4K monitor running at 30Hz instead of 60Hz
I got a 32 inch 3840 x 2160 60Hz monitor (F32TU87).
When I connect it to my laptop via HDMI, I only get 30Hz.
I used it with a macbook as well, with HDMI and thunderbolt ports, where I get 60Hz in both cases. So we know that the monitor and HDMI cable are fine.
The linux laptop is HP ac179tx. The CPU is i5-6200U which does support 4K@60Hz. However there could be other parts in the laptop which don’t support the resolution.
I tried to force the resolution to 60Hz using xrandr as follows, but the monitor simply resets to 30Hz
xrandr -q
Screen 0: minimum 320 x 200, current 5760 x 2160, maximum 16384 x 16384
eDP-1 connected 1920x1080+0+360 (normal left inverted right x axis y axis) 344mm x 193mm
   1920x1080     60.06 +  60.01*   59.97    59.96    59.93    40.04
   1680x1050     59.95    59.88
   1400x1050     59.98
   1600x900      59.99    59.94    59.95    59.82
   1280x1024     60.02
   1400x900      59.96    59.88
   1280x960      60.00
   1440x810      60.00    59.97
   1368x768      59.88    59.85
   1280x800      59.99    59.97    59.81    59.91
   1280x720      60.00    59.99    59.86    59.74
   1024x768      60.04    60.00
   960x720       60.00
   928x696       60.05
   896x672       60.01
   1024x576      59.95    59.96    59.90    59.82
   960x600       59.93    60.00
   960x540       59.96    59.99    59.63    59.82
   800x600       60.00    60.32    56.25
   840x525       60.01    59.88
   864x486       59.92    59.57
   700x525       59.98
   800x450       59.95    59.82
   640x512       60.02
   700x450       59.96    59.88
   640x480       60.00    59.94
   720x405       59.51    58.99
   684x384       59.88    59.85
   640x400       59.88    59.98
   640x360       59.86    59.83    59.84    59.32
   512x384       60.00
   512x288       60.00    59.92
   480x270       59.63    59.82
   400x300       60.32    56.34
   432x243       59.92    59.57
   320x240       60.05
   360x202       59.51    59.13
   320x180       59.84    59.32
HDMI-1 connected primary 3840x2160+1920+0 (normal left inverted right x axis y axis) 698mm x 393mm
   3840x2160     30.00*   29.97
   2560x1440     59.95
   1920x1080     60.00    50.00    59.94
   1680x1050     59.88
   1600x900      60.00
   1280x1024     75.02    60.02
   1440x900      59.90
   1280x800      59.91
   1152x864      75.00
   1280x720      60.00    50.00    59.94
   1024x768      75.03    70.07    60.00
   832x624       74.55
   800x600       72.19    75.00    60.32    56.25
   720x576       50.00
   720x480       60.00    59.94
   640x480       75.00    72.81    66.67    60.00    59.94
   720x400       70.08
Next I added a new mode to xrandr
xrandr --newmode "3840x2160_60.00"  712.75  3840 4160 4576 5312  2160 2163 2168 2237 -hsync +vsync
Add that mode to the monitor
xrandr --addmode HDMI-1 3840x2160_60.00
Try to set the output to this mode, and get an error
xrandr --output HDMI-1 --mode 3840x2160_60.00
xrandr: Configure crtc 0 failed
What else can I try? Could I somehow try to make it use the secondary GPU available? Is there a way I could confirm that this laptop doesn’t support 4K@60Hz?
Here are some relevant system details,
inxi -Fxxx # I removed the irrelevant sections
  Host: aaaa-pc Kernel: 5.15.81-1-MANJARO arch: x86_64 bits: 64
    compiler: gcc v: 12.2.0 Desktop: Xfce v: 4.16.1 tk: Gtk v: 3.24.34
    info: xfce4-panel wm: xfwm v: 4.16.1 vt: 7 dm: LightDM v: 1.32.0
  Type: Laptop System: HP product: HP Notebook v: Type1ProductConfigId
  Mobo: HP model: 8136 v: 31.36 serial: <superuser required> UEFI: Insyde
    v: F.1F date: 01/18/2016
  Info: dual core model: Intel Core i5-6200U bits: 64 type: MT MCP
    smt: enabled arch: Skylake rev: 3 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
  Speed (MHz): avg: 800 min/max: 400/2800 cores: 1: 800 2: 800 3: 800 4: 800
    bogomips: 19204
  Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Hewlett-Packard
    driver: i915 v: kernel arch: Gen-9 ports: active: HDMI-A-1,eDP-1 empty: none
    bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
  Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 M430 Radeon
    520 Mobile] vendor: Hewlett-Packard driver: radeon v: kernel arch: GCN-1
    pcie: speed: 8 GT/s lanes: 4 bus-ID: 01:00.0 chip-ID: 1002:6660
    class-ID: 0380 temp: 55.0 C
  Device-3: Realtek HP Truevision HD type: USB driver: uvcvideo
    bus-ID: 1-5:6 chip-ID: 0bda:57d6 class-ID: 0e02 serial: DEWKP01BI9L83M
  Display: x11 server: X.Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver: X:
    loaded: modesetting unloaded: radeon alternate: fbdev,vesa
    dri: iris,radeonsi gpu: i915 display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 5760x2160 s-dpi: 96 s-size: 1524x572mm (60.00x22.52")
    s-diag: 1628mm (64.09")
  Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary,top-right
    model: Samsung LF32TU87 serial: HNTTA00160 res: 3840x2160 hz: 30 dpi: 140
    size: 698x393mm (27.48x15.47") diag: 806mm (31.7") modes: max: 3840x2160
    min: 720x400
  Monitor-2: eDP-1 pos: bottom-l model: AU Optronics 0x38ed res: 1920x1080
    dpi: 142 size: 344x193mm (13.54x7.6") diag: 394mm (15.5") modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 22.2.4 renderer: Mesa Intel HD Graphics 520 (SKL
    GT2) direct render: Yes
  Processes: 223 Uptime: 16m wakeups: 1 Memory: 7.66 GiB
  used: 3.73 GiB (48.7%) Init: systemd v: 251 default: graphical Compilers:
  gcc: 12.2.0 clang: 14.0.6 Packages: 2117 pm: pacman pkgs: 2106 pm: snap
  pkgs: 11 Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.23
Unfortunately your iGPU does not support 4k@60Hz via HDMI, but 24Hz
Max Resolution (HDMI) 4096x2304@24Hz
See the official detail:
https://www.intel.com/content/www/us/en/products/sku/88193/intel-core-i56200u-processor-3m-cache-up-to-2-80-ghz/specifications.html
That is UHD but it is smaller than 4096x2304
UHD at ~ 30Hz is for your iGPU’s HDMI with the limit.
Try to switch to DP that support 4096x2304@60Hz in the detail.
If your laptop has no DP, then unhappiness.
Thanks for the help. Sadly my laptop doesn’t have DP. I guess it’s time to buy a new one.
No, you have to switch from the intel-igpu to your amd-gpu. search the forum for amd and optimus.
