So, I am currently running kernel 5.7 because, whenever I suspend my PC on 5.8 or later, only one of my displays (my 1080p one on display port) turns back on. To get the other one (my 2k one on HDMI) up and running, I have to unplug and replug it in. I am on XFCE and Nvidia graphics, what can I do?
More info:
Kernel: 5.7.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Desktop System: Micro-Star product: MS-7B51 v: 1.0 serial: <filter>
Mobo: Micro-Star model: MPG Z390 GAMING PLUS (MS-7B51) v: 1.0
serial: <filter> UEFI: American Megatrends v: 1.10 date: 08/22/2018
Device-1: hidpp_battery_0 model: Logitech K520 serial: <filter>
charge: 70% (should be ignored) rechargeable: yes status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse M510
status: Discharging
Topology: 6-Core model: Intel Core i7-8700K bits: 64 type: MT MCP
arch: Kaby Lake rev: A L2 cache: 12.0 MiB
bogomips: 88824
Speed: 4394 MHz min/max: 800/4700 MHz Core speeds (MHz): 1: 4400 2: 4400
3: 4400 4: 4400 5: 4400 6: 4401 7: 4400 8: 4400 9: 4400 10: 4400 11: 4400
12: 4400
Device-1: NVIDIA TU106 [GeForce RTX 2070 Rev. A] vendor: Micro-Star MSI
driver: nvidia v: 455.28 bus ID: 01:00.0 chip ID: 10de:1f07
Display: x11 server: X.Org 1.20.9 driver: nvidia resolution: 1: 2560x1440
2: 1920x1080~75Hz s-dpi: 96
OpenGL: renderer: GeForce RTX 2070/PCIe/SSE2 v: 4.6.0 NVIDIA 455.28
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:a348
Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:10f9
Device-3: JMTek LLC. JOUNIVO JV605PRO type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-2:3 chip ID: 0c76:605d
serial: <filter>
Sound Server: ALSA v: k5.7.19-2-MANJARO
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: 3.2.6-k port: efa0 bus ID: 00:1f.6 chip ID: 8086:15bc
Device-2: Ralink RT5572 Wireless Adapter type: USB driver: rt2800usb
bus ID: 1-9:8 chip ID: 148f:5572 serial: <filter>
IF: wlp0s20f0u9 state: up mac: <filter>
Local Storage: total: 1.44 TiB used: 436.70 GiB (29.7%)
ID-1: /dev/sda vendor: SanDisk model: SDSSDH31000G size: 931.51 GiB
speed: 6.0 Gb/s serial: <filter> rev: 70RL scheme: GPT
ID-2: /dev/sdb vendor: SanDisk model: SDSSDH3500G size: 465.76 GiB
ID-3: /dev/sdc type: USB model: N/A size: 14.65 GiB serial: <filter>
rev: 2.00 scheme: MBR
ID-4: /dev/sdd type: USB vendor: Generic model: Flash Disk size: 58.59 GiB
serial: <filter> rev: 8.07 scheme: MBR
ID-1: / size: 34.18 GiB used: 9.45 GiB (27.7%) fs: btrfs dev: /dev/sda2
ID-2: /home size: 874.43 GiB used: 405.13 GiB (46.3%) fs: ext4
dev: /dev/sda3
ID-1: swap-1 type: partition size: 7.82 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda4
System Temperatures: cpu: 32.0 C mobo: N/A gpu: nvidia temp: 39 C
Processes: 330 Uptime: 5m Memory: 15.58 GiB used: 1.83 GiB (11.8%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: 1148 pacman: 1137
flatpak: 11 Shell: Zsh v: 5.8 running in: xfce4-terminal inxi: 3.1.05
