I am having a similar problem as @wuegsd
Video Card: AMD rx590
Monitor: Gigabyte M32U
Kernel: 5.15.12-1-MANJARO
I did a little digging into Xorg.0.log (see below) and noticed that Xorg managed to detect all the potential modelines correctly when it is probed. However,. later on, DDC is invoked and the modelines don’t reflect what is probed earlier in the log.
Unfortunately, amdgpu doesn’t make available the options NoDDC or DDC to disable it.
Xorg.0.log
[ 1011.519] (--) Log file renamed from "/var/log/Xorg.pid-27916.log" to "/var/log/Xorg.0.log"
[ 1011.519]
X.Org X Server 1.21.1.2
[ 1011.519] Current Operating System: Linux kronos 5.15.12-1-MANJARO #1 SMP PREEMPT Wed Dec 29 18:08:07 UTC 2021 x86_64
[ 1011.519] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=67aaaea9-f5b9-4560-9ab8-0f69bfb3d6c3 rw quiet splash apparmor=1 security=apparmor udev.log_priority=3 acpi_enforce_resources=lax nowatchdog mitigations=off amdgpu.dpm=1 amdgpu.exp_hw_support=1
[ 1011.519]
[ 1011.519] Current version of pixman: 0.40.0
[ 1011.519] Before reporting problems, check http://wiki.x.org
[ 1011.519] Markers: (--) probed, (**) from config file, (==) default setting,
[ 1011.519] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Jan 22 21:24:36 2022
[ 1011.519] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 1011.519] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 1011.519] (==) No Layout section. Using the first Screen section.
[ 1011.519] (==) No screen section available. Using defaults.
[ 1011.519] (**) |-->Screen "Default Screen Section" (0)
[ 1011.519] (**) | |-->Monitor "<default monitor>"
[ 1011.520] (==) No device specified for screen "Default Screen Section".
Using the first device section listed.
[ 1011.520] (**) | |-->Device "AMD"
[ 1011.520] (==) No monitor specified for screen "Default Screen Section".
[ 1011.520] (**) Option "DontVTSwitch" "false"
[ 1011.520] (==) Automatically adding devices
[ 1011.520] (==) Automatically enabling devices
[ 1011.520] (==) Automatically adding GPU devices
[ 1011.520] (==) Automatically binding GPU devices
[ 1011.520] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 1011.520] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 1011.520] Entry deleted from font path.
[ 1011.520] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 1011.520] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 1011.520] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF,
/usr/share/fonts/OTF
[ 1011.520] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 1011.520] (II) The server relies on udev to provide the list of input devices.
[ 1011.520] (II) Module ABI versions:
[ 1011.520] X.Org ANSI C Emulation: 0.4
[ 1011.520] X.Org Video Driver: 25.2
[ 1011.520] X.Org XInput driver : 24.4
[ 1011.520] X.Org Server Extension : 10.0
[ 1011.520] (++) using VT number 1
[ 1011.520] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 1011.521] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 1011.521] (II) Platform probe for /sys/devices/pci0000:00/0000:00:03.1/0000:07:00.0/drm/card0
[ 1011.523] (--) PCI:*(7@0:0:0) 1002:67df:1da2:e366 rev 225, Mem @ 0xd0000000/268435456, 0xe0000000/2097152, 0xfce00000/262144, I/O @ 0x0000e000/256, BIOS @ 0x????????/131072
[ 1011.523] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 1011.523] (II) LoadModule: "glx"
[ 1011.523] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 1011.524] (II) Module glx: vendor="X.Org Foundation"
[ 1011.524] compiled for 1.21.1.2, module version = 1.0.0
[ 1011.524] ABI class: X.Org Server Extension, version 10.0
[ 1011.524] (II) LoadModule: "amdgpu"
[ 1011.524] (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
[ 1011.526] (II) Module amdgpu: vendor="X.Org Foundation"
[ 1011.526] compiled for 1.21.1, module version = 21.0.0
[ 1011.526] Module class: X.Org Video Driver
[ 1011.526] ABI class: X.Org Video Driver, version 25.2
[ 1011.526] (II) AMDGPU: Driver for AMD Radeon:
All GPUs supported by the amdgpu kernel driver
[ 1011.526] (II) AMDGPU(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 1011.526] (==) AMDGPU(0): Depth 24, (--) framebuffer bpp 32
[ 1011.526] (II) AMDGPU(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[ 1011.526] (==) AMDGPU(0): Default visual is TrueColor
[ 1011.526] (**) AMDGPU(0): Option "TearFree" "true"
[ 1011.526] (**) AMDGPU(0): Option "VariableRefresh" "true"
[ 1011.526] (==) AMDGPU(0): RGB weight 888
[ 1011.526] (II) AMDGPU(0): Using 8 bits per RGB (8 bit DAC)
[ 1011.526] (--) AMDGPU(0): Chipset: "AMD Radeon RX 590 Series" (ChipID = 0x67df)
[ 1011.526] (II) Loading sub module "fb"
[ 1011.526] (II) LoadModule: "fb"
[ 1011.526] (II) Module "fb" already built-in
[ 1011.526] (II) Loading sub module "dri2"
[ 1011.526] (II) LoadModule: "dri2"
[ 1011.526] (II) Module "dri2" already built-in
[ 1011.542] (II) Loading sub module "glamoregl"
[ 1011.542] (II) LoadModule: "glamoregl"
[ 1011.542] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 1011.544] (II) Module glamoregl: vendor="X.Org Foundation"
[ 1011.544] compiled for 1.21.1.2, module version = 1.0.1
[ 1011.544] ABI class: X.Org ANSI C Emulation, version 0.4
[ 1011.551] (II) AMDGPU(0): glamor X acceleration enabled on AMD Radeon RX 590 Series (POLARIS10, DRM 3.42.0, 5.15.12-1-MANJARO, LLVM 13.0.0)
[ 1011.551] (II) AMDGPU(0): glamor detected, initialising EGL layer.
[ 1011.551] (**) AMDGPU(0): TearFree property default: on
[ 1011.551] (**) AMDGPU(0): VariableRefresh: enabled
[ 1011.551] (II) AMDGPU(0): KMS Pageflipping: enabled
[ 1011.552] (II) AMDGPU(0): Output DisplayPort-0 has no monitor section
[ 1011.552] (II) AMDGPU(0): Output DisplayPort-1 has no monitor section
[ 1011.552] (II) AMDGPU(0): Output HDMI-A-0 has no monitor section
[ 1011.552] (II) AMDGPU(0): Output HDMI-A-1 has no monitor section
[ 1011.552] (II) AMDGPU(0): Output DVI-D-0 has no monitor section
[ 1011.558] (II) AMDGPU(0): EDID for output DisplayPort-0
[ 1011.558] (II) AMDGPU(0): Manufacturer: GBT Model: 3204 Serial#: 2558
[ 1011.558] (II) AMDGPU(0): Year: 2021 Week: 35
[ 1011.558] (II) AMDGPU(0): EDID Version: 1.4
[ 1011.558] (II) AMDGPU(0): Digital Display Input
[ 1011.558] (II) AMDGPU(0): 10 bits per channel
[ 1011.558] (II) AMDGPU(0): Digital interface is DisplayPort
[ 1011.558] (II) AMDGPU(0): Max Image Size [cm]: horiz.: 70 vert.: 39
[ 1011.558] (II) AMDGPU(0): Gamma: 2.20
[ 1011.558] (II) AMDGPU(0): DPMS capabilities: Off
[ 1011.558] (II) AMDGPU(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4 YCrCb 4:2:2
[ 1011.558] (II) AMDGPU(0): First detailed timing is preferred mode
[ 1011.558] (II) AMDGPU(0): Preferred mode is native pixel format and refresh rate
[ 1011.558] (II) AMDGPU(0): Display is continuous-frequency
[ 1011.558] (II) AMDGPU(0): redX: 0.679 redY: 0.314 greenX: 0.270 greenY: 0.626
[ 1011.558] (II) AMDGPU(0): blueX: 0.146 blueY: 0.054 whiteX: 0.313 whiteY: 0.329
[ 1011.558] (II) AMDGPU(0): Supported established timings:
[ 1011.558] (II) AMDGPU(0): 720x400@70Hz
[ 1011.558] (II) AMDGPU(0): 640x480@60Hz
[ 1011.558] (II) AMDGPU(0): 640x480@67Hz
[ 1011.558] (II) AMDGPU(0): 640x480@72Hz
[ 1011.558] (II) AMDGPU(0): 640x480@75Hz
[ 1011.558] (II) AMDGPU(0): 800x600@56Hz
[ 1011.558] (II) AMDGPU(0): 800x600@60Hz
[ 1011.558] (II) AMDGPU(0): 800x600@72Hz
[ 1011.558] (II) AMDGPU(0): 800x600@75Hz
[ 1011.558] (II) AMDGPU(0): 1024x768@60Hz
[ 1011.558] (II) AMDGPU(0): 1024x768@70Hz
[ 1011.558] (II) AMDGPU(0): 1024x768@75Hz
[ 1011.558] (II) AMDGPU(0): 1280x1024@75Hz
[ 1011.558] (II) AMDGPU(0): Manufacturer's mask: 0
[ 1011.558] (II) AMDGPU(0): Supported standard timings:
[ 1011.558] (II) AMDGPU(0): #0: hsize: 1280 vsize 960 refresh: 60 vid: 16513
[ 1011.558] (II) AMDGPU(0): #1: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 1011.558] (II) AMDGPU(0): #2: hsize: 1440 vsize 900 refresh: 60 vid: 149
[ 1011.558] (II) AMDGPU(0): #3: hsize: 1152 vsize 864 refresh: 75 vid: 20337
[ 1011.558] (II) AMDGPU(0): #4: hsize: 1280 vsize 720 refresh: 60 vid: 49281
[ 1011.558] (II) AMDGPU(0): #5: hsize: 1680 vsize 1050 refresh: 60 vid: 179
[ 1011.558] (II) AMDGPU(0): #6: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 1011.558] (II) AMDGPU(0): Supported detailed timing:
[ 1011.558] (II) AMDGPU(0): clock: 533.2 MHz Image Size: 697 x 392 mm
[ 1011.558] (II) AMDGPU(0): h_active: 3840 h_sync: 3888 h_sync_end 3920 h_blank_end 4000 h_border: 0
[ 1011.558] (II) AMDGPU(0): v_active: 2160 v_sync: 2163 v_sync_end 2168 v_blanking: 2222 v_border: 0
[ 1011.558] (II) AMDGPU(0): Serial No: 21351B002558
[ 1011.558] (II) AMDGPU(0): Ranges: V min: 48 V max: 144 Hz, H min: 255 H max: 255 kHz, PixClock max 1315 MHz
[ 1011.558] (II) AMDGPU(0): Monitor name: Gigabyte M32U
[ 1011.558] (II) AMDGPU(0): clock: 241.5 MHz Image Size: 697 x 392 mm
[ 1011.558] (II) AMDGPU(0): h_active: 2560 h_sync: 2608 h_sync_end 2640 h_blank_end 2720 h_border: 0
[ 1011.558] (II) AMDGPU(0): v_active: 1440 v_sync: 1443 v_sync_end 1448 v_blanking: 1481 v_border: 0
[ 1011.558] (II) AMDGPU(0): clock: 285.5 MHz Image Size: 697 x 392 mm
[ 1011.558] (II) AMDGPU(0): h_active: 1920 h_sync: 1968 h_sync_end 2000 h_blank_end 2080 h_border: 0
[ 1011.558] (II) AMDGPU(0): v_active: 1080 v_sync: 1130 v_sync_end 1138 v_blanking: 1144 v_border: 0
[ 1011.558] (II) AMDGPU(0): clock: 497.8 MHz Image Size: 697 x 392 mm
[ 1011.558] (II) AMDGPU(0): v_active: 1440 v_sync: 1443 v_sync_end 1448 v_blanking: 1525 v_border: 0
[ 1011.558] (II) AMDGPU(0): Number of EDID sections to follow: 2
[ 1011.558] (II) AMDGPU(0): EDID (in hex):
[ 1011.558] (II) AMDGPU(0): 00ffffffffffff001c540432fe090000
[ 1011.558] (II) AMDGPU(0): 231f0104b54627783be1b5ad5045a025
[ 1011.558] (II) AMDGPU(0): 0d5054bfcf00814081809500714f81c0
[ 1011.558] (II) AMDGPU(0): b300d1c001014dd000a0f0703e803020
[ 1011.558] (II) AMDGPU(0): 3500b9882100001a000000ff00323133
[ 1011.558] (II) AMDGPU(0): 3531423030323535380a000000fd0030
[ 1011.558] (II) AMDGPU(0): 90ffff83010a202020202020000000fc
[ 1011.558] (II) AMDGPU(0): 004769676162797465204d3332550212
[ 1011.558] (II) AMDGPU(0): 020342f156010304131f120211900f0e
[ 1011.558] (II) AMDGPU(0): 1d1e60610514765d5e5f2f2309070783
[ 1011.558] (II) AMDGPU(0): 01000065030c0010006d1a0000020b30
[ 1011.558] (II) AMDGPU(0): 900005653c653ce305c301e606050165
[ 1011.558] (II) AMDGPU(0): 6512565e00a0a0a0295030203500b988
[ 1011.558] (II) AMDGPU(0): 2100001a8a6f80a0703840403020280c
[ 1011.558] (II) AMDGPU(0): b9882100001a6fc200a0a0a055503020
[ 1011.558] (II) AMDGPU(0): 3500b9882100001a0000000000000035
[ 1011.558] (II) AMDGPU(0): 701279000003016447f80104ff0e4f00
[ 1011.558] (II) AMDGPU(0): 07001f006f087e0070000700eba30104
[ 1011.558] (II) AMDGPU(0): ff0e4f0007001f006f087e0070000700
[ 1011.558] (II) AMDGPU(0): d0500104ff0e9f0010003e006f082700
[ 1011.558] (II) AMDGPU(0): 14000700fb7e00047f07870017001f00
[ 1011.558] (II) AMDGPU(0): 3704110002000400f7e30004ff099f00
[ 1011.558] (II) AMDGPU(0): 07001f009f0531001800070000000000
[ 1011.558] (II) AMDGPU(0): 0000000000000000000000000000d190
[ 1011.558] (II) AMDGPU(0): Printing probed modes for output DisplayPort-0
[ 1011.558] (II) AMDGPU(0): Modeline "3840x2160"x60.0 533.25 3840 3888 3920 4000 2160 2163 2168 2222 +hsync -vsync (133.3 kHz eP)
[ 1011.558] (II) AMDGPU(0): Modeline "3840x2160"x144.0 1290.96 3840 3848 3880 3920 2160 2273 2281 2287 -hsync -vsync (329.3 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "3840x2160"x120.0 1188.00 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync (270.0 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "3840x2160"x119.9 1186.81 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync (269.7 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "3840x2160"x119.9 1075.00 3840 3848 3880 3920 2160 2273 2281 2287 -hsync -vsync (274.2 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "3840x2160"x98.0 862.25 3840 3857 3920 4000 2160 2181 2189 2200 -hsync -vsync (215.6 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "3840x2160"x60.0 594.00 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync (135.0 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "3840x2160"x50.0 594.00 3840 4896 4984 5280 2160 2168 2178 2250 +hsync +vsync (112.5 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "3840x2160"x59.9 593.41 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync (134.9 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "3840x2160"x30.0 297.00 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync (67.5 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "3840x2160"x25.0 297.00 3840 4896 4984 5280 2160 2168 2178 2250 +hsync +vsync (56.2 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "3840x2160"x24.0 297.00 3840 5116 5204 5500 2160 2168 2178 2250 +hsync +vsync (54.0 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "3840x2160"x30.0 296.70 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync (67.4 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "3840x2160"x24.0 296.70 3840 5116 5204 5500 2160 2168 2178 2250 +hsync +vsync (53.9 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "2560x1440"x144.0 583.60 2560 2568 2600 2720 1440 1465 1473 1490 -hsync -vsync (214.6 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "2560x1440"x120.0 497.75 2560 2608 2640 2720 1440 1443 1448 1525 +hsync -vsync (183.0 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "2560x1440"x60.0 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync (88.8 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "1920x1200"x60.0 533.25 1920 3888 3920 4000 1200 2163 2168 2222 +hsync -vsync (133.3 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "1920x1080"x144.0 325.08 1920 1944 1976 2056 1080 1083 1088 1098 -hsync -vsync (158.1 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "1920x1080"x120.0 285.54 1920 1968 2000 2080 1080 1130 1138 1144 +hsync -vsync (137.3 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 -hsync -vsync (67.5 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "1920x1080"x50.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "1600x1200"x60.0 533.25 1600 3888 3920 4000 1200 2163 2168 2222 +hsync -vsync (133.3 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "1440x900"x59.9 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "1280x800"x60.0 533.25 1280 3888 3920 4000 800 2163 2168 2222 +hsync -vsync (133.3 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "1280x720"x120.0 148.50 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (90.0 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "1280x720"x119.9 148.35 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (89.9 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "1280x720"x50.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "1440x576"x50.0 54.00 1440 1464 1592 1728 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "1440x480"x60.0 54.05 1440 1472 1596 1716 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "1440x480"x59.9 54.00 1440 1472 1596 1716 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "720x576"x50.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "720x480"x60.0 27.03 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "640x480"x66.7 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 1011.558] (II) AMDGPU(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 1011.558] (II) AMDGPU(0): EDID for output DisplayPort-1
[ 1011.558] (II) AMDGPU(0): EDID for output HDMI-A-0
[ 1011.558] (II) AMDGPU(0): EDID for output HDMI-A-1
[ 1011.558] (II) AMDGPU(0): EDID for output DVI-D-0
[ 1011.558] (II) AMDGPU(0): Output DisplayPort-0 connected
[ 1011.558] (II) AMDGPU(0): Output DisplayPort-1 disconnected
[ 1011.558] (II) AMDGPU(0): Output HDMI-A-0 disconnected
[ 1011.558] (II) AMDGPU(0): Output HDMI-A-1 disconnected
[ 1011.558] (II) AMDGPU(0): Output DVI-D-0 disconnected
[ 1011.558] (II) AMDGPU(0): Using exact sizes for initial modes
[ 1011.558] (II) AMDGPU(0): Output DisplayPort-0 using initial mode 3840x2160 +0+0
[ 1011.558] (II) AMDGPU(0): mem size init: gart size :1ff86b000 vram size: s:1fd32c000 visible:fad0000
[ 1011.558] (==) AMDGPU(0): DPI set to (96, 96)
[ 1011.558] (==) AMDGPU(0): Using gamma correction (1.0, 1.0, 1.0)
[ 1011.558] (II) Loading sub module "ramdac"
[ 1011.558] (II) LoadModule: "ramdac"
[ 1011.558] (II) Module "ramdac" already built-in
[ 1011.558] (II) AMDGPU(0): [DRI2] Setup complete
[ 1011.558] (II) AMDGPU(0): [DRI2] DRI driver: radeonsi
[ 1011.558] (II) AMDGPU(0): [DRI2] VDPAU driver: radeonsi
[ 1011.559] (II) AMDGPU(0): Front buffer pitch: 15360 bytes
[ 1011.559] (II) AMDGPU(0): SYNC extension fences enabled
[ 1011.559] (II) AMDGPU(0): Present extension enabled
[ 1011.559] (==) AMDGPU(0): DRI3 enabled
[ 1011.559] (==) AMDGPU(0): Backing store enabled
[ 1011.559] (II) AMDGPU(0): Direct rendering enabled
[ 1011.563] (II) AMDGPU(0): Use GLAMOR acceleration.
[ 1011.563] (II) AMDGPU(0): Acceleration enabled
[ 1011.563] (==) AMDGPU(0): DPMS enabled
[ 1011.563] (==) AMDGPU(0): Silken mouse enabled
[ 1011.563] (II) AMDGPU(0): Set up textured video (glamor)
[ 1011.574] (WW) AMDGPU(0): Option "DDC" is not used
[ 1011.574] (II) Initializing extension Generic Event Extension
[ 1011.574] (II) Initializing extension SHAPE
[ 1011.574] (II) Initializing extension MIT-SHM
[ 1011.574] (II) Initializing extension XInputExtension
[ 1011.574] (II) Initializing extension XTEST
[ 1011.574] (II) Initializing extension BIG-REQUESTS
[ 1011.574] (II) Initializing extension SYNC
[ 1011.574] (II) Initializing extension XKEYBOARD
[ 1011.574] (II) Initializing extension XC-MISC
[ 1011.574] (II) Initializing extension SECURITY
[ 1011.574] (II) Initializing extension XFIXES
[ 1011.574] (II) Initializing extension RENDER
[ 1011.574] (II) Initializing extension RANDR
[ 1011.574] (II) Initializing extension COMPOSITE
[ 1011.575] (II) Initializing extension DAMAGE
[ 1011.575] (II) Initializing extension MIT-SCREEN-SAVER
[ 1011.575] (II) Initializing extension DOUBLE-BUFFER
[ 1011.575] (II) Initializing extension RECORD
[ 1011.575] (II) Initializing extension DPMS
[ 1011.575] (II) Initializing extension Present
[ 1011.575] (II) Initializing extension DRI3
[ 1011.575] (II) Initializing extension X-Resource
[ 1011.575] (II) Initializing extension XVideo
[ 1011.575] (II) Initializing extension XVideo-MotionCompensation
[ 1011.575] (II) Initializing extension GLX
[ 1011.580] (II) AIGLX: Loaded and initialized radeonsi
[ 1011.580] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 1011.580] (II) Initializing extension XFree86-VidModeExtension
[ 1011.580] (II) Initializing extension XFree86-DGA
[ 1011.580] (II) Initializing extension XFree86-DRI
[ 1011.580] (II) Initializing extension DRI2
[ 1011.580] (II) AMDGPU(0): Setting screen physical size to 1016 x 571
[ 1011.586] (EE) AMDGPU(0): Failed to make import prime FD as pixmap: 22
[.....truncated]
[ 1017.361] (II) AMDGPU(0): EDID vendor "GBT", prod id 12804
[ 1017.361] (II) AMDGPU(0): Using EDID range info for horizontal sync
[ 1017.361] (II) AMDGPU(0): Using EDID range info for vertical refresh
[ 1017.361] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 1017.361] (II) AMDGPU(0): Modeline "3840x2160"x0.0 533.25 3840 3888 3920 4000 2160 2163 2168 2222 +hsync -vsync (133.3 kHz eP)
[ 1017.361] (II) AMDGPU(0): Modeline "2560x1440"x0.0 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync (88.8 kHz e)
[ 1017.361] (II) AMDGPU(0): Modeline "1920x1080"x0.0 285.54 1920 1968 2000 2080 1080 1130 1138 1144 +hsync -vsync (137.3 kHz e)
[ 1017.361] (II) AMDGPU(0): Modeline "2560x1440"x0.0 497.75 2560 2608 2640 2720 1440 1443 1448 1525 +hsync -vsync (183.0 kHz e)
[ 1017.361] (II) AMDGPU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 1017.361] (II) AMDGPU(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 1017.361] (II) AMDGPU(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 1017.361] (II) AMDGPU(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 1017.361] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 1017.361] (II) AMDGPU(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 1017.361] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 1017.361] (II) AMDGPU(0): Modeline "1440x480"x0.0 54.00 1440 1472 1596 1716 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 1017.361] (II) AMDGPU(0): Modeline "1440x576"x0.0 54.00 1440 1464 1592 1728 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 1017.361] (II) AMDGPU(0): Modeline "1920x1080i"x0.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[ 1017.361] (II) AMDGPU(0): Modeline "1920x1080i"x0.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[ 1017.361] (II) AMDGPU(0): Modeline "1280x720"x0.0 148.50 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (90.0 kHz e)
[ 1017.361] (II) AMDGPU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 1017.361] (II) AMDGPU(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 1017.361] (II) AMDGPU(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 1017.361] (II) AMDGPU(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 1017.361] (II) AMDGPU(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 1017.361] (II) AMDGPU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 1017.361] (II) AMDGPU(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 1017.361] (II) AMDGPU(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 1017.361] (II) AMDGPU(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 1017.361] (II) AMDGPU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 1017.361] (II) AMDGPU(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 1017.361] (II) AMDGPU(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 1017.361] (II) AMDGPU(0): Modeline "1280x960"x0.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[ 1017.361] (II) AMDGPU(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 1017.361] (II) AMDGPU(0): Modeline "1440x900"x0.0 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz e)
[ 1017.361] (II) AMDGPU(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 1017.361] (II) AMDGPU(0): Modeline "1680x1050"x0.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
20-amdgpu.conf
Section "Device"
Identifier "AMD"
Driver "amdgpu"
EndSection
Output of xrandr --properties --current after running similar commands as @wuegsd (and receiving the same error)
Screen 0: minimum 320 x 200, current 3840 x 2160, maximum 16384 x 16384
DisplayPort-0 connected primary 3840x2160+0+0 (normal left inverted right x axis y axis) 697mm x 392mm
EDID:
GAMMA_LUT_SIZE: 4096
range: (0, -1)
DEGAMMA_LUT_SIZE: 4096
range: (0, -1)
GAMMA_LUT: 0
range: (0, 65535)
CTM: 0 1 0 0 0 0 0 0 0 1 0 0 0 0 0 0
0 1
DEGAMMA_LUT: 0
range: (0, 65535)
TearFree: on
supported: off, on, auto
subconnector: Native
supported: Unknown, VGA, DVI-D, HDMI, DP, Wireless, Native
vrr_capable: 1
range: (0, 1)
max bpc: 8
range: (8, 16)
underscan vborder: 0
range: (0, 128)
underscan hborder: 0
range: (0, 128)
underscan: off
scaling mode: None
supported: None, Full, Center, Full aspect
link-status: Good
supported: Good, Bad
CONNECTOR_ID: 65
supported: 65
non-desktop: 0
range: (0, 1)
3840x2160 60.00 + 144.00 120.00 119.88 119.91 97.98 60.00* 50.00 59.94 30.00 25.00 24.00 29.97 23.98
2560x1440 144.00 120.00 59.95
1920x1200 60.00
1920x1080 144.00 120.00 60.00 60.00 50.00 59.94
1600x1200 60.00
1680x1050 59.95
1280x1024 75.02 60.02
1440x900 59.89
1280x960 60.00
1280x800 60.00
1152x864 75.00
1280x720 120.00 119.88 60.00 50.00 59.94
1440x576 50.00
1024x768 75.03 70.07 60.00
1440x480 60.00 59.94
800x600 72.19 75.00 60.32 56.25
720x576 50.00
720x480 60.00 59.94
640x480 75.00 72.81 66.67 60.00 59.94
720x400 70.08
3840x2160_120.00 120.00
