here is full message, nothing new after fold/unfold.
I tried it multiple times, I thought it worked once, but I lost results of that try. It was probably just a random other thing that appears sometimes after an event(?)
[ 1.290450] usb 1-2: Manufacturer: Logitech
[ 1.293679] usb 3-2: New USB device found, idVendor=0bda, idProduct=b00b, bcdDevice= 1.10
[ 1.293681] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.293683] usb 3-2: Product: Bluetooth Radio
[ 1.293684] usb 3-2: Manufacturer: Realtek
[ 1.293685] usb 3-2: SerialNumber: 00e04c000001
[ 1.376960] acpi_cpufreq: overriding BIOS provided _PSD data
[ 1.399735] snd_pci_acp3x 0000:04:00.5: enabling device (0000 -> 0002)
[ 1.399922] snd_pci_acp3x 0000:04:00.5: Invalid ACP audio mode : 1
[ 1.402299] snd_rn_pci_acp3x: probe of 0000:04:00.5 failed with error -22
[ 1.424312] usb 1-4: new full-speed USB device number 3 using xhci_hcd
[ 1.431986] acpi-tad ACPI000E:00: Missing _PRW
[ 1.434261] ccp 0000:04:00.2: enabling device (0000 -> 0002)
[ 1.434338] input: HP Wireless hotkeys as /devices/virtual/input/input4
[ 1.434740] random: mktemp: uninitialized urandom read (6 bytes read)
[ 1.436470] hid: raw HID events driver (C) Jiri Kosina
[ 1.440699] hp_accel: laptop model unknown, using default axes configuration
[ 1.444456] ccp 0000:04:00.2: ccp enabled
[ 1.444465] ccp 0000:04:00.2: psp: unable to access the device: you might be running a broken BIOS.
[ 1.444578] ACPI: EC: event unblocked
[ 1.444583] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 1.444585] ACPI: \_SB_.PCI0.SBRG.EC0_: Boot DSDT EC initialization complete
[ 1.444587] ACPI: \_SB_.PCI0.SBRG.EC0_: EC: Used to handle transactions and events
[ 1.444711] i2c_hid i2c-ELAN2514:00: HID over i2c has not been provided an Int IRQ
[ 1.444749] i2c_hid: probe of i2c-ELAN2514:00 failed with error -22
[ 1.444835] i2c_hid i2c-SYNA328F:01: HID over i2c has not been provided an Int IRQ
[ 1.444941] i2c_hid: probe of i2c-SYNA328F:01 failed with error -22
[ 1.459238] tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xd7d11000-0xd7d11fff flags 0x200] vs d7d11000 4000
[ 1.459249] tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xd7d15000-0xd7d15fff flags 0x200] vs d7d15000 4000
[ 1.472115] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 1.477788] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 1.511145] lis3lv02d: unknown sensor type 0x0
[ 1.511157] hp_accel: probe of HPQ6007:00 failed with error -22
[ 1.514134] acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 1.514255] acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 1.514338] tsc: Refined TSC clocksource calibration: 2096.062 MHz
[ 1.514348] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x1e36a88731c, max_idle_ns: 440795269020 ns
[ 1.514391] clocksource: Switched to clocksource tsc
[ 1.514430] acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 1.518437] ACPI: AC Adapter [ADP1] (off-line)
[ 1.534239] battery: ACPI: Battery Slot [BAT0] (battery present)
[ 1.572464] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0
[ 1.572468] piix4_smbus 0000:00:14.0: Using register 0x02 for SMBus port selection
[ 1.572609] piix4_smbus 0000:00:14.0: Auxiliary SMBus Host Controller at 0xb20
[ 1.576094] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
[ 1.576282] sp5100-tco sp5100-tco: Using 0xfed80b00 for watchdog MMIO address
[ 1.576294] sp5100-tco sp5100-tco: Watchdog hardware is disabled
[ 1.583480] usb 1-4: New USB device found, idVendor=06cb, idProduct=00c9, bcdDevice= 0.00
[ 1.583484] usb 1-4: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[ 1.583487] usb 1-4: SerialNumber: 873d5c2ae505
[ 1.632464] snd_hda_intel 0000:04:00.1: enabling device (0000 -> 0002)
[ 1.632662] snd_hda_intel 0000:04:00.1: Handle vga_switcheroo audio client
[ 1.632942] snd_hda_intel 0000:04:00.6: enabling device (0000 -> 0002)
[ 1.651665] input: HD-Audio Generic HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:08.1/0000:04:00.1/sound/card0/input5
[ 1.668347] input: PC Speaker as /devices/platform/pcspkr/input/input6
[ 1.751143] RAPL PMU: API unit is 2^-32 Joules, 1 fixed counters, 163840 ms ovfl timer
[ 1.751146] RAPL PMU: hw unit of domain package 2^-16 Joules
[ 1.755371] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC285: line_outs=1 (0x17/0x0/0x0/0x0/0x0) type:speaker
[ 1.755378] snd_hda_codec_realtek hdaudioC1D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 1.755382] snd_hda_codec_realtek hdaudioC1D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 1.755385] snd_hda_codec_realtek hdaudioC1D0: mono: mono_out=0x0
[ 1.755387] snd_hda_codec_realtek hdaudioC1D0: inputs:
[ 1.755391] snd_hda_codec_realtek hdaudioC1D0: Mic=0x19
[ 1.755394] snd_hda_codec_realtek hdaudioC1D0: Internal Mic=0x12
[ 1.761022] rtw_8822be 0000:02:00.0: enabling device (0000 -> 0003)
[ 1.761719] cryptd: max_cpu_qlen set to 1000
[ 1.761891] rtw_8822be 0000:02:00.0: Firmware version 27.2.0, H2C version 13
[ 1.775455] AVX2 version of gcm_enc/dec engaged.
[ 1.775457] AES CTR mode by8 optimization enabled
[ 1.840798] input: HD-Audio Generic Mic as /devices/pci0000:00/0000:00:08.1/0000:04:00.6/sound/card1/input7
[ 1.840901] input: HD-Audio Generic Headphone as /devices/pci0000:00/0000:00:08.1/0000:04:00.6/sound/card1/input8
[ 2.026022] kvm: Nested Virtualization enabled
[ 2.026057] SVM: kvm: Nested Paging enabled
[ 2.026058] SVM: Virtual VMLOAD VMSAVE supported
[ 2.026058] SVM: Virtual GIF supported
[ 2.032361] MCE: In-kernel MCE decoding enabled.
[ 2.044380] EDAC amd64: F17h_M10h detected (node 0).
[ 2.044473] EDAC amd64: Node 0: DRAM ECC disabled.
[ 2.115539] EDAC amd64: F17h_M10h detected (node 0).
[ 2.115625] EDAC amd64: Node 0: DRAM ECC disabled.
[ 2.122147] input: HP WMI hotkeys as /devices/virtual/input/input9
[ 2.154648] rtw_8822be 0000:02:00.0 wlo1: renamed from wlan0
[ 2.209676] acer_wmi: Acer Laptop ACPI-WMI Extras
[ 2.210238] EDAC amd64: F17h_M10h detected (node 0).
[ 2.210321] EDAC amd64: Node 0: DRAM ECC disabled.
[ 2.217653] [drm] amdgpu kernel modesetting enabled.
[ 2.234426] amdgpu: Topology: Add APU node [0x0:0x0]
[ 2.234604] checking generic (e0000000 7f0000) vs hw (e0000000 10000000)
[ 2.234606] fb0: switching to amdgpudrmfb from EFI VGA
[ 2.234723] amdgpu 0000:04:00.0: vgaarb: deactivate vga console
[ 2.234805] amdgpu 0000:04:00.0: enabling device (0006 -> 0007)
[ 2.235015] [drm] initializing kernel modesetting (RAVEN 0x1002:0x15D8 0x103C:0x85DE 0xC2).
[ 2.235020] amdgpu 0000:04:00.0: amdgpu: Trusted Memory Zone (TMZ) feature disabled as experimental (default)
[ 2.245057] [drm] register mmio base: 0xFE400000
[ 2.245061] [drm] register mmio size: 524288
[ 2.245089] [drm] add ip block number 0 <soc15_common>
[ 2.245090] [drm] add ip block number 1 <gmc_v9_0>
[ 2.245092] [drm] add ip block number 2 <vega10_ih>
[ 2.245093] [drm] add ip block number 3 <psp>
[ 2.245095] [drm] add ip block number 4 <gfx_v9_0>
[ 2.245096] [drm] add ip block number 5 <sdma_v4_0>
[ 2.245098] [drm] add ip block number 6 <powerplay>
[ 2.245100] [drm] add ip block number 7 <dm>
[ 2.245101] [drm] add ip block number 8 <vcn_v1_0>
[ 2.246680] amdgpu: ATOM BIOS: 113-PICASSO-114
[ 2.247062] [drm] VCN decode is enabled in VM mode
[ 2.247064] [drm] VCN encode is enabled in VM mode
[ 2.247065] [drm] JPEG decode is enabled in VM mode
[ 2.247139] [drm] vm size is 262144 GB, 4 levels, block size is 9-bit, fragment size is 9-bit
[ 2.247160] amdgpu 0000:04:00.0: amdgpu: VRAM: 2048M 0x000000F400000000 - 0x000000F47FFFFFFF (2048M used)
[ 2.247163] amdgpu 0000:04:00.0: amdgpu: GART: 1024M 0x0000000000000000 - 0x000000003FFFFFFF
[ 2.247165] amdgpu 0000:04:00.0: amdgpu: AGP: 267419648M 0x000000F800000000 - 0x0000FFFFFFFFFFFF
[ 2.247171] [drm] Detected VRAM RAM=2048M, BAR=2048M
[ 2.247174] [drm] RAM width 128bits DDR4
[ 2.249579] [TTM] Zone kernel: Available graphics memory: 3010256 KiB
[ 2.249582] [TTM] Zone dma32: Available graphics memory: 2097152 KiB
[ 2.249583] [TTM] Initializing pool allocator
[ 2.249590] [TTM] Initializing DMA pool allocator
[ 2.249735] [drm] amdgpu: 2048M of VRAM memory ready
[ 2.249741] [drm] amdgpu: 3072M of GTT memory ready.
[ 2.249746] [drm] GART: num cpu pages 262144, num gpu pages 262144
[ 2.250049] [drm] PCIE GART of 1024M enabled (table at 0x000000F400900000).
[ 2.259966] amdgpu: hwmgr_sw_init smu backed is smu10_smu
[ 2.261843] [drm] Found VCN firmware Version ENC: 1.12 DEC: 2 VEP: 0 Revision: 5
[ 2.261876] [drm] PSP loading VCN firmware
[ 2.284238] [drm] reserve 0x400000 from 0xf47fc00000 for PSP TMR
[ 2.308410] loop: module loaded
[ 2.321931] EDAC amd64: F17h_M10h detected (node 0).
[ 2.322026] EDAC amd64: Node 0: DRAM ECC disabled.
[ 2.404384] random: crng init done
[ 2.404387] random: 7 urandom warning(s) missed due to ratelimiting
[ 2.432511] EDAC amd64: F17h_M10h detected (node 0).
[ 2.432616] EDAC amd64: Node 0: DRAM ECC disabled.
[ 2.433036] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.508614] EDAC amd64: F17h_M10h detected (node 0).
[ 2.508705] EDAC amd64: Node 0: DRAM ECC disabled.
[ 2.514339] amdgpu 0000:04:00.0: amdgpu: RAS: optional ras ta ucode is not available
[ 2.539923] [drm] kiq ring mec 2 pipe 1 q 0
[ 2.541431] [drm] DM_PPLIB: values for F clock
[ 2.541434] [drm] DM_PPLIB: 400000 in kHz, 2924 in mV
[ 2.541435] [drm] DM_PPLIB: 933000 in kHz, 3249 in mV
[ 2.541435] [drm] DM_PPLIB: 1067000 in kHz, 3924 in mV
[ 2.541436] [drm] DM_PPLIB: 1200000 in kHz, 4074 in mV
[ 2.541438] [drm] DM_PPLIB: values for DCF clock
[ 2.541439] [drm] DM_PPLIB: 300000 in kHz, 2924 in mV
[ 2.541439] [drm] DM_PPLIB: 600000 in kHz, 3249 in mV
[ 2.541440] [drm] DM_PPLIB: 626000 in kHz, 3924 in mV
[ 2.541440] [drm] DM_PPLIB: 654000 in kHz, 4074 in mV
[ 2.541856] [drm] Display Core initialized with v3.2.95!
[ 2.545692] snd_hda_intel 0000:04:00.1: bound 0000:04:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
[ 2.575066] EDAC amd64: F17h_M10h detected (node 0).
[ 2.575190] EDAC amd64: Node 0: DRAM ECC disabled.
[ 2.596635] [drm] VCN decode and encode initialized successfully(under DPG Mode).
[ 2.599407] kfd kfd: Allocated 3969056 bytes on gart
[ 2.600909] amdgpu: Topology: Add APU node [0x15d8:0x1002]
[ 2.600915] kfd kfd: added device 1002:15d8
[ 2.600921] amdgpu 0000:04:00.0: amdgpu: SE 1, SH per SE 1, CU per SH 11, active_cu_number 8
[ 2.603336] [drm] fb mappable at 0x19FBCA000
[ 2.603338] [drm] vram apper at 0x19F000000
[ 2.603339] [drm] size 8294400
[ 2.603340] [drm] fb depth is 24
[ 2.603341] [drm] pitch is 7680
[ 2.603480] fbcon: amdgpudrmfb (fb0) is primary device
[ 2.603482] fbcon: Deferring console take-over
[ 2.603485] amdgpu 0000:04:00.0: [drm] fb0: amdgpudrmfb frame buffer device
[ 2.641219] amdgpu 0000:04:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
[ 2.641224] amdgpu 0000:04:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
[ 2.641227] amdgpu 0000:04:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
[ 2.641231] amdgpu 0000:04:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
[ 2.641234] amdgpu 0000:04:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
[ 2.641236] amdgpu 0000:04:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
[ 2.641239] amdgpu 0000:04:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
[ 2.641242] amdgpu 0000:04:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
[ 2.641245] amdgpu 0000:04:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
[ 2.641248] amdgpu 0000:04:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
[ 2.641250] amdgpu 0000:04:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 1
[ 2.641253] amdgpu 0000:04:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 1
[ 2.641256] amdgpu 0000:04:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 1
[ 2.641259] amdgpu 0000:04:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 1
[ 2.641262] amdgpu 0000:04:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 1
[ 2.642049] EDAC amd64: F17h_M10h detected (node 0).
[ 2.642183] EDAC amd64: Node 0: DRAM ECC disabled.
[ 2.667697] [drm] Initialized amdgpu 3.39.0 20150101 for 0000:04:00.0 on minor 0
[ 2.694681] rtw_8822be 0000:02:00.0: start vif a4:fc:77:52:2a:8b on port 0
[ 2.694829] ------------[ cut here ]------------
[ 2.694970] WARNING: CPU: 5 PID: 726 at drivers/gpu/drm/amd/amdgpu/../display/dc/core/dc_link.c:2548 dc_link_set_backlight_level+0x8a/0xf0 [amdgpu]
[ 2.694971] Modules linked in: squashfs loop hp_wmi wmi_bmof sparse_keymap edac_mce_amd kvm_amd amdgpu kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel aesni_intel nls_iso8859_1 crypto_simd rtw88_8822be nls_cp437 cryptd rtw88_8822b glue_helper snd_hda_codec_realtek rtw88_pci vfat rapl input_leds fat snd_hda_codec_generic rtw88_core pcspkr ledtrig_audio snd_hda_codec_hdmi k10temp snd_hda_intel gpu_sched snd_intel_dspcfg mac80211 i2c_algo_bit sp5100_tco ucsi_acpi typec_ucsi i2c_piix4 ttm typec snd_hda_codec wmi snd_hda_core drm_kms_helper battery ac evdev mac_hid snd_hwdep cec tpm_crb cfg80211 snd_pcm tpm_tis rc_core tpm_tis_core i2c_hid syscopyarea hp_accel sysfillrect tpm sysimgblt snd_timer lis3lv02d fb_sys_fops hid hp_wireless pinctrl_amd snd acpi_tad ccp snd_rn_pci_acp3x
[ 2.695028] fbcon: Taking over console
[ 2.695028] soundcore snd_pci_acp3x rng_core rfkill libarc4 acpi_cpufreq drm msr fuse crypto_user agpgart ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 rtsx_pci_sdmmc serio_raw mmc_core atkbd libps2 xhci_pci crc32c_intel xhci_hcd rtsx_pci i8042 serio
[ 2.695048] CPU: 5 PID: 726 Comm: systemd-backlig Not tainted 5.9.16-1-MANJARO #1
[ 2.695049] Hardware name: HP HP ENVY x360 Convertible 13-ar0xxx/85DE, BIOS F.19 12/26/2019
[ 2.695152] RIP: 0010:dc_link_set_backlight_level+0x8a/0xf0 [amdgpu]
[ 2.695155] Code: 70 03 00 00 31 c0 48 8d 96 c0 01 00 00 48 8b 0a 48 85 c9 74 06 48 3b 59 08 74 20 83 c0 01 48 81 c2 d8 04 00 00 83 f8 06 75 e3 <0f> 0b 45 31 e4 5b 44 89 e0 5d 41 5c 41 5d 41 5e c3 48 98 48 69 c0
[ 2.695156] RSP: 0018:ffffb52e01e43df0 EFLAGS: 00010246
[ 2.695158] RAX: 0000000000000006 RBX: ffff956d12088c00 RCX: 0000000000000000
[ 2.695159] RDX: ffff956d157c1ed0 RSI: ffff956d157c0000 RDI: 0000000000000000
[ 2.695160] RBP: ffff956d03fc0000 R08: 0000000000000046 R09: 000000000000000a
[ 2.695161] R10: 000000000000000a R11: f000000000000000 R12: 0000000000004d01
[ 2.695162] R13: 0000000000000000 R14: 0000000000004d8f R15: ffff956d0b2c9460
[ 2.695164] FS: 00007f77e9603a40(0000) GS:ffff956d18b40000(0000) knlGS:0000000000000000
[ 2.695165] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 2.695166] CR2: 000056449dc6dc78 CR3: 0000000181caa000 CR4: 00000000003506e0
[ 2.695168] Call Trace:
[ 2.695301] amdgpu_dm_backlight_update_status+0xb4/0xc0 [amdgpu]
[ 2.695312] backlight_device_set_brightness+0x7e/0x130
[ 2.695316] brightness_store+0x63/0x80
[ 2.695323] kernfs_fop_write+0xce/0x1b0
[ 2.695329] vfs_write+0xc7/0x210
[ 2.695332] ksys_write+0x67/0xe0
[ 2.695338] do_syscall_64+0x33/0x40
[ 2.695342] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 2.695346] RIP: 0033:0x7f77e9f740f7
[ 2.695348] Code: 0d 00 f7 d8 64 89 02 48 c7 c0 ff ff ff ff eb b7 0f 1f 00 f3 0f 1e fa 64 8b 04 25 18 00 00 00 85 c0 75 10 b8 01 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 51 c3 48 83 ec 28 48 89 54 24 18 48 89 74 24
[ 2.695349] RSP: 002b:00007ffc510ac568 EFLAGS: 00000246 ORIG_RAX: 0000000000000001
[ 2.695351] RAX: ffffffffffffffda RBX: 0000000000000003 RCX: 00007f77e9f740f7
[ 2.695352] RDX: 0000000000000003 RSI: 00007ffc510ac650 RDI: 0000000000000004
[ 2.695353] RBP: 00007ffc510ac650 R08: 0000000000000000 R09: 00007ffc510ac686
[ 2.695354] R10: 0000000000000000 R11: 0000000000000246 R12: 0000000000000003
[ 2.695355] R13: 000056449dc573c0 R14: 0000000000000003 R15: 00007f77ea046700
[ 2.695358] ---[ end trace 099989ed35f893c0 ]---
[ 2.695989] rtw_8822be 0000:02:00.0: stop vif a4:fc:77:52:2a:8b on port 0
[ 2.713237] Console: switching to colour frame buffer device 240x67
[ 2.810039] Bluetooth: Core ver 2.22
[ 2.810081] NET: Registered protocol family 31
[ 2.810083] Bluetooth: HCI device and connection manager initialized
[ 2.810090] Bluetooth: HCI socket layer initialized
[ 2.810094] Bluetooth: L2CAP socket layer initialized
[ 2.810102] Bluetooth: SCO socket layer initialized
[ 2.824984] usbcore: registered new interface driver btusb
[ 2.826723] Bluetooth: hci0: RTL: examining hci_ver=07 hci_rev=000b lmp_ver=07 lmp_subver=8822
[ 2.826782] usbcore: registered new interface driver usbhid
[ 2.826784] usbhid: USB HID core driver
[ 2.830062] Bluetooth: hci0: RTL: rom_version status=0 version=2
[ 2.830067] Bluetooth: hci0: RTL: loading rtl_bt/rtl8822b_fw.bin
[ 2.830668] Bluetooth: hci0: RTL: loading rtl_bt/rtl8822b_config.bin
[ 2.830844] Bluetooth: hci0: RTL: cfg_sz 14, total sz 20270
[ 2.838686] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.0/0003:046D:C539.0001/input/input10
[ 2.868174] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 2.868177] Bluetooth: BNEP filters: protocol multicast
[ 2.868187] Bluetooth: BNEP socket layer initialized
[ 2.897978] hid-generic 0003:046D:C539.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:04:00.3-2/input0
[ 2.898253] input: Logitech USB Receiver Mouse as /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1/0003:046D:C539.0002/input/input11
[ 2.898340] input: Logitech USB Receiver Consumer Control as /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1/0003:046D:C539.0002/input/input12
[ 2.954556] input: Logitech USB Receiver System Control as /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.1/0003:046D:C539.0002/input/input13
[ 2.954839] hid-generic 0003:046D:C539.0002: input,hiddev0,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:04:00.3-2/input1
[ 2.955278] hid-generic 0003:046D:C539.0003: hiddev1,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:04:00.3-2/input2
[ 3.059376] logitech-djreceiver 0003:046D:C539.0001: hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:04:00.3-2/input0
[ 3.174757] rtw_8822be 0000:02:00.0: start vif 46:57:48:69:26:49 on port 0
[ 3.269039] logitech-djreceiver 0003:046D:C539.0002: hiddev0,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:04:00.3-2/input1
[ 3.324876] logitech-djreceiver 0003:046D:C539.0003: hiddev1,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:04:00.3-2/input2
[ 3.385489] logitech-djreceiver 0003:046D:C539.0003: device of type eQUAD Lightspeed 1 (0x0c) connected on slot 1
[ 3.386346] input: Logitech Wireless Mouse PID:4085 Keyboard as /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.2/0003:046D:C539.0003/0003:046D:4085.0004/input/input15
[ 3.386693] input: Logitech Wireless Mouse PID:4085 Mouse as /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.2/0003:046D:C539.0003/0003:046D:4085.0004/input/input16
[ 3.386853] hid-generic 0003:046D:4085.0004: input,hidraw3: USB HID v1.11 Keyboard [Logitech Wireless Mouse PID:4085] on usb-0000:04:00.3-2/input2:1
[ 3.399045] mousedev: PS/2 mouse device common for all mice
[ 3.557050] [drm] Cannot allocate secure buffer since TMZ is disabled
[ 3.619666] input: Logitech G604 as /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-2/1-2:1.2/0003:046D:C539.0003/0003:046D:4085.0004/input/input20
[ 3.619955] logitech-hidpp-device 0003:046D:4085.0004: input,hidraw3: USB HID v1.11 Keyboard [Logitech G604 ] on usb-0000:04:00.3-2/input2:1
[ 3.735813] Bluetooth: hci0: RTL: fw version 0xab6b705c
[ 3.862583] NET: Registered protocol family 38
[ 4.962097] rfkill: input handler disabled
[ 5.396653] usb 1-4: reset full-speed USB device number 3 using xhci_hcd
[ 5.551710] kauditd_printk_skb: 68 callbacks suppressed
[ 5.551714] audit: type=1130 audit(1619447297.499:79): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.687320] audit: type=1130 audit(1619447297.632:80): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=colord comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7.474325] audit: type=1131 audit(1619447299.419:81): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7.621569] rtw_8822be 0000:02:00.0: stop vif 46:57:48:69:26:49 on port 0
[ 7.841087] audit: type=1131 audit(1619447299.789:82): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 8.098217] rtw_8822be 0000:02:00.0: start vif a4:fc:77:52:2a:8b on port 0
[ 11.782444] input: G604 LIGHTSPEED Keyboard as /devices/virtual/misc/uhid/0005:046D:B024.0005/input/input21
[ 11.782611] input: G604 LIGHTSPEED Mouse as /devices/virtual/misc/uhid/0005:046D:B024.0005/input/input22
[ 11.782775] input: G604 LIGHTSPEED Consumer Control as /devices/virtual/misc/uhid/0005:046D:B024.0005/input/input23
[ 11.782881] hid-generic 0005:046D:B024.0005: input,hidraw4: BLUETOOTH HID v0.14 Keyboard [G604 LIGHTSPEED] on a4:fc:77:52:2a:8c
[ 12.185717] audit: type=1131 audit(1619447304.132:83): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 12.258949] wlo1: authenticate with f8:18:97:6a:d5:9e
[ 12.787727] wlo1: send auth to f8:18:97:6a:d5:9e (try 1/3)
[ 12.796102] wlo1: authenticated
[ 12.800988] wlo1: associate with f8:18:97:6a:d5:9e (try 1/3)
[ 12.806515] wlo1: RX AssocResp from f8:18:97:6a:d5:9e (capab=0x411 status=0 aid=4)
[ 12.806539] rtw_8822be 0000:02:00.0: sta f8:18:97:6a:d5:9e joined with macid 0
[ 12.806803] wlo1: associated
[ 12.861572] IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
[ 12.904814] audit: type=1130 audit(1619447304.852:84): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 17.370560] audit: type=1100 audit(1619447309.315:85): pid=1480 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="joel" exe="/usr/lib/gdm-session-worker" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[ 17.373150] audit: type=1101 audit(1619447309.319:86): pid=1480 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="joel" exe="/usr/lib/gdm-session-worker" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[ 17.374531] audit: type=1103 audit(1619447309.322:87): pid=1480 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="joel" exe="/usr/lib/gdm-session-worker" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[ 17.386711] audit: type=1006 audit(1619447309.332:88): pid=1480 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=3 res=1
[ 17.417678] audit: type=1130 audit(1619447309.362:89): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 17.425915] audit: type=1101 audit(1619447309.372:90): pid=1514 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="joel" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 17.425924] audit: type=1103 audit(1619447309.372:91): pid=1514 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="joel" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 17.425982] audit: type=1006 audit(1619447309.372:92): pid=1514 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=4 res=1
[ 17.427990] audit: type=1105 audit(1619447309.375:93): pid=1514 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="joel" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 17.437457] audit: type=1334 audit(1619447309.382:94): prog-id=16 op=LOAD
[ 17.907230] rfkill: input handler enabled
[ 19.672308] Bluetooth: RFCOMM TTY layer initialized
[ 19.672317] Bluetooth: RFCOMM socket layer initialized
[ 19.672326] Bluetooth: RFCOMM ver 1.11
[ 20.265063] rfkill: input handler disabled
[ 23.184079] kauditd_printk_skb: 11 callbacks suppressed
[ 23.184083] audit: type=1131 audit(1619447315.129:106): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 32.640500] audit: type=1131 audit(1619447324.015:107): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 32.652266] audit: type=1131 audit(1619447324.028:108): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 36.205674] audit: type=1131 audit(1619447327.581:109): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 38.802552] audit: type=1334 audit(1619447330.175:110): prog-id=17 op=LOAD
[ 38.802558] audit: type=1334 audit(1619447330.175:111): prog-id=18 op=LOAD
[ 38.906362] audit: type=1130 audit(1619447330.281:112): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 43.740031] input: G604 LIGHTSPEED Keyboard as /devices/virtual/misc/uhid/0005:046D:B024.0006/input/input25
[ 43.740142] input: G604 LIGHTSPEED Mouse as /devices/virtual/misc/uhid/0005:046D:B024.0006/input/input26
[ 43.740282] input: G604 LIGHTSPEED Consumer Control as /devices/virtual/misc/uhid/0005:046D:B024.0006/input/input27
[ 43.740364] hid-generic 0005:046D:B024.0006: input,hidraw4: BLUETOOTH HID v0.14 Keyboard [G604 LIGHTSPEED] on a4:fc:77:52:2a:8c
[ 51.350525] audit: type=1131 audit(1619447342.725:113): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 51.466423] audit: type=1334 audit(1619447342.845:114): prog-id=13 op=UNLOAD
[ 51.466430] audit: type=1334 audit(1619447342.845:115): prog-id=12 op=UNLOAD
[ 63.077689] ucsi_acpi USBC000:00: PPM init failed (-110)
[ 68.947137] audit: type=1131 audit(1619447360.324:116): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 68.958879] audit: type=1334 audit(1619447360.337:117): prog-id=18 op=UNLOAD
[ 68.958884] audit: type=1334 audit(1619447360.337:118): prog-id=17 op=UNLOAD
[ 77.664107] audit: type=1131 audit(1619447369.040:119): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 77.749307] audit: type=1334 audit(1619447369.126:120): prog-id=10 op=UNLOAD
[ 77.749327] audit: type=1334 audit(1619447369.126:121): prog-id=9 op=UNLOAD
[ 80.462386] audit: type=1334 audit(1619447371.836:122): prog-id=19 op=LOAD
[ 80.462480] audit: type=1334 audit(1619447371.836:123): prog-id=20 op=LOAD
[ 80.531607] audit: type=1130 audit(1619447371.906:124): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 110.660653] audit: type=1131 audit(1619447402.035:125): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 110.784308] audit: type=1334 audit(1619447402.159:126): prog-id=20 op=UNLOAD
[ 110.784322] audit: type=1334 audit(1619447402.159:127): prog-id=19 op=UNLOAD
[ 225.414147] rfkill: input handler enabled
[ 229.374500] audit: type=1100 audit(1619447520.741:128): pid=2595 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_succeed_if,pam_permit acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[ 229.375098] audit: type=1101 audit(1619447520.741:129): pid=2595 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_succeed_if,pam_permit acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[ 229.377806] audit: type=1103 audit(1619447520.744:130): pid=2595 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[ 229.391871] audit: type=1006 audit(1619447520.761:131): pid=2595 uid=0 subj==unconfined old-auid=4294967295 auid=120 tty=(none) old-ses=4294967295 ses=5 res=1
[ 229.419258] audit: type=1130 audit(1619447520.787:132): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 229.429198] audit: type=1101 audit(1619447520.797:133): pid=2600 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="gdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 229.429304] audit: type=1103 audit(1619447520.797:134): pid=2600 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="gdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 229.429448] audit: type=1006 audit(1619447520.797:135): pid=2600 uid=0 subj==unconfined old-auid=4294967295 auid=120 tty=(none) old-ses=4294967295 ses=6 res=1
[ 229.432399] audit: type=1105 audit(1619447520.801:136): pid=2600 uid=0 auid=120 ses=6 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="gdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 229.442110] audit: type=1334 audit(1619447520.811:137): prog-id=21 op=LOAD
[ 231.138715] rfkill: input handler disabled
[ 231.644683] usb 1-4: reset full-speed USB device number 3 using xhci_hcd
[ 232.147723] rfkill: input handler enabled
[ 232.148805] rfkill: input handler disabled
[ 242.201973] kauditd_printk_skb: 18 callbacks suppressed
[ 242.201979] audit: type=1106 audit(1619447533.567:155): pid=2595 uid=0 auid=120 ses=5 subj==unconfined msg='op=PAM:session_close grantors=pam_loginuid,pam_keyinit,pam_succeed_if,pam_permit,pam_systemd,pam_env acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[ 242.203178] audit: type=1104 audit(1619447533.567:156): pid=2595 uid=0 auid=120 ses=5 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[ 242.315246] audit: type=1100 audit(1619447533.680:157): pid=3012 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_succeed_if,pam_permit acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[ 242.316064] audit: type=1101 audit(1619447533.683:158): pid=3012 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_succeed_if,pam_permit acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[ 242.318731] audit: type=1103 audit(1619447533.683:159): pid=3012 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[ 242.329745] audit: type=1006 audit(1619447533.697:160): pid=3012 uid=0 subj==unconfined old-auid=4294967295 auid=120 tty=(none) old-ses=4294967295 ses=7 res=1
[ 242.347900] audit: type=1105 audit(1619447533.713:161): pid=3012 uid=0 auid=120 ses=7 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_succeed_if,pam_permit,pam_systemd,pam_env acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[ 242.359787] rfkill: input handler enabled
[ 244.172893] rfkill: input handler disabled
[ 249.345746] audit: type=1100 audit(1619447540.713:162): pid=3289 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="joel" exe="/usr/lib/gdm-session-worker" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[ 249.348918] audit: type=1101 audit(1619447540.713:163): pid=3289 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="joel" exe="/usr/lib/gdm-session-worker" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[ 249.350820] audit: type=1110 audit(1619447540.717:164): pid=3289 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="joel" exe="/usr/lib/gdm-session-worker" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[ 250.197904] traps: gjs[2952] trap int3 ip:7f188b789ba8 sp:7ffc4f159890 error:0 in libglib-2.0.so.0.6800.1[7f188b74c000+8c000]
[ 250.197998] audit: type=1701 audit(1619447541.563:165): auid=1000 uid=1000 gid=1000 ses=4 subj==unconfined pid=2952 comm="gjs" exe="/usr/bin/gjs-console" sig=5 res=1
[ 250.216168] audit: type=1334 audit(1619447541.583:166): prog-id=28 op=LOAD
[ 250.216255] audit: type=1334 audit(1619447541.583:167): prog-id=29 op=LOAD
[ 250.218075] audit: type=1130 audit(1619447541.583:168): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@1-3299-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 250.749494] audit: type=1131 audit(1619447542.117:169): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@1-3299-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 250.845861] audit: type=1334 audit(1619447542.213:170): prog-id=29 op=UNLOAD
[ 260.510859] kauditd_printk_skb: 1 callbacks suppressed
[ 260.510862] audit: type=1106 audit(1619447551.876:172): pid=3012 uid=0 auid=120 ses=7 subj==unconfined msg='op=PAM:session_close grantors=pam_loginuid,pam_keyinit,pam_succeed_if,pam_permit,pam_systemd,pam_env acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[ 260.511005] audit: type=1104 audit(1619447551.876:173): pid=3012 uid=0 auid=120 ses=7 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[ 262.205823] audit: type=1131 audit(1619447553.569:174): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 270.762333] audit: type=1131 audit(1619447562.127:175): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 270.774691] audit: type=1131 audit(1619447562.137:176): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 274.247419] audit: type=1131 audit(1619447565.610:177): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 274.292272] audit: type=1131 audit(1619447565.653:178): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 274.340070] audit: type=1334 audit(1619447565.703:179): prog-id=23 op=UNLOAD
[ 274.340078] audit: type=1334 audit(1619447565.703:180): prog-id=22 op=UNLOAD
[ 274.470013] audit: type=1334 audit(1619447565.833:181): prog-id=25 op=UNLOAD
[ 274.470022] audit: type=1334 audit(1619447565.833:182): prog-id=24 op=UNLOAD
[ 472.428763] usb 1-4: reset full-speed USB device number 3 using xhci_hcd
[ 472.583916] audit: type=1130 audit(1619447763.929:183): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 477.596388] audit: type=1100 audit(1619447768.939:184): pid=4184 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:authentication grantors=pam_unix acct="joel" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 477.598509] audit: type=1101 audit(1619447768.942:185): pid=4184 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="joel" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 477.598848] audit: type=1110 audit(1619447768.942:186): pid=4184 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 477.603534] audit: type=1105 audit(1619447768.945:187): pid=4184 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 477.622512] audit: type=1106 audit(1619447768.965:188): pid=4184 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 477.622646] audit: type=1104 audit(1619447768.965:189): pid=4184 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 503.223528] audit: type=1131 audit(1619447794.567:190): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 627.930467] audit: type=1101 audit(1619447919.245:191): pid=4218 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="joel" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 627.930843] audit: type=1110 audit(1619447919.248:192): pid=4218 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 627.938118] audit: type=1105 audit(1619447919.255:193): pid=4218 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 628.708681] audit: type=1106 audit(1619447920.025:194): pid=4218 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 628.708757] audit: type=1104 audit(1619447920.025:195): pid=4218 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 691.917217] audit: type=1101 audit(1619447983.226:196): pid=4254 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="joel" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 691.917593] audit: type=1110 audit(1619447983.226:197): pid=4254 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 691.922889] audit: type=1105 audit(1619447983.229:198): pid=4254 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 692.970816] audit: type=1106 audit(1619447984.279:199): pid=4254 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 692.970892] audit: type=1104 audit(1619447984.279:200): pid=4254 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 852.639110] amdgpu 0000:04:00.0: amdgpu: [gfxhub0] retry page fault (src_id:0 ring:0 vmid:4 pasid:32774, for process Xwayland pid 1634 thread Xwayland:cs0 pid 1977)
[ 852.639113] amdgpu 0000:04:00.0: amdgpu: in page starting at address 0x0000800101700000 from client 27
[ 852.639115] amdgpu 0000:04:00.0: amdgpu: VM_L2_PROTECTION_FAULT_STATUS:0x00441051
[ 852.639116] amdgpu 0000:04:00.0: amdgpu: Faulty UTCL2 client ID: 0x8
[ 852.639118] amdgpu 0000:04:00.0: amdgpu: MORE_FAULTS: 0x1
[ 852.639119] amdgpu 0000:04:00.0: amdgpu: WALKER_ERROR: 0x0
[ 852.639120] amdgpu 0000:04:00.0: amdgpu: PERMISSION_FAULTS: 0x5
[ 852.639121] amdgpu 0000:04:00.0: amdgpu: MAPPING_ERROR: 0x0
[ 852.639122] amdgpu 0000:04:00.0: amdgpu: RW: 0x1
[ 852.639130] amdgpu 0000:04:00.0: amdgpu: [gfxhub0] retry page fault (src_id:0 ring:0 vmid:4 pasid:32774, for process Xwayland pid 1634 thread Xwayland:cs0 pid 1977)
[ 852.639132] amdgpu 0000:04:00.0: amdgpu: in page starting at address 0x0000800101701000 from client 27
[ 852.639133] amdgpu 0000:04:00.0: amdgpu: VM_L2_PROTECTION_FAULT_STATUS:0x00441051
[ 852.639134] amdgpu 0000:04:00.0: amdgpu: Faulty UTCL2 client ID: 0x8
[ 852.639135] amdgpu 0000:04:00.0: amdgpu: MORE_FAULTS: 0x1
[ 852.639136] amdgpu 0000:04:00.0: amdgpu: WALKER_ERROR: 0x0
[ 852.639137] amdgpu 0000:04:00.0: amdgpu: PERMISSION_FAULTS: 0x5
[ 852.639138] amdgpu 0000:04:00.0: amdgpu: MAPPING_ERROR: 0x0
[ 852.639139] amdgpu 0000:04:00.0: amdgpu: RW: 0x1
[ 852.639146] amdgpu 0000:04:00.0: amdgpu: [gfxhub0] retry page fault (src_id:0 ring:0 vmid:4 pasid:32774, for process Xwayland pid 1634 thread Xwayland:cs0 pid 1977)
[ 852.639147] amdgpu 0000:04:00.0: amdgpu: in page starting at address 0x0000800101707000 from client 27
[ 852.639148] amdgpu 0000:04:00.0: amdgpu: VM_L2_PROTECTION_FAULT_STATUS:0x00441051
[ 852.639149] amdgpu 0000:04:00.0: amdgpu: Faulty UTCL2 client ID: 0x8
[ 852.639150] amdgpu 0000:04:00.0: amdgpu: MORE_FAULTS: 0x1
[ 852.639151] amdgpu 0000:04:00.0: amdgpu: WALKER_ERROR: 0x0
[ 852.639152] amdgpu 0000:04:00.0: amdgpu: PERMISSION_FAULTS: 0x5
[ 852.639153] amdgpu 0000:04:00.0: amdgpu: MAPPING_ERROR: 0x0
[ 852.639154] amdgpu 0000:04:00.0: amdgpu: RW: 0x1
[ 852.639160] amdgpu 0000:04:00.0: amdgpu: [gfxhub0] retry page fault (src_id:0 ring:0 vmid:4 pasid:32774, for process Xwayland pid 1634 thread Xwayland:cs0 pid 1977)
[ 852.639161] amdgpu 0000:04:00.0: amdgpu: in page starting at address 0x0000800101703000 from client 27
[ 852.639163] amdgpu 0000:04:00.0: amdgpu: VM_L2_PROTECTION_FAULT_STATUS:0x00441051
[ 852.639164] amdgpu 0000:04:00.0: amdgpu: Faulty UTCL2 client ID: 0x8
[ 852.639164] amdgpu 0000:04:00.0: amdgpu: MORE_FAULTS: 0x1
[ 852.639166] amdgpu 0000:04:00.0: amdgpu: WALKER_ERROR: 0x0
[ 852.639167] amdgpu 0000:04:00.0: amdgpu: PERMISSION_FAULTS: 0x5
[ 852.639167] amdgpu 0000:04:00.0: amdgpu: MAPPING_ERROR: 0x0
[ 852.639168] amdgpu 0000:04:00.0: amdgpu: RW: 0x1
[ 852.639175] amdgpu 0000:04:00.0: amdgpu: [gfxhub0] retry page fault (src_id:0 ring:0 vmid:4 pasid:32774, for process Xwayland pid 1634 thread Xwayland:cs0 pid 1977)
[ 852.639176] amdgpu 0000:04:00.0: amdgpu: in page starting at address 0x0000800101702000 from client 27
[ 852.639177] amdgpu 0000:04:00.0: amdgpu: VM_L2_PROTECTION_FAULT_STATUS:0x00441051
[ 852.639179] amdgpu 0000:04:00.0: amdgpu: Faulty UTCL2 client ID: 0x8
[ 852.639180] amdgpu 0000:04:00.0: amdgpu: MORE_FAULTS: 0x1
[ 852.639181] amdgpu 0000:04:00.0: amdgpu: WALKER_ERROR: 0x0
[ 852.639182] amdgpu 0000:04:00.0: amdgpu: PERMISSION_FAULTS: 0x5
[ 852.639183] amdgpu 0000:04:00.0: amdgpu: MAPPING_ERROR: 0x0
[ 852.639184] amdgpu 0000:04:00.0: amdgpu: RW: 0x1
[ 852.639191] amdgpu 0000:04:00.0: amdgpu: [gfxhub0] retry page fault (src_id:0 ring:0 vmid:4 pasid:32774, for process Xwayland pid 1634 thread Xwayland:cs0 pid 1977)
[ 852.639192] amdgpu 0000:04:00.0: amdgpu: in page starting at address 0x0000800101705000 from client 27
[ 852.639195] amdgpu 0000:04:00.0: amdgpu: VM_L2_PROTECTION_FAULT_STATUS:0x00441051
[ 852.639196] amdgpu 0000:04:00.0: amdgpu: Faulty UTCL2 client ID: 0x8
[ 852.639198] amdgpu 0000:04:00.0: amdgpu: MORE_FAULTS: 0x1
[ 852.639199] amdgpu 0000:04:00.0: amdgpu: WALKER_ERROR: 0x0
[ 852.639200] amdgpu 0000:04:00.0: amdgpu: PERMISSION_FAULTS: 0x5
[ 852.639201] amdgpu 0000:04:00.0: amdgpu: MAPPING_ERROR: 0x0
[ 852.639202] amdgpu 0000:04:00.0: amdgpu: RW: 0x1
[ 852.639209] amdgpu 0000:04:00.0: amdgpu: [gfxhub0] retry page fault (src_id:0 ring:0 vmid:4 pasid:32774, for process Xwayland pid 1634 thread Xwayland:cs0 pid 1977)
[ 852.639210] amdgpu 0000:04:00.0: amdgpu: in page starting at address 0x0000800101704000 from client 27
[ 852.639211] amdgpu 0000:04:00.0: amdgpu: VM_L2_PROTECTION_FAULT_STATUS:0x00441051
[ 852.639212] amdgpu 0000:04:00.0: amdgpu: Faulty UTCL2 client ID: 0x8
[ 852.639213] amdgpu 0000:04:00.0: amdgpu: MORE_FAULTS: 0x1
[ 852.639214] amdgpu 0000:04:00.0: amdgpu: WALKER_ERROR: 0x0
[ 852.639215] amdgpu 0000:04:00.0: amdgpu: PERMISSION_FAULTS: 0x5
[ 852.639216] amdgpu 0000:04:00.0: amdgpu: MAPPING_ERROR: 0x0
[ 852.639217] amdgpu 0000:04:00.0: amdgpu: RW: 0x1
[ 852.639224] amdgpu 0000:04:00.0: amdgpu: [gfxhub0] retry page fault (src_id:0 ring:0 vmid:4 pasid:32774, for process Xwayland pid 1634 thread Xwayland:cs0 pid 1977)
[ 852.639225] amdgpu 0000:04:00.0: amdgpu: in page starting at address 0x0000800101706000 from client 27
[ 852.639227] amdgpu 0000:04:00.0: amdgpu: VM_L2_PROTECTION_FAULT_STATUS:0x00441051
[ 852.639228] amdgpu 0000:04:00.0: amdgpu: Faulty UTCL2 client ID: 0x8
[ 852.639229] amdgpu 0000:04:00.0: amdgpu: MORE_FAULTS: 0x1
[ 852.639230] amdgpu 0000:04:00.0: amdgpu: WALKER_ERROR: 0x0
[ 852.639231] amdgpu 0000:04:00.0: amdgpu: PERMISSION_FAULTS: 0x5
[ 852.639233] amdgpu 0000:04:00.0: amdgpu: MAPPING_ERROR: 0x0
[ 852.639234] amdgpu 0000:04:00.0: amdgpu: RW: 0x1
[ 852.639243] amdgpu 0000:04:00.0: amdgpu: [gfxhub0] retry page fault (src_id:0 ring:0 vmid:4 pasid:32774, for process Xwayland pid 1634 thread Xwayland:cs0 pid 1977)
[ 852.639244] amdgpu 0000:04:00.0: amdgpu: in page starting at address 0x0000800101708000 from client 27
[ 852.639245] amdgpu 0000:04:00.0: amdgpu: VM_L2_PROTECTION_FAULT_STATUS:0x00441051
[ 852.639246] amdgpu 0000:04:00.0: amdgpu: Faulty UTCL2 client ID: 0x8
[ 852.639247] amdgpu 0000:04:00.0: amdgpu: MORE_FAULTS: 0x1
[ 852.639249] amdgpu 0000:04:00.0: amdgpu: WALKER_ERROR: 0x0
[ 852.639250] amdgpu 0000:04:00.0: amdgpu: PERMISSION_FAULTS: 0x5
[ 852.639251] amdgpu 0000:04:00.0: amdgpu: MAPPING_ERROR: 0x0
[ 852.639252] amdgpu 0000:04:00.0: amdgpu: RW: 0x1
[ 852.639258] amdgpu 0000:04:00.0: amdgpu: [gfxhub0] retry page fault (src_id:0 ring:0 vmid:4 pasid:32774, for process Xwayland pid 1634 thread Xwayland:cs0 pid 1977)
[ 852.639260] amdgpu 0000:04:00.0: amdgpu: in page starting at address 0x0000800101709000 from client 27
[ 852.639261] amdgpu 0000:04:00.0: amdgpu: VM_L2_PROTECTION_FAULT_STATUS:0x00441051
[ 852.639262] amdgpu 0000:04:00.0: amdgpu: Faulty UTCL2 client ID: 0x8
[ 852.639263] amdgpu 0000:04:00.0: amdgpu: MORE_FAULTS: 0x1
[ 852.639264] amdgpu 0000:04:00.0: amdgpu: WALKER_ERROR: 0x0
[ 852.639265] amdgpu 0000:04:00.0: amdgpu: PERMISSION_FAULTS: 0x5
[ 852.639266] amdgpu 0000:04:00.0: amdgpu: MAPPING_ERROR: 0x0
[ 852.639267] amdgpu 0000:04:00.0: amdgpu: RW: 0x1
[ 857.641043] gmc_v9_0_process_interrupt: 92502 callbacks suppressed
[ 857.641050] amdgpu 0000:04:00.0: amdgpu: [gfxhub0] retry page fault (src_id:0 ring:0 vmid:4 pasid:32774, for process Xwayland pid 1634 thread Xwayland:cs0 pid 1977)
[ 857.641053] amdgpu 0000:04:00.0: amdgpu: in page starting at address 0x0000800101700000 from client 27
[ 857.641054] amdgpu 0000:04:00.0: amdgpu: VM_L2_PROTECTION_FAULT_STATUS:0x00441051
[ 857.641056] amdgpu 0000:04:00.0: amdgpu: Faulty UTCL2 client ID: 0x8
[ 857.641057] amdgpu 0000:04:00.0: amdgpu: MORE_FAULTS: 0x1
[ 857.641058] amdgpu 0000:04:00.0: amdgpu: WALKER_ERROR: 0x0
[ 857.641059] amdgpu 0000:04:00.0: amdgpu: PERMISSION_FAULTS: 0x5
[ 857.641060] amdgpu 0000:04:00.0: amdgpu: MAPPING_ERROR: 0x0
[ 857.641061] amdgpu 0000:04:00.0: amdgpu: RW: 0x1
[ 857.641069] amdgpu 0000:04:00.0: amdgpu: [gfxhub0] retry page fault (src_id:0 ring:0 vmid:4 pasid:32774, for process Xwayland pid 1634 thread Xwayland:cs0 pid 1977)
[ 857.641070] amdgpu 0000:04:00.0: amdgpu: in page starting at address 0x0000800101701000 from client 27
[ 857.641071] amdgpu 0000:04:00.0: amdgpu: VM_L2_PROTECTION_FAULT_STATUS:0x00441051
[ 857.641072] amdgpu 0000:04:00.0: amdgpu: Faulty UTCL2 client ID: 0x8
[ 857.641073] amdgpu 0000:04:00.0: amdgpu: MORE_FAULTS: 0x1
[ 857.641074] amdgpu 0000:04:00.0: amdgpu: WALKER_ERROR: 0x0
[ 857.641075] amdgpu 0000:04:00.0: amdgpu: PERMISSION_FAULTS: 0x5
[ 857.641076] amdgpu 0000:04:00.0: amdgpu: MAPPING_ERROR: 0x0
[ 857.641077] amdgpu 0000:04:00.0: amdgpu: RW: 0x1
[ 857.641084] amdgpu 0000:04:00.0: amdgpu: [gfxhub0] retry page fault (src_id:0 ring:0 vmid:4 pasid:32774, for process Xwayland pid 1634 thread Xwayland:cs0 pid 1977)
[ 857.641085] amdgpu 0000:04:00.0: amdgpu: in page starting at address 0x0000800101707000 from client 27
[ 857.641087] amdgpu 0000:04:00.0: amdgpu: VM_L2_PROTECTION_FAULT_STATUS:0x00441051
[ 857.641088] amdgpu 0000:04:00.0: amdgpu: Faulty UTCL2 client ID: 0x8
[ 857.641089] amdgpu 0000:04:00.0: amdgpu: MORE_FAULTS: 0x1
[ 857.641090] amdgpu 0000:04:00.0: amdgpu: WALKER_ERROR: 0x0
[ 857.641091] amdgpu 0000:04:00.0: amdgpu: PERMISSION_FAULTS: 0x5
[ 857.641091] amdgpu 0000:04:00.0: amdgpu: MAPPING_ERROR: 0x0
[ 857.641092] amdgpu 0000:04:00.0: amdgpu: RW: 0x1
[ 857.641099] amdgpu 0000:04:00.0: amdgpu: [gfxhub0] retry page fault (src_id:0 ring:0 vmid:4 pasid:32774, for process Xwayland pid 1634 thread Xwayland:cs0 pid 1977)
[ 857.641100] amdgpu 0000:04:00.0: amdgpu: in page starting at address 0x0000800101703000 from client 27
[ 857.641101] amdgpu 0000:04:00.0: amdgpu: VM_L2_PROTECTION_FAULT_STATUS:0x00441051
[ 857.641102] amdgpu 0000:04:00.0: amdgpu: Faulty UTCL2 client ID: 0x8
[ 857.641104] amdgpu 0000:04:00.0: amdgpu: MORE_FAULTS: 0x1
[ 857.641105] amdgpu 0000:04:00.0: amdgpu: WALKER_ERROR: 0x0
[ 857.641106] amdgpu 0000:04:00.0: amdgpu: PERMISSION_FAULTS: 0x5
[ 857.641107] amdgpu 0000:04:00.0: amdgpu: MAPPING_ERROR: 0x0
[ 857.641108] amdgpu 0000:04:00.0: amdgpu: RW: 0x1
[ 857.641114] amdgpu 0000:04:00.0: amdgpu: [gfxhub0] retry page fault (src_id:0 ring:0 vmid:4 pasid:32774, for process Xwayland pid 1634 thread Xwayland:cs0 pid 1977)
[ 857.641115] amdgpu 0000:04:00.0: amdgpu: in page starting at address 0x0000800101702000 from client 27
[ 857.641116] amdgpu 0000:04:00.0: amdgpu: VM_L2_PROTECTION_FAULT_STATUS:0x00441051
[ 857.641117] amdgpu 0000:04:00.0: amdgpu: Faulty UTCL2 client ID: 0x8
[ 857.641118] amdgpu 0000:04:00.0: amdgpu: MORE_FAULTS: 0x1
[ 857.641119] amdgpu 0000:04:00.0: amdgpu: WALKER_ERROR: 0x0
[ 857.641120] amdgpu 0000:04:00.0: amdgpu: PERMISSION_FAULTS: 0x5
[ 857.641121] amdgpu 0000:04:00.0: amdgpu: MAPPING_ERROR: 0x0
[ 857.641122] amdgpu 0000:04:00.0: amdgpu: RW: 0x1
[ 857.641128] amdgpu 0000:04:00.0: amdgpu: [gfxhub0] retry page fault (src_id:0 ring:0 vmid:4 pasid:32774, for process Xwayland pid 1634 thread Xwayland:cs0 pid 1977)
[ 857.641130] amdgpu 0000:04:00.0: amdgpu: in page starting at address 0x0000800101705000 from client 27
[ 857.641131] amdgpu 0000:04:00.0: amdgpu: VM_L2_PROTECTION_FAULT_STATUS:0x00441051
[ 857.641132] amdgpu 0000:04:00.0: amdgpu: Faulty UTCL2 client ID: 0x8
[ 857.641133] amdgpu 0000:04:00.0: amdgpu: MORE_FAULTS: 0x1
[ 857.641134] amdgpu 0000:04:00.0: amdgpu: WALKER_ERROR: 0x0
[ 857.641135] amdgpu 0000:04:00.0: amdgpu: PERMISSION_FAULTS: 0x5
[ 857.641135] amdgpu 0000:04:00.0: amdgpu: MAPPING_ERROR: 0x0
[ 857.641136] amdgpu 0000:04:00.0: amdgpu: RW: 0x1
[ 857.641143] amdgpu 0000:04:00.0: amdgpu: [gfxhub0] retry page fault (src_id:0 ring:0 vmid:4 pasid:32774, for process Xwayland pid 1634 thread Xwayland:cs0 pid 1977)
[ 857.641144] amdgpu 0000:04:00.0: amdgpu: in page starting at address 0x0000800101704000 from client 27
[ 857.641145] amdgpu 0000:04:00.0: amdgpu: VM_L2_PROTECTION_FAULT_STATUS:0x00441051
[ 857.641146] amdgpu 0000:04:00.0: amdgpu: Faulty UTCL2 client ID: 0x8
[ 857.641146] amdgpu 0000:04:00.0: amdgpu: MORE_FAULTS: 0x1
[ 857.641147] amdgpu 0000:04:00.0: amdgpu: WALKER_ERROR: 0x0
[ 857.641148] amdgpu 0000:04:00.0: amdgpu: PERMISSION_FAULTS: 0x5
[ 857.641149] amdgpu 0000:04:00.0: amdgpu: MAPPING_ERROR: 0x0
[ 857.641150] amdgpu 0000:04:00.0: amdgpu: RW: 0x1
[ 857.641156] amdgpu 0000:04:00.0: amdgpu: [gfxhub0] retry page fault (src_id:0 ring:0 vmid:4 pasid:32774, for process Xwayland pid 1634 thread Xwayland:cs0 pid 1977)
[ 857.641157] amdgpu 0000:04:00.0: amdgpu: in page starting at address 0x0000800101706000 from client 27
[ 857.641158] amdgpu 0000:04:00.0: amdgpu: VM_L2_PROTECTION_FAULT_STATUS:0x00441051
[ 857.641159] amdgpu 0000:04:00.0: amdgpu: Faulty UTCL2 client ID: 0x8
[ 857.641160] amdgpu 0000:04:00.0: amdgpu: MORE_FAULTS: 0x1
[ 857.641161] amdgpu 0000:04:00.0: amdgpu: WALKER_ERROR: 0x0
[ 857.641161] amdgpu 0000:04:00.0: amdgpu: PERMISSION_FAULTS: 0x5
[ 857.641162] amdgpu 0000:04:00.0: amdgpu: MAPPING_ERROR: 0x0
[ 857.641163] amdgpu 0000:04:00.0: amdgpu: RW: 0x1
[ 857.641170] amdgpu 0000:04:00.0: amdgpu: [gfxhub0] retry page fault (src_id:0 ring:0 vmid:4 pasid:32774, for process Xwayland pid 1634 thread Xwayland:cs0 pid 1977)
[ 857.641171] amdgpu 0000:04:00.0: amdgpu: in page starting at address 0x0000800101708000 from client 27
[ 857.641172] amdgpu 0000:04:00.0: amdgpu: VM_L2_PROTECTION_FAULT_STATUS:0x00441051
[ 857.641173] amdgpu 0000:04:00.0: amdgpu: Faulty UTCL2 client ID: 0x8
[ 857.641174] amdgpu 0000:04:00.0: amdgpu: MORE_FAULTS: 0x1
[ 857.641175] amdgpu 0000:04:00.0: amdgpu: WALKER_ERROR: 0x0
[ 857.641175] amdgpu 0000:04:00.0: amdgpu: PERMISSION_FAULTS: 0x5
[ 857.641176] amdgpu 0000:04:00.0: amdgpu: MAPPING_ERROR: 0x0
[ 857.641177] amdgpu 0000:04:00.0: amdgpu: RW: 0x1
[ 857.641183] amdgpu 0000:04:00.0: amdgpu: [gfxhub0] retry page fault (src_id:0 ring:0 vmid:4 pasid:32774, for process Xwayland pid 1634 thread Xwayland:cs0 pid 1977)
[ 857.641184] amdgpu 0000:04:00.0: amdgpu: in page starting at address 0x0000800101709000 from client 27
[ 857.641185] amdgpu 0000:04:00.0: amdgpu: VM_L2_PROTECTION_FAULT_STATUS:0x00441051
[ 857.641186] amdgpu 0000:04:00.0: amdgpu: Faulty UTCL2 client ID: 0x8
[ 857.641187] amdgpu 0000:04:00.0: amdgpu: MORE_FAULTS: 0x1
[ 857.641188] amdgpu 0000:04:00.0: amdgpu: WALKER_ERROR: 0x0
[ 857.641188] amdgpu 0000:04:00.0: amdgpu: PERMISSION_FAULTS: 0x5
[ 857.641189] amdgpu 0000:04:00.0: amdgpu: MAPPING_ERROR: 0x0
[ 857.641190] amdgpu 0000:04:00.0: amdgpu: RW: 0x1
[ 857.760662] [drm:amdgpu_dm_atomic_commit_tail [amdgpu]] *ERROR* Waiting for fences timed out!
[ 862.645304] gmc_v9_0_process_interrupt: 92534 callbacks suppressed
[ 862.645312] amdgpu 0000:04:00.0: amdgpu: [gfxhub0] retry page fault (src_id:0 ring:0 vmid:4 pasid:32774, for process Xwayland pid 1634 thread Xwayland:cs0 pid 1977)
[ 862.645315] amdgpu 0000:04:00.0: amdgpu: in page starting at address 0x0000800101700000 from client 27
[ 862.645317] amdgpu 0000:04:00.0: amdgpu: VM_L2_PROTECTION_FAULT_STATUS:0x00441051
[ 862.645318] amdgpu 0000:04:00.0: amdgpu: Faulty UTCL2 client ID: 0x8
[ 862.645319] amdgpu 0000:04:00.0: amdgpu: MORE_FAULTS: 0x1
[ 862.645320] amdgpu 0000:04:00.0: amdgpu: WALKER_ERROR: 0x0
[ 862.645322] amdgpu 0000:04:00.0: amdgpu: PERMISSION_FAULTS: 0x5
[ 862.645323] amdgpu 0000:04:00.0: amdgpu: MAPPING_ERROR: 0x0
[ 862.645324] amdgpu 0000:04:00.0: amdgpu: RW: 0x1
[ 862.645331] amdgpu 0000:04:00.0: amdgpu: [gfxhub0] retry page fault (src_id:0 ring:0 vmid:4 pasid:32774, for process Xwayland pid 1634 thread Xwayland:cs0 pid 1977)
[ 862.645332] amdgpu 0000:04:00.0: amdgpu: in page starting at address 0x0000800101701000 from client 27
[ 862.645334] amdgpu 0000:04:00.0: amdgpu: VM_L2_PROTECTION_FAULT_STATUS:0x00441051
[ 862.645335] amdgpu 0000:04:00.0: amdgpu: Faulty UTCL2 client ID: 0x8
[ 862.645336] amdgpu 0000:04:00.0: amdgpu: MORE_FAULTS: 0x1
[ 862.645337] amdgpu 0000:04:00.0: amdgpu: WALKER_ERROR: 0x0
[ 862.645338] amdgpu 0000:04:00.0: amdgpu: PERMISSION_FAULTS: 0x5
[ 862.645339] amdgpu 0000:04:00.0: amdgpu: MAPPING_ERROR: 0x0
[ 862.645340] amdgpu 0000:04:00.0: amdgpu: RW: 0x1
[ 862.645347] amdgpu 0000:04:00.0: amdgpu: [gfxhub0] retry page fault (src_id:0 ring:0 vmid:4 pasid:32774, for process Xwayland pid 1634 thread Xwayland:cs0 pid 1977)
[ 862.645348] amdgpu 0000:04:00.0: amdgpu: in page starting at address 0x0000800101707000 from client 27
[ 862.645349] amdgpu 0000:04:00.0: amdgpu: VM_L2_PROTECTION_FAULT_STATUS:0x00441051
[ 862.645350] amdgpu 0000:04:00.0: amdgpu: Faulty UTCL2 client ID: 0x8
[ 862.645351] amdgpu 0000:04:00.0: amdgpu: MORE_FAULTS: 0x1
[ 862.645352] amdgpu 0000:04:00.0: amdgpu: WALKER_ERROR: 0x0
[ 862.645353] amdgpu 0000:04:00.0: amdgpu: PERMISSION_FAULTS: 0x5
[ 862.645354] amdgpu 0000:04:00.0: amdgpu: MAPPING_ERROR: 0x0
[ 862.645355] amdgpu 0000:04:00.0: amdgpu: RW: 0x1
[ 862.645361] amdgpu 0000:04:00.0: amdgpu: [gfxhub0] retry page fault (src_id:0 ring:0 vmid:4 pasid:32774, for process Xwayland pid 1634 thread Xwayland:cs0 pid 1977)
[ 862.645363] amdgpu 0000:04:00.0: amdgpu: in page starting at address 0x0000800101703000 from client 27
[ 862.645364] amdgpu 0000:04:00.0: amdgpu: VM_L2_PROTECTION_FAULT_STATUS:0x00441051
[ 862.645365] amdgpu 0000:04:00.0: amdgpu: Faulty UTCL2 client ID: 0x8
[ 862.645366] amdgpu 0000:04:00.0: amdgpu: MORE_FAULTS: 0x1
[ 862.645367] amdgpu 0000:04:00.0: amdgpu: WALKER_ERROR: 0x0
[ 862.645368] amdgpu 0000:04:00.0: amdgpu: PERMISSION_FAULTS: 0x5
[ 862.645369] amdgpu 0000:04:00.0: amdgpu: MAPPING_ERROR: 0x0
[ 862.645370] amdgpu 0000:04:00.0: amdgpu: RW: 0x1
[ 862.645376] amdgpu 0000:04:00.0: amdgpu: [gfxhub0] retry page fault (src_id:0 ring:0 vmid:4 pasid:32774, for process Xwayland pid 1634 thread Xwayland:cs0 pid 1977)
[ 862.645377] amdgpu 0000:04:00.0: amdgpu: in page starting at address 0x0000800101702000 from client 27
[ 862.645378] amdgpu 0000:04:00.0: amdgpu: VM_L2_PROTECTION_FAULT_STATUS:0x00441051
[ 862.645379] amdgpu 0000:04:00.0: amdgpu: Faulty UTCL2 client ID: 0x8
[ 862.645380] amdgpu 0000:04:00.0: amdgpu: MORE_FAULTS: 0x1
[ 862.645381] amdgpu 0000:04:00.0: amdgpu: WALKER_ERROR: 0x0
[ 862.645382] amdgpu 0000:04:00.0: amdgpu: PERMISSION_FAULTS: 0x5
[ 862.645383] amdgpu 0000:04:00.0: amdgpu: MAPPING_ERROR: 0x0
[ 862.645384] amdgpu 0000:04:00.0: amdgpu: RW: 0x1
[ 862.645391] amdgpu 0000:04:00.0: amdgpu: [gfxhub0] retry page fault (src_id:0 ring:0 vmid:4 pasid:32774, for process Xwayland pid 1634 thread Xwayland:cs0 pid 1977)
[ 862.645392] amdgpu 0000:04:00.0: amdgpu: in page starting at address 0x0000800101705000 from client 27
[ 862.645393] amdgpu 0000:04:00.0: amdgpu: VM_L2_PROTECTION_FAULT_STATUS:0x00441051
[ 862.645394] amdgpu 0000:04:00.0: amdgpu: Faulty UTCL2 client ID: 0x8
[ 862.645395] amdgpu 0000:04:00.0: amdgpu: MORE_FAULTS: 0x1
[ 862.645396] amdgpu 0000:04:00.0: amdgpu: WALKER_ERROR: 0x0
[ 862.645397] amdgpu 0000:04:00.0: amdgpu: PERMISSION_FAULTS: 0x5
[ 862.645398] amdgpu 0000:04:00.0: amdgpu: MAPPING_ERROR: 0x0
[ 862.645399] amdgpu 0000:04:00.0: amdgpu: RW: 0x1
[ 862.645405] amdgpu 0000:04:00.0: amdgpu: [gfxhub0] retry page fault (src_id:0 ring:0 vmid:4 pasid:32774, for process Xwayland pid 1634 thread Xwayland:cs0 pid 1977)
[ 862.645406] amdgpu 0000:04:00.0: amdgpu: in page starting at address 0x0000800101704000 from client 27
[ 862.645408] amdgpu 0000:04:00.0: amdgpu: VM_L2_PROTECTION_FAULT_STATUS:0x00441051
[ 862.645409] amdgpu 0000:04:00.0: amdgpu: Faulty UTCL2 client ID: 0x8
[ 862.645410] amdgpu 0000:04:00.0: amdgpu: MORE_FAULTS: 0x1
[ 862.645411] amdgpu 0000:04:00.0: amdgpu: WALKER_ERROR: 0x0
[ 862.645412] amdgpu 0000:04:00.0: amdgpu: PERMISSION_FAULTS: 0x5
[ 862.645413] amdgpu 0000:04:00.0: amdgpu: MAPPING_ERROR: 0x0
[ 862.645413] amdgpu 0000:04:00.0: amdgpu: RW: 0x1
[ 862.645420] amdgpu 0000:04:00.0: amdgpu: [gfxhub0] retry page fault (src_id:0 ring:0 vmid:4 pasid:32774, for process Xwayland pid 1634 thread Xwayland:cs0 pid 1977)
[ 862.645421] amdgpu 0000:04:00.0: amdgpu: in page starting at address 0x0000800101706000 from client 27
[ 862.645422] amdgpu 0000:04:00.0: amdgpu: VM_L2_PROTECTION_FAULT_STATUS:0x00441051
[ 862.645423] amdgpu 0000:04:00.0: amdgpu: Faulty UTCL2 client ID: 0x8
[ 862.645424] amdgpu 0000:04:00.0: amdgpu: MORE_FAULTS: 0x1
[ 862.645425] amdgpu 0000:04:00.0: amdgpu: WALKER_ERROR: 0x0
[ 862.645426] amdgpu 0000:04:00.0: amdgpu: PERMISSION_FAULTS: 0x5
[ 862.645427] amdgpu 0000:04:00.0: amdgpu: MAPPING_ERROR: 0x0
[ 862.645428] amdgpu 0000:04:00.0: amdgpu: RW: 0x1
[ 862.645436] amdgpu 0000:04:00.0: amdgpu: [gfxhub0] retry page fault (src_id:0 ring:0 vmid:4 pasid:32774, for process Xwayland pid 1634 thread Xwayland:cs0 pid 1977)
[ 862.645437] amdgpu 0000:04:00.0: amdgpu: in page starting at address 0x0000800101708000 from client 27
[ 862.645438] amdgpu 0000:04:00.0: amdgpu: VM_L2_PROTECTION_FAULT_STATUS:0x00441051
[ 862.645439] amdgpu 0000:04:00.0: amdgpu: Faulty UTCL2 client ID: 0x8
[ 862.645440] amdgpu 0000:04:00.0: amdgpu: MORE_FAULTS: 0x1
[ 862.645441] amdgpu 0000:04:00.0: amdgpu: WALKER_ERROR: 0x0
[ 862.645442] amdgpu 0000:04:00.0: amdgpu: PERMISSION_FAULTS: 0x5
[ 862.645443] amdgpu 0000:04:00.0: amdgpu: MAPPING_ERROR: 0x0
[ 862.645444] amdgpu 0000:04:00.0: amdgpu: RW: 0x1
[ 862.645450] amdgpu 0000:04:00.0: amdgpu: [gfxhub0] retry page fault (src_id:0 ring:0 vmid:4 pasid:32774, for process Xwayland pid 1634 thread Xwayland:cs0 pid 1977)
[ 862.645451] amdgpu 0000:04:00.0: amdgpu: in page starting at address 0x0000800101709000 from client 27
[ 862.645452] amdgpu 0000:04:00.0: amdgpu: VM_L2_PROTECTION_FAULT_STATUS:0x00441051
[ 862.645453] amdgpu 0000:04:00.0: amdgpu: Faulty UTCL2 client ID: 0x8
[ 862.645454] amdgpu 0000:04:00.0: amdgpu: MORE_FAULTS: 0x1
[ 862.645455] amdgpu 0000:04:00.0: amdgpu: WALKER_ERROR: 0x0
[ 862.645455] amdgpu 0000:04:00.0: amdgpu: PERMISSION_FAULTS: 0x5
[ 862.645456] amdgpu 0000:04:00.0: amdgpu: MAPPING_ERROR: 0x0
[ 862.645457] amdgpu 0000:04:00.0: amdgpu: RW: 0x1
[ 862.668290] [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring gfx timeout, but soft recovered
[ 870.852446] rfkill: input handler enabled
[ 877.450339] kauditd_printk_skb: 446 callbacks suppressed
[ 877.450343] audit: type=1100 audit(1619448168.740:208): pid=4324 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_succeed_if,pam_permit acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[ 877.450939] audit: type=1101 audit(1619448168.740:209): pid=4324 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_succeed_if,pam_permit acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[ 877.452823] audit: type=1103 audit(1619448168.743:210): pid=4324 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[ 877.466401] audit: type=1006 audit(1619448168.757:211): pid=4324 uid=0 subj==unconfined old-auid=4294967295 auid=120 tty=(none) old-ses=4294967295 ses=8 res=1
[ 877.487361] audit: type=1130 audit(1619448168.777:212): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 877.495190] audit: type=1101 audit(1619448168.783:213): pid=4329 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="gdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 877.495231] audit: type=1103 audit(1619448168.783:214): pid=4329 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="gdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 877.495310] audit: type=1006 audit(1619448168.783:215): pid=4329 uid=0 subj==unconfined old-auid=4294967295 auid=120 tty=(none) old-ses=4294967295 ses=9 res=1
[ 877.497290] audit: type=1105 audit(1619448168.787:216): pid=4329 uid=0 auid=120 ses=9 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="gdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 877.503319] audit: type=1334 audit(1619448168.793:217): prog-id=32 op=LOAD
[ 879.638679] rfkill: input handler disabled
[ 880.080865] usb 1-4: reset full-speed USB device number 3 using xhci_hcd
[ 884.616824] kauditd_printk_skb: 10 callbacks suppressed
[ 884.616827] audit: type=1100 audit(1619448175.906:228): pid=4628 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="joel" exe="/usr/lib/gdm-session-worker" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[ 884.619307] audit: type=1101 audit(1619448175.906:229): pid=4628 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="joel" exe="/usr/lib/gdm-session-worker" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[ 884.621053] audit: type=1110 audit(1619448175.909:230): pid=4628 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="joel" exe="/usr/lib/gdm-session-worker" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[ 884.744121] rfkill: input handler enabled
[ 894.607168] audit: type=1130 audit(1619448185.895:231): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=getty@tty3 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 895.724033] audit: type=1106 audit(1619448187.012:232): pid=4324 uid=0 auid=120 ses=8 subj==unconfined msg='op=PAM:session_close grantors=pam_loginuid,pam_keyinit,pam_succeed_if,pam_permit,pam_systemd,pam_env acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[ 895.724145] audit: type=1104 audit(1619448187.012:233): pid=4324 uid=0 auid=120 ses=8 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[ 905.851701] audit: type=1131 audit(1619448197.138:234): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 905.863352] audit: type=1131 audit(1619448197.148:235): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 905.870892] audit: type=1130 audit(1619448197.154:236): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 905.870900] audit: type=1131 audit(1619448197.154:237): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 908.134400] audit: type=1100 audit(1619448199.417:238): pid=4635 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="joel" exe="/usr/bin/login" hostname=manjaro addr=? terminal=/dev/tty3 res=success'
[ 908.136865] audit: type=1101 audit(1619448199.421:239): pid=4635 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="joel" exe="/usr/bin/login" hostname=manjaro addr=? terminal=/dev/tty3 res=success'
[ 908.137733] audit: type=1103 audit(1619448199.421:240): pid=4635 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="joel" exe="/usr/bin/login" hostname=manjaro addr=? terminal=/dev/tty3 res=success'
[ 908.137886] audit: type=1006 audit(1619448199.421:241): pid=4635 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=tty3 old-ses=4294967295 ses=10 res=1
[ 908.158165] audit: type=1105 audit(1619448199.444:242): pid=4635 uid=0 auid=1000 ses=10 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="joel" exe="/usr/bin/login" hostname=manjaro addr=? terminal=/dev/tty3 res=success'
[ 908.158246] audit: type=1110 audit(1619448199.444:243): pid=4635 uid=0 auid=1000 ses=10 subj==unconfined msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="joel" exe="/usr/bin/login" hostname=manjaro addr=? terminal=/dev/tty3 res=success'
[ 914.684376] kauditd_printk_skb: 7 callbacks suppressed
[ 914.684378] audit: type=1334 audit(1619448205.970:251): prog-id=37 op=LOAD
[ 914.685989] audit: type=1334 audit(1619448205.970:252): prog-id=38 op=LOAD
[ 914.790679] audit: type=1130 audit(1619448206.077:253): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 914.810526] rfkill: input handler disabled
[ 914.857444] audit: type=1334 audit(1619448206.144:254): prog-id=39 op=LOAD
[ 914.857503] audit: type=1334 audit(1619448206.144:255): prog-id=40 op=LOAD
[ 914.925205] audit: type=1101 audit(1619448206.210:256): pid=5063 uid=1000 auid=1000 ses=10 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="joel" exe="/usr/bin/sudo" hostname=manjaro addr=? terminal=/dev/tty3 res=success'
[ 914.926205] audit: type=1110 audit(1619448206.214:257): pid=5063 uid=1000 auid=1000 ses=10 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=manjaro addr=? terminal=/dev/tty3 res=success'
[ 914.932309] audit: type=1105 audit(1619448206.220:258): pid=5063 uid=1000 auid=1000 ses=10 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=manjaro addr=? terminal=/dev/tty3 res=success'
[ 914.935046] audit: type=1130 audit(1619448206.220:259): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 914.963366] audit: type=1106 audit(1619448206.250:260): pid=5063 uid=1000 auid=1000 ses=10 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=manjaro addr=? terminal=/dev/tty3 res=success'
[ 944.847916] kauditd_printk_skb: 1 callbacks suppressed
[ 944.847920] audit: type=1131 audit(1619448236.131:262): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 944.917888] audit: type=1334 audit(1619448236.201:263): prog-id=38 op=UNLOAD
[ 944.917897] audit: type=1334 audit(1619448236.201:264): prog-id=37 op=UNLOAD
[ 944.978711] audit: type=1131 audit(1619448236.261:265): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 945.101752] audit: type=1334 audit(1619448236.388:266): prog-id=40 op=UNLOAD
[ 945.101760] audit: type=1334 audit(1619448236.388:267): prog-id=39 op=UNLOAD
[ 961.101703] audit: type=1106 audit(1619448252.383:268): pid=1480 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:session_close grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_gnome_keyring acct="joel" exe="/usr/lib/gdm-session-worker" hostname=manjaro addr=? terminal=/dev/tty2 res=success'
[ 961.102983] audit: type=1104 audit(1619448252.383:269): pid=1480 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="joel" exe="/usr/lib/gdm-session-worker" hostname=manjaro addr=? terminal=/dev/tty2 res=success'
[ 961.626345] rfkill: input handler enabled
[ 961.728932] audit: type=1100 audit(1619448253.010:270): pid=5796 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_succeed_if,pam_permit acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[ 961.729716] audit: type=1101 audit(1619448253.013:271): pid=5796 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_succeed_if,pam_permit acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[ 961.732318] audit: type=1103 audit(1619448253.013:272): pid=5796 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[ 961.747279] audit: type=1006 audit(1619448253.030:273): pid=5796 uid=0 subj==unconfined old-auid=4294967295 auid=120 tty=(none) old-ses=4294967295 ses=11 res=1
[ 961.771971] audit: type=1130 audit(1619448253.053:274): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 961.783167] audit: type=1101 audit(1619448253.066:275): pid=5801 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="gdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 961.783262] audit: type=1103 audit(1619448253.066:276): pid=5801 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="gdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 961.783336] audit: type=1006 audit(1619448253.066:277): pid=5801 uid=0 subj==unconfined old-auid=4294967295 auid=120 tty=(none) old-ses=4294967295 ses=12 res=1
[ 963.599518] rfkill: input handler disabled
[ 963.944882] usb 1-4: reset full-speed USB device number 3 using xhci_hcd
[ 969.729406] kauditd_printk_skb: 12 callbacks suppressed
[ 969.729411] audit: type=1100 audit(1619448261.009:290): pid=6127 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="joel" exe="/usr/lib/gdm-session-worker" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[ 969.732429] audit: type=1101 audit(1619448261.012:291): pid=6127 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="joel" exe="/usr/lib/gdm-session-worker" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[ 969.734083] audit: type=1103 audit(1619448261.016:292): pid=6127 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="joel" exe="/usr/lib/gdm-session-worker" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[ 969.744354] audit: type=1006 audit(1619448261.026:293): pid=6127 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=13 res=1
[ 969.766080] audit: type=1105 audit(1619448261.046:294): pid=6127 uid=0 auid=1000 ses=13 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_gnome_keyring acct="joel" exe="/usr/lib/gdm-session-worker" hostname=manjaro addr=? terminal=/dev/tty2 res=success'
[ 970.040606] rfkill: input handler enabled
[ 971.983736] traps: gjs[5215] trap int3 ip:7f219c1aaba8 sp:7ffe4346e120 error:0 in libglib-2.0.so.0.6800.1[7f219c16d000+8c000]
[ 971.983798] audit: type=1701 audit(1619448263.266:295): auid=1000 uid=1000 gid=1000 ses=10 subj==unconfined pid=5215 comm="gjs" exe="/usr/bin/gjs-console" sig=5 res=1
[ 972.004373] audit: type=1334 audit(1619448263.286:296): prog-id=46 op=LOAD
[ 972.004489] audit: type=1334 audit(1619448263.286:297): prog-id=47 op=LOAD
[ 972.006386] audit: type=1130 audit(1619448263.286:298): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@3-6365-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 972.330029] rfkill: input handler disabled
[ 984.603934] kauditd_printk_skb: 10 callbacks suppressed
[ 984.603936] audit: type=1131 audit(1619448275.881:309): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 984.619893] audit: type=1131 audit(1619448275.898:310): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 994.301805] audit: type=1131 audit(1619448285.584:311): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1003.116600] audit: type=1131 audit(1619448294.397:312): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1003.239729] audit: type=1334 audit(1619448294.520:313): prog-id=43 op=UNLOAD
[ 1003.239737] audit: type=1334 audit(1619448294.520:314): prog-id=42 op=UNLOAD
[ 1003.598167] audit: type=1131 audit(1619448294.876:315): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1003.706326] audit: type=1334 audit(1619448294.986:316): prog-id=45 op=UNLOAD
[ 1003.706335] audit: type=1334 audit(1619448294.986:317): prog-id=44 op=UNLOAD
[ 1063.993683] rtw_8822be 0000:02:00.0: firmware failed to restore hardware setting
[ 1898.033419] audit: type=1334 audit(1619449189.445:318): prog-id=48 op=LOAD
[ 1898.033427] audit: type=1334 audit(1619449189.445:319): prog-id=49 op=LOAD
[ 1898.133514] audit: type=1130 audit(1619449189.545:320): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1899.481049] audit: type=1130 audit(1619449190.895:321): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1928.168677] audit: type=1131 audit(1619449219.585:322): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1928.194618] audit: type=1334 audit(1619449219.611:323): prog-id=49 op=UNLOAD
[ 1928.194626] audit: type=1334 audit(1619449219.611:324): prog-id=48 op=UNLOAD
[ 2128.337833] audit: type=1131 audit(1619449419.776:325): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3233.762519] rtw_8822be 0000:02:00.0: firmware failed to restore hardware setting
[ 4249.652099] rtw_8822be 0000:02:00.0: firmware failed to restore hardware setting
[ 4250.158723] ------------[ cut here ]------------
[ 4250.158743] purge skb(s) not reported by firmware
[ 4250.158802] WARNING: CPU: 6 PID: 0 at drivers/net/wireless/realtek/rtw88/tx.c:161 rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 4250.158805] Modules linked in: rfcomm ccm uhid cmac algif_hash algif_skcipher af_alg hid_logitech_hidpp joydev mousedev hid_logitech_dj bnep hid_generic btusb btrtl btbcm btintel usbhid bluetooth ecdh_generic ecc squashfs loop hp_wmi wmi_bmof sparse_keymap edac_mce_amd kvm_amd amdgpu kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel aesni_intel nls_iso8859_1 crypto_simd rtw88_8822be nls_cp437 cryptd rtw88_8822b glue_helper snd_hda_codec_realtek rtw88_pci vfat rapl input_leds fat snd_hda_codec_generic rtw88_core pcspkr ledtrig_audio snd_hda_codec_hdmi k10temp snd_hda_intel gpu_sched snd_intel_dspcfg mac80211 i2c_algo_bit sp5100_tco ucsi_acpi typec_ucsi i2c_piix4 ttm typec snd_hda_codec wmi snd_hda_core drm_kms_helper battery ac evdev mac_hid snd_hwdep cec tpm_crb cfg80211 snd_pcm tpm_tis rc_core tpm_tis_core i2c_hid syscopyarea hp_accel sysfillrect tpm sysimgblt snd_timer lis3lv02d fb_sys_fops hid hp_wireless pinctrl_amd snd acpi_tad ccp snd_rn_pci_acp3x soundcore
[ 4250.158866] snd_pci_acp3x rng_core rfkill libarc4 acpi_cpufreq drm msr fuse crypto_user agpgart ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 rtsx_pci_sdmmc serio_raw mmc_core atkbd libps2 xhci_pci crc32c_intel xhci_hcd rtsx_pci i8042 serio
[ 4250.158892] CPU: 6 PID: 0 Comm: swapper/6 Tainted: G W 5.9.16-1-MANJARO #1
[ 4250.158895] Hardware name: HP HP ENVY x360 Convertible 13-ar0xxx/85DE, BIOS F.19 12/26/2019
[ 4250.158907] RIP: 0010:rtw_tx_report_purge_timer+0x20/0x50 [rtw88_core]
[ 4250.158913] Code: 0f 1f 84 00 00 00 00 00 66 90 0f 1f 44 00 00 8b 47 f0 85 c0 75 01 c3 41 54 55 53 48 89 fb 48 c7 c7 88 ea b8 c0 e8 62 0f 27 c1 <0f> 0b 4c 8d 63 d8 4c 89 e7 e8 b2 19 2d c1 48 8d 7b e0 48 89 c5 e8
[ 4250.158917] RSP: 0018:ffffb52e0033cea8 EFLAGS: 00010286
[ 4250.158921] RAX: 0000000000000000 RBX: ffff956d098d6288 RCX: 0000000000000000
[ 4250.158925] RDX: 0000000000000102 RSI: ffffffff82789e1a RDI: 00000000ffffffff
[ 4250.158928] RBP: ffff956d18b9ce00 R08: 000000000000063a R09: 0000000000000001
[ 4250.158931] R10: 0000000000000000 R11: 0000000000000001 R12: ffff956d098d6288
[ 4250.158934] R13: ffffffffc0b7a1d0 R14: ffffffffc0b7a1d0 R15: ffff956d098d6288
[ 4250.158938] FS: 0000000000000000(0000) GS:ffff956d18b80000(0000) knlGS:0000000000000000
[ 4250.158942] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 4250.158945] CR2: 00007f5bdfbf9000 CR3: 00000000b87e8000 CR4: 00000000003506e0
[ 4250.158949] Call Trace:
[ 4250.158954] <IRQ>
[ 4250.158964] call_timer_fn+0x2d/0x160
[ 4250.158977] ? rtw_tx_write_data_h2c_get+0x90/0x90 [rtw88_core]
[ 4250.158981] __run_timers+0x1ec/0x280
[ 4250.158988] run_timer_softirq+0x2b/0x50
[ 4250.158995] __do_softirq+0xff/0x344
[ 4250.159002] asm_call_irq_on_stack+0x12/0x20
[ 4250.159006] </IRQ>
[ 4250.159012] do_softirq_own_stack+0x5d/0x80
[ 4250.159018] irq_exit_rcu+0xd8/0x120
[ 4250.159025] sysvec_apic_timer_interrupt+0x47/0xe0
[ 4250.159031] asm_sysvec_apic_timer_interrupt+0x12/0x20
[ 4250.159037] RIP: 0010:cpuidle_enter_state+0xcc/0x3c0
[ 4250.159043] Code: 8a ea 44 7e e8 b5 25 90 ff 49 89 c7 0f 1f 44 00 00 31 ff e8 b6 33 90 ff 80 7c 24 0f 00 0f 85 11 02 00 00 fb 66 0f 1f 44 00 00 <45> 85 e4 0f 88 53 01 00 00 49 63 d4 4c 2b 3c 24 48 8d 04 52 48 8d
[ 4250.159048] RSP: 0018:ffffb52e00187ea0 EFLAGS: 00000246
[ 4250.159052] RAX: ffff956d18b80000 RBX: ffff956d143a0c00 RCX: 000000000000001f
[ 4250.159055] RDX: 0000000000000000 RSI: ffffffff82789e1a RDI: ffffffff827697e9
[ 4250.159058] RBP: ffffffff82ad43c0 R08: 000003dd913304b6 R09: 0000000000000020
[ 4250.159061] R10: 000000000000b358 R11: 00000000000047be R12: 0000000000000002
[ 4250.159064] R13: ffffffff82ad44a8 R14: 0000000000000002 R15: 000003dd913304b6
[ 4250.159073] cpuidle_enter+0x29/0x40
[ 4250.159079] do_idle+0x1ed/0x280
[ 4250.159084] cpu_startup_entry+0x19/0x20
[ 4250.159089] secondary_startup_64+0xb6/0xc0
[ 4250.159095] ---[ end trace 099989ed35f893c1 ]---
[ 4893.947565] rtw_8822be 0000:02:00.0: firmware failed to restore hardware setting
[ 5457.822712] rtw_8822be 0000:02:00.0: firmware failed to restore hardware setting
[ 6179.990352] rtw_8822be 0000:02:00.0: firmware failed to restore hardware setting
[ 6312.049451] rtw_8822be 0000:02:00.0: firmware failed to restore hardware setting
[ 6710.999445] rtw_8822be 0000:02:00.0: firmware failed to restore hardware setting
[ 6951.009990] rtw_8822be 0000:02:00.0: firmware failed to restore hardware setting
[ 7441.910470] rtw_8822be 0000:02:00.0: firmware failed to restore hardware setting
[ 7566.890271] Bluetooth: hci0: advertising data len corrected 31 -> 27
[ 7567.026273] Bluetooth: hci0: advertising data len corrected 31 -> 27
[ 7567.068272] Bluetooth: hci0: advertising data len corrected 31 -> 27
[ 7567.202255] Bluetooth: hci0: advertising data len corrected 31 -> 27
[ 7567.428273] Bluetooth: hci0: advertising data len corrected 31 -> 27
[ 7567.560275] Bluetooth: hci0: advertising data len corrected 31 -> 27
[ 7568.144275] Bluetooth: hci0: advertising data len corrected 31 -> 27
[ 7568.524275] Bluetooth: hci0: advertising data len corrected 31 -> 27
[ 7569.665294] Bluetooth: hci0: advertising data len corrected 31 -> 27
[ 7569.888274] Bluetooth: hci0: advertising data len corrected 31 -> 27
[ 8081.671794] rtw_8822be 0000:02:00.0: firmware failed to restore hardware setting
[ 8397.783783] rtw_8822be 0000:02:00.0: failed to send h2c command
[ 8501.816250] rtw_8822be 0000:02:00.0: firmware failed to restore hardware setting
[ 8956.518437] wlo1: deauthenticated from f8:18:97:6a:d5:9e (Reason: 7=CLASS3_FRAME_FROM_NONASSOC_STA)
[ 8956.654938] rtw_8822be 0000:02:00.0: sta f8:18:97:6a:d5:9e with macid 0 left
[ 8956.708860] wlo1: authenticate with f8:18:97:6a:d5:9e
[ 8957.234918] wlo1: send auth to f8:18:97:6a:d5:9e (try 1/3)
[ 8957.255940] wlo1: authenticated
[ 8957.258326] wlo1: associate with f8:18:97:6a:d5:9e (try 1/3)
[ 8957.262385] wlo1: RX AssocResp from f8:18:97:6a:d5:9e (capab=0x411 status=0 aid=4)
[ 8957.262407] rtw_8822be 0000:02:00.0: sta f8:18:97:6a:d5:9e joined with macid 0
[ 8957.262638] wlo1: associated
[ 9129.848808] rtw_8822be 0000:02:00.0: failed to send h2c command
[ 9190.869624] bt_err_ratelimited: 6 callbacks suppressed
[ 9190.869627] Bluetooth: hci0: advertising data len corrected 31 -> 27
[ 9190.872594] Bluetooth: hci0: advertising data len corrected 31 -> 24
[ 9191.940656] Bluetooth: hci0: advertising data len corrected 31 -> 27
[ 9193.019661] Bluetooth: hci0: advertising data len corrected 31 -> 27
[ 9193.155672] Bluetooth: hci0: advertising data len corrected 31 -> 27
[ 9193.379681] Bluetooth: hci0: advertising data len corrected 31 -> 27
[ 9193.566650] Bluetooth: hci0: advertising data len corrected 31 -> 27
[ 9194.283184] Bluetooth: hci0: advertising data len corrected 31 -> 27
[ 9195.005676] Bluetooth: hci0: advertising data len corrected 31 -> 27
[ 9195.194676] Bluetooth: hci0: advertising data len corrected 31 -> 27
[ 9196.218678] bt_err_ratelimited: 2 callbacks suppressed
[ 9196.218682] Bluetooth: hci0: advertising data len corrected 31 -> 27
[ 9196.752674] Bluetooth: hci0: advertising data len corrected 31 -> 27
[ 9196.878674] Bluetooth: hci0: advertising data len corrected 31 -> 27
[ 9498.974958] rtw_8822be 0000:02:00.0: failed to send h2c command
[ 9635.698511] input: G604 LIGHTSPEED Keyboard as /devices/virtual/misc/uhid/0005:046D:B024.0007/input/input29
[ 9635.698777] input: G604 LIGHTSPEED Mouse as /devices/virtual/misc/uhid/0005:046D:B024.0007/input/input30
[ 9635.699024] input: G604 LIGHTSPEED Consumer Control as /devices/virtual/misc/uhid/0005:046D:B024.0007/input/input31
[ 9635.699200] hid-generic 0005:046D:B024.0007: input,hidraw4: BLUETOOTH HID v0.14 Keyboard [G604 LIGHTSPEED] on a4:fc:77:52:2a:8c
[ 9974.048634] rtw_8822be 0000:02:00.0: firmware failed to restore hardware setting
[10667.903532] usb 1-4: reset full-speed USB device number 3 using xhci_hcd
[10668.059056] audit: type=1130 audit(1619457959.572:326): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[10672.153218] audit: type=1100 audit(1619457963.664:327): pid=10421 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:authentication grantors=pam_unix acct="joel" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[10672.155396] audit: type=1101 audit(1619457963.667:328): pid=10421 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="joel" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[10672.155751] audit: type=1110 audit(1619457963.667:329): pid=10421 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[10672.160894] audit: type=1105 audit(1619457963.674:330): pid=10421 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[10698.060235] audit: type=1131 audit(1619457989.584:331): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[10797.819658] usb 1-4: reset full-speed USB device number 3 using xhci_hcd
[10797.978771] audit: type=1130 audit(1619458089.441:332): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[10804.966906] audit: type=1100 audit(1619458096.407:333): pid=10474 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:authentication grantors=pam_unix acct="joel" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/3 res=success'
[10804.969236] audit: type=1101 audit(1619458096.410:334): pid=10474 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="joel" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/3 res=success'
[10804.969762] audit: type=1110 audit(1619458096.410:335): pid=10474 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/3 res=success'
[10804.974950] audit: type=1105 audit(1619458096.417:336): pid=10474 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/3 res=success'
[10810.845248] audit: type=1106 audit(1619458102.272:337): pid=10421 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[10810.845509] audit: type=1104 audit(1619458102.272:338): pid=10421 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[10813.431301] audit: type=1106 audit(1619458104.852:339): pid=10474 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/3 res=success'
[10813.431523] audit: type=1104 audit(1619458104.852:340): pid=10474 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/3 res=success'
[10821.851397] audit: type=1100 audit(1619458113.256:341): pid=10517 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:authentication grantors=pam_unix acct="joel" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[10821.853565] audit: type=1101 audit(1619458113.259:342): pid=10517 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="joel" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[10821.853875] audit: type=1110 audit(1619458113.259:343): pid=10517 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[10821.858573] audit: type=1105 audit(1619458113.266:344): pid=10517 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[10828.168440] audit: type=1131 audit(1619458119.562:345): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[10850.351167] audit: type=1106 audit(1619458141.719:346): pid=10517 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[10850.351260] audit: type=1104 audit(1619458141.719:347): pid=10517 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[10852.328481] audit: type=1101 audit(1619458143.694:348): pid=10527 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="joel" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[10852.328808] audit: type=1110 audit(1619458143.694:349): pid=10527 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[10852.333070] audit: type=1105 audit(1619458143.697:350): pid=10527 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[10893.763044] audit: type=1106 audit(1619458185.101:351): pid=10527 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[10893.763156] audit: type=1104 audit(1619458185.101:352): pid=10527 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[10898.007704] usb 1-4: reset full-speed USB device number 3 using xhci_hcd
[10898.166716] audit: type=1130 audit(1619458189.505:353): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[10901.884809] audit: type=1100 audit(1619458193.220:354): pid=10570 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:authentication grantors=pam_unix acct="joel" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[10901.886969] audit: type=1101 audit(1619458193.220:355): pid=10570 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="joel" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[10901.887399] audit: type=1110 audit(1619458193.224:356): pid=10570 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[10901.892070] audit: type=1105 audit(1619458193.227:357): pid=10570 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[10928.250456] audit: type=1131 audit(1619458219.580:358): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[10951.696808] audit: type=1106 audit(1619458243.026:359): pid=10570 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[10951.696974] audit: type=1104 audit(1619458243.026:360): pid=10570 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[10954.794676] audit: type=1101 audit(1619458246.122:361): pid=10595 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="joel" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[10954.794864] audit: type=1110 audit(1619458246.122:362): pid=10595 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[10954.797874] audit: type=1105 audit(1619458246.126:363): pid=10595 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[11052.579107] audit: type=1106 audit(1619458343.882:364): pid=10595 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[11052.579119] audit: type=1104 audit(1619458343.882:365): pid=10595 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[11062.472065] rfkill: input handler enabled
[11063.966245] rfkill: input handler disabled
[11066.310386] rfkill: input handler enabled
[11066.315057] audit: type=1130 audit(1619458357.615:366): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=getty@tty4 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[11070.810796] audit: type=1100 audit(1619458362.107:367): pid=10687 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="joel" exe="/usr/bin/login" hostname=manjaro addr=? terminal=/dev/tty4 res=success'
[11070.812792] audit: type=1101 audit(1619458362.110:368): pid=10687 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="joel" exe="/usr/bin/login" hostname=manjaro addr=? terminal=/dev/tty4 res=success'
[11070.813511] audit: type=1103 audit(1619458362.110:369): pid=10687 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="joel" exe="/usr/bin/login" hostname=manjaro addr=? terminal=/dev/tty4 res=success'
[11070.813625] audit: type=1006 audit(1619458362.110:370): pid=10687 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=tty4 old-ses=4294967295 ses=14 res=1
[11070.839192] audit: type=1105 audit(1619458362.137:371): pid=10687 uid=0 auid=1000 ses=14 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="joel" exe="/usr/bin/login" hostname=manjaro addr=? terminal=/dev/tty4 res=success'
[11070.839335] audit: type=1110 audit(1619458362.137:372): pid=10687 uid=0 auid=1000 ses=14 subj==unconfined msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="joel" exe="/usr/bin/login" hostname=manjaro addr=? terminal=/dev/tty4 res=success'
[11073.787755] usb 1-4: reset full-speed USB device number 3 using xhci_hcd
[11073.942745] audit: type=1130 audit(1619458365.242:373): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[11076.165900] audit: type=1100 audit(1619458367.465:374): pid=10710 uid=1000 auid=1000 ses=14 subj==unconfined msg='op=PAM:authentication grantors=pam_unix acct="joel" exe="/usr/bin/sudo" hostname=manjaro addr=? terminal=/dev/tty4 res=success'
[11076.167880] audit: type=1101 audit(1619458367.465:375): pid=10710 uid=1000 auid=1000 ses=14 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="joel" exe="/usr/bin/sudo" hostname=manjaro addr=? terminal=/dev/tty4 res=success'
[11076.168078] audit: type=1110 audit(1619458367.465:376): pid=10710 uid=1000 auid=1000 ses=14 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=manjaro addr=? terminal=/dev/tty4 res=success'
[11076.170895] audit: type=1105 audit(1619458367.468:377): pid=10710 uid=1000 auid=1000 ses=14 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=manjaro addr=? terminal=/dev/tty4 res=success'
[11104.294192] audit: type=1131 audit(1619458395.583:378): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[11104.934613] rtw_8822be 0000:02:00.0: firmware failed to restore hardware setting
[11187.155694] audit: type=1106 audit(1619458478.426:379): pid=10710 uid=1000 auid=1000 ses=14 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=manjaro addr=? terminal=/dev/tty4 res=success'
[11187.155787] audit: type=1104 audit(1619458478.426:380): pid=10710 uid=1000 auid=1000 ses=14 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=manjaro addr=? terminal=/dev/tty4 res=success'
[11190.518333] audit: type=1100 audit(1619458481.785:381): pid=10735 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_succeed_if,pam_permit acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[11190.518881] audit: type=1101 audit(1619458481.789:382): pid=10735 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_succeed_if,pam_permit acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[11190.521480] audit: type=1103 audit(1619458481.789:383): pid=10735 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[11190.535727] audit: type=1006 audit(1619458481.805:384): pid=10735 uid=0 subj==unconfined old-auid=4294967295 auid=120 tty=(none) old-ses=4294967295 ses=15 res=1
[11190.562613] audit: type=1130 audit(1619458481.832:385): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[11190.571026] audit: type=1101 audit(1619458481.839:386): pid=10740 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="gdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[11190.571070] audit: type=1103 audit(1619458481.839:387): pid=10740 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="gdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[11190.571132] audit: type=1006 audit(1619458481.839:388): pid=10740 uid=0 subj==unconfined old-auid=4294967295 auid=120 tty=(none) old-ses=4294967295 ses=16 res=1
[11192.272282] kauditd_printk_skb: 8 callbacks suppressed
[11192.272285] audit: type=1334 audit(1619458483.538:397): prog-id=53 op=LOAD
[11192.272639] audit: type=1334 audit(1619458483.538:398): prog-id=54 op=LOAD
[11192.371201] audit: type=1130 audit(1619458483.638:399): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[11192.389783] rfkill: input handler disabled
[11192.591296] usb 1-4: reset full-speed USB device number 3 using xhci_hcd
[11192.746400] audit: type=1130 audit(1619458484.015:400): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[11205.317208] audit: type=1106 audit(1619458496.583:401): pid=10735 uid=0 auid=120 ses=15 subj==unconfined msg='op=PAM:session_close grantors=pam_loginuid,pam_keyinit,pam_succeed_if,pam_permit,pam_systemd,pam_env acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[11205.317285] audit: type=1104 audit(1619458496.583:402): pid=10735 uid=0 auid=120 ses=15 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[11215.608583] audit: type=1131 audit(1619458506.871:403): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[11215.624251] audit: type=1131 audit(1619458506.888:404): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[11217.359000] audit: type=1100 audit(1619458508.621:405): pid=11177 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:authentication grantors=pam_unix acct="joel" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[11217.360651] audit: type=1101 audit(1619458508.624:406): pid=11177 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="joel" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[11217.361217] audit: type=1110 audit(1619458508.624:407): pid=11177 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[11217.367297] audit: type=1105 audit(1619458508.631:408): pid=11177 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[11223.101139] audit: type=1131 audit(1619458514.366:409): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[11223.111346] audit: type=1131 audit(1619458514.376:410): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[11223.185190] audit: type=1334 audit(1619458514.450:411): prog-id=52 op=UNLOAD
[11223.185198] audit: type=1334 audit(1619458514.450:412): prog-id=51 op=UNLOAD
[11223.307192] audit: type=1334 audit(1619458514.570:413): prog-id=54 op=UNLOAD
[11223.307224] audit: type=1334 audit(1619458514.570:414): prog-id=53 op=UNLOAD
[11223.309760] audit: type=1131 audit(1619458514.573:415): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[11226.775504] rtw_8822be 0000:02:00.0: firmware failed to restore hardware setting
[11252.331829] audit: type=1106 audit(1619458543.587:416): pid=11177 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[11252.332031] audit: type=1104 audit(1619458543.587:417): pid=11177 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[11422.288953] audit: type=1101 audit(1619458713.506:418): pid=11224 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="joel" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[11422.289143] audit: type=1110 audit(1619458713.506:419): pid=11224 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[11422.293534] audit: type=1105 audit(1619458713.509:420): pid=11224 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[11437.089213] rtw_8822be 0000:02:00.0: firmware failed to restore hardware setting
[11611.947436] rtw_8822be 0000:02:00.0: firmware failed to restore hardware setting
[11679.904359] audit: type=1130 audit(1619458971.047:421): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[11988.162708] audit: type=1106 audit(1619459279.554:422): pid=11224 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[11988.162790] audit: type=1104 audit(1619459279.554:423): pid=11224 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[12009.987490] usb 1-4: reset full-speed USB device number 3 using xhci_hcd
[12010.143310] audit: type=1130 audit(1619459301.541:424): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[12013.322291] audit: type=1100 audit(1619459304.722:425): pid=11719 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:authentication grantors=pam_unix acct="joel" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[12013.324580] audit: type=1101 audit(1619459304.722:426): pid=11719 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="joel" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[12013.324973] audit: type=1110 audit(1619459304.722:427): pid=11719 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[12013.329776] audit: type=1105 audit(1619459304.729:428): pid=11719 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
