How can I install these two files? (hope this is correct forum)
I tried:
sudo pacman -S libvulkan1:i386
sudo pacman -S mesa-vulkan-drivers:i386
But files were not found. I used these commands on Debian based Linux:
sudo apt install libvulkan1:i386
sudo apt install mesa-vulkan-drivers:i386
It is for some old 32bit game, that needs these drivers
Those are Debian / Ubuntu package names. It depends on your graphics chip:
❯ pacman -Ss vulkan lib32
multilib/lib32-amdvlk 2021.Q2.2-1
AMD's standalone Vulkan driver
multilib/lib32-nvidia-390xx-utils 390.143-1
NVIDIA drivers utilities (32-bit)
multilib/lib32-nvidia-utils 465.27-1 [installed]
multilib/lib32-primus_vk 1.5-1
Nvidia Vulkan offloading for Bumblebee
multilib/lib32-vkd3d 1.2-2 [installed]
Direct3D 12 to Vulkan translation library By WineHQ
multilib/lib32-vulkan-icd-loader 1.2.176-1 [installed]
Vulkan Installable Client Driver (ICD) Loader (32-bit)
multilib/lib32-vulkan-intel 21.1.0-1
Intel's Vulkan mesa driver (32-bit)
multilib/lib32-vulkan-mesa-layers 21.1.0-1
Mesa's Vulkan layers (32-bit)
multilib/lib32-vulkan-radeon 21.1.0-1
Radeon's Vulkan mesa driver (32-bit)
multilib/lib32-vulkan-validation-layers 1.2.172-1
Vulkan Validation Layers (32-bit)
Ah, this is the command, thank you very much!
Strit
4
To show the packages yes, not to install them.
What you want is probably something like:
sudo pacman -S <the package names in previous list>
system
Closed
5
