Manjaro stable crashes on me randomly with sometimes frozen screens that then go into standby (black).
REISUB does nothing. I think it’s not the CPU (a first generation Ryzen) because I have AMD IBS turned on in my EFI. With AMD IBS turned off I get even more system crashes in Debian and Ubuntu (but not windows 10 they must have fixed it somewhere). About IBS see forum manjaro org /t/system-random-freeze/13280/11 (post bot made me butcher link). I haven’t tried the kernel parameters yet since enabling IBS works so well.
I tried lowering my kernel from 5.10 to 5.4 and crashes seem to have stopped.
What should I do? Do I just stay like this for a few months using 5.4? I suspect it might be my new MSI Radeon RX 570 Ellesmere but wondering if I need more than just enabling IBS. I am not concerned about the performance hit by enabling IBS. Games seem to be running ok.
$ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.4.124-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=xxxxxxxx-xxxx-4f25-95b8-8429d89e983e rw quiet apparmor=1
resume=UUID=xxxxxxxx-xxxx-413b-bb6e-fc2be1f99f06
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm4 vt: 7
Type: Desktop Mobo: Gigabyte model: AX370-Gaming 5 serial: <filter>
UEFI: American Megatrends v: F50e date: 07/02/2020
RAM: total: 15.65 GiB used: 2.63 GiB (16.8%)
Info: 6-Core model: AMD Ryzen 5 1600X bits: 64 type: MT MCP arch: Zen
family: 17 (23) model-id: 1 stepping: 1 microcode: 8001138 cache: L2: 3 MiB
bogomips: 86268
Speed: 3211 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
1: 3211 2: 2419 3: 2191 4: 2196 5: 2129 6: 2195 7: 2198 8: 2196 9: 3243
10: 2218 11: 2128 12: 2195
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rdrand rdseed rdtscp rep_good sep sev sha_ni skinit smap smca sme smep
ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
disabled, RSB filling
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Micro-Star MSI driver: amdgpu v: kernel bus-ID: 08:00.0
chip-ID: 1002:67df class-ID: 0300
Display: x11 server: X.Org 1.20.11 driver: loaded: amdgpu,ati
unloaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 2970x1680 s-dpi: 96 s-size: 786x445mm (30.9x17.5")
s-diag: 903mm (35.6")
Monitor-1: HDMI-A-1 res: 1920x1200 hz: 60 dpi: 305 size: 160x90mm (6.3x3.5")
diag: 184mm (7.2")
Monitor-2: DVI-D-0 res: 1050x1680 hz: 60
OpenGL: renderer: Radeon RX 570 Series (POLARIS10 DRM 3.35.0
5.4.124-1-MANJARO LLVM 12.0.0)
v: 4.6 Mesa 21.1.2 direct render: Yes
Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 08:00.1
chip-ID: 1002:aaf0 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus-ID: 0a:00.3 chip-ID: 1022:1457 class-ID: 0403
Sound Server-1: ALSA v: k5.4.124-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.30 running: no
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: 5.6.0-k
port: e000 bus-ID: 05:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Qualcomm Atheros Killer E2500 Gigabit Ethernet vendor: Gigabyte
driver: alx v: kernel port: d000 bus-ID: 06:00.0 chip-ID: 1969:e0b1
class-ID: 0200
IF: enp6s0 state: down mac: <filter>
Permissions: Unable to run lvs. Root privileges required.
Local Storage: total: 1.36 TiB used: 1.14 TiB (83.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 960 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 rotation: SSD serial: <filter> rev: 2B7QCXE7 scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Hitachi model: HTS545025B9A300
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: C64G scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT1000MX500SSD1
rotation: SSD serial: <filter> rev: 033 scheme: GPT
Optical-1: /dev/sr0 vendor: PIONEER model: DVD-RW DVR-212D rev: 1.28
dev-links: cdrom
Features: speed: 40 multisession: yes audio: yes dvd: yes
rw: cd-r,cd-rw,dvd-r state: running
ID-1: / raw-size: 325.52 GiB size: 319.34 GiB (98.10%)
used: 10.35 GiB (3.2%) fs: ext4 dev: /dev/sdb8 maj-min: 8:24 label: manjaro0
uuid: xxxxxxxx-xxxx-4f25-95b8-8429d89e983e
ID-2: /boot/efi raw-size: 953 MiB size: 951.1 MiB (99.80%)
used: 47.2 MiB (5.0%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: 4838-B07D
ID-3: /home/<filter>/zz-sshfs-chairry raw-size: N/A size: 1.43 TiB
used: 386.6 GiB (26.3%) fs: fuse.sshfs
remote: sawdis@carava:/mnt/data/arachdata/chairry label: N/A uuid: N/A
ID-4: /home/<filter>/zz-sshfs-cow raw-size: N/A size: 1.43 TiB
remote: sawdis@carava:/mnt/data/arachdata/cowboycurtis label: N/A uuid: N/A
ID-5: /home/<filter>/zz-sshfs-video2 raw-size: N/A size: 1.43 TiB
remote: sawdis@carava:/mnt/data/video2 label: N/A uuid: N/A
ID-1: swap-1 type: partition size: 33 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: xxxxxxxx-xxxx-413b-bb6e-fc2be1f99f06
ID-1: /dev/nvme0n1p2 maj-min: 259:1 size: 15.23 GiB fs: <superuser required>
label: windows platter uuid: 1BD948EC51D08B64
ID-2: /dev/nvme0n1p5 maj-min: 259:2 size: 100.35 GiB
fs: <superuser required> label: deb2-root
uuid: xxxxxxxx-xxxx-4234-99c2-b82ad134dd88
ID-3: /dev/nvme0n1p6 maj-min: 259:3 size: 37.25 GiB fs: <superuser required>
label: ubuntu0-root uuid: xxxxxxxx-xxxx-41b2-abd7-f6b539660e59
ID-4: /dev/nvme0n1p7 maj-min: 259:4 size: 80.05 GiB fs: <superuser required>
label: ubuntu0-home uuid: xxxxxxxx-xxxx-4cfb-a42b-6c425c8829fe
ID-5: /dev/sda1 maj-min: 8:1 size: 232.88 GiB fs: <superuser required>
label: N/A uuid: xxxxxxxx-xxxx-4067-970d-b9407fc95770
ID-6: /dev/sdb3 maj-min: 8:19 size: 16 MiB fs: <superuser required>
ID-7: /dev/sdb4 maj-min: 8:20 size: 97.14 GiB fs: <superuser required>
label: main-win10 uuid: xxxxxxxxxxxx0295
ID-8: /dev/sdb5 maj-min: 8:21 size: 514 MiB fs: <superuser required>
label: N/A uuid: xxxxxxxxxxxxCD77
ID-9: /dev/sdb6 maj-min: 8:22 size: 101.3 GiB fs: <superuser required>
label: games-win10 uuid: xxxxxxxxxxxxEDD7
ID-10: /dev/sdb7 maj-min: 8:23 size: 325.52 GiB fs: <superuser required>
label: deadspace uuid: xxxxxxxx-xxxx-4a59-8361-1ad37574eec0
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 14 rev: 2.0
Device-1: 1-14:2 info: Logitech F310 Gamepad [XInput Mode]
type: <vendor specific> driver: xpad interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 046d:c21d class-ID: ff00 serial: <filter>
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 5-3:2 info: Primax Dynex 5-Button Wired Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 0461:4d42 class-ID: 0301
Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 29.4 C mobo: 0 C gpu: amdgpu temp: 31.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1112
Processes: 295 Uptime: 1h 04m wakeups: 0 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.0 Packages: pacman: 1193
lib: 316 flatpak: 0 Shell: Bash v: 5.1.8 running-in: tmux: inxi: 3.3.04
attn: next code block has changed since yesterday
$ sudo journalctl -b -2 -p 4
-- Journal begins at Wed 2021-06-30 18:46:06 EDT, ends at Mon 2021-07-05 11:38:17 EDT. --
Jul 04 13:16:36 organza kernel: Expanded resource Reserved due to conflict with PCI Bus 0000:00
Jul 04 13:16:36 organza kernel: PPR NX GT IA GA PC GA_vAPIC
Jul 04 13:16:36 organza kernel: efifb: Ignoring BGRT: unexpected or invalid BMP data
Jul 04 13:16:36 organza kernel: [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
Jul 04 13:16:36 organza kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
Jul 04 13:16:36 organza kernel: usb: port power management may be unreliable
Jul 04 13:16:36 organza kernel: ata4.00: supports DRM functions and may not be fully accessible
Jul 04 13:16:36 organza kernel: cgroup2: Unknown parameter 'memory_recursiveprot'
Jul 04 13:16:37 organza kernel: wmi_bus wmi_bus-PNP0C14:01: WQAA data block query control method not found
Jul 04 13:16:37 organza kernel: ACPI Warning: SystemIO range 0x0000000000000B00-0x0000000000000B08 conflicts with OpRegion 0x0000000000000B00-0x0000000000000B0F (\GSA1.SMBI) (20190816/utaddress-204)
Jul 04 13:16:37 organza kernel: kvm: disabled by bios
Jul 04 13:16:38 organza kernel: kvm: disabled by bios
Jul 04 13:16:38 organza kernel: kauditd_printk_skb: 29 callbacks suppressed
Jul 04 13:16:39 organza kernel: kvm: disabled by bios
Jul 04 13:16:39 organza kernel: proc: Bad value for 'hidepid'
Jul 04 13:16:40 organza systemd-xdg-autostart-generator[724]: Configuration file /etc/xdg/autostart/msm_notifier.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Jul 04 13:16:45 organza kernel: kauditd_printk_skb: 23 callbacks suppressed
Jul 04 13:16:48 organza lightdm[779]: gkr-pam: unable to locate daemon control file
Jul 04 13:16:48 organza systemd-xdg-autostart-generator[800]: Configuration file /home/sawdis/.config/autostart/xfce-panel-workaround.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Jul 04 13:16:48 organza systemd-xdg-autostart-generator[800]: /home/sawdis/.config/autostart/xcape.desktop:9: Unknown key name 'RunHook' in section 'Desktop Entry', ignoring.
Jul 04 13:16:48 organza systemd-xdg-autostart-generator[800]: /home/sawdis/.config/autostart/connect carava drives.desktop:9: Unknown key name 'RunHook' in section 'Desktop Entry', ignoring.
Jul 04 13:16:48 organza systemd-xdg-autostart-generator[800]: Configuration file /home/sawdis/.config/autostart/xfce-pbw.sh is marked executable. Please remove executable permission bits. Proceeding anyway.
Jul 04 13:16:48 organza systemd-xdg-autostart-generator[800]: /home/sawdis/.config/autostart/xfce-pbw.sh:2: Assignment outside of section. Ignoring.
Jul 04 13:16:48 organza systemd-xdg-autostart-generator[800]: /home/sawdis/.config/autostart/xfce-pbw.sh:3: Assignment outside of section. Ignoring.
Jul 04 13:16:48 organza systemd-xdg-autostart-generator[800]: /home/sawdis/.config/autostart/xfce-pbw.sh:4: Assignment outside of section. Ignoring.
Jul 04 13:16:48 organza systemd-xdg-autostart-generator[800]: /home/sawdis/.config/autostart/xfce-pbw.sh:5: Assignment outside of section. Ignoring.
Jul 04 13:16:48 organza systemd-xdg-autostart-generator[800]: /home/sawdis/.config/autostart/xfce-pbw.sh:6: Assignment outside of section. Ignoring.
Jul 04 13:16:48 organza systemd-xdg-autostart-generator[800]: /home/sawdis/.config/autostart/xfce-pbw.sh:7: Assignment outside of section. Ignoring.
Jul 04 13:16:48 organza systemd-xdg-autostart-generator[800]: Configuration file /etc/xdg/autostart/msm_notifier.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Jul 04 13:16:49 organza pulseaudio[897]: Failed to get the verb HiFi
Jul 04 13:16:49 organza pulseaudio[897]: No UCM verb is valid for hw:1
Jul 04 13:16:49 organza tumblerd[940]: Failed to load plugin "tumbler-gepub-thumbnailer.so": libgepub-0.6.so.0: cannot open shared object file: No such file or directory
Jul 04 13:16:50 organza blueman-mechani[1134]: gtk_icon_theme_get_for_screen: assertion 'GDK_IS_SCREEN (screen)' failed
Jul 04 13:16:50 organza kernel: kauditd_printk_skb: 10 callbacks suppressed
Jul 04 13:17:14 organza pulseaudio[897]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
Jul 04 13:40:26 organza vlc[2739]: edit: index was invalid
Jul 04 13:40:26 organza vlc[2739]: edit: editing failed
Jul 04 13:42:08 organza vlc[2739]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 16999, resource id: 11392975, major code: 40 (TranslateCoords), minor code: 0
Jul 04 13:44:48 organza vlc[2739]: Non-native QFileDialog supports only local files
Jul 04 13:45:42 organza vlc[2739]: QObject::~QObject: Timers cannot be stopped from another thread
Jul 04 14:10:46 organza kernel: proc: Bad value for 'hidepid'
Jul 04 14:22:49 organza kernel: proc: Bad value for 'hidepid'
Jul 04 14:30:53 organza python[6684]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 448, resource id: 0, major code: 18 (ChangeProperty), minor code: 0
Jul 04 14:32:56 organza python[6684]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4552, resource id: 11441819, major code: 40 (TranslateCoords), minor code: 0
Jul 04 15:00:48 organza vlc[75958]: QObject::~QObject: Timers cannot be stopped from another thread
Jul 04 15:10:11 organza kernel: proc: Bad value for 'hidepid'
Jul 04 15:12:14 organza systemd-xdg-autostart-generator[76385]: Configuration file /etc/xdg/autostart/msm_notifier.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Jul 04 17:28:51 organza lightdm[76450]: gkr-pam: unable to locate daemon control file
Jul 04 18:12:40 organza systemd-xdg-autostart-generator[79065]: Configuration file /etc/xdg/autostart/msm_notifier.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Jul 04 18:17:39 organza lightdm[79122]: gkr-pam: unable to locate daemon control file
Jul 04 18:26:50 organza kernel: proc: Bad value for 'hidepid'
Jul 04 19:14:00 organza kernel: proc: Bad value for 'hidepid'
Jul 04 19:17:02 organza qpdfview[81120]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1900, resource id: 11301781, major code: 40 (TranslateCoords), minor code: 0
Jul 04 19:48:02 organza systemd-xdg-autostart-generator[82171]: Configuration file /etc/xdg/autostart/msm_notifier.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Jul 04 20:42:55 organza lightdm[82229]: gkr-pam: unable to locate daemon control file
Jul 04 20:45:07 organza pulseaudio[897]: Error opening PCM device front:1: No such file or directory
Jul 04 20:45:08 organza kernel: watchdog: watchdog0: watchdog did not stop!
