Here, worked this time. Cut some hopefully irrelevant parts out because the forum was interpreting it as a link.
$ inxi -Fxxz
System: Kernel: 5.7.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: KDE Plasma 5.20.2 tk: Qt 5.15.1
wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Desktop Mobo: ASRock model: TRX40 Creator serial: <filter> UEFI: American Megatrends v: P1.70
date: 05/29/2020
CPU: Info: 24-Core (3-Die) model: AMD Ryzen Threadripper 3960X bits: 64 type: MT MCP MCM arch: Zen 2 L2 cache: 12.0 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 364978
Speed: 2200 MHz min/max: 2200/3800 MHz boost: enabled Core speeds (MHz): 1: 2197 2: 2199 3: 2055 4: 2055 5: 2199
6: 2196 7: 2199 8: 2199 9: 2197 10: 2201 11: 2198 12: 2200 13: 2200 14: 2199 15: 1993 16: 3608 17: 2021 18: 2236
19: 2024 20: 2027 21: 2201 22: 2199 23: 2198 24: 2198 25: 2197 26: 2201 27: 2200 28: 3598 29: 2057 30: 2055
31: 2196 32: 2199 33: 2200 34: 2194 35: 2201 36: 2197 37: 2200 38: 2200 39: 2199 40: 2197 41: 1991 42: 4489
43: 2047 44: 2198 45: 2199 46: 2198 47: 2200 48: 3598
Audio: Device-1: NVIDIA TU116 High Definition Audio vendor: eVga(dot)com. driver: snd_hda_intel v: kernel bus ID: 01:00.1
chip ID: 10de:1aeb
Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio driver: snd_hda_intel v: kernel bus ID: 22:00.4
chip ID: 1022:1487
Device-3: Generic USB Audio type: USB driver: hid-generic,snd-usb-audio,usbhid bus ID: 11-5:4 chip ID: 26ce:0a01
Sound Server: ALSA v: k5.7.19-2-MANJARO
$ sudo dmesg
[ 0.000000] Linux version 5.7.19-2-MANJARO (builduser@LEGION) (gcc version 10.2.0 (GCC), GNU ld (GNU Binutils) 2.35) #1 SMP PREEMPT Fri Aug 28 20:22:12 UTC 2020
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64 root=UUID=162e4a44-4858-4edf-b959-f4db6c38427a rw quiet udev.log_priority=3
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] Hygon HygonGenuine
[ 0.000000] Centaur CentaurHauls
[ 0.000000] zhaoxin Shanghai
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'compacted' format.
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000003ffffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000004000000-0x000000000400cfff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000000400d000-0x0000000009df1fff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000009df2000-0x0000000009ffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000000a000000-0x00000000a7e30fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000a7e31000-0x00000000a936bfff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000a936c000-0x00000000a93b8fff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x00000000a93b9000-0x00000000a9884fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000a9885000-0x00000000aad38fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000aad39000-0x00000000aad3cfff] type 20
[ 0.000000] BIOS-e820: [mem 0x00000000aad3d000-0x00000000aad3dfff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000aad3e000-0x00000000aadfefff] type 20
[ 0.000000] BIOS-e820: [mem 0x00000000aadff000-0x00000000abffffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000ac000000-0x00000000afffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000b2500000-0x00000000b2580fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000b3580000-0x00000000b3600fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000e2100000-0x00000000e2280fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fa180000-0x00000000fa200fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fa300000-0x00000000fa3fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fea00000-0x00000000feafffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec10000-0x00000000fec10fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed40000-0x00000000fed44fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed80000-0x00000000fed8ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fedc2000-0x00000000fedcffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fedd4000-0x00000000fedd5fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000feefffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000204f1fffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000204f200000-0x000000204fffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000010000000000-0x00000100103fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x000003cb90000000-0x000003cba03fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x000003cbc0000000-0x000003cbd03fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000069750000000-0x00000697603fffff] reserved
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] efi: EFI v2.70 by American Megatrends
[ 0.000000] efi: ACPI=0xa986d000 ACPI 2.0=0xa986d014 SMBIOS=0xaac20000 SMBIOS 3.0=0xaac1f000 MEMATTR=0xa2ea2018 ESRT=0xa33f9818
[ 0.000000] SMBIOS 3.2.0 present.
[ 0.000000] DMI: To Be Filled By O.E.M. To Be Filled By O.E.M./TRX40 Creator, BIOS P1.70 05/29/2020
[ 0.000000] tsc: Fast TSC calibration failed
[ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000000] last_pfn = 0x204f200 max_arch_pfn = 0x400000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-DFFFF uncachable
[ 0.000000] E0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000000 mask FFFF80000000 write-back
[ 0.000000] 1 base 000080000000 mask FFFFE0000000 write-back
[ 0.000000] 2 base 0000A0000000 mask FFFFF0000000 write-back
[ 0.000000] 3 disabled
[ 0.000000] 4 base 0000A9D40000 mask FFFFFFFF0000 uncachable
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] TOM2: 0000002050000000 aka 132352M
[ 0.000000] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.000000] total RAM covered: 2815M
[ 0.000000] Found optimal setting for mtrr clean up
[ 0.000000] gran_size: 64K chunk_size: 128M num_reg: 4 lose cover RAM: 0G
[ 0.000000] e820: update [mem 0xa9d40000-0xa9d4ffff] usable ==> reserved
[ 0.000000] e820: update [mem 0xb0000000-0xffffffff] usable ==> reserved
[ 0.000000] last_pfn = 0xac000 max_arch_pfn = 0x400000000
[ 0.000000] esrt: Reserving ESRT space from 0x00000000a33f9818 to 0x00000000a33f9850.
[ 0.000000] e820: update [mem 0xa33f9000-0xa33f9fff] usable ==> reserved
[ 0.000000] check: Scanning 1 areas for low memory corruption
[ 0.000000] Using GB pages for direct mapping
[ 0.000000] Secure boot could not be determined
[ 0.000000] RAMDISK: [mem 0x36d73000-0x376b0fff]
[ 0.000000] ACPI: Early table checksum verification disabled
[ 0.000000] ACPI: RSDP 0x00000000A986D014 000024 (v02 AMD )
[ 0.000000] ACPI: XSDT 0x00000000A986C728 0000BC (v01 AMD A M I 03242016 AMI 01000013)
[ 0.000000] ACPI: FACP 0x00000000A93AB000 000114 (v06 AMD A M I 03242016 AMI 00010013)
[ 0.000000] ACPI: DSDT 0x00000000A939C000 00E80F (v02 AMD A M I 03242016 INTL 20120913)
[ 0.000000] ACPI: FACS 0x00000000A9862000 000040
[ 0.000000] ACPI: SSDT 0x00000000A93B0000 008C98 (v02 AMD AmdTable 00000002 MSFT 04000000)
[ 0.000000] ACPI: SSDT 0x00000000A93AC000 0038C7 (v01 AMD AMD AOD 00000001 INTL 20120913)
[ 0.000000] ACPI: FIDT 0x00000000A939B000 00009C (v01 AMD A M I 03242016 AMI 00010013)
[ 0.000000] ACPI: MCFG 0x00000000A939A000 00003C (v01 AMD A M I 03242016 MSFT 00010013)
[ 0.000000] ACPI: SSDT 0x00000000A9399000 00029C (v02 AMD CPUSSDT 03242016 AMI 03242016)
[ 0.000000] ACPI: AAFT 0x00000000A9398000 0004A0 (v01 AMD OEMAAFT 03242016 MSFT 00000097)
[ 0.000000] ACPI: HPET 0x00000000A9397000 000038 (v01 AMD A M I 03242016 AMI 00000005)
[ 0.000000] ACPI: SSDT 0x00000000A9396000 000024 (v01 AMD BIXBY 00001000 INTL 20120913)
[ 0.000000] ACPI: IVRS 0x00000000A9395000 0001F0 (v02 AMD AmdTable 00000001 AMD 00000000)
[ 0.000000] ACPI: PCCT 0x00000000A9394000 00006E (v02 AMD AmdTable 00000001 AMD 00000000)
[ 0.000000] ACPI: SSDT 0x00000000A9388000 00BBC9 (v01 AMD AmdTable 00000001 AMD 00000001)
[ 0.000000] ACPI: CRAT 0x00000000A9385000 002CA8 (v01 AMD AmdTable 00000001 AMD 00000001)
[ 0.000000] ACPI: CDIT 0x00000000A9384000 000029 (v01 AMD AmdTable 00000001 AMD 00000001)
[ 0.000000] ACPI: SSDT 0x00000000A9381000 002B51 (v01 AMD SHAKTOOH 00000001 INTL 20120913)
[ 0.000000] ACPI: WSMT 0x00000000A9380000 000028 (v01 AMD A M I 03242016 AMI 00010013)
[ 0.000000] ACPI: APIC 0x00000000A937F000 000482 (v03 AMD A M I 03242016 AMI 00010013)
[ 0.000000] ACPI: SSDT 0x00000000A937D000 0010AF (v01 AMD SHAKTOOH 00000001 INTL 20120913)
[ 0.000000] ACPI: FPDT 0x00000000A937C000 000044 (v01 AMD A M I 01072009 AMI 01000013)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] No NUMA configuration found
[ 0.000000] Faking a node at [mem 0x0000000000000000-0x000000204f1fffff]
[ 0.000000] NODE_DATA(0) allocated [mem 0x204f1fa000-0x204f1fdfff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.000000] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x000000204f1fffff]
[ 0.000000] Device empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000001000-0x000000000009ffff]
[ 0.000000] node 0: [mem 0x0000000000100000-0x0000000003ffffff]
[ 0.000000] node 0: [mem 0x000000000400d000-0x0000000009df1fff]
[ 0.000000] node 0: [mem 0x000000000a000000-0x00000000a7e30fff]
[ 0.000000] node 0: [mem 0x00000000aadff000-0x00000000abffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000204f1fffff]
[ 0.000000] Zeroed struct page in unavailable ranges: 32842 pages
[ 0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000204f1fffff]
[ 0.000000] On node 0 totalpages: 33521590
[ 0.000000] DMA zone: 64 pages used for memmap
[ 0.000000] DMA zone: 30 pages reserved
[ 0.000000] DMA zone: 3999 pages, LIFO batch:0
[ 0.000000] DMA32 zone: 10745 pages used for memmap
[ 0.000000] DMA32 zone: 687639 pages, LIFO batch:63
[ 0.000000] Normal zone: 512968 pages used for memmap
[ 0.000000] Normal zone: 32829952 pages, LIFO batch:63
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.000000] IOAPIC[0]: apic_id 128, version 33, address 0xfec00000, GSI 0-23
[ 0.000000] IOAPIC[1]: apic_id 129, version 33, address 0xfa200000, GSI 120-151
[ 0.000000] IOAPIC[2]: apic_id 130, version 33, address 0xb3600000, GSI 88-119
[ 0.000000] IOAPIC[3]: apic_id 131, version 33, address 0xb2580000, GSI 56-87
[ 0.000000] IOAPIC[4]: apic_id 132, version 33, address 0xe2280000, GSI 24-55
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x10228201 base: 0xfed00000
[ 0.000000] smpboot: Allowing 128 CPUs, 80 hotplug CPUs
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0x04000000-0x0400cfff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0x09df2000-0x09ffffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xa33f9000-0xa33f9fff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xa7e31000-0xa936bfff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xa936c000-0xa93b8fff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xa93b9000-0xa9884fff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xa9885000-0xaad38fff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xaad39000-0xaad3cfff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xaad3d000-0xaad3dfff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xaad3e000-0xaadfefff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xac000000-0xafffffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xb0000000-0xb24fffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xb2500000-0xb2580fff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xb2581000-0xb357ffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xb3580000-0xb3600fff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xb3601000-0xe20fffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xe2100000-0xe2280fff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xe2281000-0xfa17ffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xfa180000-0xfa200fff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xfa201000-0xfa2fffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xfa300000-0xfa3fffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xfa400000-0xfe9fffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xfea00000-0xfeafffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xfeb00000-0xfebfffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfec0ffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xfec10000-0xfec10fff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xfec11000-0xfecfffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xfed00000-0xfed00fff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xfed01000-0xfed3ffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xfed40000-0xfed44fff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xfed45000-0xfed7ffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xfed80000-0xfed8ffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xfed90000-0xfedc1fff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xfedc2000-0xfedcffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xfedd0000-0xfedd3fff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xfedd4000-0xfedd5fff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xfedd6000-0xfedfffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfeefffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xfef00000-0xfeffffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
[ 0.000000] [mem 0xb3601000-0xe20fffff] available for PCI devices
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.000000] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:128 nr_node_ids:1
[ 0.000000] percpu: Embedded 57 pages/cpu s196608 r8192 d28672 u262144
[ 0.000000] pcpu-alloc: s196608 r8192 d28672 u262144 alloc=1*2097152
[ 0.000000] pcpu-alloc: [0] 000 001 002 003 004 005 006 007
[ 0.000000] pcpu-alloc: [0] 008 009 010 011 012 013 014 015
[ 0.000000] pcpu-alloc: [0] 016 017 018 019 020 021 022 023
[ 0.000000] pcpu-alloc: [0] 024 025 026 027 028 029 030 031
[ 0.000000] pcpu-alloc: [0] 032 033 034 035 036 037 038 039
[ 0.000000] pcpu-alloc: [0] 040 041 042 043 044 045 046 047
[ 0.000000] pcpu-alloc: [0] 048 049 050 051 052 053 054 055
[ 0.000000] pcpu-alloc: [0] 056 057 058 059 060 061 062 063
[ 0.000000] pcpu-alloc: [0] 064 065 066 067 068 069 070 071
[ 0.000000] pcpu-alloc: [0] 072 073 074 075 076 077 078 079
[ 0.000000] pcpu-alloc: [0] 080 081 082 083 084 085 086 087
[ 0.000000] pcpu-alloc: [0] 088 089 090 091 092 093 094 095
[ 0.000000] pcpu-alloc: [0] 096 097 098 099 100 101 102 103
[ 0.000000] pcpu-alloc: [0] 104 105 106 107 108 109 110 111
[ 0.000000] pcpu-alloc: [0] 112 113 114 115 116 117 118 119
[ 0.000000] pcpu-alloc: [0] 120 121 122 123 124 125 126 127
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 32997783
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64 root=UUID=162e4a44-4858-4edf-b959-f4db6c38427a rw quiet udev.log_priority=3
[ 0.000000] printk: log_buf_len individual max cpu contribution: 4096 bytes
[ 0.000000] printk: log_buf_len total cpu_extra contributions: 520192 bytes
[ 0.000000] printk: log_buf_len min size: 131072 bytes
[ 0.000000] printk: log_buf_len: 1048576 bytes
[ 0.000000] printk: early log buf free: 114188(87%)
[ 0.000000] Dentry cache hash table entries: 8388608 (order: 14, 67108864 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.000000] mem auto-init: stack:byref_all, heap alloc:on, heap free:off
[ 0.000000] Memory: 131653872K/134086360K available (12291K kernel code, 1463K rwdata, 4596K rodata, 1632K init, 3108K bss, 2432488K reserved, 0K cma-reserved)
[ 0.000000] random: get_random_u64 called from __kmem_cache_create+0x3e/0x600 with crng_init=0
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=128, Nodes=1
[ 0.000000] ftrace: allocating 39785 entries in 156 pages
[ 0.000000] ftrace: allocated 156 pages with 4 groups
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=128.
[ 0.000000] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=128
[ 0.000000] NR_IRQS: 20736, nr_irqs: 3624, preallocated irqs: 16
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] printk: console [tty0] enabled
[ 0.000000] ACPI: Core revision 20200326
[ 0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
[ 0.000000] APIC: Switch to symmetric I/O mode setup
[ 0.003333] Switched APIC routing to physical flat.
[ 0.006666] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.026666] tsc: PIT calibration matches HPET. 1 loops
[ 0.026666] tsc: Detected 3800.021 MHz processor
[ 0.000007] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x6d8cd9e7171, max_idle_ns: 881591018712 ns
[ 0.000009] Calibrating delay loop (skipped), value calculated using timer frequency.. 7603.71 BogoMIPS (lpj=12666736)
[ 0.000010] pid_max: default: 131072 minimum: 1024
[ 0.002004] efi: memattr: Entry attributes invalid: RO and XP bits both cleared
[ 0.002006] efi: memattr: ! 0x0000aad39000-0x0000aad3cfff [Runtime Code |RUN| | | | | | | | | | | | ]
[ 0.003009] LSM: Security Framework initializing
[ 0.003012] Yama: becoming mindful.
[ 0.003163] Mount-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.003246] Mountpoint-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.003713] x86/cpu: User Mode Instruction Prevention (UMIP) activated
[ 0.003773] LVT offset 1 assigned for vector 0xf9
[ 0.003919] LVT offset 2 assigned for vector 0xf4
[ 0.003958] Last level iTLB entries: 4KB 1024, 2MB 1024, 4MB 512
[ 0.003959] Last level dTLB entries: 4KB 2048, 2MB 2048, 4MB 1024, 1GB 0
[ 0.003962] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.003963] Spectre V2 : Mitigation: Full AMD retpoline
[ 0.003963] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.003964] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.003965] Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
[ 0.003965] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ 0.004222] Freeing SMP alternatives memory: 32K
[ 0.111979] smpboot: CPU0: AMD Ryzen Threadripper 3960X 24-Core Processor (family: 0x17, model: 0x31, stepping: 0x0)
[ 0.112099] Performance Events: Fam17h+ core perfctr, AMD PMU driver.
[ 0.112101] ... version: 0
[ 0.112101] ... bit width: 48
[ 0.112102] ... generic registers: 6
[ 0.112102] ... value mask: 0000ffffffffffff
[ 0.112102] ... max period: 00007fffffffffff
[ 0.112102] ... fixed-purpose events: 0
[ 0.112103] ... event mask: 000000000000003f
[ 0.112214] rcu: Hierarchical SRCU implementation.
[ 0.112599] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.113223] smp: Bringing up secondary CPUs ...
[ 0.113301] x86: Booting SMP configuration:
[ 0.113302] .... node #0, CPUs: #1 #2 #3 #4 #5 #6 #7 #8 #9 #10 #11 #12 #13 #14 #15 #16 #17 #18 #19 #20 #21 #22 #23 #24 #25 #26 #27 #28 #29 #30 #31 #32 #33 #34 #35 #36 #37 #38 #39 #40 #41 #42 #43 #44 #45 #46 #47
[ 0.223985] smp: Brought up 1 node, 48 CPUs
[ 0.223987] smpboot: Max logical packages: 3
[ 0.223989] smpboot: Total of 48 processors activated (364947.08 BogoMIPS)
[ 0.232525] devtmpfs: initialized
[ 0.232525] x86/mm: Memory block size: 128MB
[ 0.246710] PM: Registering ACPI NVS region [mem 0x04000000-0x0400cfff] (53248 bytes)
[ 0.246712] PM: Registering ACPI NVS region [mem 0xa93b9000-0xa9884fff] (5029888 bytes)
[ 0.246989] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.246989] futex hash table entries: 32768 (order: 9, 2097152 bytes, linear)
[ 0.247573] pinctrl core: initialized pinctrl subsystem
[ 0.247668] PM: RTC time: 12:06:48, date: 2020-11-08
[ 0.247673] thermal_sys: Registered thermal governor 'fair_share'
[ 0.247673] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.247674] thermal_sys: Registered thermal governor 'step_wise'
[ 0.247674] thermal_sys: Registered thermal governor 'user_space'
[ 0.247674] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.247710] NET: Registered protocol family 16
[ 0.247710] audit: initializing netlink subsys (disabled)
[ 0.247710] audit: type=2000 audit(1604837207.273:1): state=initialized audit_enabled=0 res=1
[ 0.247710] cpuidle: using governor ladder
[ 0.247710] cpuidle: using governor menu
[ 0.247710] Detected 1 PCC Subspaces
[ 0.247710] Registering PCC driver as Mailbox controller
[ 0.250066] ACPI: bus type PCI registered
[ 0.250068] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.250212] PCI: MMCONFIG for domain 0000 [bus 00-7f] at [mem 0xf0000000-0xf7ffffff] (base 0xf0000000)
[ 0.250219] PCI: not using MMCONFIG
[ 0.250219] PCI: Using configuration type 1 for base access
[ 0.250219] PCI: Using configuration type 1 for extended access
[ 0.261579] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.261579] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.263582] ACPI: Added _OSI(Module Device)
[ 0.263582] ACPI: Added _OSI(Processor Device)
[ 0.263582] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.263582] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.263582] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.263582] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.263582] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.280773] ACPI BIOS Error (bug): Failure creating named object [\_SB.I2CA.WT1A], AE_ALREADY_EXISTS (20200326/dswload2-326)
[ 0.280777] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200326/psobject-220)
[ 0.280778] ACPI: Skipping parse of AML opcode: Device (0x5B82)
[ 0.280779] ACPI BIOS Error (bug): Failure creating named object [\_SB.I2CA.MT1A], AE_ALREADY_EXISTS (20200326/dswload2-326)
[ 0.280781] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200326/psobject-220)
[ 0.280781] ACPI: Skipping parse of AML opcode: Device (0x5B82)
[ 0.280782] ACPI BIOS Error (bug): Failure creating named object [\_SB.I2CA.WT2A], AE_ALREADY_EXISTS (20200326/dswload2-326)
[ 0.280784] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200326/psobject-220)
[ 0.280784] ACPI: Skipping parse of AML opcode: Device (0x5B82)
[ 0.280785] ACPI BIOS Error (bug): Failure creating named object [\_SB.I2CA.MT2A], AE_ALREADY_EXISTS (20200326/dswload2-326)
[ 0.280786] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200326/psobject-220)
[ 0.280787] ACPI: Skipping parse of AML opcode: Device (0x5B82)
[ 0.280788] ACPI BIOS Error (bug): Failure creating named object [\_SB.I2CA.WT3A], AE_ALREADY_EXISTS (20200326/dswload2-326)
[ 0.280789] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200326/psobject-220)
[ 0.280790] ACPI: Skipping parse of AML opcode: Device (0x5B82)
[ 0.280791] ACPI BIOS Error (bug): Failure creating named object [\_SB.I2CA.MT3A], AE_ALREADY_EXISTS (20200326/dswload2-326)
[ 0.280792] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200326/psobject-220)
[ 0.280792] ACPI: Skipping parse of AML opcode: Device (0x5B82)
[ 0.280793] ACPI BIOS Error (bug): Failure creating named object [\_SB.I2CA.WT4A], AE_ALREADY_EXISTS (20200326/dswload2-326)
[ 0.280794] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200326/psobject-220)
[ 0.280795] ACPI: Skipping parse of AML opcode: Device (0x5B82)
[ 0.280796] ACPI BIOS Error (bug): Failure creating named object [\_SB.I2CA.MT4A], AE_ALREADY_EXISTS (20200326/dswload2-326)
[ 0.280797] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200326/psobject-220)
[ 0.280798] ACPI: Skipping parse of AML opcode: Device (0x5B82)
[ 0.280799] ACPI BIOS Error (bug): Failure creating named object [\_SB.I2CA.MT5A], AE_ALREADY_EXISTS (20200326/dswload2-326)
[ 0.280800] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200326/psobject-220)
[ 0.280800] ACPI: Skipping parse of AML opcode: Device (0x5B82)
[ 0.280803] ACPI BIOS Error (bug): Failure creating named object [\_SB.I2CB.WT1B], AE_ALREADY_EXISTS (20200326/dswload2-326)
[ 0.280804] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200326/psobject-220)
[ 0.280805] ACPI: Skipping parse of AML opcode: Device (0x5B82)
[ 0.280805] ACPI BIOS Error (bug): Failure creating named object [\_SB.I2CB.MT1B], AE_ALREADY_EXISTS (20200326/dswload2-326)
[ 0.280807] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200326/psobject-220)
[ 0.280807] ACPI: Skipping parse of AML opcode: Device (0x5B82)
[ 0.280808] ACPI BIOS Error (bug): Failure creating named object [\_SB.I2CB.WT2B], AE_ALREADY_EXISTS (20200326/dswload2-326)
[ 0.280809] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200326/psobject-220)
[ 0.280810] ACPI: Skipping parse of AML opcode: Device (0x5B82)
[ 0.280811] ACPI BIOS Error (bug): Failure creating named object [\_SB.I2CB.MT2B], AE_ALREADY_EXISTS (20200326/dswload2-326)
[ 0.280812] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200326/psobject-220)
[ 0.280812] ACPI: Skipping parse of AML opcode: Device (0x5B82)
[ 0.280813] ACPI BIOS Error (bug): Failure creating named object [\_SB.I2CB.WT3B], AE_ALREADY_EXISTS (20200326/dswload2-326)
[ 0.280814] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200326/psobject-220)
[ 0.280815] ACPI: Skipping parse of AML opcode: Device (0x5B82)
[ 0.280816] ACPI BIOS Error (bug): Failure creating named object [\_SB.I2CB.MT3B], AE_ALREADY_EXISTS (20200326/dswload2-326)
[ 0.280817] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200326/psobject-220)
[ 0.280818] ACPI: Skipping parse of AML opcode: Device (0x5B82)
[ 0.280819] ACPI BIOS Error (bug): Failure creating named object [\_SB.I2CB.WT4B], AE_ALREADY_EXISTS (20200326/dswload2-326)
[ 0.280820] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200326/psobject-220)
[ 0.280820] ACPI: Skipping parse of AML opcode: Device (0x5B82)
[ 0.280821] ACPI BIOS Error (bug): Failure creating named object [\_SB.I2CB.MT4B], AE_ALREADY_EXISTS (20200326/dswload2-326)
[ 0.280822] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200326/psobject-220)
[ 0.280823] ACPI: Skipping parse of AML opcode: Device (0x5B82)
[ 0.280824] ACPI BIOS Error (bug): Failure creating named object [\_SB.I2CB.MT5B], AE_ALREADY_EXISTS (20200326/dswload2-326)
[ 0.280825] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200326/psobject-220)
[ 0.280826] ACPI: Skipping parse of AML opcode: Device (0x5B82)
[ 0.280828] ACPI BIOS Error (bug): Failure creating named object [\_SB.I2CC.WT1C], AE_ALREADY_EXISTS (20200326/dswload2-326)
[ 0.280829] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200326/psobject-220)
[ 0.280830] ACPI: Skipping parse of AML opcode: Device (0x5B82)
[ 0.280831] ACPI BIOS Error (bug): Failure creating named object [\_SB.I2CC.MT1C], AE_ALREADY_EXISTS (20200326/dswload2-326)
[ 0.280832] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200326/psobject-220)
[ 0.280832] ACPI: Skipping parse of AML opcode: Device (0x5B82)
[ 0.280833] ACPI BIOS Error (bug): Failure creating named object [\_SB.I2CC.WT2C], AE_ALREADY_EXISTS (20200326/dswload2-326)
[ 0.280834] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200326/psobject-220)
[ 0.280835] ACPI: Skipping parse of AML opcode: Device (0x5B82)
[ 0.280836] ACPI BIOS Error (bug): Failure creating named object [\_SB.I2CC.MT2C], AE_ALREADY_EXISTS (20200326/dswload2-326)
[ 0.280837] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200326/psobject-220)
[ 0.280838] ACPI: Skipping parse of AML opcode: Device (0x5B82)
[ 0.280839] ACPI BIOS Error (bug): Failure creating named object [\_SB.I2CC.WT3C], AE_ALREADY_EXISTS (20200326/dswload2-326)
[ 0.280840] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200326/psobject-220)
[ 0.280840] ACPI: Skipping parse of AML opcode: Device (0x5B82)
[ 0.280841] ACPI BIOS Error (bug): Failure creating named object [\_SB.I2CC.MT3C], AE_ALREADY_EXISTS (20200326/dswload2-326)
[ 0.280842] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200326/psobject-220)
[ 0.280843] ACPI: Skipping parse of AML opcode: Device (0x5B82)
[ 0.280844] ACPI BIOS Error (bug): Failure creating named object [\_SB.I2CC.WT4C], AE_ALREADY_EXISTS (20200326/dswload2-326)
[ 0.280845] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200326/psobject-220)
[ 0.280846] ACPI: Skipping parse of AML opcode: Device (0x5B82)
[ 0.280846] ACPI BIOS Error (bug): Failure creating named object [\_SB.I2CC.MT4C], AE_ALREADY_EXISTS (20200326/dswload2-326)
[ 0.280848] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200326/psobject-220)
[ 0.280848] ACPI: Skipping parse of AML opcode: Device (0x5B82)
[ 0.280849] ACPI BIOS Error (bug): Failure creating named object [\_SB.I2CC.MT5C], AE_ALREADY_EXISTS (20200326/dswload2-326)
[ 0.280850] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200326/psobject-220)
[ 0.280851] ACPI: Skipping parse of AML opcode: Device (0x5B82)
[ 0.280853] ACPI BIOS Error (bug): Failure creating named object [\_SB.I2CD.WT1D], AE_ALREADY_EXISTS (20200326/dswload2-326)
[ 0.280854] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200326/psobject-220)
[ 0.280855] ACPI: Skipping parse of AML opcode: Device (0x5B82)
[ 0.280856] ACPI BIOS Error (bug): Failure creating named object [\_SB.I2CD.MT1D], AE_ALREADY_EXISTS (20200326/dswload2-326)
[ 0.280857] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200326/psobject-220)
[ 0.280858] ACPI: Skipping parse of AML opcode: Device (0x5B82)
[ 0.280858] ACPI BIOS Error (bug): Failure creating named object [\_SB.I2CD.WT2D], AE_ALREADY_EXISTS (20200326/dswload2-326)
[ 0.280860] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200326/psobject-220)
[ 0.280860] ACPI: Skipping parse of AML opcode: Device (0x5B82)
[ 0.280861] ACPI BIOS Error (bug): Failure creating named object [\_SB.I2CD.MT2D], AE_ALREADY_EXISTS (20200326/dswload2-326)
[ 0.280862] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200326/psobject-220)
[ 0.280863] ACPI: Skipping parse of AML opcode: Device (0x5B82)
[ 0.280864] ACPI BIOS Error (bug): Failure creating named object [\_SB.I2CD.WT3D], AE_ALREADY_EXISTS (20200326/dswload2-326)
[ 0.280865] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200326/psobject-220)
[ 0.280866] ACPI: Skipping parse of AML opcode: Device (0x5B82)
[ 0.280866] ACPI BIOS Error (bug): Failure creating named object [\_SB.I2CD.MT3D], AE_ALREADY_EXISTS (20200326/dswload2-326)
[ 0.280867] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200326/psobject-220)
[ 0.280868] ACPI: Skipping parse of AML opcode: Device (0x5B82)
[ 0.280869] ACPI BIOS Error (bug): Failure creating named object [\_SB.I2CD.WT4D], AE_ALREADY_EXISTS (20200326/dswload2-326)
[ 0.280870] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200326/psobject-220)
[ 0.280871] ACPI: Skipping parse of AML opcode: Device (0x5B82)
[ 0.280872] ACPI BIOS Error (bug): Failure creating named object [\_SB.I2CD.MT4D], AE_ALREADY_EXISTS (20200326/dswload2-326)
[ 0.280873] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200326/psobject-220)
[ 0.280873] ACPI: Skipping parse of AML opcode: Device (0x5B82)
[ 0.280874] ACPI BIOS Error (bug): Failure creating named object [\_SB.I2CD.MT5D], AE_ALREADY_EXISTS (20200326/dswload2-326)
[ 0.280875] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200326/psobject-220)
[ 0.280876] ACPI: Skipping parse of AML opcode: Device (0x5B82)
[ 0.280947] ACPI: 8 ACPI AML tables successfully acquired and loaded
[ 0.286226] ACPI: Interpreter enabled
[ 0.286237] ACPI: (supports S0 S3 S4 S5)
[ 0.286238] ACPI: Using IOAPIC for interrupt routing
[ 0.286504] PCI: MMCONFIG for domain 0000 [bus 00-7f] at [mem 0xf0000000-0xf7ffffff] (base 0xf0000000)
[ 0.286540] PCI: MMCONFIG at [mem 0xf0000000-0xf7ffffff] reserved in ACPI motherboard resources
[ 0.286549] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.287024] ACPI: Enabled 3 GPEs in block 00 to 1F
[ 0.303712] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-1f])
[ 0.303716] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.303892] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
[ 0.304141] PCI host bridge to bus 0000:00
[ 0.304142] pci_bus 0000:00: root bus resource [io 0x0000-0x03af window]
[ 0.304142] pci_bus 0000:00: root bus resource [io 0x03e0-0x0cf7 window]
[ 0.304143] pci_bus 0000:00: root bus resource [io 0x03b0-0x03df window]
[ 0.304144] pci_bus 0000:00: root bus resource [io 0x0d00-0x3fff window]
[ 0.304144] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.304145] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000dffff window]
[ 0.304145] pci_bus 0000:00: root bus resource [mem 0xc0000000-0xe1fffffe window]
[ 0.304146] pci_bus 0000:00: root bus resource [bus 00-1f]
[ 0.304152] pci 0000:00:00.0: [1022:1480] type 00 class 0x060000
[ 0.304241] pci 0000:00:00.2: [1022:1481] type 00 class 0x080600
[ 0.304344] pci 0000:00:01.0: [1022:1482] type 00 class 0x060000
[ 0.304416] pci 0000:00:01.1: [1022:1483] type 01 class 0x060400
[ 0.304510] pci 0000:00:01.1: PME# supported from D0 D3hot D3cold
[ 0.304627] pci 0000:00:02.0: [1022:1482] type 00 class 0x060000
[ 0.304702] pci 0000:00:03.0: [1022:1482] type 00 class 0x060000
[ 0.304777] pci 0000:00:04.0: [1022:1482] type 00 class 0x060000
[ 0.304853] pci 0000:00:05.0: [1022:1482] type 00 class 0x060000
[ 0.304929] pci 0000:00:07.0: [1022:1482] type 00 class 0x060000
[ 0.304999] pci 0000:00:07.1: [1022:1484] type 01 class 0x060400
[ 0.305030] pci 0000:00:07.1: enabling Extended Tags
[ 0.305069] pci 0000:00:07.1: PME# supported from D0 D3hot D3cold
[ 0.305163] pci 0000:00:08.0: [1022:1482] type 00 class 0x060000
[ 0.305233] pci 0000:00:08.1: [1022:1484] type 01 class 0x060400
[ 0.305265] pci 0000:00:08.1: enabling Extended Tags
[ 0.305305] pci 0000:00:08.1: PME# supported from D0 D3hot D3cold
[ 0.305417] pci 0000:00:14.0: [1022:790b] type 00 class 0x0c0500
[ 0.305535] pci 0000:00:14.3: [1022:790e] type 00 class 0x060100
[ 0.305662] pci 0000:00:18.0: [1022:1490] type 00 class 0x060000
[ 0.305713] pci 0000:00:18.1: [1022:1491] type 00 class 0x060000
[ 0.305762] pci 0000:00:18.2: [1022:1492] type 00 class 0x060000
[ 0.305810] pci 0000:00:18.3: [1022:1493] type 00 class 0x060000
[ 0.305858] pci 0000:00:18.4: [1022:1494] type 00 class 0x060000
[ 0.305907] pci 0000:00:18.5: [1022:1495] type 00 class 0x060000
[ 0.305955] pci 0000:00:18.6: [1022:1496] type 00 class 0x060000
[ 0.306004] pci 0000:00:18.7: [1022:1497] type 00 class 0x060000
[ 0.306103] pci 0000:01:00.0: [10de:21c4] type 00 class 0x030000
[ 0.306131] pci 0000:01:00.0: reg 0x10: [mem 0xe0000000-0xe0ffffff]
[ 0.306144] pci 0000:01:00.0: reg 0x14: [mem 0xc0000000-0xcfffffff 64bit pref]
[ 0.306157] pci 0000:01:00.0: reg 0x1c: [mem 0xd0000000-0xd1ffffff 64bit pref]
[ 0.306165] pci 0000:01:00.0: reg 0x24: [io 0x3000-0x307f]
[ 0.306173] pci 0000:01:00.0: reg 0x30: [mem 0xe1000000-0xe107ffff pref]
[ 0.306189] pci 0000:01:00.0: BAR 1: assigned to efifb
[ 0.306244] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[ 0.306329] pci 0000:01:00.0: 32.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x16 link at 0000:00:01.1 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
[ 0.306359] pci 0000:01:00.1: [10de:1aeb] type 00 class 0x040300
[ 0.306375] pci 0000:01:00.1: reg 0x10: [mem 0xe1080000-0xe1083fff]
[ 0.306505] pci 0000:01:00.2: [10de:1aec] type 00 class 0x0c0330
[ 0.306528] pci 0000:01:00.2: reg 0x10: [mem 0xd2000000-0xd203ffff 64bit pref]
[ 0.306548] pci 0000:01:00.2: reg 0x1c: [mem 0xd2040000-0xd204ffff 64bit pref]
[ 0.306614] pci 0000:01:00.2: PME# supported from D0 D3hot D3cold
[ 0.306664] pci 0000:01:00.3: [10de:1aed] type 00 class 0x0c8000
[ 0.306683] pci 0000:01:00.3: reg 0x10: [mem 0xe1084000-0xe1084fff]
[ 0.306767] pci 0000:01:00.3: PME# supported from D0 D3hot D3cold
[ 0.306868] pci 0000:00:01.1: PCI bridge to [bus 01]
[ 0.306871] pci 0000:00:01.1: bridge window [io 0x3000-0x3fff]
[ 0.306873] pci 0000:00:01.1: bridge window [mem 0xe0000000-0xe10fffff]
[ 0.306877] pci 0000:00:01.1: bridge window [mem 0xc0000000-0xd20fffff 64bit pref]
[ 0.306921] pci 0000:02:00.0: [1022:148a] type 00 class 0x130000
[ 0.306957] pci 0000:02:00.0: enabling Extended Tags
[ 0.307074] pci 0000:00:07.1: PCI bridge to [bus 02]
[ 0.307130] pci 0000:03:00.0: [1022:1485] type 00 class 0x130000
[ 0.307171] pci 0000:03:00.0: enabling Extended Tags
[ 0.307282] pci 0000:03:00.3: [1022:148c] type 00 class 0x0c0330
[ 0.307301] pci 0000:03:00.3: reg 0x10: [mem 0xe1200000-0xe12fffff 64bit]
[ 0.307330] pci 0000:03:00.3: enabling Extended Tags
[ 0.307374] pci 0000:03:00.3: PME# supported from D0 D3hot D3cold
[ 0.307460] pci 0000:00:08.1: PCI bridge to [bus 03]
[ 0.307464] pci 0000:00:08.1: bridge window [mem 0xe1200000-0xe12fffff]
[ 0.307481] pci_bus 0000:00: on NUMA node 0
[ 0.307904] ACPI: PCI Root Bridge [S0D1] (domain 0000 [bus 20-3f])
[ 0.307906] acpi PNP0A08:01: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.308079] acpi PNP0A08:01: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
[ 0.308269] PCI host bridge to bus 0000:20
[ 0.308270] pci_bus 0000:20: root bus resource [io 0x4000-0x6fff window]
[ 0.308271] pci_bus 0000:20: root bus resource [mem 0xb0000000-0xb23ffffe window]
[ 0.308272] pci_bus 0000:20: root bus resource [bus 20-3f]
[ 0.308277] pci 0000:20:00.0: [1022:1480] type 00 class 0x060000
[ 0.308348] pci 0000:20:00.2: [1022:1481] type 00 class 0x080600
[ 0.308441] pci 0000:20:01.0: [1022:1482] type 00 class 0x060000
[ 0.308505] pci 0000:20:02.0: [1022:1482] type 00 class 0x060000
[ 0.308567] pci 0000:20:03.0: [1022:1482] type 00 class 0x060000
[ 0.308630] pci 0000:20:04.0: [1022:1482] type 00 class 0x060000
[ 0.308693] pci 0000:20:05.0: [1022:1482] type 00 class 0x060000
[ 0.308761] pci 0000:20:07.0: [1022:1482] type 00 class 0x060000
[ 0.308824] pci 0000:20:07.1: [1022:1484] type 01 class 0x060400
[ 0.308855] pci 0000:20:07.1: enabling Extended Tags
[ 0.308894] pci 0000:20:07.1: PME# supported from D0 D3hot D3cold
[ 0.308981] pci 0000:20:08.0: [1022:1482] type 00 class 0x060000
[ 0.309047] pci 0000:20:08.1: [1022:1484] type 01 class 0x060400
[ 0.309078] pci 0000:20:08.1: enabling Extended Tags
[ 0.309119] pci 0000:20:08.1: PME# supported from D0 D3hot D3cold
[ 0.309252] pci 0000:21:00.0: [1022:148a] type 00 class 0x130000
[ 0.309287] pci 0000:21:00.0: enabling Extended Tags
[ 0.309404] pci 0000:20:07.1: PCI bridge to [bus 21]
[ 0.309461] pci 0000:22:00.0: [1022:1485] type 00 class 0x130000
[ 0.309500] pci 0000:22:00.0: enabling Extended Tags
[ 0.309609] pci 0000:22:00.1: [1022:1486] type 00 class 0x108000
[ 0.309630] pci 0000:22:00.1: reg 0x18: [mem 0xb2100000-0xb21fffff]
[ 0.309641] pci 0000:22:00.1: reg 0x24: [mem 0xb2208000-0xb2209fff]
[ 0.309649] pci 0000:22:00.1: enabling Extended Tags
[ 0.309747] pci 0000:22:00.3: [1022:148c] type 00 class 0x0c0330
[ 0.309765] pci 0000:22:00.3: reg 0x10: [mem 0xb2000000-0xb20fffff 64bit]
[ 0.309794] pci 0000:22:00.3: enabling Extended Tags
[ 0.309838] pci 0000:22:00.3: PME# supported from D0 D3hot D3cold
[ 0.309900] pci 0000:22:00.4: [1022:1487] type 00 class 0x040300
[ 0.309914] pci 0000:22:00.4: reg 0x10: [mem 0xb2200000-0xb2207fff]
[ 0.309939] pci 0000:22:00.4: enabling Extended Tags
[ 0.309979] pci 0000:22:00.4: PME# supported from D0 D3hot D3cold
[ 0.310069] pci 0000:20:08.1: PCI bridge to [bus 22]
[ 0.310073] pci 0000:20:08.1: bridge window [mem 0xb2000000-0xb22fffff]
[ 0.310085] pci_bus 0000:20: on NUMA node 1
[ 0.310452] ACPI: PCI Root Bridge [S0D2] (domain 0000 [bus 40-5f])
[ 0.310454] acpi PNP0A08:02: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.310629] acpi PNP0A08:02: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
[ 0.310816] PCI host bridge to bus 0000:40
[ 0.310817] pci_bus 0000:40: root bus resource [io 0x7000-0xcfff window]
[ 0.310818] pci_bus 0000:40: root bus resource [mem 0xb5000000-0xb7fffffe window]
[ 0.310819] pci_bus 0000:40: root bus resource [bus 40-5f]
[ 0.310823] pci 0000:40:00.0: [1022:1480] type 00 class 0x060000
[ 0.310894] pci 0000:40:00.2: [1022:1481] type 00 class 0x080600
[ 0.310987] pci 0000:40:01.0: [1022:1482] type 00 class 0x060000
[ 0.311051] pci 0000:40:01.1: [1022:1483] type 01 class 0x060400
[ 0.311084] pci 0000:40:01.1: enabling Extended Tags
[ 0.311132] pci 0000:40:01.1: PME# supported from D0 D3hot D3cold
[ 0.311227] pci 0000:40:01.2: [1022:1483] type 01 class 0x060400
[ 0.311260] pci 0000:40:01.2: enabling Extended Tags
[ 0.311307] pci 0000:40:01.2: PME# supported from D0 D3hot D3cold
[ 0.311400] pci 0000:40:02.0: [1022:1482] type 00 class 0x060000
[ 0.311462] pci 0000:40:03.0: [1022:1482] type 00 class 0x060000
[ 0.311525] pci 0000:40:04.0: [1022:1482] type 00 class 0x060000
[ 0.311588] pci 0000:40:05.0: [1022:1482] type 00 class 0x060000
[ 0.311650] pci 0000:40:07.0: [1022:1482] type 00 class 0x060000
[ 0.311715] pci 0000:40:07.1: [1022:1484] type 01 class 0x060400
[ 0.311745] pci 0000:40:07.1: enabling Extended Tags
[ 0.311783] pci 0000:40:07.1: PME# supported from D0 D3hot D3cold
[ 0.311865] pci 0000:40:08.0: [1022:1482] type 00 class 0x060000
[ 0.311930] pci 0000:40:08.1: [1022:1484] type 01 class 0x060400
[ 0.311961] pci 0000:40:08.1: enabling Extended Tags
[ 0.312000] pci 0000:40:08.1: PME# supported from D0 D3hot D3cold
[ 0.312127] pci 0000:41:00.0: [1022:57ad] type 01 class 0x060400
[ 0.312198] pci 0000:41:00.0: enabling Extended Tags
[ 0.312282] pci 0000:41:00.0: PME# supported from D0 D3hot D3cold
[ 0.312449] pci 0000:40:01.1: PCI bridge to [bus 41-49]
[ 0.312452] pci 0000:40:01.1: bridge window [io 0xc000-0xcfff]
[ 0.312454] pci 0000:40:01.1: bridge window [mem 0xb7000000-0xb7cfffff]
[ 0.312678] pci 0000:42:02.0: [1022:57a3] type 01 class 0x060400
[ 0.312785] pci 0000:42:02.0: enabling Extended Tags
[ 0.313030] pci 0000:42:02.0: PME# supported from D0 D3hot D3cold
[ 0.313342] pci 0000:42:03.0: [1022:57a3] type 01 class 0x060400
[ 0.313450] pci 0000:42:03.0: enabling Extended Tags
[ 0.313686] pci 0000:42:03.0: PME# supported from D0 D3hot D3cold
[ 0.314024] pci 0000:42:04.0: [1022:57a3] type 01 class 0x060400
[ 0.314131] pci 0000:42:04.0: enabling Extended Tags
[ 0.314355] pci 0000:42:04.0: PME# supported from D0 D3hot D3cold
[ 0.314669] pci 0000:42:05.0: [1022:57a3] type 01 class 0x060400
[ 0.314776] pci 0000:42:05.0: enabling Extended Tags
[ 0.315012] pci 0000:42:05.0: PME# supported from D0 D3hot D3cold
[ 0.315351] pci 0000:42:08.0: [1022:57a4] type 01 class 0x060400
[ 0.315445] pci 0000:42:08.0: enabling Extended Tags
[ 0.315601] pci 0000:42:08.0: PME# supported from D0 D3hot D3cold
[ 0.315778] pci 0000:42:09.0: [1022:57a4] type 01 class 0x060400
[ 0.315872] pci 0000:42:09.0: enabling Extended Tags
[ 0.316028] pci 0000:42:09.0: PME# supported from D0 D3hot D3cold
[ 0.316199] pci 0000:42:0a.0: [1022:57a4] type 01 class 0x060400
[ 0.316293] pci 0000:42:0a.0: enabling Extended Tags
[ 0.316449] pci 0000:42:0a.0: PME# supported from D0 D3hot D3cold
[ 0.316645] pci 0000:41:00.0: PCI bridge to [bus 42-49]
[ 0.316651] pci 0000:41:00.0: bridge window [io 0xc000-0xcfff]
[ 0.316655] pci 0000:41:00.0: bridge window [mem 0xb7000000-0xb7cfffff]
[ 0.316754] pci 0000:43:00.0: [1b21:3242] type 00 class 0x0c0330
[ 0.316798] pci 0000:43:00.0: reg 0x10: [mem 0xb7c00000-0xb7c07fff 64bit]
[ 0.316871] pci 0000:43:00.0: enabling Extended Tags
[ 0.316976] pci 0000:43:00.0: PME# supported from D0 D3hot D3cold
[ 0.317196] pci 0000:42:02.0: PCI bridge to [bus 43]
[ 0.317205] pci 0000:42:02.0: bridge window [mem 0xb7c00000-0xb7cfffff]
[ 0.317303] pci 0000:44:00.0: [1d6a:07b1] type 00 class 0x020000
[ 0.317342] pci 0000:44:00.0: reg 0x10: [mem 0xb7440000-0xb744ffff 64bit]
[ 0.317357] pci 0000:44:00.0: reg 0x18: [mem 0xb7450000-0xb7450fff 64bit]
[ 0.317372] pci 0000:44:00.0: reg 0x20: [mem 0xb7000000-0xb73fffff 64bit]
[ 0.317381] pci 0000:44:00.0: reg 0x30: [mem 0xb7400000-0xb743ffff pref]
[ 0.317391] pci 0000:44:00.0: enabling Extended Tags
[ 0.317482] pci 0000:44:00.0: supports D1 D2
[ 0.317482] pci 0000:44:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.317556] pci 0000:44:00.0: 15.752 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x2 link at 0000:42:03.0 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link)
[ 0.317650] pci 0000:42:03.0: PCI bridge to [bus 44]
[ 0.317659] pci 0000:42:03.0: bridge window [mem 0xb7000000-0xb74fffff]
[ 0.317765] pci 0000:45:00.0: [8086:2723] type 00 class 0x028000
[ 0.317809] pci 0000:45:00.0: reg 0x10: [mem 0xb7b00000-0xb7b03fff 64bit]
[ 0.317978] pci 0000:45:00.0: PME# supported from D0 D3hot D3cold
[ 0.318182] pci 0000:42:04.0: PCI bridge to [bus 45]
[ 0.318191] pci 0000:42:04.0: bridge window [mem 0xb7b00000-0xb7bfffff]
[ 0.318294] pci 0000:46:00.0: [10ec:8125] type 00 class 0x020000
[ 0.318341] pci 0000:46:00.0: reg 0x10: [io 0xc000-0xc0ff]
[ 0.318368] pci 0000:46:00.0: reg 0x18: [mem 0xb7a00000-0xb7a0ffff 64bit]
[ 0.318385] pci 0000:46:00.0: reg 0x20: [mem 0xb7a10000-0xb7a13fff 64bit]
[ 0.318406] pci 0000:46:00.0: enabling Extended Tags
[ 0.318544] pci 0000:46:00.0: supports D1 D2
[ 0.318545] pci 0000:46:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.318628] pci 0000:46:00.0: reg 0x1b4: [mem 0x00000000-0x0000ffff 64bit]
[ 0.318628] pci 0000:46:00.0: VF(n) BAR2 space: [mem 0x00000000-0x0006ffff 64bit] (contains BAR2 for 7 VFs)
[ 0.318645] pci 0000:46:00.0: reg 0x1bc: [mem 0x00000000-0x00003fff 64bit]
[ 0.318646] pci 0000:46:00.0: VF(n) BAR4 space: [mem 0x00000000-0x0001bfff 64bit] (contains BAR4 for 7 VFs)
[ 0.318931] pci 0000:42:05.0: PCI bridge to [bus 46]
[ 0.318937] pci 0000:42:05.0: bridge window [io 0xc000-0xcfff]
[ 0.318940] pci 0000:42:05.0: bridge window [mem 0xb7a00000-0xb7afffff]
[ 0.319054] pci 0000:47:00.0: [1022:1485] type 00 class 0x130000
[ 0.319136] pci 0000:47:00.0: enabling Extended Tags
[ 0.319295] pci 0000:47:00.0: 126.024 Gb/s available PCIe bandwidth, limited by 16.0 GT/s PCIe x8 link at 0000:40:01.1 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
[ 0.319427] pci 0000:47:00.1: [1022:149c] type 00 class 0x0c0330
[ 0.319792] pci 0000:47:00.1: reg 0x10: [mem 0xb7700000-0xb77fffff 64bit]
[ 0.320529] pci 0000:47:00.1: enabling Extended Tags
[ 0.321068] pci 0000:47:00.1: PME# supported from D0 D3hot D3cold
[ 0.321368] pci 0000:47:00.3: [1022:149c] type 00 class 0x0c0330
[ 0.321402] pci 0000:47:00.3: reg 0x10: [mem 0xb7600000-0xb76fffff 64bit]
[ 0.321462] pci 0000:47:00.3: enabling Extended Tags
[ 0.321539] pci 0000:47:00.3: PME# supported from D0 D3hot D3cold
[ 0.321689] pci 0000:42:08.0: PCI bridge to [bus 47]
[ 0.321698] pci 0000:42:08.0: bridge window [mem 0xb7600000-0xb77fffff]
[ 0.321792] pci 0000:48:00.0: [1022:7901] type 00 class 0x010601
[ 0.321878] pci 0000:48:00.0: reg 0x24: [mem 0xb7900000-0xb79007ff]
[ 0.321898] pci 0000:48:00.0: enabling Extended Tags
[ 0.321992] pci 0000:48:00.0: PME# supported from D3hot D3cold
[ 0.322075] pci 0000:48:00.0: 126.024 Gb/s available PCIe bandwidth, limited by 16.0 GT/s PCIe x8 link at 0000:40:01.1 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
[ 0.322147] pci 0000:42:09.0: PCI bridge to [bus 48]
[ 0.322156] pci 0000:42:09.0: bridge window [mem 0xb7900000-0xb79fffff]
[ 0.322248] pci 0000:49:00.0: [1022:7901] type 00 class 0x010601
[ 0.322334] pci 0000:49:00.0: reg 0x24: [mem 0xb7800000-0xb78007ff]
[ 0.322353] pci 0000:49:00.0: enabling Extended Tags
[ 0.322448] pci 0000:49:00.0: PME# supported from D3hot D3cold
[ 0.322530] pci 0000:49:00.0: 126.024 Gb/s available PCIe bandwidth, limited by 16.0 GT/s PCIe x8 link at 0000:40:01.1 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
[ 0.322602] pci 0000:42:0a.0: PCI bridge to [bus 49]
[ 0.322611] pci 0000:42:0a.0: bridge window [mem 0xb7800000-0xb78fffff]
[ 0.322703] pci 0000:4a:00.0: [144d:a808] type 00 class 0x010802
[ 0.322730] pci 0000:4a:00.0: reg 0x10: [mem 0xb7e00000-0xb7e03fff 64bit]
[ 0.322937] pci 0000:40:01.2: PCI bridge to [bus 4a]
[ 0.322941] pci 0000:40:01.2: bridge window [mem 0xb7e00000-0xb7efffff]
[ 0.322983] pci 0000:4b:00.0: [1022:148a] type 00 class 0x130000
[ 0.323018] pci 0000:4b:00.0: enabling Extended Tags
[ 0.323133] pci 0000:40:07.1: PCI bridge to [bus 4b]
[ 0.323188] pci 0000:4c:00.0: [1022:1485] type 00 class 0x130000
[ 0.323227] pci 0000:4c:00.0: enabling Extended Tags
[ 0.323380] pci 0000:40:08.1: PCI bridge to [bus 4c]
[ 0.323403] pci_bus 0000:40: on NUMA node 2
[ 0.323782] ACPI: PCI Root Bridge [S0D3] (domain 0000 [bus 60-ff])
[ 0.323784] acpi PNP0A08:03: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.323956] acpi PNP0A08:03: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
[ 0.323964] acpi PNP0A08:03: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-7f] only partially covers this bridge
[ 0.324141] PCI host bridge to bus 0000:60
[ 0.324142] pci_bus 0000:60: root bus resource [io 0xd000-0xffff window]
[ 0.324142] pci_bus 0000:60: root bus resource [mem 0xf8000000-0xf9ffffff window]
[ 0.324143] pci_bus 0000:60: root bus resource [bus 60-ff]
[ 0.324147] pci 0000:60:00.0: [1022:1480] type 00 class 0x060000
[ 0.324224] pci 0000:60:00.2: [1022:1481] type 00 class 0x080600
[ 0.324315] pci 0000:60:01.0: [1022:1482] type 00 class 0x060000
[ 0.324376] pci 0000:60:02.0: [1022:1482] type 00 class 0x060000
[ 0.324439] pci 0000:60:03.0: [1022:1482] type 00 class 0x060000
[ 0.324501] pci 0000:60:04.0: [1022:1482] type 00 class 0x060000
[ 0.324562] pci 0000:60:05.0: [1022:1482] type 00 class 0x060000
[ 0.324625] pci 0000:60:07.0: [1022:1482] type 00 class 0x060000
[ 0.324687] pci 0000:60:07.1: [1022:1484] type 01 class 0x060400
[ 0.324717] pci 0000:60:07.1: enabling Extended Tags
[ 0.324755] pci 0000:60:07.1: PME# supported from D0 D3hot D3cold
[ 0.324841] pci 0000:60:08.0: [1022:1482] type 00 class 0x060000
[ 0.324904] pci 0000:60:08.1: [1022:1484] type 01 class 0x060400
[ 0.324935] pci 0000:60:08.1: enabling Extended Tags
[ 0.324975] pci 0000:60:08.1: PME# supported from D0 D3hot D3cold
[ 0.325106] pci 0000:61:00.0: [1022:148a] type 00 class 0x130000
[ 0.325141] pci 0000:61:00.0: enabling Extended Tags
[ 0.325259] pci 0000:60:07.1: PCI bridge to [bus 61]
[ 0.325313] pci 0000:62:00.0: [1022:1485] type 00 class 0x130000
[ 0.325352] pci 0000:62:00.0: enabling Extended Tags
[ 0.325477] pci 0000:60:08.1: PCI bridge to [bus 62]
[ 0.325492] pci_bus 0000:60: on NUMA node 3
[ 0.325788] ACPI: PCI Interrupt Link [LNKA] (IRQs 4 5 7 10 11 14 15) *0
[ 0.325831] ACPI: PCI Interrupt Link [LNKB] (IRQs 4 5 7 10 11 14 15) *0
[ 0.325868] ACPI: PCI Interrupt Link [LNKC] (IRQs 4 5 7 10 11 14 15) *0
[ 0.325914] ACPI: PCI Interrupt Link [LNKD] (IRQs 4 5 7 10 11 14 15) *0
[ 0.325955] ACPI: PCI Interrupt Link [LNKE] (IRQs 4 5 7 10 11 14 15) *0
[ 0.325989] ACPI: PCI Interrupt Link [LNKF] (IRQs 4 5 7 10 11 14 15) *0
[ 0.326023] ACPI: PCI Interrupt Link [LNKG] (IRQs 4 5 7 10 11 14 15) *0
[ 0.326057] ACPI: PCI Interrupt Link [LNKH] (IRQs 4 5 7 10 11 14 15) *0
[ 0.326678] iommu: Default domain type: Translated
[ 0.326694] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[ 0.326722] pci 0000:01:00.0: vgaarb: bridge control possible
[ 0.326723] pci 0000:01:00.0: vgaarb: setting as boot device
[ 0.326723] vgaarb: loaded
[ 0.326902] SCSI subsystem initialized
[ 0.326972] libata version 3.00 loaded.
[ 0.326972] ACPI: bus type USB registered
[ 0.326972] usbcore: registered new interface driver usbfs
[ 0.326972] usbcore: registered new interface driver hub
[ 0.326972] usbcore: registered new device driver usb
[ 0.332217] pps_core: LinuxPPS API ver. 1 registered
[ 0.332217] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.332217] PTP clock support registered
[ 0.332217] EDAC MC: Ver: 3.0.0
[ 0.333367] Registered efivars operations
[ 0.333408] PCI: Using ACPI for IRQ routing
[ 0.334250] PCI: pci_cache_line_size set to 64 bytes
[ 0.334441] e820: reserve RAM buffer [mem 0x09df2000-0x0bffffff]
[ 0.334441] e820: reserve RAM buffer [mem 0xa33f9000-0xa3ffffff]
[ 0.334442] e820: reserve RAM buffer [mem 0xa7e31000-0xa7ffffff]
[ 0.334442] e820: reserve RAM buffer [mem 0x204f200000-0x204fffffff]
[ 0.334547] NetLabel: Initializing
[ 0.334547] NetLabel: domain hash size = 128
[ 0.334547] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.334556] NetLabel: unlabeled traffic allowed by default
[ 0.336701] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.336703] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[ 0.338772] clocksource: Switched to clocksource tsc-early
[ 0.344703] VFS: Disk quotas dquot_6.6.0
[ 0.344748] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.344838] pnp: PnP ACPI init
[ 0.344930] system 00:00: [mem 0xf0000000-0xf7ffffff] has been reserved
[ 0.344933] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.345281] system 00:01: [mem 0xfa180000-0xfa1fffff] could not be reserved
[ 0.345283] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.345354] system 00:02: [mem 0xe2100000-0xe21fffff] has been reserved
[ 0.345356] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.345583] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.345719] system 00:04: [io 0x0a00-0x0a0f] has been reserved
[ 0.345720] system 00:04: [io 0x0a10-0x0a1f] has been reserved
[ 0.345720] system 00:04: [io 0x0a20-0x0a2f] has been reserved
[ 0.345722] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.345922] system 00:05: [io 0x04d0-0x04d1] has been reserved
[ 0.345923] system 00:05: [io 0x040b] has been reserved
[ 0.345923] system 00:05: [io 0x04d6] has been reserved
[ 0.345924] system 00:05: [io 0x0c00-0x0c01] has been reserved
[ 0.345925] system 00:05: [io 0x0c14] has been reserved
[ 0.345925] system 00:05: [io 0x0c50-0x0c51] has been reserved
[ 0.345926] system 00:05: [io 0x0c52] has been reserved
[ 0.345927] system 00:05: [io 0x0c6c] has been reserved
[ 0.345928] system 00:05: [io 0x0c6f] has been reserved
[ 0.345928] system 00:05: [io 0x0cd0-0x0cd1] has been reserved
[ 0.345929] system 00:05: [io 0x0cd2-0x0cd3] has been reserved
[ 0.345930] system 00:05: [io 0x0cd4-0x0cd5] has been reserved
[ 0.345930] system 00:05: [io 0x0cd6-0x0cd7] has been reserved
[ 0.345931] system 00:05: [io 0x0cd8-0x0cdf] has been reserved
[ 0.345932] system 00:05: [io 0x0800-0x089f] has been reserved
[ 0.345932] system 00:05: [io 0x0b00-0x0b0f] has been reserved
[ 0.345933] system 00:05: [io 0x0b20-0x0b3f] has been reserved
[ 0.345934] system 00:05: [io 0x0900-0x090f] has been reserved
[ 0.345935] system 00:05: [io 0x0910-0x091f] has been reserved
[ 0.345936] system 00:05: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.345937] system 00:05: [mem 0xfedc0000-0xfedc0fff] has been reserved
[ 0.345937] system 00:05: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.345938] system 00:05: [mem 0xfed80000-0xfed8ffff] could not be reserved
[ 0.345939] system 00:05: [mem 0xfec10000-0xfec10fff] has been reserved
[ 0.345939] system 00:05: [mem 0xff000000-0xffffffff] has been reserved
[ 0.345941] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.346388] system 00:06: [mem 0xb3580000-0xb35fffff] could not be reserved
[ 0.346390] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.347202] system 00:07: [mem 0xb2500000-0xb257ffff] could not be reserved
[ 0.347204] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.348151] system 00:08: [mem 0xe2200000-0xe227ffff] could not be reserved
[ 0.348153] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.348745] pnp: PnP ACPI: found 9 devices
[ 0.354036] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.354063] pci 0000:00:01.1: PCI bridge to [bus 01]
[ 0.354065] pci 0000:00:01.1: bridge window [io 0x3000-0x3fff]
[ 0.354068] pci 0000:00:01.1: bridge window [mem 0xe0000000-0xe10fffff]
[ 0.354070] pci 0000:00:01.1: bridge window [mem 0xc0000000-0xd20fffff 64bit pref]
[ 0.354074] pci 0000:00:07.1: PCI bridge to [bus 02]
[ 0.354081] pci 0000:00:08.1: PCI bridge to [bus 03]
[ 0.354083] pci 0000:00:08.1: bridge window [mem 0xe1200000-0xe12fffff]
[ 0.354088] pci_bus 0000:00: resource 4 [io 0x0000-0x03af window]
[ 0.354089] pci_bus 0000:00: resource 5 [io 0x03e0-0x0cf7 window]
[ 0.354089] pci_bus 0000:00: resource 6 [io 0x03b0-0x03df window]
[ 0.354090] pci_bus 0000:00: resource 7 [io 0x0d00-0x3fff window]
[ 0.354091] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000bffff window]
[ 0.354091] pci_bus 0000:00: resource 9 [mem 0x000c0000-0x000dffff window]
[ 0.354092] pci_bus 0000:00: resource 10 [mem 0xc0000000-0xe1fffffe window]
[ 0.354092] pci_bus 0000:01: resource 0 [io 0x3000-0x3fff]
[ 0.354093] pci_bus 0000:01: resource 1 [mem 0xe0000000-0xe10fffff]
[ 0.354093] pci_bus 0000:01: resource 2 [mem 0xc0000000-0xd20fffff 64bit pref]
[ 0.354094] pci_bus 0000:03: resource 1 [mem 0xe1200000-0xe12fffff]
[ 0.354128] pci 0000:20:07.1: PCI bridge to [bus 21]
[ 0.354134] pci 0000:20:08.1: PCI bridge to [bus 22]
[ 0.354137] pci 0000:20:08.1: bridge window [mem 0xb2000000-0xb22fffff]
[ 0.354141] pci_bus 0000:20: resource 4 [io 0x4000-0x6fff window]
[ 0.354141] pci_bus 0000:20: resource 5 [mem 0xb0000000-0xb23ffffe window]
[ 0.354142] pci_bus 0000:22: resource 1 [mem 0xb2000000-0xb22fffff]
[ 0.354170] pci_bus 0000:40: max bus depth: 3 pci_try_num: 4
[ 0.354174] pci 0000:42:02.0: PCI bridge to [bus 43]
[ 0.354179] pci 0000:42:02.0: bridge window [mem 0xb7c00000-0xb7cfffff]
[ 0.354189] pci 0000:42:03.0: PCI bridge to [bus 44]
[ 0.354193] pci 0000:42:03.0: bridge window [mem 0xb7000000-0xb74fffff]
[ 0.354202] pci 0000:42:04.0: PCI bridge to [bus 45]
[ 0.354207] pci 0000:42:04.0: bridge window [mem 0xb7b00000-0xb7bfffff]
[ 0.354218] pci 0000:46:00.0: BAR 9: assigned [mem 0xb7a20000-0xb7a8ffff 64bit]
[ 0.354225] pci 0000:46:00.0: BAR 11: assigned [mem 0xb7a90000-0xb7aabfff 64bit]
[ 0.354232] pci 0000:42:05.0: PCI bridge to [bus 46]
[ 0.354233] pci 0000:42:05.0: bridge window [io 0xc000-0xcfff]
[ 0.354238] pci 0000:42:05.0: bridge window [mem 0xb7a00000-0xb7afffff]
[ 0.354247] pci 0000:42:08.0: PCI bridge to [bus 47]
[ 0.354253] pci 0000:42:08.0: bridge window [mem 0xb7600000-0xb77fffff]
[ 0.354262] pci 0000:42:09.0: PCI bridge to [bus 48]
[ 0.354266] pci 0000:42:09.0: bridge window [mem 0xb7900000-0xb79fffff]
[ 0.354275] pci 0000:42:0a.0: PCI bridge to [bus 49]
[ 0.354280] pci 0000:42:0a.0: bridge window [mem 0xb7800000-0xb78fffff]
[ 0.354289] pci 0000:41:00.0: PCI bridge to [bus 42-49]
[ 0.354291] pci 0000:41:00.0: bridge window [io 0xc000-0xcfff]
[ 0.354295] pci 0000:41:00.0: bridge window [mem 0xb7000000-0xb7cfffff]
[ 0.354304] pci 0000:40:01.1: PCI bridge to [bus 41-49]
[ 0.354305] pci 0000:40:01.1: bridge window [io 0xc000-0xcfff]
[ 0.354308] pci 0000:40:01.1: bridge window [mem 0xb7000000-0xb7cfffff]
[ 0.354312] pci 0000:40:01.2: PCI bridge to [bus 4a]
[ 0.354314] pci 0000:40:01.2: bridge window [mem 0xb7e00000-0xb7efffff]
[ 0.354319] pci 0000:40:07.1: PCI bridge to [bus 4b]
[ 0.354325] pci 0000:40:08.1: PCI bridge to [bus 4c]
[ 0.354331] pci_bus 0000:40: resource 4 [io 0x7000-0xcfff window]
[ 0.354331] pci_bus 0000:40: resource 5 [mem 0xb5000000-0xb7fffffe window]
[ 0.354332] pci_bus 0000:41: resource 0 [io 0xc000-0xcfff]
[ 0.354333] pci_bus 0000:41: resource 1 [mem 0xb7000000-0xb7cfffff]
[ 0.354333] pci_bus 0000:42: resource 0 [io 0xc000-0xcfff]
[ 0.354334] pci_bus 0000:42: resource 1 [mem 0xb7000000-0xb7cfffff]
[ 0.354335] pci_bus 0000:43: resource 1 [mem 0xb7c00000-0xb7cfffff]
[ 0.354335] pci_bus 0000:44: resource 1 [mem 0xb7000000-0xb74fffff]
[ 0.354336] pci_bus 0000:45: resource 1 [mem 0xb7b00000-0xb7bfffff]
[ 0.354336] pci_bus 0000:46: resource 0 [io 0xc000-0xcfff]
[ 0.354337] pci_bus 0000:46: resource 1 [mem 0xb7a00000-0xb7afffff]
[ 0.354338] pci_bus 0000:47: resource 1 [mem 0xb7600000-0xb77fffff]
[ 0.354338] pci_bus 0000:48: resource 1 [mem 0xb7900000-0xb79fffff]
[ 0.354339] pci_bus 0000:49: resource 1 [mem 0xb7800000-0xb78fffff]
[ 0.354339] pci_bus 0000:4a: resource 1 [mem 0xb7e00000-0xb7efffff]
[ 0.354376] pci 0000:60:07.1: PCI bridge to [bus 61]
[ 0.354383] pci 0000:60:08.1: PCI bridge to [bus 62]
[ 0.354389] pci_bus 0000:60: resource 4 [io 0xd000-0xffff window]
[ 0.354389] pci_bus 0000:60: resource 5 [mem 0xf8000000-0xf9ffffff window]
[ 0.354503] NET: Registered protocol family 2
[ 0.354984] tcp_listen_portaddr_hash hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.355363] TCP established hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.355802] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.355863] TCP: Hash tables configured (established 524288 bind 65536)
[ 0.356210] UDP hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 0.356485] UDP-Lite hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 0.356784] NET: Registered protocol family 1
[ 0.356788] NET: Registered protocol family 44
[ 0.356841] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[ 0.356890] pci 0000:01:00.2: D0 power state depends on 0000:01:00.0
[ 0.357049] pci 0000:01:00.3: D0 power state depends on 0000:01:00.0
[ 0.357763] PCI: CLS 64 bytes, default 64
[ 0.357797] Trying to unpack rootfs image as initramfs...
[ 0.441475] Freeing initrd memory: 9464K
[ 0.441516] pci 0000:60:00.2: AMD-Vi: IOMMU performance counters supported
[ 0.441554] pci 0000:40:00.2: AMD-Vi: IOMMU performance counters supported
[ 0.441575] pci 0000:20:00.2: AMD-Vi: IOMMU performance counters supported
[ 0.441591] pci 0000:00:00.2: AMD-Vi: IOMMU performance counters supported
[ 0.441643] pci 0000:00:01.0: Adding to iommu group 0
[ 0.442429] pci 0000:00:01.1: Adding to iommu group 1
[ 0.442963] pci 0000:00:02.0: Adding to iommu group 2
[ 0.443708] pci 0000:00:03.0: Adding to iommu group 3
[ 0.444385] pci 0000:00:04.0: Adding to iommu group 4
[ 0.444899] pci 0000:00:05.0: Adding to iommu group 5
[ 0.445610] pci 0000:00:07.0: Adding to iommu group 6
[ 0.446149] pci 0000:00:07.1: Adding to iommu group 7
[ 0.446889] pci 0000:00:08.0: Adding to iommu group 8
[ 0.447417] pci 0000:00:08.1: Adding to iommu group 9
[ 0.448149] pci 0000:00:14.0: Adding to iommu group 10
[ 0.448674] pci 0000:00:14.3: Adding to iommu group 10
[ 0.448731] pci 0000:00:18.0: Adding to iommu group 11
[ 0.449448] pci 0000:00:18.1: Adding to iommu group 11
[ 0.449471] pci 0000:00:18.2: Adding to iommu group 11
[ 0.449492] pci 0000:00:18.3: Adding to iommu group 11
[ 0.449514] pci 0000:00:18.4: Adding to iommu group 11
[ 0.449534] pci 0000:00:18.5: Adding to iommu group 11
[ 0.449568] pci 0000:00:18.6: Adding to iommu group 11
[ 0.449589] pci 0000:00:18.7: Adding to iommu group 11
[ 0.449650] pci 0000:01:00.0: Adding to iommu group 12
[ 0.450188] pci 0000:01:00.1: Adding to iommu group 12
[ 0.450223] pci 0000:01:00.2: Adding to iommu group 12
[ 0.450258] pci 0000:01:00.3: Adding to iommu group 12
[ 0.450282] pci 0000:02:00.0: Adding to iommu group 13
[ 0.451004] pci 0000:03:00.0: Adding to iommu group 14
[ 0.451428] pci 0000:03:00.3: Adding to iommu group 15
[ 0.452036] pci 0000:20:01.0: Adding to iommu group 16
[ 0.452447] pci 0000:20:02.0: Adding to iommu group 17
[ 0.453066] pci 0000:20:03.0: Adding to iommu group 18
[ 0.453479] pci 0000:20:04.0: Adding to iommu group 19
[ 0.454087] pci 0000:20:05.0: Adding to iommu group 20
[ 0.454491] pci 0000:20:07.0: Adding to iommu group 21
[ 0.455092] pci 0000:20:07.1: Adding to iommu group 22
[ 0.455488] pci 0000:20:08.0: Adding to iommu group 23
[ 0.456101] pci 0000:20:08.1: Adding to iommu group 24
[ 0.456660] pci 0000:21:00.0: Adding to iommu group 25
[ 0.457065] pci 0000:22:00.0: Adding to iommu group 26
[ 0.457680] pci 0000:22:00.1: Adding to iommu group 27
[ 0.458091] pci 0000:22:00.3: Adding to iommu group 28
[ 0.458690] pci 0000:22:00.4: Adding to iommu group 29
[ 0.459098] pci 0000:40:01.0: Adding to iommu group 30
[ 0.459748] pci 0000:40:01.1: Adding to iommu group 31
[ 0.460318] pci 0000:40:01.2: Adding to iommu group 32
[ 0.460722] pci 0000:40:02.0: Adding to iommu group 33
[ 0.461346] pci 0000:40:03.0: Adding to iommu group 34
[ 0.461760] pci 0000:40:04.0: Adding to iommu group 35
[ 0.462378] pci 0000:40:05.0: Adding to iommu group 36
[ 0.462796] pci 0000:40:07.0: Adding to iommu group 37
[ 0.463414] pci 0000:40:07.1: Adding to iommu group 38
[ 0.463838] pci 0000:40:08.0: Adding to iommu group 39
[ 0.464462] pci 0000:40:08.1: Adding to iommu group 40
[ 0.464874] pci 0000:41:00.0: Adding to iommu group 41
[ 0.465558] pci 0000:42:02.0: Adding to iommu group 42
[ 0.466022] pci 0000:42:03.0: Adding to iommu group 43
[ 0.466689] pci 0000:42:04.0: Adding to iommu group 44
[ 0.467142] pci 0000:42:05.0: Adding to iommu group 45
[ 0.467725] pci 0000:42:08.0: Adding to iommu group 46
[ 0.468357] pci 0000:42:09.0: Adding to iommu group 47
[ 0.468781] pci 0000:42:0a.0: Adding to iommu group 48
[ 0.469442] pci 0000:43:00.0: Adding to iommu group 49
[ 0.469895] pci 0000:44:00.0: Adding to iommu group 50
[ 0.470545] pci 0000:45:00.0: Adding to iommu group 51
[ 0.471003] pci 0000:46:00.0: Adding to iommu group 52
[ 0.471618] pci 0000:47:00.0: Adding to iommu group 46
[ 0.471651] pci 0000:47:00.1: Adding to iommu group 46
[ 0.471674] pci 0000:47:00.3: Adding to iommu group 46
[ 0.471704] pci 0000:48:00.0: Adding to iommu group 47
[ 0.471733] pci 0000:49:00.0: Adding to iommu group 48
[ 0.471761] pci 0000:4a:00.0: Adding to iommu group 53
[ 0.472160] pci 0000:4b:00.0: Adding to iommu group 54
[ 0.472776] pci 0000:4c:00.0: Adding to iommu group 55
[ 0.473351] pci 0000:60:01.0: Adding to iommu group 56
[ 0.473755] pci 0000:60:02.0: Adding to iommu group 57
[ 0.474374] pci 0000:60:03.0: Adding to iommu group 58
[ 0.474782] pci 0000:60:04.0: Adding to iommu group 59
[ 0.475428] pci 0000:60:05.0: Adding to iommu group 60
[ 0.475841] pci 0000:60:07.0: Adding to iommu group 61
[ 0.476512] pci 0000:60:07.1: Adding to iommu group 62
[ 0.476919] pci 0000:60:08.0: Adding to iommu group 63
[ 0.477549] pci 0000:60:08.1: Adding to iommu group 64
[ 0.477965] pci 0000:61:00.0: Adding to iommu group 65
[ 0.478434] pci 0000:62:00.0: Adding to iommu group 66
[ 0.479120] pci 0000:60:00.2: AMD-Vi: Found IOMMU cap 0x40
[ 0.479121] pci 0000:60:00.2: AMD-Vi: Extended features (0x58f77ef22294ade):
[ 0.479121] PPR X2APIC NX GT IA GA PC GA_vAPIC
[ 0.479124] pci 0000:40:00.2: AMD-Vi: Found IOMMU cap 0x40
[ 0.479125] pci 0000:40:00.2: AMD-Vi: Extended features (0x58f77ef22294ade):
[ 0.479125] PPR X2APIC NX GT IA GA PC GA_vAPIC
[ 0.479126] pci 0000:20:00.2: AMD-Vi: Found IOMMU cap 0x40
[ 0.479127] pci 0000:20:00.2: AMD-Vi: Extended features (0x58f77ef22294ade):
[ 0.479127] PPR X2APIC NX GT IA GA PC GA_vAPIC
[ 0.479128] pci 0000:00:00.2: AMD-Vi: Found IOMMU cap 0x40
[ 0.479129] pci 0000:00:00.2: AMD-Vi: Extended features (0x58f77ef22294ade):
[ 0.479129] PPR X2APIC NX GT IA GA PC GA_vAPIC
[ 0.479130] AMD-Vi: Interrupt remapping enabled
[ 0.479130] AMD-Vi: Virtual APIC enabled
[ 0.479130] AMD-Vi: X2APIC enabled
[ 0.479758] AMD-Vi: Lazy IO/TLB flushing enabled
[ 0.480639] amd_uncore: AMD NB counters detected
[ 0.480654] amd_uncore: AMD LLC counters detected
[ 0.482026] LVT offset 0 assigned for vector 0x400
[ 0.482756] perf: AMD IBS detected (0x000003ff)
[ 0.482774] perf/amd_iommu: Detected AMD IOMMU #0 (2 banks, 4 counters/bank).
[ 0.482787] perf/amd_iommu: Detected AMD IOMMU #1 (2 banks, 4 counters/bank).
[ 0.482800] perf/amd_iommu: Detected AMD IOMMU #2 (2 banks, 4 counters/bank).
[ 0.482813] perf/amd_iommu: Detected AMD IOMMU #3 (2 banks, 4 counters/bank).
[ 0.482862] check: Scanning for low memory corruption every 60 seconds
[ 0.483719] Initialise system trusted keyrings
[ 0.483733] Key type blacklist registered
[ 0.483793] workingset: timestamp_bits=41 max_order=25 bucket_order=0
[ 0.484447] zbud: loaded
[ 0.485513] Key type asymmetric registered
[ 0.485514] Asymmetric key parser 'x509' registered
[ 0.485521] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.485624] io scheduler mq-deadline registered
[ 0.485624] io scheduler kyber registered
[ 0.485650] io scheduler bfq registered
[ 0.486958] pcieport 0000:00:01.1: PME: Signaling with IRQ 31
[ 0.487039] pcieport 0000:00:01.1: AER: enabled with IRQ 31
[ 0.487079] pcieport 0000:00:01.1: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 6, DL_ActiveErr+
[ 0.487304] pcieport 0000:00:07.1: PME: Signaling with IRQ 33
[ 0.487371] pcieport 0000:00:07.1: AER: enabled with IRQ 33
[ 0.487488] pcieport 0000:00:08.1: PME: Signaling with IRQ 34
[ 0.487549] pcieport 0000:00:08.1: AER: enabled with IRQ 34
[ 0.487725] pcieport 0000:20:07.1: PME: Signaling with IRQ 36
[ 0.487785] pcieport 0000:20:07.1: AER: enabled with IRQ 36
[ 0.487880] pcieport 0000:20:08.1: PME: Signaling with IRQ 37
[ 0.487948] pcieport 0000:20:08.1: AER: enabled with IRQ 37
[ 0.488049] pcieport 0000:40:01.1: PME: Signaling with IRQ 38
[ 0.488126] pcieport 0000:40:01.1: AER: enabled with IRQ 38
[ 0.488155] pcieport 0000:40:01.1: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 6, DL_ActiveErr+
[ 0.488265] pcieport 0000:40:01.2: PME: Signaling with IRQ 39
[ 0.488323] pcieport 0000:40:01.2: AER: enabled with IRQ 39
[ 0.488359] pcieport 0000:40:01.2: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 6, DL_ActiveErr+
[ 0.488528] pcieport 0000:40:07.1: PME: Signaling with IRQ 41
[ 0.488591] pcieport 0000:40:07.1: AER: enabled with IRQ 41
[ 0.488725] pcieport 0000:40:08.1: PME: Signaling with IRQ 43
[ 0.488791] pcieport 0000:40:08.1: AER: enabled with IRQ 43
[ 0.490661] pcieport 0000:60:07.1: PME: Signaling with IRQ 54
[ 0.490731] pcieport 0000:60:07.1: AER: enabled with IRQ 54
[ 0.490863] pcieport 0000:60:08.1: PME: Signaling with IRQ 56
[ 0.490932] pcieport 0000:60:08.1: AER: enabled with IRQ 56
[ 0.491039] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.491117] efifb: probing for efifb
[ 0.491138] efifb: No BGRT, not showing boot graphics
[ 0.491138] efifb: framebuffer at 0xc0000000, using 23040k, total 23040k
[ 0.491139] efifb: mode is 2560x1440x32, linelength=16384, pages=1
[ 0.491139] efifb: scrolling: redraw
[ 0.491140] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.491166] fbcon: Deferring console take-over
[ 0.491167] fb0: EFI VGA frame buffer device
[ 0.491274] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.491292] ACPI: Power Button [PWRB]
[ 0.491331] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 0.491436] ACPI: Power Button [PWRF]
[ 0.491536] Monitor-Mwait will be used to enter C-1 state
[ 0.491542] ACPI: \_PR_.C000: Found 2 idle states
[ 0.491670] ACPI: \_PR_.C002: Found 2 idle states
[ 0.491723] ACPI: \_PR_.C004: Found 2 idle states
[ 0.491778] ACPI: \_PR_.C006: Found 2 idle states
[ 0.491835] ACPI: \_PR_.C008: Found 2 idle states
[ 0.491901] ACPI: \_PR_.C00A: Found 2 idle states
[ 0.491956] ACPI: \_PR_.C00C: Found 2 idle states
[ 0.492083] ACPI: \_PR_.C00E: Found 2 idle states
[ 0.492139] ACPI: \_PR_.C010: Found 2 idle states
[ 0.492207] ACPI: \_PR_.C012: Found 2 idle states
[ 0.492376] ACPI: \_PR_.C014: Found 2 idle states
[ 0.492472] ACPI: \_PR_.C016: Found 2 idle states
[ 0.492669] ACPI: \_PR_.C018: Found 2 idle states
[ 0.492764] ACPI: \_PR_.C01A: Found 2 idle states
[ 0.492872] ACPI: \_PR_.C01C: Found 2 idle states
[ 0.493062] ACPI: \_PR_.C01E: Found 2 idle states
[ 0.493145] ACPI: \_PR_.C020: Found 2 idle states
[ 0.493255] ACPI: \_PR_.C022: Found 2 idle states
[ 0.493458] ACPI: \_PR_.C024: Found 2 idle states
[ 0.493554] ACPI: \_PR_.C026: Found 2 idle states
[ 0.493658] ACPI: \_PR_.C028: Found 2 idle states
[ 0.493840] ACPI: \_PR_.C02A: Found 2 idle states
[ 0.493937] ACPI: \_PR_.C02C: Found 2 idle states
[ 0.494149] ACPI: \_PR_.C02E: Found 2 idle states
[ 0.494316] ACPI: \_PR_.C001: Found 2 idle states
[ 0.494431] ACPI: \_PR_.C003: Found 2 idle states
[ 0.494520] ACPI: \_PR_.C005: Found 2 idle states
[ 0.494584] ACPI: \_PR_.C007: Found 2 idle states
[ 0.494689] ACPI: \_PR_.C009: Found 2 idle states
[ 0.494813] ACPI: \_PR_.C00B: Found 2 idle states
[ 0.494876] ACPI: \_PR_.C00D: Found 2 idle states
[ 0.494950] ACPI: \_PR_.C00F: Found 2 idle states
[ 0.495017] ACPI: \_PR_.C011: Found 2 idle states
[ 0.495184] ACPI: \_PR_.C013: Found 2 idle states
[ 0.495272] ACPI: \_PR_.C015: Found 2 idle states
[ 0.495377] ACPI: \_PR_.C017: Found 2 idle states
[ 0.495535] ACPI: \_PR_.C019: Found 2 idle states
[ 0.495619] ACPI: \_PR_.C01B: Found 2 idle states
[ 0.495738] ACPI: \_PR_.C01D: Found 2 idle states
[ 0.495894] ACPI: \_PR_.C01F: Found 2 idle states
[ 0.495980] ACPI: \_PR_.C021: Found 2 idle states
[ 0.496087] ACPI: \_PR_.C023: Found 2 idle states
[ 0.496242] ACPI: \_PR_.C025: Found 2 idle states
[ 0.496410] ACPI: \_PR_.C027: Found 2 idle states
[ 0.496565] ACPI: \_PR_.C029: Found 2 idle states
[ 0.496722] ACPI: \_PR_.C02B: Found 2 idle states
[ 0.496829] ACPI: \_PR_.C02D: Found 2 idle states
[ 0.496956] ACPI: \_PR_.C02F: Found 2 idle states
[ 0.497432] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.497931] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[ 0.500853] nvme nvme0: pci function 0000:4a:00.0
[ 0.500898] ahci 0000:48:00.0: version 3.0
[ 0.508368] nvme nvme0: missing or invalid SUBNQN field.
[ 0.508386] nvme nvme0: Shutdown timeout set to 8 seconds
[ 0.536145] nvme nvme0: 32/0/0 default/read/poll queues
[ 0.540728] nvme0n1: p1 p2 p3
[ 1.493735] tsc: Refined TSC clocksource calibration: 3799.995 MHz
[ 1.493779] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x6d8ca817dab, max_idle_ns: 881590735735 ns
[ 1.493903] clocksource: Switched to clocksource tsc
[ 1.500985] ahci 0000:48:00.0: failed stop FIS RX (-16)
[ 1.501000] ahci 0000:48:00.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[ 1.501001] ahci 0000:48:00.0: flags: 64bit ncq sntf ilck pm led clo only pmp fbs pio slum part
[ 1.501259] scsi host0: ahci
[ 1.501340] ata1: SATA max UDMA/133 abar m2048@0xb7900000 port 0xb7900100 irq 59
[ 1.811045] ata1: SATA link down (SStatus 0 SControl 300)
[ 2.508463] ahci 0000:49:00.0: failed stop FIS RX (-16)
[ 2.508478] ahci 0000:49:00.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[ 2.508480] ahci 0000:49:00.0: flags: 64bit ncq sntf ilck pm led clo only pmp fbs pio slum part
[ 2.508922] scsi host1: ahci
[ 2.508989] ata2: SATA max UDMA/133 abar m2048@0xb7800000 port 0xb7800100 irq 92
[ 2.509052] usbcore: registered new interface driver usbserial_generic
[ 2.509055] usbserial: USB Serial support registered for generic
[ 2.509078] rtc_cmos 00:03: RTC can wake from S4
[ 2.509298] rtc_cmos 00:03: registered as rtc0
[ 2.509398] rtc_cmos 00:03: setting system clock to 2020-11-08T12:06:51 UTC (1604837211)
[ 2.509409] rtc_cmos 00:03: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 2.510900] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.511260] drop_monitor: Initializing network drop monitor service
[ 2.511456] NET: Registered protocol family 10
[ 2.514519] Segment Routing with IPv6
[ 2.514520] RPL Segment Routing with IPv6
[ 2.514532] NET: Registered protocol family 17
[ 2.517671] RAS: Correctable Errors collector initialized.
[ 2.517720] microcode: CPU0: patch_level=0x08301039
[ 2.517723] microcode: CPU1: patch_level=0x08301039
[ 2.517736] microcode: CPU2: patch_level=0x08301039
[ 2.517751] microcode: CPU3: patch_level=0x08301039
[ 2.517765] microcode: CPU4: patch_level=0x08301039
[ 2.517780] microcode: CPU5: patch_level=0x08301039
[ 2.517797] microcode: CPU6: patch_level=0x08301039
[ 2.517834] microcode: CPU7: patch_level=0x08301039
[ 2.517851] microcode: CPU8: patch_level=0x08301039
[ 2.517868] microcode: CPU9: patch_level=0x08301039
[ 2.517884] microcode: CPU10: patch_level=0x08301039
[ 2.517900] microcode: CPU11: patch_level=0x08301039
[ 2.517918] microcode: CPU12: patch_level=0x08301039
[ 2.517955] microcode: CPU13: patch_level=0x08301039
[ 2.517971] microcode: CPU14: patch_level=0x08301039
[ 2.517988] microcode: CPU15: patch_level=0x08301039
[ 2.518003] microcode: CPU16: patch_level=0x08301039
[ 2.518019] microcode: CPU17: patch_level=0x08301039
[ 2.518057] microcode: CPU18: patch_level=0x08301039
[ 2.518073] microcode: CPU19: patch_level=0x08301039
[ 2.518089] microcode: CPU20: patch_level=0x08301039
[ 2.518105] microcode: CPU21: patch_level=0x08301039
[ 2.518140] microcode: CPU22: patch_level=0x08301039
[ 2.518155] microcode: CPU23: patch_level=0x08301039
[ 2.518170] microcode: CPU24: patch_level=0x08301039
[ 2.518175] microcode: CPU25: patch_level=0x08301039
[ 2.518188] microcode: CPU26: patch_level=0x08301039
[ 2.518202] microcode: CPU27: patch_level=0x08301039
[ 2.518216] microcode: CPU28: patch_level=0x08301039
[ 2.518231] microcode: CPU29: patch_level=0x08301039
[ 2.518247] microcode: CPU30: patch_level=0x08301039
[ 2.518262] microcode: CPU31: patch_level=0x08301039
[ 2.518278] microcode: CPU32: patch_level=0x08301039
[ 2.518294] microcode: CPU33: patch_level=0x08301039
[ 2.518310] microcode: CPU34: patch_level=0x08301039
[ 2.518326] microcode: CPU35: patch_level=0x08301039
[ 2.518342] microcode: CPU36: patch_level=0x08301039
[ 2.518358] microcode: CPU37: patch_level=0x08301039
[ 2.518375] microcode: CPU38: patch_level=0x08301039
[ 2.518382] microcode: CPU39: patch_level=0x08301039
[ 2.518397] microcode: CPU40: patch_level=0x08301039
[ 2.518413] microcode: CPU41: patch_level=0x08301039
[ 2.518428] microcode: CPU42: patch_level=0x08301039
[ 2.518444] microcode: CPU43: patch_level=0x08301039
[ 2.518458] microcode: CPU44: patch_level=0x08301039
[ 2.518473] microcode: CPU45: patch_level=0x08301039
[ 2.518480] microcode: CPU46: patch_level=0x08301039
[ 2.518494] microcode: CPU47: patch_level=0x08301039
[ 2.518554] microcode: Microcode Update Driver: v2.2.
[ 2.519610] resctrl: L3 allocation detected
[ 2.519610] resctrl: L3DATA allocation detected
[ 2.519611] resctrl: L3CODE allocation detected
[ 2.519611] resctrl: MB allocation detected
[ 2.519611] resctrl: L3 monitoring detected
[ 2.519615] IPI shorthand broadcast: enabled
[ 2.519622] sched_clock: Marking stable (2546254632, -26658526)->(2524417706, -4821600)
[ 2.519868] registered taskstats version 1
[ 2.519875] Loading compiled-in X.509 certificates
[ 2.521256] Loaded X.509 cert 'Build time autogenerated kernel key: 441e7a2023411efa2b6a2888e7d70ee4cdac6d83'
[ 2.528027] zswap: loaded using pool zstd/z3fold
[ 2.529040] Key type ._fscrypt registered
[ 2.529040] Key type .fscrypt registered
[ 2.529041] Key type fscrypt-provisioning registered
[ 2.531325] Key type big_key registered
[ 2.531932] PM: Magic number: 12:966:126
[ 2.532096] acpi device:01: hash matches
[ 2.532155] memory memory717: hash matches
[ 2.821480] ata2: SATA link down (SStatus 0 SControl 300)
[ 2.822855] Freeing unused decrypted memory: 2040K
[ 2.823214] Freeing unused kernel image (initmem) memory: 1632K
[ 2.823220] Write protecting the kernel read-only data: 20480k
[ 2.823926] Freeing unused kernel image (text/rodata gap) memory: 2044K
[ 2.824319] Freeing unused kernel image (rodata/data gap) memory: 1548K
[ 2.846773] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 2.846775] Run /init as init process
[ 2.846776] with arguments:
[ 2.846776] /init
[ 2.846777] with environment:
[ 2.846777] HOME=/
[ 2.846777] TERM=linux
[ 2.846778] BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64
[ 2.944244] xhci_hcd 0000:01:00.2: xHCI Host Controller
[ 2.944250] xhci_hcd 0000:01:00.2: new USB bus registered, assigned bus number 1
[ 2.944861] xhci_hcd 0000:01:00.2: hcc params 0x0180ff05 hci version 0x110 quirks 0x0000000000000010
[ 2.945027] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.07
[ 2.945028] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.945029] usb usb1: Product: xHCI Host Controller
[ 2.945031] usb usb1: Manufacturer: Linux 5.7.19-2-MANJARO xhci-hcd
[ 2.945032] usb usb1: SerialNumber: 0000:01:00.2
[ 2.945141] hub 1-0:1.0: USB hub found
[ 2.945147] hub 1-0:1.0: 2 ports detected
[ 2.945280] xhci_hcd 0000:01:00.2: xHCI Host Controller
[ 2.945281] xhci_hcd 0000:01:00.2: new USB bus registered, assigned bus number 2
[ 2.945283] xhci_hcd 0000:01:00.2: Host supports USB 3.1 Enhanced SuperSpeed
[ 2.945308] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 2.945321] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.07
[ 2.945321] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.945322] usb usb2: Product: xHCI Host Controller
[ 2.945323] usb usb2: Manufacturer: Linux 5.7.19-2-MANJARO xhci-hcd
[ 2.945323] usb usb2: SerialNumber: 0000:01:00.2
[ 2.945389] hub 2-0:1.0: USB hub found
[ 2.945397] hub 2-0:1.0: 4 ports detected
[ 2.945571] xhci_hcd 0000:03:00.3: xHCI Host Controller
[ 2.945574] xhci_hcd 0000:03:00.3: new USB bus registered, assigned bus number 3
[ 2.945660] xhci_hcd 0000:03:00.3: hcc params 0x0260ffe5 hci version 0x110 quirks 0x0000000000000410
[ 2.946020] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.07
[ 2.946021] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.946021] usb usb3: Product: xHCI Host Controller
[ 2.946022] usb usb3: Manufacturer: Linux 5.7.19-2-MANJARO xhci-hcd
[ 2.946022] usb usb3: SerialNumber: 0000:03:00.3
[ 2.946088] hub 3-0:1.0: USB hub found
[ 2.946093] hub 3-0:1.0: 2 ports detected
[ 2.946159] xhci_hcd 0000:03:00.3: xHCI Host Controller
[ 2.946160] xhci_hcd 0000:03:00.3: new USB bus registered, assigned bus number 4
[ 2.946162] xhci_hcd 0000:03:00.3: Host supports USB 3.1 Enhanced SuperSpeed
[ 2.946170] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 2.946180] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.07
[ 2.946181] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.946182] usb usb4: Product: xHCI Host Controller
[ 2.946183] usb usb4: Manufacturer: Linux 5.7.19-2-MANJARO xhci-hcd
[ 2.946184] usb usb4: SerialNumber: 0000:03:00.3
[ 2.946242] hub 4-0:1.0: USB hub found
[ 2.946247] hub 4-0:1.0: 2 ports detected
[ 2.946380] xhci_hcd 0000:22:00.3: xHCI Host Controller
[ 2.946384] xhci_hcd 0000:22:00.3: new USB bus registered, assigned bus number 5
[ 2.946470] xhci_hcd 0000:22:00.3: hcc params 0x0260ffe5 hci version 0x110 quirks 0x0000000000000410
[ 2.946845] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.07
[ 2.946846] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.946847] usb usb5: Product: xHCI Host Controller
[ 2.946847] usb usb5: Manufacturer: Linux 5.7.19-2-MANJARO xhci-hcd
[ 2.946848] usb usb5: SerialNumber: 0000:22:00.3
[ 2.946930] hub 5-0:1.0: USB hub found
[ 2.946935] hub 5-0:1.0: 2 ports detected
[ 2.947069] xhci_hcd 0000:22:00.3: xHCI Host Controller
[ 2.947071] xhci_hcd 0000:22:00.3: new USB bus registered, assigned bus number 6
[ 2.947072] xhci_hcd 0000:22:00.3: Host supports USB 3.1 Enhanced SuperSpeed
[ 2.947080] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[ 2.947091] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.07
[ 2.947092] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.947093] usb usb6: Product: xHCI Host Controller
[ 2.947093] usb usb6: Manufacturer: Linux 5.7.19-2-MANJARO xhci-hcd
[ 2.947094] usb usb6: SerialNumber: 0000:22:00.3
[ 2.947142] hub 6-0:1.0: USB hub found
[ 2.947146] hub 6-0:1.0: 2 ports detected
[ 2.947251] xhci_hcd 0000:43:00.0: xHCI Host Controller
[ 2.947254] xhci_hcd 0000:43:00.0: new USB bus registered, assigned bus number 7
[ 3.002005] xhci_hcd 0000:43:00.0: hcc params 0x0200ef81 hci version 0x110 quirks 0x0000000000000010
[ 3.002413] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.07
[ 3.002414] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.002414] usb usb7: Product: xHCI Host Controller
[ 3.002415] usb usb7: Manufacturer: Linux 5.7.19-2-MANJARO xhci-hcd
[ 3.002415] usb usb7: SerialNumber: 0000:43:00.0
[ 3.002483] hub 7-0:1.0: USB hub found
[ 3.002488] hub 7-0:1.0: 1 port detected
[ 3.002564] xhci_hcd 0000:43:00.0: xHCI Host Controller
[ 3.002565] xhci_hcd 0000:43:00.0: new USB bus registered, assigned bus number 8
[ 3.002566] xhci_hcd 0000:43:00.0: Host supports USB 3.2 Enhanced SuperSpeed
[ 3.002595] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM.
[ 3.002605] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.07
[ 3.002606] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.002606] usb usb8: Product: xHCI Host Controller
[ 3.002607] usb usb8: Manufacturer: Linux 5.7.19-2-MANJARO xhci-hcd
[ 3.002607] usb usb8: SerialNumber: 0000:43:00.0
[ 3.002669] hub 8-0:1.0: USB hub found
[ 3.002674] hub 8-0:1.0: 1 port detected
[ 3.002854] xhci_hcd 0000:47:00.1: xHCI Host Controller
[ 3.002856] xhci_hcd 0000:47:00.1: new USB bus registered, assigned bus number 9
[ 3.003010] xhci_hcd 0000:47:00.1: hcc params 0x0278ffe5 hci version 0x110 quirks 0x0000000000000410
[ 3.003435] usb usb9: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.07
[ 3.003436] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.003436] usb usb9: Product: xHCI Host Controller
[ 3.003437] usb usb9: Manufacturer: Linux 5.7.19-2-MANJARO xhci-hcd
[ 3.003437] usb usb9: SerialNumber: 0000:47:00.1
[ 3.003503] hub 9-0:1.0: USB hub found
[ 3.003513] hub 9-0:1.0: 6 ports detected
[ 3.003702] xhci_hcd 0000:47:00.1: xHCI Host Controller
[ 3.003704] xhci_hcd 0000:47:00.1: new USB bus registered, assigned bus number 10
[ 3.003705] xhci_hcd 0000:47:00.1: Host supports USB 3.1 Enhanced SuperSpeed
[ 3.003714] usb usb10: We don't know the algorithms for LPM for this host, disabling LPM.
[ 3.003725] usb usb10: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.07
[ 3.003726] usb usb10: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.003726] usb usb10: Product: xHCI Host Controller
[ 3.003727] usb usb10: Manufacturer: Linux 5.7.19-2-MANJARO xhci-hcd
[ 3.003728] usb usb10: SerialNumber: 0000:47:00.1
[ 3.003791] hub 10-0:1.0: USB hub found
[ 3.003798] hub 10-0:1.0: 4 ports detected
[ 3.003946] xhci_hcd 0000:47:00.3: xHCI Host Controller
[ 3.003948] xhci_hcd 0000:47:00.3: new USB bus registered, assigned bus number 11
[ 3.004108] xhci_hcd 0000:47:00.3: hcc params 0x0278ffe5 hci version 0x110 quirks 0x0000000000000410
[ 3.004520] usb usb11: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.07
[ 3.004521] usb usb11: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.004522] usb usb11: Product: xHCI Host Controller
[ 3.004522] usb usb11: Manufacturer: Linux 5.7.19-2-MANJARO xhci-hcd
[ 3.004523] usb usb11: SerialNumber: 0000:47:00.3
[ 3.004588] hub 11-0:1.0: USB hub found
[ 3.004599] hub 11-0:1.0: 6 ports detected
[ 3.004792] xhci_hcd 0000:47:00.3: xHCI Host Controller
[ 3.004793] xhci_hcd 0000:47:00.3: new USB bus registered, assigned bus number 12
[ 3.004794] xhci_hcd 0000:47:00.3: Host supports USB 3.1 Enhanced SuperSpeed
[ 3.004804] usb usb12: We don't know the algorithms for LPM for this host, disabling LPM.
[ 3.004819] usb usb12: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.07
[ 3.004820] usb usb12: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.004820] usb usb12: Product: xHCI Host Controller
[ 3.004821] usb usb12: Manufacturer: Linux 5.7.19-2-MANJARO xhci-hcd
[ 3.004821] usb usb12: SerialNumber: 0000:47:00.3
[ 3.004884] hub 12-0:1.0: USB hub found
[ 3.004892] hub 12-0:1.0: 4 ports detected
[ 3.004926] usb: port power management may be unreliable
[ 3.037373] random: fast init done
[ 3.044831] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.098982] systemd[1]: systemd 246.6-1-manjaro running in system mode. (+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 3.113388] systemd[1]: Detected architecture x86-64.
[ 3.171051] systemd[1]: Set hostname to <workstation>.
[ 3.233815] systemd[1]: Queued start job for default target Graphical Interface.
[ 3.234982] systemd[1]: Created slice system-getty.slice.
[ 3.235225] systemd[1]: Created slice system-modprobe.slice.
[ 3.235443] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 3.235668] systemd[1]: Created slice User and Session Slice.
[ 3.235701] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 3.235720] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.235823] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 3.235839] systemd[1]: Reached target Local Encrypted Volumes.
[ 3.235846] systemd[1]: Reached target Login Prompts.
[ 3.235861] systemd[1]: Reached target Remote File Systems.
[ 3.235868] systemd[1]: Reached target Slices.
[ 3.235878] systemd[1]: Reached target Swap.
[ 3.235917] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 3.235953] systemd[1]: Listening on LVM2 metadata daemon socket.
[ 3.236079] systemd[1]: Listening on LVM2 poll daemon socket.
[ 3.236963] systemd[1]: Listening on Process Core Dump Socket.
[ 3.237023] systemd[1]: Listening on Journal Audit Socket.
[ 3.237063] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.237106] systemd[1]: Listening on Journal Socket.
[ 3.237154] systemd[1]: Listening on udev Control Socket.
[ 3.237184] systemd[1]: Listening on udev Kernel Socket.
[ 3.237942] systemd[1]: Mounting Huge Pages File System...
[ 3.238490] systemd[1]: Mounting POSIX Message Queue File System...
[ 3.239135] systemd[1]: Mounting Kernel Debug File System...
[ 3.239984] systemd[1]: Mounting Kernel Trace File System...
[ 3.240880] systemd[1]: Mounting Temporary Directory (/tmp)...
[ 3.241624] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 3.242251] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 3.243062] systemd[1]: Starting Load Kernel Module drm...
[ 3.243940] systemd[1]: Starting Set Up Additional Binary Formats...
[ 3.243974] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 3.245612] systemd[1]: Starting Journal Service...
[ 3.246540] systemd[1]: Starting Load Kernel Modules...
[ 3.247320] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 3.247350] systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
[ 3.247902] random: lvm: uninitialized urandom read (4 bytes read)
[ 3.248078] systemd[1]: Starting Coldplug All udev Devices...
[ 3.248928] systemd[1]: Mounted Huge Pages File System.
[ 3.249003] systemd[1]: Mounted POSIX Message Queue File System.
[ 3.249069] systemd[1]: Mounted Kernel Debug File System.
[ 3.249148] systemd[1]: Mounted Kernel Trace File System.
[ 3.249218] systemd[1]: Mounted Temporary Directory (/tmp).
[ 3.249479] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 3.249639] systemd[1]: modprobe@drm.service: Succeeded.
[ 3.249801] systemd[1]: Finished Load Kernel Module drm.
[ 3.249878] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 598 (systemd-binfmt)
[ 3.250623] systemd[1]: Mounting Arbitrary Executable File Formats File System...
[ 3.252284] EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
[ 3.252770] systemd[1]: Mounted Arbitrary Executable File Formats File System.
[ 3.253093] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 3.253192] systemd[1]: Condition check resulted in First Boot Wizard being skipped.
[ 3.253577] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 3.254347] systemd[1]: Starting Load/Save Random Seed...
[ 3.254930] systemd[1]: Starting Create System Users...
[ 3.255393] systemd[1]: Finished Set Up Additional Binary Formats.
[ 3.269204] systemd[1]: Finished Create System Users.
[ 3.269895] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 3.273362] usb 3-2: new high-speed USB device number 2 using xhci_hcd
[ 3.277956] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 3.280318] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 3.336684] usb 11-2: new full-speed USB device number 2 using xhci_hcd
[ 3.336689] usb 9-5: new full-speed USB device number 2 using xhci_hcd
[ 3.338184] systemd[1]: Finished Coldplug All udev Devices.
[ 3.347385] nvidia: loading out-of-tree module taints kernel.
[ 3.347391] nvidia: module license 'NVIDIA' taints kernel.
[ 3.347392] Disabling lock debugging due to kernel taint
[ 3.354418] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 3.361052] nvidia-nvlink: Nvlink Core is being initialized, major device number 242
[ 3.361455] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
[ 3.406706] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 450.80.02 Wed Sep 23 01:13:39 UTC 2020
[ 3.415818] usb 3-2: New USB device found, idVendor=0781, idProduct=5567, bcdDevice= 1.00
[ 3.415820] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.415821] usb 3-2: Product: Cruzer Blade
[ 3.415821] usb 3-2: Manufacturer: SanDisk
[ 3.415822] usb 3-2: SerialNumber: 4C530000240429113225
[ 3.417200] Linux agpgart interface v0.103
[ 3.448698] systemd[1]: Started Journal Service.
[ 3.448764] audit: type=1130 audit(1604837212.436:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.459309] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 450.80.02 Wed Sep 23 00:48:09 UTC 2020
[ 3.461457] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 3.461458] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 0
[ 3.465943] audit: type=1130 audit(1604837212.453:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.471965] audit: type=1130 audit(1604837212.460:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.480023] audit: type=1130 audit(1604837212.470:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.481162] audit: type=1130 audit(1604837212.470:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-lvmetad comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.492298] audit: type=1130 audit(1604837212.480:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.499735] usb 9-5: New USB device found, idVendor=26ce, idProduct=01a2, bcdDevice= 0.00
[ 3.499739] usb 9-5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.499740] usb 9-5: Product: LED Controller
[ 3.499741] usb 9-5: Manufacturer: ASRock
[ 3.499743] usb 9-5: SerialNumber: A02019100900
[ 3.502692] acpi_cpufreq: overriding BIOS provided _PSD data
[ 3.502823] usb 11-2: New USB device found, idVendor=1b1c, idProduct=0c22, bcdDevice= 1.00
[ 3.502824] usb 11-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.502826] usb 11-2: Product: H150iRGBPROXT
[ 3.502827] usb 11-2: Manufacturer: Corsair Inc.
[ 3.585478] random: mktemp: uninitialized urandom read (6 bytes read)
[ 3.585635] random: mktemp: uninitialized urandom read (6 bytes read)
[ 3.602082] MACsec IEEE 802.1AE
[ 3.602103] nvidia-gpu 0000:01:00.3: enabling device (0000 -> 0002)
[ 3.602181] input: PC Speaker as /devices/platform/pcspkr/input/input2
[ 3.602491] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0
[ 3.602494] piix4_smbus 0000:00:14.0: Using register 0x02 for SMBus port selection
[ 3.602557] piix4_smbus 0000:00:14.0: Auxiliary SMBus Host Controller at 0xb20
[ 3.603480] usb 12-3: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 3.609077] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
[ 3.609174] sp5100-tco sp5100-tco: Using 0xfed80b00 for watchdog MMIO address
[ 3.609181] sp5100-tco sp5100-tco: Watchdog hardware is disabled
[ 3.609267] cryptd: max_cpu_qlen set to 1000
[ 3.613773] ccp 0000:22:00.1: enabling device (0000 -> 0002)
[ 3.618461] atlantic 0000:44:00.0: enabling device (0000 -> 0002)
[ 3.619933] AVX2 version of gcm_enc/dec engaged.
[ 3.619934] AES CTR mode by8 optimization enabled
[ 3.620786] ccp 0000:22:00.1: ccp enabled
[ 3.624975] usb 12-3: New USB device found, idVendor=05e3, idProduct=0616, bcdDevice=92.24
[ 3.624977] usb 12-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.624979] usb 12-3: Product: USB3.0 Hub
[ 3.624980] usb 12-3: Manufacturer: GenesysLogic
[ 3.630024] usb 9-6: new full-speed USB device number 3 using xhci_hcd
[ 3.645213] hub 12-3:1.0: USB hub found
[ 3.645479] hub 12-3:1.0: 2 ports detected
[ 3.666261] r8169 0000:46:00.0: enabling device (0000 -> 0003)
[ 3.674696] libphy: r8169: probed
[ 3.674925] r8169 0000:46:00.0 eth0: RTL8125, a8:a1:59:19:ee:6a, XID 609, IRQ 147
[ 3.674927] r8169 0000:46:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[ 3.743386] usb 11-3: new high-speed USB device number 3 using xhci_hcd
[ 3.784825] audit: type=1130 audit(1604837212.773:8): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.797738] usb 9-6: New USB device found, idVendor=8087, idProduct=0029, bcdDevice= 0.01
[ 3.797740] usb 9-6: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.809467] audit: type=1130 audit(1604837212.796:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-9E32\x2d613B comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.854579] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 3.855811] snd_hda_intel 0000:01:00.1: enabling device (0000 -> 0002)
[ 3.855983] snd_hda_intel 0000:01:00.1: Disabling MSI
[ 3.855998] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[ 3.856074] snd_hda_intel 0000:22:00.4: enabling device (0000 -> 0002)
[ 3.857256] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 3.859615] snd_hda_intel 0000:22:00.4: no codecs found!
[ 3.867611] kvm: Nested Virtualization enabled
[ 3.867714] SVM: kvm: Nested Paging enabled
[ 3.867714] SVM: Virtual VMLOAD VMSAVE supported
[ 3.867714] SVM: Virtual GIF supported
[ 3.871118] MCE: In-kernel MCE decoding enabled.
[ 3.874340] EDAC amd64: F17h_M30h detected (node 0).
[ 3.874510] EDAC amd64: Node 0: DRAM ECC disabled.
[ 3.877582] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input3
[ 3.877616] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input4
[ 3.877642] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input5
[ 3.877667] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input6
[ 3.877697] input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input7
[ 3.877722] input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input8
[ 3.880249] Intel(R) Wireless WiFi driver for Linux
[ 3.880249] Copyright(c) 2003- 2015 Intel Corporation
[ 3.880325] iwlwifi 0000:45:00.0: enabling device (0000 -> 0002)
[ 3.885140] iwlwifi 0000:45:00.0: api flags index 2 larger than supported by driver
[ 3.885153] iwlwifi 0000:45:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 68.3.35.22
[ 3.885155] iwlwifi 0000:45:00.0: Found debug destination: EXTERNAL_DRAM
[ 3.885155] iwlwifi 0000:45:00.0: Found debug configuration: 0
[ 3.885402] iwlwifi 0000:45:00.0: loaded firmware version 53.c31ac674.0 cc-a0-53.ucode op_mode iwlmvm
[ 3.885418] iwlwifi 0000:45:00.0: Direct firmware load for iwl-debug-yoyo.bin failed with error -2
[ 3.891829] audit: type=1130 audit(1604837212.880:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.893179] usb 11-3: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=92.24
[ 3.893181] usb 11-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.893182] usb 11-3: Product: USB2.0 Hub
[ 3.893183] usb 11-3: Manufacturer: GenesysLogic
[ 3.933210] hub 11-3:1.0: USB hub found
[ 3.934060] hub 11-3:1.0: 2 ports detected
[ 4.011825] EDAC amd64: F17h_M30h detected (node 0).
[ 4.012001] EDAC amd64: Node 0: DRAM ECC disabled.
[ 4.120027] usb 11-5: new high-speed USB device number 4 using xhci_hcd
[ 4.140895] nct6683: Found NCT6683D or compatible chip at 0x2e:0xa20
[ 4.140955] EDAC amd64: F17h_M30h detected (node 0).
[ 4.141220] EDAC amd64: Node 0: DRAM ECC disabled.
[ 4.266930] EDAC amd64: F17h_M30h detected (node 0).
[ 4.267119] EDAC amd64: Node 0: DRAM ECC disabled.
[ 4.271204] iwlwifi 0000:45:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz, REV=0x340
[ 4.365776] EDAC amd64: F17h_M30h detected (node 0).
[ 4.365985] EDAC amd64: Node 0: DRAM ECC disabled.
[ 4.436012] r8169 0000:46:00.0 enp70s0: renamed from eth0
[ 4.440735] random: crng init done
[ 4.440738] random: 7 urandom warning(s) missed due to ratelimiting
[ 4.440826] iwlwifi 0000:45:00.0: base HW address: 5c:80:b6:45:12:ee
[ 4.477332] thermal thermal_zone0: failed to read out thermal zone (-61)
[ 4.484160] RTL8125 2.5Gbps internal r8169-4600:00: attached PHY driver [RTL8125 2.5Gbps internal] (mii_bus:phy_addr=r8169-4600:00, irq=IGNORE)
[ 4.489870] EDAC amd64: F17h_M30h detected (node 0).
[ 4.490108] EDAC amd64: Node 0: DRAM ECC disabled.
[ 4.571853] r8169 0000:46:00.0 enp70s0: Link is Down
[ 4.572574] atlantic 0000:44:00.0 enp68s0: renamed from eth1
[ 4.590420] iwlwifi 0000:45:00.0 wlp69s0: renamed from wlan0
[ 4.608479] EDAC amd64: F17h_M30h detected (node 0).
[ 4.608675] EDAC amd64: Node 0: DRAM ECC disabled.
[ 4.745415] EDAC amd64: F17h_M30h detected (node 0).
[ 4.745626] EDAC amd64: Node 0: DRAM ECC disabled.
[ 4.891695] EDAC amd64: F17h_M30h detected (node 0).
[ 4.891904] EDAC amd64: Node 0: DRAM ECC disabled.
[ 5.038654] EDAC amd64: F17h_M30h detected (node 0).
[ 5.038870] EDAC amd64: Node 0: DRAM ECC disabled.
[ 5.041824] usb-storage 3-2:1.0: USB Mass Storage device detected
[ 5.042014] scsi host2: usb-storage 3-2:1.0
[ 5.042223] usbcore: registered new interface driver usb-storage
[ 5.044270] hid: raw HID events driver (C) Jiri Kosina
[ 5.046475] usbcore: registered new interface driver uas
[ 5.062883] usbcore: registered new interface driver usbhid
[ 5.062884] usbhid: USB HID core driver
[ 5.070750] input: ASRock LED Controller as /devices/pci0000:40/0000:40:01.1/0000:41:00.0/0000:42:08.0/0000:47:00.1/usb9/9-5/9-5:1.0/0003:26CE:01A2.0001/input/input9
[ 5.126784] hid-generic 0003:26CE:01A2.0001: input,hidraw0: USB HID v1.10 Device [ASRock LED Controller] on usb-0000:47:00.1-5/input0
[ 5.126965] hid-generic 0003:1B1C:0C22.0002: hiddev0,hidraw1: USB HID v1.11 Device [Corsair Inc. H150iRGBPROXT] on usb-0000:47:00.3-2/input0
[ 5.171725] EDAC amd64: F17h_M30h detected (node 0).
[ 5.171950] EDAC amd64: Node 0: DRAM ECC disabled.
[ 5.179839] Bluetooth: Core ver 2.22
[ 5.179877] NET: Registered protocol family 31
[ 5.179878] Bluetooth: HCI device and connection manager initialized
[ 5.179887] Bluetooth: HCI socket layer initialized
[ 5.179890] Bluetooth: L2CAP socket layer initialized
[ 5.179893] Bluetooth: SCO socket layer initialized
[ 5.292962] EDAC amd64: F17h_M30h detected (node 0).
[ 5.293159] EDAC amd64: Node 0: DRAM ECC disabled.
[ 5.294047] usbcore: registered new interface driver btusb
[ 5.296743] Bluetooth: hci0: Firmware revision 0.0 build 188 week 26 2020
[ 5.316935] kauditd_printk_skb: 27 callbacks suppressed
[ 5.316937] audit: type=1130 audit(1604837214.306:38): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.424763] EDAC amd64: F17h_M30h detected (node 0).
[ 5.424980] EDAC amd64: Node 0: DRAM ECC disabled.
[ 5.426637] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 5.426639] Bluetooth: BNEP filters: protocol multicast
[ 5.426645] Bluetooth: BNEP socket layer initialized
[ 5.439101] NET: Registered protocol family 38
[ 5.518717] nvidia-gpu 0000:01:00.3: i2c timeout error e0000000
[ 5.518724] ucsi_ccg 1-0008: i2c_transfer failed -110
[ 5.518728] ucsi_ccg 1-0008: ucsi_ccg_init failed - -110
[ 5.518738] ucsi_ccg: probe of 1-0008 failed with error -110
[ 5.523223] audit: type=1130 audit(1604837214.510:39): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.558527] EDAC amd64: F17h_M30h detected (node 0).
[ 5.558812] EDAC amd64: Node 0: DRAM ECC disabled.
[ 5.704918] EDAC amd64: F17h_M30h detected (node 0).
[ 5.705133] EDAC amd64: Node 0: DRAM ECC disabled.
[ 5.864941] EDAC amd64: F17h_M30h detected (node 0).
[ 5.865162] EDAC amd64: Node 0: DRAM ECC disabled.
[ 6.038529] EDAC amd64: F17h_M30h detected (node 0).
[ 6.038708] EDAC amd64: Node 0: DRAM ECC disabled.
[ 6.050786] scsi 2:0:0:0: Direct-Access SanDisk Cruzer Blade 1.00 PQ: 0 ANSI: 6
[ 6.053254] sd 2:0:0:0: [sda] 30031872 512-byte logical blocks: (15.4 GB/14.3 GiB)
[ 6.053517] sd 2:0:0:0: [sda] Write Protect is off
[ 6.053519] sd 2:0:0:0: [sda] Mode Sense: 43 00 00 00
[ 6.053746] sd 2:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 6.079790] sda: sda1
[ 6.082349] sd 2:0:0:0: [sda] Attached SCSI removable disk
[ 6.153840] audit: type=1100 audit(1604837215.143:40): pid=1645 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 6.153844] audit: type=1101 audit(1604837215.143:41): pid=1645 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 6.154349] audit: type=1103 audit(1604837215.143:42): pid=1645 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 6.172522] audit: type=1130 audit(1604837215.160:43): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@968 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6.181213] audit: type=1101 audit(1604837215.170:44): pid=1649 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6.181218] audit: type=1103 audit(1604837215.170:45): pid=1649 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 6.181277] audit: type=1006 audit(1604837215.170:46): pid=1649 uid=0 old-auid=4294967295 auid=968 tty=(none) old-ses=4294967295 ses=1 res=1
[ 6.182519] audit: type=1105 audit(1604837215.170:47): pid=1649 uid=0 auid=968 ses=1 msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6.190891] EDAC amd64: F17h_M30h detected (node 0).
[ 6.191107] EDAC amd64: Node 0: DRAM ECC disabled.
[ 6.256708] usb 11-3.2: new low-speed USB device number 5 using xhci_hcd
[ 6.318133] EDAC amd64: F17h_M30h detected (node 0).
[ 6.318345] EDAC amd64: Node 0: DRAM ECC disabled.
[ 6.371866] usb 11-3.2: New USB device found, idVendor=04d9, idProduct=4545, bcdDevice= 1.05
[ 6.371869] usb 11-3.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 6.371870] usb 11-3.2: Product: USB Keyboard
[ 6.431391] EDAC amd64: F17h_M30h detected (node 0).
[ 6.431593] EDAC amd64: Node 0: DRAM ECC disabled.
[ 6.472081] input: USB Keyboard as /devices/pci0000:40/0000:40:01.1/0000:41:00.0/0000:42:08.0/0000:47:00.3/usb11/11-3/11-3.2/11-3.2:1.0/0003:04D9:4545.0003/input/input10
[ 6.526832] hid-generic 0003:04D9:4545.0003: input,hidraw2: USB HID v1.10 Keyboard [USB Keyboard] on usb-0000:47:00.3-3.2/input0
[ 6.545233] EDAC amd64: F17h_M30h detected (node 0).
[ 6.545450] EDAC amd64: Node 0: DRAM ECC disabled.
[ 6.548845] input: USB Keyboard Consumer Control as /devices/pci0000:40/0000:40:01.1/0000:41:00.0/0000:42:08.0/0000:47:00.3/usb11/11-3/11-3.2/11-3.2:1.1/0003:04D9:4545.0004/input/input11
[ 6.603464] input: USB Keyboard System Control as /devices/pci0000:40/0000:40:01.1/0000:41:00.0/0000:42:08.0/0000:47:00.3/usb11/11-3/11-3.2/11-3.2:1.1/0003:04D9:4545.0004/input/input12
[ 6.603578] hid-generic 0003:04D9:4545.0004: input,hidraw3: USB HID v1.10 Device [USB Keyboard] on usb-0000:47:00.3-3.2/input1
[ 6.691853] EDAC amd64: F17h_M30h detected (node 0).
[ 6.692072] EDAC amd64: Node 0: DRAM ECC disabled.
[ 6.798498] EDAC amd64: F17h_M30h detected (node 0).
[ 6.798708] EDAC amd64: Node 0: DRAM ECC disabled.
[ 6.884515] EDAC amd64: F17h_M30h detected (node 0).
[ 6.884700] EDAC amd64: Node 0: DRAM ECC disabled.
[ 6.958099] EDAC amd64: F17h_M30h detected (node 0).
[ 6.958300] EDAC amd64: Node 0: DRAM ECC disabled.
[ 7.031287] EDAC amd64: F17h_M30h detected (node 0).
[ 7.031506] EDAC amd64: Node 0: DRAM ECC disabled.
[ 7.091478] EDAC amd64: F17h_M30h detected (node 0).
[ 7.091692] EDAC amd64: Node 0: DRAM ECC disabled.
[ 7.198088] EDAC amd64: F17h_M30h detected (node 0).
[ 7.198304] EDAC amd64: Node 0: DRAM ECC disabled.
[ 7.304923] EDAC amd64: F17h_M30h detected (node 0).
[ 7.305129] EDAC amd64: Node 0: DRAM ECC disabled.
[ 7.411213] EDAC amd64: F17h_M30h detected (node 0).
[ 7.411412] EDAC amd64: Node 0: DRAM ECC disabled.
[ 7.437909] usb 11-5: New USB device found, idVendor=26ce, idProduct=0a01, bcdDevice= 0.04
[ 7.437912] usb 11-5: New USB device strings: Mfr=3, Product=1, SerialNumber=0
[ 7.437914] usb 11-5: Product: USB Audio
[ 7.437916] usb 11-5: Manufacturer: Generic
[ 7.502221] EDAC amd64: F17h_M30h detected (node 0).
[ 7.502425] EDAC amd64: Node 0: DRAM ECC disabled.
[ 7.541530] input: Generic USB Audio Consumer Control as /devices/pci0000:40/0000:40:01.1/0000:41:00.0/0000:42:08.0/0000:47:00.3/usb11/11-5/11-5:1.7/0003:26CE:0A01.0005/input/input13
[ 7.581562] EDAC amd64: F17h_M30h detected (node 0).
[ 7.581730] EDAC amd64: Node 0: DRAM ECC disabled.
[ 7.596795] input: Generic USB Audio as /devices/pci0000:40/0000:40:01.1/0000:41:00.0/0000:42:08.0/0000:47:00.3/usb11/11-5/11-5:1.7/0003:26CE:0A01.0005/input/input14
[ 7.596865] hid-generic 0003:26CE:0A01.0005: input,hiddev1,hidraw4: USB HID v1.11 Device [Generic USB Audio] on usb-0000:47:00.3-5/input7
[ 7.651626] EDAC amd64: F17h_M30h detected (node 0).
[ 7.651841] EDAC amd64: Node 0: DRAM ECC disabled.
[ 7.758092] EDAC amd64: F17h_M30h detected (node 0).
[ 7.758286] EDAC amd64: Node 0: DRAM ECC disabled.
[ 7.838258] EDAC amd64: F17h_M30h detected (node 0).
[ 7.838462] EDAC amd64: Node 0: DRAM ECC disabled.
[ 7.934612] EDAC amd64: F17h_M30h detected (node 0).
[ 7.934963] EDAC amd64: Node 0: DRAM ECC disabled.
[ 8.037695] EDAC amd64: F17h_M30h detected (node 0).
[ 8.038038] EDAC amd64: Node 0: DRAM ECC disabled.
[ 8.144421] EDAC amd64: F17h_M30h detected (node 0).
[ 8.144770] EDAC amd64: Node 0: DRAM ECC disabled.
[ 8.265256] EDAC amd64: F17h_M30h detected (node 0).
[ 8.265458] EDAC amd64: Node 0: DRAM ECC disabled.
[ 8.363836] EDAC amd64: F17h_M30h detected (node 0).
[ 8.364042] EDAC amd64: Node 0: DRAM ECC disabled.
[ 8.465132] EDAC amd64: F17h_M30h detected (node 0).
[ 8.465533] EDAC amd64: Node 0: DRAM ECC disabled.
[ 8.567461] EDAC amd64: F17h_M30h detected (node 0).
[ 8.567663] EDAC amd64: Node 0: DRAM ECC disabled.
[ 8.665789] EDAC amd64: F17h_M30h detected (node 0).
[ 8.665986] EDAC amd64: Node 0: DRAM ECC disabled.
[ 8.759376] mc: Linux media interface: v0.10
[ 8.759416] EDAC amd64: F17h_M30h detected (node 0).
[ 8.759700] EDAC amd64: Node 0: DRAM ECC disabled.
[ 8.820261] EDAC amd64: F17h_M30h detected (node 0).
[ 8.820459] EDAC amd64: Node 0: DRAM ECC disabled.
[ 8.891381] EDAC amd64: F17h_M30h detected (node 0).
[ 8.891585] EDAC amd64: Node 0: DRAM ECC disabled.
[ 8.957848] EDAC amd64: F17h_M30h detected (node 0).
[ 8.958040] EDAC amd64: Node 0: DRAM ECC disabled.
[ 9.011266] EDAC amd64: F17h_M30h detected (node 0).
[ 9.011463] EDAC amd64: Node 0: DRAM ECC disabled.
[ 11.162863] kauditd_printk_skb: 9 callbacks suppressed
[ 11.162865] audit: type=1130 audit(1604837220.150:57): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 11.198476] audit: type=1130 audit(1604837220.186:58): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=colord comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 11.257860] audit: type=1130 audit(1604837220.246:59): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=org.cups.cupsd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 12.082625] usbcore: registered new interface driver snd-usb-audio
[ 14.986199] audit: type=1131 audit(1604837223.973:60): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 35.440002] audit: type=1131 audit(1604837244.426:61): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 35.576789] audit: type=1334 audit(1604837244.566:62): prog-id=10 op=UNLOAD
[ 35.576794] audit: type=1334 audit(1604837244.566:63): prog-id=9 op=UNLOAD
[ 210.570892] audit: type=1100 audit(1604837419.560:64): pid=1928 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="dj343" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 210.572110] audit: type=1101 audit(1604837419.560:65): pid=1928 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="dj343" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 210.572572] audit: type=1103 audit(1604837419.560:66): pid=1928 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="dj343" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 210.572669] audit: type=1006 audit(1604837419.560:67): pid=1928 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
[ 210.591268] audit: type=1130 audit(1604837419.580:68): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 210.597671] audit: type=1101 audit(1604837419.586:69): pid=1932 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="dj343" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 210.597700] audit: type=1103 audit(1604837419.586:70): pid=1932 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="dj343" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 210.597756] audit: type=1006 audit(1604837419.586:71): pid=1932 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=3 res=1
[ 210.598732] audit: type=1105 audit(1604837419.586:72): pid=1932 uid=0 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="dj343" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 210.607078] audit: type=1334 audit(1604837419.593:73): prog-id=14 op=LOAD
[ 211.824207] input: MX Master Keyboard as /devices/virtual/misc/uhid/0005:046D:B017.0006/input/input15
[ 211.824368] input: MX Master Mouse as /devices/virtual/misc/uhid/0005:046D:B017.0006/input/input16
[ 211.824470] hid-generic 0005:046D:B017.0006: input,hidraw5: BLUETOOTH HID v0.17 Keyboard [MX Master] on 5c:80:b6:45:12:f2
[ 211.830793] mousedev: PS/2 mouse device common for all mice
[ 211.923084] snd_hda_intel 0000:01:00.1: IRQ timing workaround is activated for card #0. Suggest a bigger bdl_pos_adj.
[ 212.066643] fuse: init (API version 7.31)
[ 212.752996] Bluetooth: RFCOMM TTY layer initialized
[ 212.753004] Bluetooth: RFCOMM socket layer initialized
[ 212.753008] Bluetooth: RFCOMM ver 1.11
[ 214.660902] wlp69s0: authenticate with 80:20:da:7d:a8:d8
[ 214.664256] wlp69s0: send auth to 80:20:da:7d:a8:d8 (try 1/3)
[ 214.689675] wlp69s0: authenticated
[ 214.690017] wlp69s0: associate with 80:20:da:7d:a8:d8 (try 1/3)
[ 214.691055] wlp69s0: RX AssocResp from 80:20:da:7d:a8:d8 (capab=0x11 status=0 aid=2)
[ 214.693509] wlp69s0: associated
[ 214.712501] IPv6: ADDRCONF(NETDEV_CHANGE): wlp69s0: link becomes ready
[ 214.784528] wlp69s0: Limiting TX power to 30 (30 - 0) dBm as advertised by 80:20:da:7d:a8:d8
[ 220.927883] kauditd_printk_skb: 12 callbacks suppressed
[ 220.927885] audit: type=1131 audit(1604837429.455:86): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@968 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 220.937380] audit: type=1131 audit(1604837429.465:87): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@968 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 224.983486] audit: type=1131 audit(1604837433.511:88): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 241.958061] audit: type=1131 audit(1604837450.485:89): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 242.090094] audit: type=1334 audit(1604837450.618:90): prog-id=16 op=UNLOAD
[ 242.090096] audit: type=1334 audit(1604837450.618:91): prog-id=15 op=UNLOAD
[ 243.797973] audit: type=1131 audit(1604837452.325:92): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 244.029159] input: MX Master Keyboard as /devices/virtual/misc/uhid/0005:046D:B017.0007/input/input18
[ 244.029249] input: MX Master Mouse as /devices/virtual/misc/uhid/0005:046D:B017.0007/input/input19
[ 244.029371] hid-generic 0005:046D:B017.0007: input,hidraw5: BLUETOOTH HID v0.17 Keyboard [MX Master] on 5c:80:b6:45:12:f2
[ 917.193284] audit: type=1130 audit(1604838125.727:93): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 917.193289] audit: type=1131 audit(1604838125.727:94): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1843.295673] audit: type=1100 audit(1604839051.832:95): pid=7300 uid=1000 auid=1000 ses=2 msg='op=PAM:unix_chkpwd acct="dj343" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
[ 2102.476759] audit: type=1100 audit(1604839311.016:96): pid=8015 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="dj343" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 2102.478229] audit: type=1101 audit(1604839311.016:97): pid=8015 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_permit,pam_time acct="dj343" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 2102.478558] audit: type=1110 audit(1604839311.020:98): pid=8015 uid=0 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 2102.480746] audit: type=1105 audit(1604839311.020:99): pid=8015 uid=0 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 2102.502576] audit: type=1106 audit(1604839311.043:100): pid=8015 uid=0 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 2102.502609] audit: type=1104 audit(1604839311.043:101): pid=8015 uid=0 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 2107.780762] audit: type=1101 audit(1604839316.320:102): pid=8071 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_permit,pam_time acct="dj343" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 2107.780958] audit: type=1110 audit(1604839316.320:103): pid=8071 uid=0 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 2107.783127] audit: type=1105 audit(1604839316.323:104): pid=8071 uid=0 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 2107.795210] audit: type=1106 audit(1604839316.336:105): pid=8071 uid=0 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 2107.795243] audit: type=1104 audit(1604839316.336:106): pid=8071 uid=0 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 2202.345486] audit: type=1101 audit(1604839410.887:107): pid=8831 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_permit,pam_time acct="dj343" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 2207.481996] audit: type=1101 audit(1604839416.024:108): pid=8882 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_permit,pam_time acct="dj343" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 2207.482204] audit: type=1110 audit(1604839416.024:109): pid=8882 uid=0 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 2207.484326] audit: type=1105 audit(1604839416.024:110): pid=8882 uid=0 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
