390xx-bumblebee doesn't optirun
Asus Laptop K73SV / i5-2410M / dGPU GeForce GT540M/
Did a clean install of Manjaro Gnome.
Updated everything.
Installed Kernel 5.4.159-1. deinstalled the Kernel 5.14. rebooted.
deinstalled the free drivers and installed the 390xx-bumblebee
sudo mhwd -f -r pci video-linux
sudo mhwd -f -i pci video-hybrid-intel-nvidia-390xx-bumblebee
added myself to bumblebee
sudo gpasswd -a $USER bumblebee
rebooted.
Disabled Wayland
sudo gedit /etc/gdm/custom.conf
WaylandEnable=false
installed
sudo pacman -S virtualgl
rebooted.
glxspheres64
runs, but
optirun glxspheres64
gives
[ 1508.017942] [ERROR]Cannot access secondary GPU - error: [XORG] (EE) NVIDIA: Use the -ignoreABI option to override this check.
[ 1508.017994] [ERROR]Aborting because fallback start is disabled.
mhwd
gives
> 0000:01:00.0 (0300:10de:0df4) Display controller nVidia Corporation:
video-hybrid-intel-nvidia-390xx-bumblebee            2021.11.04               false            PCI
    video-nvidia-390xx            2021.11.04               false            PCI
           video-linux            2018.05.04                true            PCI
> 0000:00:02.0 (0300:8086:0116) Display controller Intel Corporation:
Is there anything i can do to use my GPU? At this point i wouldnt care if i have to reboot to change between graphics, run optirun before programs or use optimusmanger, just need a way to use the dGPU.
Thanks, this worked.
