread 2.8ghz
12GB DDR4-2133
2TB WD Blue HDD
Asus h110m e motherboard
asus gtx 750ti 2gb
would appreciate any help [:
Please provide system information as described (below). This may help others to identify possible contributors to your issue.
The following article may be of some use, but in the meantime I suggest searching the forum using black screen as keywords.
I’m sure someone will help when they are able.
Update Announcements
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Highly Recommended
Required Reading
Technical Resources
Do you use the proprietary driver or the open source driver? Is the NVIDIA GPU configured correctly? Older NVIDIA GPUs need often extra adjustments. How did you switch the GPU? Did you switch the GPU in Linux?
Please post more information about available GPU drivers
mhwd -l
GTX 750Ti is a legacy device and would not work with latest proprietary driver, but it should be possible to boot a Manjaro Live ISO with open-source driver (FREE option in boot menu)
Configure Graphics Cards - Manjaro Wiki
The GeForce GTX 750 Ti is supported by Nvidia 570.144 for Linux and no doubt any iterations released since April.
GeForce 700 Series
GeForce GTX 750 Ti, GeForce GTX 750, GeForce GTX 745
Though support is steadily decreasing as each major driver version is released, which certainly makes graphic support a valid consideration, going forward.
I tried the open source and nvidia driver 390 and both failed, i tried the gpu on mint aswell and had the same issue where it disconnected, i think i might give up trying for now as ive been at this for like 3 days
