Hi everybody,
the start (Gnome) with kernel 6.6.8-2 does not work: The screen remains black.
Selecting 6.5.13-7 in the selection menu and the system starts. I have now uninstalled the newer kernel, but am prompted to install the new kernel.
Does anyone have any idea why the above kernel is causing problems?
Regards
Thomas
$ inxi -Fxxyc0
Host: tom-manjaro Kernel: 6.5.13-7-MANJARO arch: x86_64 bits: 64
compiler: gcc v: 13.2.1 Desktop: GNOME v: 45.2 tk: GTK v: 3.24.39
wm: gnome-shell dm: GDM Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: ASUS product: All Series v: N/A
serial: <superuser required>
Mobo: ASUSTeK model: Z97-A-USB31 v: Rev 1.xx serial: <superuser required>
UEFI-[Legacy]: American Megatrends v: 3503 date: 04/18/2018
Info: quad core model: Intel Xeon E3-1231 v3 bits: 64 type: MT MCP
arch: Haswell rev: 3 cache: L1: 256 KiB L2: 1024 KiB L3: 8 MiB
Speed (MHz): avg: 2738 high: 3800 min/max: 800/3800 cores: 1: 3800 2: 3401
3: 3401 4: 3401 5: 2500 6: 3407 7: 800 8: 1200 bogomips: 54431
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Sapphire driver: amdgpu v: kernel arch: GCN-4 pcie: speed: 8 GT/s
lanes: 16 ports: active: HDMI-A-2 empty: DP-1, DP-2, DVI-D-1, HDMI-A-1
bus-ID: 01:00.0 chip-ID: 1002:67df temp: 48.0 C
Display: x11 server: X.org v: 1.21.1.10 with: Xwayland v: 23.2.3
compositor: gnome-shell driver: X: loaded: amdgpu
gpu: amdgpu display-ID: :1 screens: 1
Screen-1: 0 s-res: 1920x1080
Monitor-1: HDMI-A-2 mapped: HDMI-A-1 model: Acer S273HL res: 1920x1080
dpi: 82 diag: 685mm (27")
API: EGL v: 1.5 platforms: device: 0 drv: radeonsi device: 1 drv: swrast
surfaceless: drv: radeonsi x11: drv: radeonsi inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 570 Series (polaris10
LLVM 16.0.6 DRM 3.54 6.5.13-7-MANJARO) device-ID: 1002:67df
Device-1: Intel 9 Series Family HD Audio vendor: ASUSTeK 9
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8ca0
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Sapphire driver: snd_hda_intel v: kernel pcie: speed: 8 GT/s
lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0
Device-3: VIA VT1720/24 [Envy24PT/HT] PCI Multi-Channel Audio
driver: snd_ice1724 v: kernel bus-ID: 07:00.0 chip-ID: 1412:1724
API: ALSA v: k6.5.13-7-MANJARO status: kernel-api with: aoss
type: oss-emulator
Server-1: JACK v: 1.9.22 status: off
Server-2: PipeWire v: 1.0.0 status: off with: pipewire-media-session
status: active
Server-3: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module
Device-1: Intel Ethernet I218-V vendor: ASUSTeK driver: e1000e v: kernel
port: f040 bus-ID: 00:19.0 chip-ID: 8086:15a1
IF: eno1 state: up speed: 1000 Mbps duplex: full mac: 08:62:66:c5:c6:52
Local Storage: total: 4.77 TiB used: 277.1 GiB (5.7%)
ID-1: /dev/sda vendor: Patriot model: Burst size: 223.57 GiB
speed: 6.0 Gb/s serial: F90B079A1E0400135665
ID-2: /dev/sdb vendor: Western Digital model: WD20EZRX-00D8PB0
size: 1.82 TiB speed: 3.0 Gb/s serial: WD-WMC4N0520994
ID-3: /dev/sdc vendor: Western Digital model: WD30EZRX-00DC0B0
size: 2.73 TiB speed: 3.0 Gb/s serial: WD-WCC1T0982886
ID-1: / size: 86.92 GiB used: 53.1 GiB (61.1%) fs: ext4 dev: /dev/sda3
ID-2: /home size: 583.1 GiB used: 224 GiB (38.4%) fs: ext4 dev: /dev/sdb2
ID-1: swap-1 type: partition size: 6.77 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda6
System Temperatures: cpu: 38.0 C mobo: N/A gpu: amdgpu temp: 48.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 1542
Processes: 299 Uptime: 58m Memory: total: 16 GiB available: 15.56 GiB
used: 2.79 GiB (17.9%) Init: systemd v: 254 default: graphical Compilers:
gcc: 13.2.1 clang: 16.0.6 Packages: 1897 pm: pacman pkgs: 1890 pm: rpm
pkgs: 1 pm: flatpak pkgs: 6 Shell: Bash v: 5.2.21 running-in: gnome-terminal
inxi: 3.3.31
