Hello,
I’m using Manjaro for a year now and I love it.
I’ve just updated to kernel 5.15.12-1 with the latest update. I’ve been running the 5.15.1 kernel as a daily driver, I haven’t done anything weird, I just updated the 43x packages pamac suggested.
After reboot I saw the bootup phase printed out and it hung after mentioning something about no APU architecture so it’s changing the mode. I wish I made a screenshot because it’s not displaying that text anymore the screen stays blank.
I tried the fallback option same blank screen.
Luckily I also have the 5.16 anbox kernel installed too so I can use the system.
I’m writing to let you know that there might be something in the 5.15.12-1 kernel that isn’t cool with a Radeon VII.
Hi,
I did mange to boot into the 5.16.0-1-MANJARO x86_64 kernel using the fallback option. Normal boot hangs after the initializing usb mouse and keyboard.
Virtualbox doesn’t work with the 5.16 kernel that an AUR script compiled for me for anbox.
I’ve also tried the 5.15-7rt kernel as well and that seems to hang at the USBs just like 5.16.
I since reverted to the 5.14 kernel for stability.
The site won’t let me post the outputs of inxi.
Kernel: 5.16.0-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64
root=UUID=14ab930a-e879-4c93-a4a5-4bbab0928835 rw quiet apparmor=1
security=apparmor udev.log_priority=3 amdgpu.ppfeaturemask=0xffffffff
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Gigabyte product: X470 AORUS ULTRA GAMING v: N/A
serial: <superuser required>
Mobo: Gigabyte model: X470 AORUS ULTRA GAMING-CF v: x.x
serial: <superuser required> UEFI: American Megatrends LLC. v: F60
date: 02/24/2021
RAM: total: 31.35 GiB used: 11.27 GiB (35.9%)
RAM Report:
Info: model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+
family: 0x17 (23) model-id: 8 stepping: 2 microcode: 0x800820D
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 768 KiB desc: d-8x32 KiB; i-8x64 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3513 high: 4199 min/max: 2200/3700 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3261 2: 3685
3: 3452 4: 3348 5: 2717 6: 3145 7: 4175 8: 4112 9: 3913 10: 3701 11: 3145
12: 2803 13: 3224 14: 3176 15: 4166 16: 4199 bogomips: 118454
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm
mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rapl rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap
smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock
syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme
vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
disabled, RSB filling
Device-1: AMD Vega 20 [Radeon VII] driver: amdgpu v: kernel bus-ID: 0b:00.0
chip-ID: 1002:66af class-ID: 0300
Display: x11 server: X.Org 1.21.1.2 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 52
size: 930x530mm (36.6x20.9") diag: 1070mm (42.1")
OpenGL:
renderer: AMD Radeon VII (VEGA20 DRM 3.44.0 5.16.0-1-MANJARO LLVM 13.0.0)
v: 4.6 Mesa 21.3.2 direct render: Yes
Device-1: AMD Vega 20 HDMI Audio [Radeon VII] driver: snd_hda_intel
v: kernel bus-ID: 0b:00.1 chip-ID: 1002:ab20 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus-ID: 0d:00.3 chip-ID: 1022:1457 class-ID: 0403
Sound Server-1: ALSA v: k5.16.0-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.42 running: yes
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
port: f000 bus-ID: 06:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: anbox0 state: down mac: <filter>
Local Storage: total: 2.95 TiB used: 1.53 TiB (51.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SV300S37A120G
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: BBF0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 840 Series
type: SSD serial: <filter> rev: 8B0Q scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST2000DM008-2FR102
type: HDD rpm: 7200 serial: <filter> rev: 0001 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 vendor: Toshiba model: DT01ACA100
type: HDD rpm: 7200 serial: <filter> rev: A750 scheme: MBR
ID-1: / raw-size: 111.49 GiB size: 111.49 GiB (100.00%)
used: 53.82 GiB (48.3%) fs: reiserfs dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 14ab930a-e879-4c93-a4a5-4bbab0928835
used: 336 KiB (0.1%) fs: vfat dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: B1EF-3BE7
ID-3: /mnt/2tb raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
used: 1.09 TiB (59.8%) fs: btrfs dev: /dev/sdc1 maj-min: 8:33 label: 2tb
uuid: 01144c9c-ea4f-49b0-8cbe-be731f32964d
ID-4: /mnt/C raw-size: 111.18 GiB size: 111.18 GiB (100.00%)
used: 39.67 GiB (35.7%) fs: ntfs dev: /dev/sdb3 maj-min: 8:19 label: N/A
uuid: 429C140D9C13F9DD
ID-5: /mnt/E raw-size: 931.51 GiB size: 915.89 GiB (98.32%)
used: 356.74 GiB (38.9%) fs: ext3 dev: /dev/sdd1 maj-min: 8:49
label: Tosh1gb uuid: 9eeb0d24-4249-4079-a225-81eddb60df6c
ID-1: /dev/sdb1 maj-min: 8:17 size: 100 MiB fs: vfat label: N/A
uuid: D20B-4EF4
ID-2: /dev/sdb2 maj-min: 8:18 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sdb4 maj-min: 8:20 size: 505 MiB fs: ntfs label: N/A
uuid: E40E7E3C0E7E07B6
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 14 rev: 2.0
Device-1: 1-9:2 info: Pixart Imaging Gaming Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 093a:2530 class-ID: 0301
Device-2: 1-13:3 info: Canon CanoScan LiDE 100 type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA
chip-ID: 04a9:1904 class-ID: ff00
Hub-2: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 5-1:2 info: CASUE USB KB type: Keyboard,HID
power: 100mA chip-ID: 2a7a:9a27 class-ID: 0300
Hub-6: 6-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 39.9 C mobo: N/A gpu: amdgpu temp: 30.0 C
mem: 32.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 908
Processes: 385 Uptime: 14m wakeups: 0 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1742 note: see --pkg
pacman: 1730 lib: 459 flatpak: 7 snap: 5 Shell: Bash v: 5.1.12
running-in: terminator inxi: 3.3.11
1.395875] ata2.00: NCQ Send/Recv Log not supported
[ 1.396212] ata2.00: NCQ Send/Recv Log not supported
[ 3.826188] usb: port power management may be unreliable
[ 4.182967] reiserfs: using flush barriers
[ 4.603899] ipmi_si: Unable to find any System Interface(s)
[ 4.711412] vboxdrv: loading out-of-tree module taints kernel.
[ 4.741182] VBoxNetAdp: Successfully started.
[ 4.746769] VBoxNetFlt: Successfully started.
[ 4.761821] wmi_bus wmi_bus-PNP0C14:01: WQAA data block query control method not found
[ 4.762122] acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:02)
[ 4.841570] ACPI Warning: SystemIO range 0x0000000000000B00-0x0000000000000B08 conflicts with OpRegion 0x0000000000000B00-0x0000000000000B0F (\GSA1.SMBI) (20210604/utaddress-204)
[ 5.479097] amdgpu 0000:0b:00.0: amdgpu: Trusted Memory Zone (TMZ) feature not supported
[ 5.483656] amdgpu 0000:0b:00.0: amdgpu: PSP runtime database doesn't exist
[ 5.962430] [drm:smu_v11_0_i2c_transmit.cold [amdgpu]] *ERROR* Received I2C_NAK_7B_ADDR_NOACK !!!
[ 5.962582] [drm:smu_v11_0_i2c_xfer [amdgpu]] *ERROR* ReadData() - I2C error occurred :1
[ 5.962714] [drm:amdgpu_ras_eeprom_init [amdgpu]] *ERROR* Failed to read EEPROM table header, ret:-5
[ 5.962833] amdgpu 0000:0b:00.0: amdgpu: Failed to initialize ras recovery!
[ 6.057015] amdgpu: SRAT table not found
[ 6.279120] kauditd_printk_skb: 71 callbacks suppressed
[ 10.623721] systemd-journald[338]: Failed to set ACL on /var/log/journal/08d5e4be09cf435297bce85e1e15da96/user-1000.journal, ignoring: Operation not supported
[ 12.211077] kauditd_printk_skb: 49 callbacks suppressed
[ 50.584641] SUPR0GipMap: fGetGipCpu=0x2b
[ 51.453832] vboxdrv: 0000000073398cc8 VMMR0.r0
[ 51.607290] vboxdrv: 00000000c9b3aeef VBoxDDR0.r0
[ 51.671390] VMMR0InitVM: eflags=246 fKernelFeatures=0x0 (SUPKERNELFEATURES_SMAP=0)
[ 309.748531] kauditd_printk_skb: 2 callbacks suppressed
Thank you for your time.
I’ve pasted it here so it’s easier for everyone to see. For some reason it thinks there’s a URL in there somewhere. Maybe it thinks the text within the carets is HTML.
Check the logs from when you attempt to boot into 5.15 as outlined in the tutorial I linked above.
I have two problems:
The first one is that when I try to boot into 5.15 kernel, the screen stays blank for hours I tried. When I boot into 5.14 and do dmesg and the others they all show me booting into 5.14.
The second problem is that I can’t get konsole to save the whole output.
I think that this is the only report that is of use:
1.409585] ata2.00: NCQ Send/Recv Log not supported
[ 1.409922] ata2.00: NCQ Send/Recv Log not supported
[ 3.857975] usb: port power management may be unreliable
[ 4.210250] reiserfs: using flush barriers
[ 4.635727] ipmi_si: Unable to find any System Interface(s)
[ 4.665761] systemd-journald[341]: File /var/log/journal/08d5e4be09cf435297bce85e1e15da96/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 4.733989] vboxdrv: loading out-of-tree module taints kernel.
[ 4.758880] wmi_bus wmi_bus-PNP0C14:01: WQAA data block query control method not found
[ 4.759226] acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:02)
[ 4.763262] VBoxNetAdp: Successfully started.
[ 4.768967] VBoxNetFlt: Successfully started.
[ 4.850036] ACPI Warning: SystemIO range 0x0000000000000B00-0x0000000000000B08 conflicts with OpRegion 0x0000000000000B00-0x0000000000000B0F (\GSA1.SMBI) (20210604/utaddress-204)
[ 5.367566] kauditd_printk_skb: 66 callbacks suppressed
[ 5.489993] amdgpu 0000:0b:00.0: amdgpu: Trusted Memory Zone (TMZ) feature not supported
[ 5.494646] amdgpu 0000:0b:00.0: amdgpu: PSP runtime database doesn't exist
[ 5.985253] [drm:smu_v11_0_i2c_transmit.cold [amdgpu]] *ERROR* Received I2C_NAK_7B_ADDR_NOACK !!!
[ 5.985407] [drm:smu_v11_0_i2c_xfer [amdgpu]] *ERROR* ReadData() - I2C error occurred :1
[ 5.985540] [drm:amdgpu_ras_eeprom_init [amdgpu]] *ERROR* Failed to read EEPROM table header, ret:-5
[ 5.985658] amdgpu 0000:0b:00.0: amdgpu: Failed to initialize ras recovery!
[ 6.070640] amdgpu: SRAT table not found
[ 10.447662] kauditd_printk_skb: 45 callbacks suppressed
[ 10.460150] systemd-journald[341]: Failed to set ACL on /var/log/journal/08d5e4be09cf435297bce85e1e15da96/user-1000.journal, ignoring: Operation not supported
[ 19.003313] kauditd_printk_skb: 1 callbacks suppressed
I’m a n00b but I’ll help you help me anyway I can
And thanks.
You can save it directly to a file (replace bootlog with whatever filename you want).
journalctl --catalog --priority=3 --boot=-1 > bootlog
If it’s very long, please upload it to a pastebin service like dpaste and link it here.
Wow great trick!
jan 03 17:04:20 taper-x470aorusultragaming kernel: kobject_add_internal failed for ashmem with -EEXIST, don't try to register things with the same name in the same directory.
jan 03 17:04:20 taper-x470aorusultragaming kernel: ashmem: failed to register misc device!
jan 03 17:04:20 taper-x470aorusultragaming kernel: debugfs: Directory 'binder' with parent '/' already present!
jan 03 17:04:20 taper-x470aorusultragaming systemd-modules-load[369]: Failed to insert module 'binder_linux': Device or resource busy
Ashmem and binder are for anbox. I thought that these are only compiled into the 5.16 mainline linux kernel and don’t affect the other kernels. This is the only new kernel that works for me, and it was compiled through AUR. I can boot into this kernel even now, that’s why I’m surprised none of the new Manjaro kernels seem to work but the earlier ones did.
Both should be enabled with 5.15. If you have Anbox DKMS packages installed from the AUR, remove them.
Tip: When pasting terminal output on Discourse forums, one can either…
Use the Preformatted text </> toolbar button.
Add three backticks ` above and below the text (Markdown):
type or paste code here
Use HTML:
<pre><code>
</pre></code>
I’ve done it for you this time.
You’re a genius! That was it.
5.15, and 5.16 Manjaro kernels work now.
Thank you.
