~> inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 6.7.7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.7-x86_64
root=UUID=77107e6e-9e05-49d6-a670-8cc0f7518b38 rw rootflags=subvol=@ quiet
splash udev.log_priority=3
Desktop: KDE Plasma v: 5.27.11 tk: Qt v: 5.15.12 info: frameworks
v: 5.115.0 wm: kwin_wayland with: krunner vt: 1 dm: SDDM Distro: Manjaro
base: Arch Linux
Type: Laptop System: Dell product: XPS 15 7590 v: N/A
Mobo: Dell model: 0VYV0G v: A00 serial: <superuser required> part-nu: 0905
uuid: <superuser required> UEFI: Dell v: 1.23.0 date: 07/18/2023
ID-1: BAT0 charge: 46.3 Wh (69.1%) condition: 67.0/97.0 Wh (69.1%)
volts: 12.5 min: 11.4 model: SMP DELL GPM0365 type: Li-ion serial: <filter>
status: charging
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard ERGO K860
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
System RAM: total: 32 GiB available: 30.98 GiB used: 8.24 GiB (26.6%)
Device-1: DIMM A type: DDR4 detail: synchronous size: 16 GiB
speed: 2667 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
data: 64 total: 64 manufacturer: 01980000802C part-no: 9905700-047.A00G
serial: <filter>
Device-2: DIMM B type: DDR4 detail: synchronous size: 16 GiB
serial: <filter>
Info: model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF4
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 800 high: 801 min/max: 800/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 9: 801 10: 801 11: 800 12: 800 bogomips: 62431
sgx sgx_lc smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Dell driver: i915
v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
active: DP-1,eDP-1 empty: DP-2,DP-3 bus-ID: 00:02.0 chip-ID: 8086:3e9b
class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Dell
driver: nvidia v: 550.54.14 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-02; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1f91 class-ID: 0302
Device-3: Microdia Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-12:5 chip-ID: 0c45:6723
class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.11 with: Xwayland v: 23.2.4
compositor: kwin_wayland driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915,nvidia
d-rect: 8960x2160 display-ID: 0
Monitor-1: DP-1 pos: primary,left res: 5120x2160 size: N/A modes: N/A
Monitor-2: eDP-1 pos: right res: 3840x2160 size: N/A modes: N/A
drv: nvidia device: 2 drv: iris device: 3 drv: swrast surfaceless:
drv: nvidia wayland: drv: iris x11: drv: iris inactive: gbm,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.0.2-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 630 (CFL GT2)
device-ID: 8086:3e9b memory: 30.26 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 1 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 1650 driver: nvidia v: 550.54.14
device-ID: 10de:1f91 surfaces: xcb,xlib,wayland
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
API: ALSA v: k6.7.7-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin tools: pactl,pw-cat,pw-cli
Device-1: Intel Wi-Fi 6 AX200 vendor: Rivet Networks Killer driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 3b:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlp59s0 state: up mac: <filter>
IF-ID-1: br-7bc2ac4d7b37 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IP v6: <filter> virtual: proto kernel_ll scope: link
IF-ID-2: br-b2b3edd4a6e8 state: down mac: <filter>
IF-ID-3: docker0 state: down mac: <filter>
IF-ID-4: veth01fc20f state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-5: veth3a64f53 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-6: veth43df34f state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-7: veth4f75521 state: up speed: 10000 Mbps duplex: full mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:6 chip-ID: 8087:0029
class-ID: e001
Local Storage: total: 476.94 GiB used: 191 GiB (40.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: PC601 NVMe 512GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 80002111 temp: 38.9 C
scheme: GPT
ID-1: / raw-size: 98.44 GiB size: 98.44 GiB (100.00%) used: 44.77 GiB (45.5%)
fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4 label: root
uuid: 77107e6e-9e05-49d6-a670-8cc0f7518b38
ID-2: /boot/efi raw-size: 343 MiB size: 342.3 MiB (99.80%)
used: 65.1 MiB (19.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 4222-33E7
ID-3: /home raw-size: 289.92 GiB size: 284.3 GiB (98.06%)
used: 139.72 GiB (49.1%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
label: home uuid: 9915a9ac-8e1a-4334-b943-c46821c1e180
ID-4: /var/cache raw-size: 98.44 GiB size: 98.44 GiB (100.00%)
used: 44.77 GiB (45.5%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
label: root uuid: 77107e6e-9e05-49d6-a670-8cc0f7518b38
ID-5: /var/lib/docker raw-size: 78.93 GiB size: 77.14 GiB (97.73%)
used: 6.42 GiB (8.3%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
label: docker uuid: 97d5b1e4-f0ac-4499-b9b6-3c7525673341
ID-6: /var/log raw-size: 98.44 GiB size: 98.44 GiB (100.00%)
Kernel: swappiness: 1 (default 60) cache-pressure: 100 (default) zswap: yes
ID-1: swap-1 type: partition size: 9.31 GiB used: 20.2 MiB (0.2%)
priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2 label: swap
uuid: 7e3c9982-6b79-4687-a9b2-427400dd2fe7
Device-1: 1-1:2 info: Logitech Unifying Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-4:6 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0029 class-ID: e001
Device-3: 1-7:4 info: Shenzhen Goodix Fingerprint Reader
type: abstract (modem),CDC-data driver: N/A interfaces: 2 rev: 2.0
chip-ID: 27c6:5395 class-ID: 0a00 serial: <filter>
Device-4: 1-12:5 info: Microdia Integrated_Webcam_HD type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 0c45:6723 class-ID: 0e02
Hub-2: 2-0:1 info: super-speed hub ports: 10 rev: 3.1
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-6: 5-1:2 info: Fresco Logic USB2.0 Hub ports: 5 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 1d5c:5801
Device-1: 5-1.3:3 info: LG USA 27UP850 - WK.AEUDCSN External Monitor 4K
type: HID,abstract (modem),CDC-data driver: cdc_acm,hid-generic,usbhid
interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
chip-ID: 043e:9a39 class-ID: 0a00 serial: <filter>
Hub-7: 5-1.4:4 info: Texas Instruments TUSB8041 4-Port Hub ports: 4
rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0451:8142
Device-1: 5-1.5:5 info: Texas Instruments TPS DMC Family
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 500mA
chip-ID: 0451:ace1 class-ID: ff00 serial: <filter>
Hub-8: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-9: 6-1:2 info: Intel USB3.0 Hub ports: 4 rev: 3.2
speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 8087:0b40
Hub-10: 6-1.4:3 info: Texas Instruments TUSB8041 4-Port Hub ports: 4
rev: 3.0 speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1
chip-ID: 0451:8140 class-ID: 0900
System Temperatures: cpu: 51.0 C pch: 55.0 C mobo: 44.0 C
Fan Speeds (rpm): cpu: 3395 fan-2: 3392
Processes: 360 Power: uptime: 12m states: freeze,mem,disk suspend: s2idle
avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend,
test_resume image: 12.38 GiB services: org_kde_powerdevil,
tool: systemctl
Packages: 1292 pm: pacman pkgs: 1280 libs: 371 tools: pamac pm: flatpak
pkgs: 0 pm: snap pkgs: 12 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: fish
v: 3.7.0 default: Bash v: 5.2.26 running-in: yakuake inxi: 3.3.33
inxi -v8zy
base: Arch Linux
ID-1: BAT0 charge: 46.9 Wh (70.0%) condition: 67.0/97.0 Wh (69.1%)
status: charging
status: discharging
System RAM: total: 32 GiB available: 30.98 GiB used: 8.9 GiB (28.7%)
serial: <filter>
serial: <filter>
Speed (MHz): avg: 800 min/max: 800/4500 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 62431
vulnerable
class-ID: 0300
class-ID: 0e02
mac: <filter>
class-ID: e001
scheme: GPT
uuid: 4222-33E7
System Temperatures: cpu: 53.0 C pch: 54.0 C mobo: 44.0 C
Fan Speeds (rpm): cpu: 3410 fan-2: 3407
Active pacman repo servers in: /etc/pacman.conf
1: https://repo.pritunl.com/stable/pacman
2: https://releases.warp.dev/linux/pacman/$repo/$arch
1: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
2: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
3: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
4: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
5: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
6: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
7: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
8: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
9: https://mirrors2.manjaro.org/stable/$repo/$arch
10: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
11: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
12: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
13: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
14: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
15: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
16: https://manjaro.kyberorg.fi/stable/$repo/$arch
17: https://mirror.funami.tech/manjaro/stable/$repo/$arch
18: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
19: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
20: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
21: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
22: http://mirror.terrahost.no/linux/manjaro/stable/$repo/$arch
23: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
24: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
25: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
26: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
27: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
28: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
29: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
30: https://manjaro.ynh.ovh/stable/$repo/$arch
31: https://mirror.23m.com/manjaro/stable/$repo/$arch
32: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
33: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
34: https://muug.ca/mirror/manjaro/stable/$repo/$arch
35: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
36: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
37: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
38: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
39: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
40: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
41: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
42: https://mirrors.xtom.de/manjaro/stable/$repo/$arch
43: https://manjaro.kurdy.org/stable/$repo/$arch
44: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
45: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
46: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
47: http://manjaro.grena.ge/stable/$repo/$arch
48: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
49: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
50: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
51: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
52: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
53: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
54: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
55: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
56: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
57: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
58: https://linorg.usp.br/manjaro/stable/$repo/$arch
59: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
60: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
61: https://mirror.init7.net/manjaro/stable/$repo/$arch
62: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
63: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
64: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
65: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
66: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
67: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
68: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
69: http://manjaro.mirrors.theom.nz/manjaro/stable/$repo/$arch
70: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
71: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
72: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
73: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
74: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
75: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
76: https://mirror.koddos.net/manjaro/stable/$repo/$arch
77: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
78: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
79: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
80: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
81: https://mirrors.manjaro.org/repo/stable/$repo/$arch
82: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
83: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
84: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
85: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
86: https://mirror.seahost.de/manjaro/stable/$repo/$arch
87: http://ftp.dei.uc.pt/pub/linux/manjaro/stable/$repo/$arch
88: https://mirror.zetup.net/manjaro/stable/$repo/$arch
89: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
90: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
91: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
92: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
93: http://mirror.fcix.net/manjaro/stable/$repo/$arch
94: https://mirror.albony.xyz/manjaro/stable/$repo/$arch
95: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
96: https://mirrors.xtom.ee/manjaro/stable/$repo/$arch
97: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
98: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
99: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
100: https://mirror.easyname.at/manjaro/stable/$repo/$arch
101: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
102: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
103: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
104: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
105: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
106: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
107: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
108: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
109: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
110: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
111: https://mirror.erickochen.nl/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 361
1: cpu: 43.8% command: plasmashell pid: 1892 mem: 474.4 MiB (1.4%)
2: cpu: 18.4% command: konsole pid: 5069 mem: 346.3 MiB (1.0%)
3: cpu: 17.9% command: firefox pid: 2985 mem: 684.6 MiB (2.1%)
4: cpu: 14.3% command: firefox pid: 3294 mem: 329.3 MiB (1.0%)
5: cpu: 9.8% command: kwin_wayland pid: 1754 mem: 654.4 MiB (2.0%)
Memory top: 5 of 361
1: mem: 815.5 MiB (2.5%) command: Telegram pid: 4287 cpu: 4.8%
2: mem: 684.6 MiB (2.1%) command: firefox pid: 2985 cpu: 17.9%
3: mem: 654.4 MiB (2.0%) command: kwin_wayland pid: 1754 cpu: 9.8%
4: mem: 474.4 MiB (1.4%) command: plasmashell pid: 1892 cpu: 43.8%
5: mem: 430.9 MiB (1.3%) command: firefox pid: 3226 cpu: 3.3%
Processes: 361 Power: uptime: 13m states: freeze,mem,disk suspend: s2idle
tool: systemctl
Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: fish v: 3.7.0 default: Bash
v: 5.2.26 running-in: konsole inxi: 3.3.33
