25.0.7 hibernation vanished
After updates and trying to resolve the .pacnew files (from the last THREE updates, because I simply forgot) my option to hibernate vanished. It is not even offered as an option. Clearly I did something wrong, but I have no idea WHAT!
So, how do you make hibernate no longer be an option and how do you REVERSE that.
It has been working properly from install (about 3.5 years ago) until this week. Any pointer would be most welcome. (As long as it is not a pointer into the WIKI, which seems to be down right now.)
UPDATE: Pinebook died, now running a DELL Ultrabook with i5-6300u X86_64 CPU.
A quick grep ".pacnew" /var/log/pacman.log does not show anything from the pacnews that could have caused that, in 2025 at least.
my pacnews
[2024-12-01T18:46:19+0100] [ALPM] warning: /etc/clamav/freshclam.conf installed as /etc/clamav/freshclam.conf.pacnew
[2024-12-01T18:47:16+0100] [ALPM] warning: /etc/tlp.conf installed as /etc/tlp.conf.pacnew
[2025-02-06T22:54:56+0100] [ALPM] warning: /etc/systemd/coredump.conf installed as /etc/systemd/coredump.conf.pacnew
[2025-03-10T18:56:44+0100] [ALPM] warning: /etc/tlp.conf installed as /etc/tlp.conf.pacnew
[2025-05-16T17:51:05+0200] [ALPM] warning: /etc/hosts installed as /etc/hosts.pacnew
[2025-05-16T17:51:05+0200] [ALPM] warning: /etc/passwd installed as /etc/passwd.pacnew
[2025-05-16T17:51:05+0200] [ALPM] warning: /etc/shells installed as /etc/shells.pacnew
[2025-08-12T12:11:14+0300] [ALPM] warning: /etc/libvirt/nwfilter/clean-traffic-gateway.xml installed as /etc/libvirt/nwfilter/clean-traffic-gateway.xml.pacnew
[2025-08-12T12:11:14+0300] [ALPM] warning: /etc/libvirt/nwfilter/clean-traffic.xml installed as /etc/libvirt/nwfilter/clean-traffic.xml.pacnew
[2025-08-12T12:11:14+0300] [ALPM] warning: /etc/libvirt/nwfilter/qemu-announce-self-rarp.xml installed as /etc/libvirt/nwfilter/qemu-announce-self-rarp.xml.pacnew
[2025-08-12T12:11:14+0300] [ALPM] warning: /etc/libvirt/nwfilter/qemu-announce-self.xml installed as /etc/libvirt/nwfilter/qemu-announce-self.xml.pacnew
Your pacnew list can of course differ. AND according to your profile you are on arm, and unfortunately that branch is beginning to differentiate significantly from the x64 one.
Why don’t you go through the procedure to activate hibernation once again and see if something is missing? Basically it will either be the resume hook in mkinitcpio or the resume in the kernel boot line in the grub config.
https://wiki.archlinux.org/title/Power_management/Suspend_and_hibernate#Hibernation
I updated my profile to include current hardware.
Ran those steps (for BIOS machine, have EFI disabled) and saw no difference. Added the resume=PARTLABEL=swap to my kernel command line in the grub config, and saw no difference. (Except it does appear on the command line and there is a generated error about not finding something. The partition label IS swap, but I have not tried using the UUID yet.
EDIT: tried the UUID and viewed the error again. It is a failure to stat device. Does that help?
PS> I notice the articles mention hibernate not working. That is not my problem, my problem is that the hibernate OPTION does not even appear. Now, the fix may be the same or related but I did not want to fail to communicate that properly.
I suspect it is automatically hidden if not working/configured.
I would have said to try the command line (systemctl hibernate), but since you already see the error on boot it is obvious it will not work.
You can see the errors in the kernel buffer and from the current boot.
journalctl -b -p3 --no-pager
journalctl -k
This and some other useful commands i have collected here.
To me so far seems like a problem with the swap partition. This error was mentioned in several topics in the forum but i cannot remember the specifics.
Post the logs here we might get new ideas.
Aug 15 15:00:12 warbler kernel: x86/cpu: SGX disabled or unsupported by BIOS.
Aug 15 15:00:15 warbler kernel: Bluetooth: hci0: Reading supported features failed (-16)
Aug 15 15:00:17 warbler systemd[1048]: Failed to start Update XDG user dir configuration.
Aug 15 15:00:17 warbler dbus-broker-launch[1070]: Ignoring duplicate name 'org.freedesktop.Notifications' in service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service'
Aug 15 15:00:23 warbler dbus-broker-launch[1307]: Ignoring duplicate name 'org.freedesktop.Notifications' in service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service'
Aug 15 15:00:29 warbler pulseaudio[1453]: Failed to open connection to session manager: None of the authentication protocols specified are supported
Aug 15 15:00:29 warbler pulseaudio[1453]: Failed to load module "module-x11-xsmp" (argument: "display=:1 xauthority=/run/user/1000/xauth_qRBNwr session_manager=local/warbler:@/tmp/.ICE-unix/1491,unix/warbler:/tmp/.ICE-unix/1491"): initialization failed.
Aug 15 15:00:33 warbler systemd[1154]: Failed to start Swaync notification daemon.
Aug 15 15:00:34 warbler systemd[1154]: Failed to start Swaync notification daemon.
Aug 15 15:00:35 warbler systemd[1154]: Failed to start Swaync notification daemon.
Aug 15 15:00:36 warbler systemd[1154]: Failed to start Swaync notification daemon.
Aug 15 15:17:10 warbler kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=1873 end=1874) time 227 us, min 1431, max 1439, scanline start 1420, end 1440
Aug 15 19:18:02 warbler kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=103454 end=103455) time 232 us, min 1431, max 1439, scanline start 1421, end 1441
And then
Aug 15 15:00:12 warbler kernel: Linux version 6.16.0-5-MANJARO (linux616@manjaro) (gcc (GCC) 15.1.1 20250729, GNU ld (GNU Binutils) 2.45.0) #1 SMP PREEMPT_DYNAMIC Thu, >
Aug 15 15:00:12 warbler kernel: Command line: BOOT_IMAGE=/@/boot/vmlinuz-6.16-x86_64 root=UUID=c0742a37-0fbc-40a4-8f94-e208c0606e5c rw rootflags=subvol=@ quiet udev.log>
Aug 15 15:00:12 warbler kernel: BIOS-provided physical RAM map:
Aug 15 15:00:12 warbler kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009dbff] usable
Aug 15 15:00:12 warbler kernel: BIOS-e820: [mem 0x000000000009dc00-0x000000000009ffff] reserved
Aug 15 15:00:12 warbler kernel: BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
Aug 15 15:00:12 warbler kernel: BIOS-e820: [mem 0x0000000000100000-0x00000000a5f63fff] usable
Aug 15 15:00:12 warbler kernel: BIOS-e820: [mem 0x00000000a5f64000-0x00000000a5f64fff] ACPI NVS
Aug 15 15:00:12 warbler kernel: BIOS-e820: [mem 0x00000000a5f65000-0x00000000ab771fff] reserved
Aug 15 15:00:12 warbler kernel: BIOS-e820: [mem 0x00000000ab772000-0x00000000ab7aafff] ACPI data
Aug 15 15:00:12 warbler kernel: BIOS-e820: [mem 0x00000000ab7ab000-0x00000000abe0ffff] ACPI NVS
Aug 15 15:00:12 warbler kernel: BIOS-e820: [mem 0x00000000abe10000-0x00000000afffffff] reserved
Aug 15 15:00:12 warbler kernel: BIOS-e820: [mem 0x00000000f0000000-0x00000000f7ffffff] reserved
Aug 15 15:00:12 warbler kernel: BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
Aug 15 15:00:12 warbler kernel: BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
Aug 15 15:00:12 warbler kernel: BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
Aug 15 15:00:12 warbler kernel: BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
Aug 15 15:00:12 warbler kernel: BIOS-e820: [mem 0x0000000100000000-0x000000044dffffff] usable
Aug 15 15:00:12 warbler kernel: NX (Execute Disable) protection: active
Aug 15 15:00:12 warbler kernel: APIC: Static calls initialized
Aug 15 15:00:12 warbler kernel: SMBIOS 3.0.0 present.
Aug 15 15:00:12 warbler kernel: DMI: Dell Inc. Latitude E7470/0T6HHJ, BIOS 1.36.3 09/18/2022
Aug 15 15:00:12 warbler kernel: DMI: Memory slots populated: 2/2
Aug 15 15:00:12 warbler kernel: tsc: Detected 2500.000 MHz processor
Aug 15 15:00:12 warbler kernel: tsc: Detected 2499.952 MHz TSC
Aug 15 15:00:12 warbler kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
Aug 15 15:00:12 warbler kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
Aug 15 15:00:12 warbler kernel: last_pfn = 0x44e000 max_arch_pfn = 0x400000000
Aug 15 15:00:12 warbler kernel: MTRR map: 4 entries (3 fixed + 1 variable; max 23), built from 10 variable MTRRs
Aug 15 15:00:12 warbler kernel: x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
Aug 15 15:00:12 warbler kernel: last_pfn = 0xab7ab max_arch_pfn = 0x400000000
Aug 15 15:00:12 warbler kernel: found SMP MP-table at [mem 0x000fcda0-0x000fcdaf]
Aug 15 15:00:12 warbler kernel: Using GB pages for direct mapping
Aug 15 15:00:12 warbler kernel: RAMDISK: [mem 0x34b0b000-0x3657cfff]
Aug 15 15:00:12 warbler kernel: ACPI: Early table checksum verification disabled
Aug 15 15:00:12 warbler kernel: ACPI: RSDP 0x00000000000E9860 000024 (v02 DELL  )
Aug 15 15:00:12 warbler kernel: ACPI: XSDT 0x00000000AB77D0A8 0000D4 (v01 DELL   CBX3     01072009 AMI  00010013)
Aug 15 15:00:12 warbler kernel: ACPI: FACP 0x00000000AB79CB58 00010C (v05 DELL   CBX3     01072009 AMI  00010013)
Aug 15 15:00:12 warbler kernel: ACPI: DSDT 0x00000000AB77D210 01F948 (v02 DELL   CBX3     01072009 INTL 20120913)
Aug 15 15:00:12 warbler kernel: ACPI: FACS 0x00000000ABE0DE80 000040
Aug 15 15:00:12 warbler kernel: ACPI: APIC 0x00000000AB79CC68 000084 (v03 DELL   CBX3     01072009 AMI  00010013)
Aug 15 15:00:12 warbler kernel: ACPI: FPDT 0x00000000AB79CCF0 000044 (v01 DELL   CBX3     01072009 AMI  00010013)
Aug 15 15:00:12 warbler kernel: ACPI: MCFG 0x00000000AB79CD38 00003C (v01 DELL   CBX3     01072009 MSFT 00000097)
Aug 15 15:00:12 warbler kernel: ACPI: HPET 0x00000000AB79CD78 000038 (v01 DELL   CBX3     01072009 AMI. 0005000B)
Aug 15 15:00:12 warbler kernel: ACPI: SSDT 0x00000000AB79CDB0 00046D (v01 SataRe SataTabl 00001000 INTL 20120913)
Aug 15 15:00:12 warbler kernel: ACPI: LPIT 0x00000000AB79D220 000094 (v01 INTEL  SKL-ULT  00000000 MSFT 0000005F)
Aug 15 15:00:12 warbler kernel: ACPI: SSDT 0x00000000AB79D2B8 000248 (v02 INTEL  sensrhub 00000000 INTL 20120913)
Aug 15 15:00:12 warbler kernel: ACPI: SSDT 0x00000000AB79D500 002BAE (v02 INTEL  PtidDevc 00001000 INTL 20120913)
Aug 15 15:00:12 warbler kernel: ACPI: SSDT 0x00000000AB7A00B0 000814 (v02 INTEL  xh_rvp07 00000000 INTL 20120913)
Aug 15 15:00:12 warbler kernel: ACPI: SSDT 0x00000000AB7A08C8 0004DC (v02 INTEL  zpodd    00001000 INTL 20120913)
Aug 15 15:00:12 warbler kernel: ACPI: DBGP 0x00000000AB7A0DA8 000034 (v01 INTEL           00000000 MSFT 0000005F)
Aug 15 15:00:12 warbler kernel: ACPI: DBG2 0x00000000AB7A0DE0 000054 (v00 INTEL           00000000 MSFT 0000005F)
Aug 15 15:00:12 warbler kernel: ACPI: SSDT 0x00000000AB7A0E38 0035DA (v02 SaSsdt SaSsdt   00003000 INTL 20120913)
Aug 15 15:00:12 warbler kernel: ACPI: UEFI 0x00000000AB7A4418 000042 (v01                 00000000      00000000)
Aug 15 15:00:12 warbler kernel: ACPI: SSDT 0x00000000AB7A4460 000E73 (v02 CpuRef CpuSsdt  00003000 INTL 20120913)
Aug 15 15:00:12 warbler kernel: ACPI: SSDT 0x00000000AB7A52D8 003BFD (v02 DptfTa DptfTabl 00001000 INTL 20120913)
Aug 15 15:00:12 warbler kernel: ACPI: MSDM 0x00000000AB7A8ED8 000055 (v03 DELL   CBX3     06222004 AMI  00010013)
Aug 15 15:00:12 warbler kernel: ACPI: SLIC 0x00000000AB7A8F30 000176 (v03 DELL   CBX3     01072009 MSFT 00010013)
Aug 15 15:00:12 warbler kernel: ACPI: DMAR 0x00000000AB7A90A8 0000A8 (v01 INTEL  SKL      00000001 INTL 00000001)
Aug 15 15:00:12 warbler kernel: ACPI: TPM2 0x00000000AB7A9150 000034 (v03        Tpm2Tabl 00000001 AMI  00000000)
Aug 15 15:00:12 warbler kernel: ACPI: ASF! 0x00000000AB7A9188 0000A5 (v32 INTEL   HCG     00000001 TFSM 000F4240)
Aug 15 15:00:12 warbler kernel: ACPI: Reserving FACP table memory at [mem 0xab79cb58-0xab79cc63]
Aug 15 15:00:12 warbler kernel: ACPI: Reserving DSDT table memory at [mem 0xab77d210-0xab79cb57]
Aug 15 15:00:12 warbler kernel: ACPI: Reserving FACS table memory at [mem 0xabe0de80-0xabe0debf]
Aug 15 15:00:12 warbler kernel: ACPI: Reserving APIC table memory at [mem 0xab79cc68-0xab79cceb]
Aug 15 15:00:12 warbler kernel: ACPI: Reserving FPDT table memory at [mem 0xab79ccf0-0xab79cd33]
Aug 15 15:00:12 warbler kernel: ACPI: Reserving MCFG table memory at [mem 0xab79cd38-0xab79cd73]
Aug 15 15:00:12 warbler kernel: ACPI: Reserving HPET table memory at [mem 0xab79cd78-0xab79cdaf]
Aug 15 15:00:12 warbler kernel: ACPI: Reserving SSDT table memory at [mem 0xab79cdb0-0xab79d21c]
Aug 15 15:00:12 warbler kernel: ACPI: Reserving LPIT table memory at [mem 0xab79d220-0xab79d2b3]
Aug 15 15:00:12 warbler kernel: ACPI: Reserving SSDT table memory at [mem 0xab79d2b8-0xab79d4ff]
Aug 15 15:00:12 warbler kernel: ACPI: Reserving SSDT table memory at [mem 0xab79d500-0xab7a00ad]
Aug 15 15:00:12 warbler kernel: ACPI: Reserving SSDT table memory at [mem 0xab7a00b0-0xab7a08c3]
Aug 15 15:00:12 warbler kernel: ACPI: Reserving SSDT table memory at [mem 0xab7a08c8-0xab7a0da3]
Aug 15 15:00:12 warbler kernel: ACPI: Reserving DBGP table memory at [mem 0xab7a0da8-0xab7a0ddb]
Aug 15 15:00:12 warbler kernel: ACPI: Reserving DBG2 table memory at [mem 0xab7a0de0-0xab7a0e33]
Aug 15 15:00:12 warbler kernel: ACPI: Reserving SSDT table memory at [mem 0xab7a0e38-0xab7a4411]
Aug 15 15:00:12 warbler kernel: ACPI: Reserving UEFI table memory at [mem 0xab7a4418-0xab7a4459]
Aug 15 15:00:12 warbler kernel: ACPI: Reserving SSDT table memory at [mem 0xab7a4460-0xab7a52d2]
Aug 15 15:00:12 warbler kernel: ACPI: Reserving SSDT table memory at [mem 0xab7a52d8-0xab7a8ed4]
Aug 15 15:00:12 warbler kernel: ACPI: Reserving MSDM table memory at [mem 0xab7a8ed8-0xab7a8f2c]
Aug 15 15:00:12 warbler kernel: ACPI: Reserving SLIC table memory at [mem 0xab7a8f30-0xab7a90a5]
Aug 15 15:00:12 warbler kernel: ACPI: Reserving DMAR table memory at [mem 0xab7a90a8-0xab7a914f]
Aug 15 15:00:12 warbler kernel: ACPI: Reserving TPM2 table memory at [mem 0xab7a9150-0xab7a9183]
Aug 15 15:00:12 warbler kernel: ACPI: Reserving ASF! table memory at [mem 0xab7a9188-0xab7a922c]
Aug 15 15:00:12 warbler kernel: No NUMA configuration found
Aug 15 15:00:12 warbler kernel: Faking a node at [mem 0x0000000000000000-0x000000044dffffff]
Aug 15 15:00:12 warbler kernel: NODE_DATA(0) allocated [mem 0x44dfd5280-0x44dffffff]
Aug 15 15:00:12 warbler kernel: Zone ranges:
Aug 15 15:00:12 warbler kernel:   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
Aug 15 15:00:12 warbler kernel:   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
Aug 15 15:00:12 warbler kernel:   Normal   [mem 0x0000000100000000-0x000000044dffffff]
Aug 15 15:00:12 warbler kernel:   Device   empty
Aug 15 15:00:12 warbler kernel: Movable zone start for each node
Aug 15 15:00:12 warbler kernel: Early memory node ranges
Aug 15 15:00:12 warbler kernel:   node   0: [mem 0x0000000000001000-0x000000000009cfff]
Aug 15 15:00:12 warbler kernel:   node   0: [mem 0x0000000000100000-0x00000000a5f63fff]
Aug 15 15:00:12 warbler kernel:   node   0: [mem 0x0000000100000000-0x000000044dffffff]
Aug 15 15:00:12 warbler kernel: Initmem setup node 0 [mem 0x0000000000001000-0x000000044dffffff]
Aug 15 15:00:12 warbler kernel: On node 0, zone DMA: 1 pages in unavailable ranges
Aug 15 15:00:12 warbler kernel: On node 0, zone DMA: 99 pages in unavailable ranges
Aug 15 15:00:12 warbler kernel: On node 0, zone Normal: 8348 pages in unavailable ranges
Aug 15 15:00:12 warbler kernel: On node 0, zone Normal: 8192 pages in unavailable ranges
Aug 15 15:00:12 warbler kernel: Reserving Intel graphics memory at [mem 0xae000000-0xafffffff]
Aug 15 15:00:12 warbler kernel: ACPI: PM-Timer IO Port: 0x1808
Aug 15 15:00:12 warbler kernel: ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
Aug 15 15:00:12 warbler kernel: ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
Aug 15 15:00:12 warbler kernel: ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
Aug 15 15:00:12 warbler kernel: ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
Aug 15 15:00:12 warbler kernel: IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
ug 15 15:00:12 warbler kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Aug 15 15:00:12 warbler kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
Aug 15 15:00:12 warbler kernel: ACPI: Using ACPI (MADT) for SMP configuration information
Aug 15 15:00:12 warbler kernel: ACPI: HPET id: 0x8086a701 base: 0xfed00000
Aug 15 15:00:12 warbler kernel: TSC deadline timer available
Aug 15 15:00:12 warbler kernel: CPU topo: Max. logical packages:   1
Aug 15 15:00:12 warbler kernel: CPU topo: Max. logical dies:       1
Aug 15 15:00:12 warbler kernel: CPU topo: Max. dies per package:   1
Aug 15 15:00:12 warbler kernel: CPU topo: Max. threads per core:   2
Aug 15 15:00:12 warbler kernel: CPU topo: Num. cores per package:     2
Aug 15 15:00:12 warbler kernel: CPU topo: Num. threads per package:   4
Aug 15 15:00:12 warbler kernel: CPU topo: Allowing 4 present CPUs plus 0 hotplug CPUs
Aug 15 15:00:12 warbler kernel: PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
Aug 15 15:00:12 warbler kernel: PM: hibernation: Registered nosave memory: [mem 0x0009d000-0x000fffff]
Aug 15 15:00:12 warbler kernel: PM: hibernation: Registered nosave memory: [mem 0xa5f64000-0xffffffff]
Aug 15 15:00:12 warbler kernel: [mem 0xb0000000-0xefffffff] available for PCI devices
Aug 15 15:00:12 warbler kernel: Booting paravirtualized kernel on bare hardware
Aug 15 15:00:12 warbler kernel: clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1910969940391419 ns
Aug 15 15:00:12 warbler kernel: setup_percpu: NR_CPUS:8192 nr_cpumask_bits:4 nr_cpu_ids:4 nr_node_ids:1
Aug 15 15:00:12 warbler kernel: percpu: Embedded 62 pages/cpu s217088 r8192 d28672 u524288
Aug 15 15:00:12 warbler kernel: pcpu-alloc: s217088 r8192 d28672 u524288 alloc=1*2097152
Aug 15 15:00:12 warbler kernel: pcpu-alloc: [0] 0 1 2 3
Aug 15 15:00:12 warbler kernel: Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-6.16-x86_64 root=UUID=c0742a37-0fbc-40a4-8f94-e208c0606e5c rw rootflags=subvol=@ quiet u>
Aug 15 15:00:12 warbler kernel: Unknown kernel command line parameters "BOOT_IMAGE=/@/boot/vmlinuz-6.16-x86_64", will be passed to user space.
Aug 15 15:00:12 warbler kernel: random: crng init done
Aug 15 15:00:12 warbler kernel: printk: log buffer data + meta data: 131072 + 458752 = 589824 bytes
Aug 15 15:00:12 warbler kernel: Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
Aug 15 15:00:12 warbler kernel: Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
Aug 15 15:00:12 warbler kernel: software IO TLB: area num 4.
Aug 15 15:00:12 warbler kernel: Fallback order for Node 0: 0
Aug 15 15:00:12 warbler kernel: Built 1 zonelists, mobility grouping on.  Total pages: 4144896
Aug 15 15:00:12 warbler kernel: Policy zone: Normal
Aug 15 15:00:12 warbler kernel: mem auto-init: stack:all(zero), heap alloc:on, heap free:off
Aug 15 15:00:12 warbler kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Aug 15 15:00:12 warbler kernel: Kernel/User page tables isolation: enabled
Aug 15 15:00:12 warbler kernel: ftrace: allocating 56032 entries in 220 pages
Aug 15 15:00:12 warbler kernel: ftrace: allocated 220 pages with 5 groups
Aug 15 15:00:12 warbler kernel: Dynamic Preempt: full
Aug 15 15:00:12 warbler kernel: rcu: Preemptible hierarchical RCU implementation.
Aug 15 15:00:12 warbler kernel: rcu:         RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=4.
Aug 15 15:00:12 warbler kernel: rcu:         RCU priority boosting: priority 1 delay 500 ms.
Aug 15 15:00:12 warbler kernel:         Trampoline variant of Tasks RCU enabled.
Aug 15 15:00:12 warbler kernel:         Rude variant of Tasks RCU enabled.
Aug 15 15:00:12 warbler kernel:         Tracing variant of Tasks RCU enabled.
Aug 15 15:00:12 warbler kernel: rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
Aug 15 15:00:12 warbler kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
Aug 15 15:00:12 warbler kernel: RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
Aug 15 15:00:12 warbler kernel: RCU Tasks Rude: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
Aug 15 15:00:12 warbler kernel: RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
Aug 15 15:00:12 warbler kernel: NR_IRQS: 524544, nr_irqs: 1024, preallocated irqs: 16
Aug 15 15:00:12 warbler kernel: rcu: srcu_init: Setting srcu_struct sizes based on contention.
Aug 15 15:00:12 warbler kernel: kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
Aug 15 15:00:12 warbler kernel: spurious 8259A interrupt: IRQ7.
Aug 15 15:00:12 warbler kernel: Console: colour dummy device 80x25
Aug 15 15:00:12 warbler kernel: printk: legacy console [tty0] enabled
Aug 15 15:00:12 warbler kernel: ACPI: Core revision 20250404
Aug 15 15:00:12 warbler kernel: clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635855245 ns
Aug 15 15:00:12 warbler kernel: APIC: Switch to symmetric I/O mode setup
Aug 15 15:00:12 warbler kernel: DMAR: Host address width 39
Aug 15 15:00:12 warbler kernel: DMAR: DRHD base: 0x000000fed90000 flags: 0x0
Aug 15 15:00:12 warbler kernel: DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 7e3ff0505e
Aug 15 15:00:12 warbler kernel: DMAR: DRHD base: 0x000000fed91000 flags: 0x1
Aug 15 15:00:12 warbler kernel: DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
Aug 15 15:00:12 warbler kernel: DMAR: RMRR base: 0x000000ab515000 end: 0x000000ab534fff
Aug 15 15:00:12 warbler kernel: DMAR: RMRR base: 0x000000ad800000 end: 0x000000afffffff
Aug 15 15:00:12 warbler kernel: DMAR-IR: IOAPIC id 2 under DRHD base  0xfed91000 IOMMU 1
Aug 15 15:00:12 warbler kernel: DMAR-IR: HPET id 0 under DRHD base 0xfed91000
Aug 15 15:00:12 warbler kernel: DMAR-IR: x2apic is disabled because BIOS sets x2apic opt out bit.
Aug 15 15:00:12 warbler kernel: DMAR-IR: Use 'intremap=no_x2apic_optout' to override the BIOS setting.
Aug 15 15:00:12 warbler kernel: DMAR-IR: Enabled IRQ remapping in xapic mode
Aug 15 15:00:12 warbler kernel: x2apic: IRQ remapping doesn't support X2APIC mode
Aug 15 15:00:12 warbler kernel: ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
Aug 15 15:00:12 warbler kernel: clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x24090c9bc00, max_idle_ns: 440795288559 ns
Aug 15 15:00:12 warbler kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 4999.90 BogoMIPS (lpj=2499952)
Aug 15 15:00:12 warbler kernel: CPU0: Thermal monitoring enabled (TM1)
Aug 15 15:00:12 warbler kernel: Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
Aug 15 15:00:12 warbler kernel: Last level dTLB entries: 4KB 64, 2MB 32, 4MB 32, 1GB 4
Aug 15 15:00:12 warbler kernel: process: using mwait in idle threads
Aug 15 15:00:12 warbler kernel: Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
Aug 15 15:00:12 warbler kernel: SRBDS: Mitigation: Microcode
Aug 15 15:00:12 warbler kernel: Spectre V2 : Mitigation: IBRS
Aug 15 15:00:12 warbler kernel: RETBleed: Mitigation: IBRS
Aug 15 15:00:12 warbler kernel: Spectre V2 : User space: Mitigation: STIBP via prctl
Aug 15 15:00:12 warbler kernel: MDS: Mitigation: Clear CPU buffers
Aug 15 15:00:12 warbler kernel: MMIO Stale Data: Mitigation: Clear CPU buffers
Aug 15 15:00:12 warbler kernel: Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
Aug 15 15:00:12 warbler kernel: Spectre V2 : Spectre v2 / SpectreRSB: Filling RSB on context switch and VMEXIT
Aug 15 15:00:12 warbler kernel: Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
Aug 15 15:00:12 warbler kernel: GDS: Vulnerable: No microcode
Aug 15 15:00:12 warbler kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
Aug 15 15:00:12 warbler kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
Aug 15 15:00:12 warbler kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
Aug 15 15:00:12 warbler kernel: x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
Aug 15 15:00:12 warbler kernel: x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
Aug 15 15:00:12 warbler kernel: x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
Aug 15 15:00:12 warbler kernel: x86/fpu: xstate_offset[3]:  832, xstate_sizes[3]:   64
Aug 15 15:00:12 warbler kernel: x86/fpu: xstate_offset[4]:  896, xstate_sizes[4]:   64
Aug 15 15:00:12 warbler kernel: x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
Aug 15 15:00:12 warbler kernel: Freeing SMP alternatives memory: 56K
Aug 15 15:00:12 warbler kernel: pid_max: default: 32768 minimum: 301
Aug 15 15:00:12 warbler kernel: LSM: initializing lsm=capability,landlock,lockdown,yama,bpf
Aug 15 15:00:12 warbler kernel: landlock: Up and running.
Aug 15 15:00:12 warbler kernel: Yama: becoming mindful.
Aug 15 15:00:12 warbler kernel: LSM support for eBPF active
Aug 15 15:00:12 warbler kernel: Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
Aug 15 15:00:12 warbler kernel: Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
Aug 15 15:00:12 warbler kernel: smpboot: CPU0: Intel(R) Core(TM) i5-6300U CPU @ 2.40GHz (family: 0x6, model: 0x4e, stepping: 0x3)
Aug 15 15:00:12 warbler kernel: Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
Aug 15 15:00:12 warbler kernel: ... version:                4
Aug 15 15:00:12 warbler kernel: ... generic registers:      4
Aug 15 15:00:12 warbler kernel: ... value mask:             0000ffffffffffff
Aug 15 15:00:12 warbler kernel: ... max period:             00007fffffffffff
Aug 15 15:00:12 warbler kernel: ... fixed-purpose events:   3
Aug 15 15:00:12 warbler kernel: ... event mask:             000000070000000f
Aug 15 15:00:12 warbler kernel: signal: max sigframe size: 2032
Aug 15 15:00:12 warbler kernel: Estimated ratio of average max frequency by base frequency (times 1024): 1187
Aug 15 15:00:12 warbler kernel: rcu: Hierarchical SRCU implementation.
Aug 15 15:00:12 warbler kernel: rcu:         Max phase no-delay instances is 400.
Aug 15 15:00:12 warbler kernel: Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
Aug 15 15:00:12 warbler kernel: NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
Aug 15 15:00:12 warbler kernel: smp: Bringing up secondary CPUs ...
Aug 15 15:00:12 warbler kernel: smpboot: x86: Booting SMP configuration:
Aug 15 15:00:12 warbler kernel: .... node  #0, CPUs:      #1 #2 #3
Aug 15 15:00:12 warbler kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more det>
Aug 15 15:00:12 warbler kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor>
Aug 15 15:00:12 warbler kernel: smp: Brought up 1 node, 4 CPUs
Aug 15 15:00:12 warbler kernel: smpboot: Total of 4 processors activated (19999.61 BogoMIPS)
Aug 15 15:00:12 warbler kernel: Memory: 16127412K/16579584K available (19832K kernel code, 2943K rwdata, 16652K rodata, 4664K init, 4952K bss, 439624K reserved, 0K cma->
Aug 15 15:00:12 warbler kernel: devtmpfs: initialized
Aug 15 15:00:12 warbler kernel: x86/mm: Memory block size: 128MB
Aug 15 15:00:12 warbler kernel: ACPI: PM: Registering ACPI NVS region [mem 0xa5f64000-0xa5f64fff] (4096 bytes)
Aug 15 15:00:12 warbler kernel: ACPI: PM: Registering ACPI NVS region [mem 0xab7ab000-0xabe0ffff] (6705152 bytes)
Aug 15 15:00:12 warbler kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
Aug 15 15:00:12 warbler kernel: posixtimers hash table entries: 2048 (order: 3, 32768 bytes, linear)
Aug 15 15:00:12 warbler kernel: futex hash table entries: 1024 (65536 bytes on 1 NUMA nodes, total 64 KiB, linear).
Aug 15 15:00:12 warbler kernel: pinctrl core: initialized pinctrl subsystem
Aug 15 15:00:12 warbler kernel: PM: RTC time: 19:00:08, date: 2025-08-15
Aug 15 15:00:12 warbler kernel: NET: Registered PF_NETLINK/PF_ROUTE protocol family
Aug 15 15:00:12 warbler kernel: DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
Aug 15 15:00:12 warbler kernel: DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
Aug 15 15:00:12 warbler kernel: DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
Aug 15 15:00:12 warbler kernel: audit: initializing netlink subsys (disabled)
Aug 15 15:00:12 warbler kernel: audit: type=2000 audit(1755284407.072:1): state=initialized audit_enabled=0 res=1
Aug 15 15:00:12 warbler kernel: thermal_sys: Registered thermal governor 'fair_share'
Aug 15 15:00:12 warbler kernel: thermal_sys: Registered thermal governor 'bang_bang'
Aug 15 15:00:12 warbler kernel: thermal_sys: Registered thermal governor 'step_wise'
Aug 15 15:00:12 warbler kernel: thermal_sys: Registered thermal governor 'user_space'
Aug 15 15:00:12 warbler kernel: thermal_sys: Registered thermal governor 'power_allocator'
Aug 15 15:00:12 warbler kernel: cpuidle: using governor ladder
Aug 15 15:00:12 warbler kernel: cpuidle: using governor menu
Aug 15 15:00:12 warbler kernel: ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
Aug 15 15:00:12 warbler kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
Aug 15 15:00:12 warbler kernel: PCI: ECAM [mem 0xf0000000-0xf7ffffff] (base 0xf0000000) for domain 0000 [bus 00-7f]
Aug 15 15:00:12 warbler kernel: PCI: Using configuration type 1 for base access
Aug 15 15:00:12 warbler kernel: kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
Aug 15 15:00:12 warbler kernel: HugeTLB: allocation took 0ms with hugepage_allocation_threads=1
Aug 15 15:00:12 warbler kernel: HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
Aug 15 15:00:12 warbler kernel: HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
Aug 15 15:00:12 warbler kernel: HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
Aug 15 15:00:12 warbler kernel: HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
Aug 15 15:00:12 warbler kernel: raid6: skipped pq benchmark and selected avx2x4
Aug 15 15:00:12 warbler kernel: raid6: using avx2x2 recovery algorithm
Aug 15 15:00:12 warbler kernel: ACPI: Added _OSI(Module Device)
Aug 15 15:00:12 warbler kernel: ACPI: Added _OSI(Processor Device)
Aug 15 15:00:12 warbler kernel: ACPI: Added _OSI(Processor Aggregator Device)
Aug 15 15:00:12 warbler kernel: ACPI: 9 ACPI AML tables successfully acquired and loaded
Aug 15 15:00:12 warbler kernel: ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
Aug 15 15:00:12 warbler kernel: ACPI: Dynamic OEM Table Load:
Aug 15 15:00:12 warbler kernel: ACPI: SSDT 0xFFFF88D5C1600400 00037F (v02 PmRef  Cpu0Cst  00003001 INTL 20120913)
Aug 15 15:00:12 warbler kernel: ACPI: SSDT 0xFFFF88D5C0F1C000 00063F (v02 PmRef  Cpu0Ist  00003000 INTL 20120913)
Aug 15 15:00:12 warbler kernel: ACPI: SSDT 0xFFFF88D5C0F1F800 0005AA (v02 PmRef  ApIst    00003000 INTL 20120913)
Aug 15 15:00:12 warbler kernel: ACPI: SSDT 0xFFFF88D5C11C2200 000119 (v02 PmRef  ApCst    00003000 INTL 20120913)
Aug 15 15:00:12 warbler kernel: ACPI: EC: EC started
Aug 15 15:00:12 warbler kernel: ACPI: EC: interrupt blocked
Aug 15 15:00:12 warbler kernel: ACPI: EC: EC_CMD/EC_SC=0x934, EC_DATA=0x930
Aug 15 15:00:12 warbler kernel: ACPI: \_SB_.PCI0.LPCB.ECDV: Boot DSDT EC used to handle transactions
Aug 15 15:00:12 warbler kernel: ACPI: Interpreter enabled
Aug 15 15:00:12 warbler kernel: ACPI: PM: (supports S0 S3 S4 S5)
Aug 15 15:00:12 warbler kernel: ACPI: Using IOAPIC for interrupt routing
Aug 15 15:00:12 warbler kernel: PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
Aug 15 15:00:12 warbler kernel: PCI: Using E820 reservations for host bridge windows
Aug 15 15:00:12 warbler kernel: ACPI: Enabled 8 GPEs in block 00 to 7F
Aug 15 15:00:12 warbler kernel: ACPI: \_SB_.PCI0.PEG0.PG00: New power resource
Aug 15 15:00:12 warbler kernel: ACPI: \_SB_.PCI0.PEG1.PG01: New power resource
Aug 15 15:00:12 warbler kernel: ACPI: \_SB_.PCI0.PEG2.PG02: New power resource
Aug 15 15:00:12 warbler kernel: ACPI: \_SB_.PCI0.RP09.PXSX.WRST: New power resource
Aug 15 15:00:12 warbler kernel: ACPI: \_SB_.PCI0.RP10.PXSX.WRST: New power resource
Aug 15 15:00:12 warbler kernel: ACPI: \_SB_.PCI0.RP11.PXSX.WRST: New power resource
Aug 15 15:00:12 warbler kernel: ACPI: \_SB_.PCI0.RP12.PXSX.WRST: New power resource
Aug 15 15:00:12 warbler kernel: ACPI: \_SB_.PCI0.RP13.PXSX.WRST: New power resource
Aug 15 15:00:12 warbler kernel: ACPI: \_SB_.PCI0.RP02.PXSX.WRST: New power resource
Aug 15 15:00:12 warbler kernel: ACPI: \_SB_.PCI0.RP03.PXSX.WRST: New power resource
Aug 15 15:00:12 warbler kernel: ACPI: \_SB_.PCI0.RP04.PXSX.WRST: New power resource
Aug 15 15:00:12 warbler kernel: ACPI: \_SB_.PCI0.RP07.PXSX.WRST: New power resource
Aug 15 15:00:12 warbler kernel: ACPI: \_SB_.PCI0.RP08.PXSX.WRST: New power resource
Aug 15 15:00:12 warbler kernel: ACPI: \_SB_.PCI0.RP17.PXSX.WRST: New power resource
Aug 15 15:00:12 warbler kernel: ACPI: \_SB_.PCI0.RP18.PXSX.WRST: New power resource
Aug 15 15:00:12 warbler kernel: ACPI: \_SB_.PCI0.RP19.PXSX.WRST: New power resource
Aug 15 15:00:12 warbler kernel: ACPI: \_SB_.PCI0.RP20.PXSX.WRST: New power resource
Aug 15 15:00:12 warbler kernel: ACPI: \_SB_.PCI0.RP14.PXSX.WRST: New power resource
Aug 15 15:00:12 warbler kernel: ACPI: \_SB_.PCI0.RP15.PXSX.WRST: New power resource
Aug 15 15:00:12 warbler kernel: ACPI: \_SB_.PCI0.RP16.PXSX.WRST: New power resource
Aug 15 15:00:12 warbler kernel: ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-7e])
Aug 15 15:00:12 warbler kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
Aug 15 15:00:12 warbler kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
Aug 15 15:00:12 warbler kernel: acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
Aug 15 15:00:12 warbler kernel: PCI host bridge to bus 0000:00
Aug 15 15:00:12 warbler kernel: pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
Aug 15 15:00:12 warbler kernel: pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
Aug 15 15:00:12 warbler kernel: pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
Aug 15 15:00:12 warbler kernel: pci_bus 0000:00: root bus resource [mem 0xb0000000-0xefffffff window]
Aug 15 15:00:12 warbler kernel: pci_bus 0000:00: root bus resource [mem 0xfd000000-0xfe7fffff window]
Aug 15 15:00:12 warbler kernel: pci_bus 0000:00: root bus resource [bus 00-7e]
Aug 15 15:00:12 warbler kernel: pci 0000:00:00.0: [8086:1904] type 00 class 0x060000 conventional PCI endpoint
Aug 15 15:00:12 warbler kernel: pci 0000:00:02.0: [8086:1916] type 00 class 0x030000 PCIe Root Complex Integrated Endpoint
Aug 15 15:00:12 warbler kernel: pci 0000:00:02.0: BAR 0 [mem 0xe0000000-0xe0ffffff 64bit]
Aug 15 15:00:12 warbler kernel: pci 0000:00:02.0: BAR 2 [mem 0xd0000000-0xdfffffff 64bit pref]
Aug 15 15:00:12 warbler kernel: pci 0000:00:02.0: BAR 4 [io  0xf000-0xf03f]
Aug 15 15:00:12 warbler kernel: pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
Aug 15 15:00:12 warbler kernel: pci 0000:00:04.0: [8086:1903] type 00 class 0x118000 conventional PCI endpoint
Aug 15 15:00:12 warbler kernel: pci 0000:00:04.0: BAR 0 [mem 0xe1340000-0xe1347fff 64bit]
Aug 15 15:00:12 warbler kernel: pci 0000:00:14.0: [8086:9d2f] type 00 class 0x0c0330 conventional PCI endpoint
Aug 15 15:00:12 warbler kernel: pci 0000:00:14.0: BAR 0 [mem 0xe1330000-0xe133ffff 64bit]
Aug 15 15:00:12 warbler kernel: pci 0000:00:14.0: PME# supported from D3hot D3cold
Aug 15 15:00:12 warbler kernel: pci 0000:00:14.2: [8086:9d31] type 00 class 0x118000 conventional PCI endpoint
Aug 15 15:00:12 warbler kernel: pci 0000:00:14.2: BAR 0 [mem 0xe1356000-0xe1356fff 64bit]
Aug 15 15:00:12 warbler kernel: pci 0000:00:16.0: [8086:9d3a] type 00 class 0x078000 conventional PCI endpoint
Aug 15 15:00:12 warbler kernel: pci 0000:00:16.0: BAR 0 [mem 0xe1355000-0xe1355fff 64bit]
Aug 15 15:00:12 warbler kernel: pci 0000:00:16.0: PME# supported from D3hot
Aug 15 15:00:12 warbler kernel: pci 0000:00:17.0: [8086:282a] type 00 class 0x010400 conventional PCI endpoint
Aug 15 15:00:12 warbler kernel: pci 0000:00:17.0: BAR 0 [mem 0xe1350000-0xe1351fff]
Aug 15 15:00:12 warbler kernel: pci 0000:00:17.0: BAR 1 [mem 0xe1354000-0xe13540ff]
Aug 15 15:00:12 warbler kernel: pci 0000:00:17.0: BAR 2 [io  0xf090-0xf097]
Aug 15 15:00:12 warbler kernel: pci 0000:00:17.0: BAR 3 [io  0xf080-0xf083]
Aug 15 15:00:12 warbler kernel: pci 0000:00:17.0: BAR 4 [io  0xf060-0xf07f]
Aug 15 15:00:12 warbler kernel: pci 0000:00:17.0: BAR 5 [mem 0xe1353000-0xe13537ff]
Aug 15 15:00:12 warbler kernel: pci 0000:00:17.0: PME# supported from D3hot
Aug 15 15:00:12 warbler kernel: pci 0000:00:1c.0: [8086:9d14] type 01 class 0x060400 PCIe Root Port
Aug 15 15:00:12 warbler kernel: pci 0000:00:1c.0: PCI bridge to [bus 01]
Aug 15 15:00:12 warbler kernel: pci 0000:00:1c.0:   bridge window [mem 0xe1200000-0xe12fffff]
Aug 15 15:00:12 warbler kernel: pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
Aug 15 15:00:12 warbler kernel: pci 0000:00:1d.0: [8086:9d18] type 01 class 0x060400 PCIe Root Port
Aug 15 15:00:12 warbler kernel: pci 0000:00:1d.0: PCI bridge to [bus 02]
Aug 15 15:00:12 warbler kernel: pci 0000:00:1d.0:   bridge window [mem 0xe1100000-0xe11fffff]
Aug 15 15:00:12 warbler kernel: pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
Aug 15 15:00:12 warbler kernel: pci 0000:00:1d.2: [8086:9d1a] type 01 class 0x060400 PCIe Root Port
Aug 15 15:00:12 warbler kernel: pci 0000:00:1d.2: PCI bridge to [bus 03]
Aug 15 15:00:12 warbler kernel: pci 0000:00:1d.2:   bridge window [mem 0xe1000000-0xe10fffff]
Aug 15 15:00:12 warbler kernel: pci 0000:00:1d.2: PME# supported from D0 D3hot D3cold
Aug 15 15:00:12 warbler kernel: pci 0000:00:1f.0: [8086:9d48] type 00 class 0x060100 conventional PCI endpoint
Aug 15 15:00:12 warbler kernel: pci 0000:00:1f.2: [8086:9d21] type 00 class 0x058000 conventional PCI endpoint
Aug 15 15:00:12 warbler kernel: pci 0000:00:1f.2: BAR 0 [mem 0xe134c000-0xe134ffff]
Aug 15 15:00:12 warbler kernel: pci 0000:00:1f.3: [8086:9d70] type 00 class 0x040300 conventional PCI endpoint
Aug 15 15:00:12 warbler kernel: pci 0000:00:1f.3: BAR 0 [mem 0xe1348000-0xe134bfff 64bit]
Aug 15 15:00:12 warbler kernel: pci 0000:00:1f.3: BAR 4 [mem 0xe1320000-0xe132ffff 64bit]
Aug 15 15:00:12 warbler kernel: pci 0000:00:1f.3: PME# supported from D3hot D3cold
Aug 15 15:00:12 warbler kernel: pci 0000:00:1f.4: [8086:9d23] type 00 class 0x0c0500 conventional PCI endpoint
Aug 15 15:00:12 warbler kernel: pci 0000:00:1f.4: BAR 0 [mem 0xe1352000-0xe13520ff 64bit]
Aug 15 15:00:12 warbler kernel: pci 0000:00:1f.4: BAR 4 [io  0xf040-0xf05f]
Aug 15 15:00:12 warbler kernel: pci 0000:00:1f.6: [8086:156f] type 00 class 0x020000 conventional PCI endpoint
Aug 15 15:00:12 warbler kernel: pci 0000:00:1f.6: BAR 0 [mem 0xe1300000-0xe131ffff]
Aug 15 15:00:12 warbler kernel: pci 0000:00:1f.6: PME# supported from D0 D3hot D3cold
Aug 15 15:00:12 warbler kernel: pci 0000:01:00.0: [8086:24f3] type 00 class 0x028000 PCIe Endpoint
Aug 15 15:00:12 warbler kernel: pci 0000:01:00.0: BAR 0 [mem 0xe1200000-0xe1201fff 64bit]
Aug 15 15:00:12 warbler kernel: pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
Aug 15 15:00:12 warbler kernel: pci 0000:02:00.0: [126f:2263] type 00 class 0x010802 PCIe Endpoint
Aug 15 15:00:12 warbler kernel: pci 0000:02:00.0: BAR 0 [mem 0xe1100000-0xe1103fff 64bit]
Aug 15 15:00:12 warbler kernel: pci 0000:02:00.0: 15.752 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x2 link at 0000:00:1d.0 (capable of 31.504 Gb/s with 8.>
Aug 15 15:00:12 warbler kernel: pci 0000:03:00.0: [10ec:525a] type 00 class 0xff0000 PCIe Endpoint
Aug 15 15:00:12 warbler kernel: pci 0000:03:00.0: BAR 1 [mem 0xe1000000-0xe1000fff]
Aug 15 15:00:12 warbler kernel: pci 0000:03:00.0: supports D1 D2
Aug 15 15:00:12 warbler kernel: pci 0000:03:00.0: PME# supported from D1 D2 D3hot D3cold
Aug 15 15:00:12 warbler kernel: ACPI: PCI: Interrupt link LNKA configured for IRQ 11
Aug 15 15:00:12 warbler kernel: ACPI: PCI: Interrupt link LNKB configured for IRQ 10
Aug 15 15:00:12 warbler kernel: ACPI: PCI: Interrupt link LNKC configured for IRQ 11
Aug 15 15:00:12 warbler kernel: ACPI: PCI: Interrupt link LNKD configured for IRQ 11
Aug 15 15:00:12 warbler kernel: ACPI: PCI: Interrupt link LNKE configured for IRQ 11
Aug 15 15:00:12 warbler kernel: ACPI: PCI: Interrupt link LNKF configured for IRQ 11
Aug 15 15:00:12 warbler kernel: ACPI: PCI: Interrupt link LNKG configured for IRQ 11
Aug 15 15:00:12 warbler kernel: ACPI: PCI: Interrupt link LNKH configured for IRQ 11
Aug 15 15:00:12 warbler kernel: ACPI: EC: interrupt unblocked
Aug 15 15:00:12 warbler kernel: ACPI: EC: event unblocked
Aug 15 15:00:12 warbler kernel: ACPI: EC: GPE=0x14
Aug 15 15:00:12 warbler kernel: ACPI: \_SB_.PCI0.LPCB.ECDV: Boot DSDT EC initialization complete
Aug 15 15:00:12 warbler kernel: ACPI: \_SB_.PCI0.LPCB.ECDV: EC: Used to handle transactions and events
Aug 15 15:00:12 warbler kernel: iommu: Default domain type: Translated
Aug 15 15:00:12 warbler kernel: iommu: DMA domain TLB invalidation policy: lazy mode
Aug 15 15:00:12 warbler kernel: SCSI subsystem initialized
Aug 15 15:00:12 warbler kernel: libata version 3.00 loaded.
Aug 15 15:00:12 warbler kernel: ACPI: bus type USB registered
Aug 15 15:00:12 warbler kernel: usbcore: registered new interface driver usbfs
Aug 15 15:00:12 warbler kernel: usbcore: registered new interface driver hub
Aug 15 15:00:12 warbler kernel: usbcore: registered new device driver usb
Aug 15 15:00:12 warbler kernel: EDAC MC: Ver: 3.0.0
Aug 15 15:00:12 warbler kernel: NetLabel: Initializing
Aug 15 15:00:12 warbler kernel: NetLabel:  domain hash size = 128
Aug 15 15:00:12 warbler kernel: NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
Aug 15 15:00:12 warbler kernel: NetLabel:  unlabeled traffic allowed by default
Aug 15 15:00:12 warbler kernel: mctp: management component transport protocol core
Aug 15 15:00:12 warbler kernel: NET: Registered PF_MCTP protocol family
Aug 15 15:00:12 warbler kernel: PCI: Using ACPI for IRQ routing
Aug 15 15:00:12 warbler kernel: PCI: pci_cache_line_size set to 64 bytes
Aug 15 15:00:12 warbler kernel: e820: reserve RAM buffer [mem 0x0009dc00-0x0009ffff]
Aug 15 15:00:12 warbler kernel: e820: reserve RAM buffer [mem 0xa5f64000-0xa7ffffff]
Aug 15 15:00:12 warbler kernel: e820: reserve RAM buffer [mem 0x44e000000-0x44fffffff]
Aug 15 15:00:12 warbler kernel: pci 0000:00:02.0: vgaarb: setting as boot VGA device
Aug 15 15:00:12 warbler kernel: pci 0000:00:02.0: vgaarb: bridge control possible
Aug 15 15:00:12 warbler kernel: pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
Aug 15 15:00:12 warbler kernel: vgaarb: loaded
Aug 15 15:00:12 warbler kernel: hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
Aug 15 15:00:12 warbler kernel: hpet0: 8 comparators, 64-bit 24.000000 MHz counter
Aug 15 15:00:12 warbler kernel: clocksource: Switched to clocksource tsc-early
Aug 15 15:00:12 warbler kernel: VFS: Disk quotas dquot_6.6.0
Aug 15 15:00:12 warbler kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Aug 15 15:00:12 warbler kernel: pnp: PnP ACPI init
Aug 15 15:00:12 warbler kernel: system 00:00: [io  0x0680-0x069f] has been reserved
Aug 15 15:00:12 warbler kernel: system 00:00: [io  0xffff] has been reserved
Aug 15 15:00:12 warbler kernel: system 00:00: [io  0x1800-0x18fe] could not be reserved
Aug 15 15:00:12 warbler kernel: system 00:00: [io  0x164e-0x164f] has been reserved
Aug 15 15:00:12 warbler kernel: system 00:05: [mem 0xfed10000-0xfed17fff] has been reserved
Aug 15 15:00:12 warbler kernel: system 00:05: [mem 0xfed18000-0xfed18fff] has been reserved
Aug 15 15:00:12 warbler kernel: system 00:05: [mem 0xfed19000-0xfed19fff] has been reserved
Aug 15 15:00:12 warbler kernel: system 00:05: [mem 0xf0000000-0xf7ffffff] has been reserved
Aug 15 15:00:12 warbler kernel: system 00:05: [mem 0xfed20000-0xfed3ffff] has been reserved
Aug 15 15:00:12 warbler kernel: system 00:05: [mem 0xfed90000-0xfed93fff] could not be reserved
Aug 15 15:00:12 warbler kernel: system 00:05: [mem 0xfed45000-0xfed8ffff] has been reserved
Aug 15 15:00:12 warbler kernel: system 00:05: [mem 0xff000000-0xffffffff] has been reserved
Aug 15 15:00:12 warbler kernel: system 00:05: [mem 0xfee00000-0xfeefffff] could not be reserved
Aug 15 15:00:12 warbler kernel: system 00:05: [mem 0xeffe0000-0xefffffff] has been reserved
Aug 15 15:00:12 warbler kernel: system 00:06: [mem 0xfd000000-0xfdabffff] has been reserved
Aug 15 15:00:12 warbler kernel: system 00:06: [mem 0xfdad0000-0xfdadffff] has been reserved
Aug 15 15:00:12 warbler kernel: system 00:06: [mem 0xfdb00000-0xfdffffff] has been reserved
Aug 15 15:00:12 warbler kernel: system 00:06: [mem 0xfe000000-0xfe01ffff] could not be reserved
Aug 15 15:00:12 warbler kernel: system 00:06: [mem 0xfe036000-0xfe03bfff] has been reserved
Aug 15 15:00:12 warbler kernel: system 00:06: [mem 0xfe03d000-0xfe3fffff] has been reserved
Aug 15 15:00:12 warbler kernel: system 00:06: [mem 0xfe410000-0xfe7fffff] has been reserved
Aug 15 15:00:12 warbler kernel: system 00:07: [io  0xff00-0xfffe] has been reserved
Aug 15 15:00:12 warbler kernel: system 00:08: [mem 0xfe029000-0xfe029fff] has been reserved
Aug 15 15:00:12 warbler kernel: system 00:08: [mem 0xfe028000-0xfe028fff] has been reserved
Aug 15 15:00:12 warbler kernel: system 00:08: [mem 0xfdaf0000-0xfdafffff] has been reserved
Aug 15 15:00:12 warbler kernel: system 00:08: [mem 0xfdae0000-0xfdaeffff] has been reserved
Aug 15 15:00:12 warbler kernel: system 00:08: [mem 0xfdac0000-0xfdacffff] has been reserved
Aug 15 15:00:12 warbler kernel: pnp: PnP ACPI: found 9 devices
Aug 15 15:00:12 warbler kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
Aug 15 15:00:12 warbler kernel: NET: Registered PF_INET protocol family
Aug 15 15:00:12 warbler kernel: IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
Aug 15 15:00:12 warbler kernel: tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
Aug 15 15:00:12 warbler kernel: Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
Aug 15 15:00:12 warbler kernel: TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
Aug 15 15:00:12 warbler kernel: TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
Aug 15 15:00:12 warbler kernel: TCP: Hash tables configured (established 131072 bind 65536)
Aug 15 15:00:12 warbler kernel: MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
Aug 15 15:00:12 warbler kernel: UDP hash table entries: 8192 (order: 7, 524288 bytes, linear)
Aug 15 15:00:12 warbler kernel: UDP-Lite hash table entries: 8192 (order: 7, 524288 bytes, linear)
Aug 15 15:00:12 warbler kernel: NET: Registered PF_UNIX/PF_LOCAL protocol family
Aug 15 15:00:12 warbler kernel: NET: Registered PF_XDP protocol family
Aug 15 15:00:12 warbler kernel: pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
Aug 15 15:00:12 warbler kernel: pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
Aug 15 15:00:12 warbler kernel: pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
Aug 15 15:00:12 warbler kernel: pci_bus 0000:00: resource 7 [mem 0xb0000000-0xefffffff window]
Aug 15 15:00:12 warbler kernel: pci_bus 0000:00: resource 8 [mem 0xfd000000-0xfe7fffff window]
Aug 15 15:00:12 warbler kernel: pci_bus 0000:01: resource 1 [mem 0xe1200000-0xe12fffff]
Aug 15 15:00:12 warbler kernel: pci_bus 0000:02: resource 1 [mem 0xe1100000-0xe11fffff]
Aug 15 15:00:12 warbler kernel: pci_bus 0000:03: resource 1 [mem 0xe1000000-0xe10fffff]
Aug 15 15:00:12 warbler kernel: PCI: CLS 0 bytes, default 64
Aug 15 15:00:12 warbler kernel: pci 0000:00:1f.1: [8086:9d20] type 00 class 0x058000 conventional PCI endpoint
Aug 15 15:00:12 warbler kernel: pci 0000:00:1f.1: BAR 0 [mem 0xfd000000-0xfdffffff 64bit]
Aug 15 15:00:12 warbler kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
Aug 15 15:00:12 warbler kernel: software IO TLB: mapped [mem 0x00000000a1f64000-0x00000000a5f64000] (64MB)
Aug 15 15:00:12 warbler kernel: Trying to unpack rootfs image as initramfs...
Aug 15 15:00:12 warbler kernel: Initialise system trusted keyrings
Aug 15 15:00:12 warbler kernel: Key type blacklist registered
Aug 15 15:00:12 warbler kernel: workingset: timestamp_bits=36 max_order=22 bucket_order=0
Aug 15 15:00:12 warbler kernel: fuse: init (API version 7.44)
Aug 15 15:00:12 warbler kernel: integrity: Platform Keyring initialized
Aug 15 15:00:12 warbler kernel: integrity: Machine keyring initialized
Aug 15 15:00:12 warbler kernel: xor: automatically using best checksumming function   avx
Aug 15 15:00:12 warbler kernel: Key type asymmetric registered
Aug 15 15:00:12 warbler kernel: Asymmetric key parser 'x509' registered
Aug 15 15:00:12 warbler kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
Aug 15 15:00:12 warbler kernel: io scheduler mq-deadline registered
Aug 15 15:00:12 warbler kernel: io scheduler kyber registered
Aug 15 15:00:12 warbler kernel: io scheduler bfq registered
Aug 15 15:00:12 warbler kernel: ledtrig-cpu: registered to indicate activity on CPUs
Aug 15 15:00:12 warbler kernel: pcieport 0000:00:1c.0: PME: Signaling with IRQ 120
Aug 15 15:00:12 warbler kernel: pcieport 0000:00:1c.0: AER: enabled with IRQ 120
Aug 15 15:00:12 warbler kernel: pcieport 0000:00:1d.0: PME: Signaling with IRQ 121
Aug 15 15:00:12 warbler kernel: pcieport 0000:00:1d.0: AER: enabled with IRQ 121
Aug 15 15:00:12 warbler kernel: pcieport 0000:00:1d.2: PME: Signaling with IRQ 122
Aug 15 15:00:12 warbler kernel: pcieport 0000:00:1d.2: AER: enabled with IRQ 122
Aug 15 15:00:12 warbler kernel: ACPI: AC: AC Adapter [AC] (on-line)
Aug 15 15:00:12 warbler kernel: input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
Aug 15 15:00:12 warbler kernel: Freeing initrd memory: 27080K
Aug 15 15:00:12 warbler kernel: ACPI: button: Lid Switch [LID0]
Aug 15 15:00:12 warbler kernel: input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
Aug 15 15:00:12 warbler kernel: ACPI: button: Power Button [PBTN]
Aug 15 15:00:12 warbler kernel: input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2
Aug 15 15:00:12 warbler kernel: ACPI: button: Sleep Button [SBTN]
Aug 15 15:00:12 warbler kernel: input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
Aug 15 15:00:12 warbler kernel: ACPI: button: Power Button [PWRF]
Aug 15 15:00:12 warbler kernel: thermal LNXTHERM:00: registered as thermal_zone0
Aug 15 15:00:12 warbler kernel: ACPI: thermal: Thermal Zone [THM] (25 C)
Aug 15 15:00:12 warbler kernel: Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
Aug 15 15:00:12 warbler kernel: Non-volatile memory driver v1.3
Aug 15 15:00:12 warbler kernel: Linux agpgart interface v0.103
Aug 15 15:00:12 warbler kernel: tpm_tis MSFT0101:00: 2.0 TPM (device-id 0xFE, rev-id 2)
Aug 15 15:00:12 warbler kernel: ACPI: battery: Slot [BAT0] (battery present)
Aug 15 15:00:12 warbler kernel: ACPI: bus type drm_connector registered
Aug 15 15:00:12 warbler kernel: ahci 0000:00:17.0: SSS flag set, parallel bus scan disabled
Aug 15 15:00:12 warbler kernel: ahci 0000:00:17.0: AHCI vers 0001.0301, 32 command slots, 6 Gbps, RAID mode
Aug 15 15:00:12 warbler kernel: ahci 0000:00:17.0: 2/2 ports implemented (port mask 0x3)
Aug 15 15:00:12 warbler kernel: ahci 0000:00:17.0: flags: 64bit ncq ilck stag pm led clo only pio slum part sxs deso sadm sds apst
Aug 15 15:00:12 warbler kernel: scsi host0: ahci
Aug 15 15:00:12 warbler kernel: scsi host1: ahci
Aug 15 15:00:12 warbler kernel: ata1: SATA max UDMA/133 abar m2048@0xe1353000 port 0xe1353100 irq 123 lpm-pol 3
Aug 15 15:00:12 warbler kernel: ata2: SATA max UDMA/133 abar m2048@0xe1353000 port 0xe1353180 irq 123 lpm-pol 0 ext
Aug 15 15:00:12 warbler kernel: xhci_hcd 0000:00:14.0: xHCI Host Controller
Aug 15 15:00:12 warbler kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
Aug 15 15:00:12 warbler kernel: xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000081109810
Aug 15 15:00:12 warbler kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
Aug 15 15:00:12 warbler kernel: xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
Aug 15 15:00:12 warbler kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.16
Aug 15 15:00:12 warbler kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 15 15:00:12 warbler kernel: usb usb1: Product: xHCI Host Controller
Aug 15 15:00:12 warbler kernel: usb usb1: Manufacturer: Linux 6.16.0-5-MANJARO xhci-hcd
Aug 15 15:00:12 warbler kernel: usb usb1: SerialNumber: 0000:00:14.0
Aug 15 15:00:12 warbler kernel: hub 1-0:1.0: USB hub found
Aug 15 15:00:12 warbler kernel: hub 1-0:1.0: 12 ports detected
Aug 15 15:00:12 warbler kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.16
Aug 15 15:00:12 warbler kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 15 15:00:12 warbler kernel: usb usb2: Product: xHCI Host Controller
Aug 15 15:00:12 warbler kernel: usb usb2: Manufacturer: Linux 6.16.0-5-MANJARO xhci-hcd
Aug 15 15:00:12 warbler kernel: usb usb2: SerialNumber: 0000:00:14.0
Aug 15 15:00:12 warbler kernel: hub 2-0:1.0: USB hub found
Aug 15 15:00:12 warbler kernel: hub 2-0:1.0: 6 ports detected
Aug 15 15:00:12 warbler kernel: usbcore: registered new interface driver usbserial_generic
Aug 15 15:00:12 warbler kernel: usbserial: USB Serial support registered for generic
Aug 15 15:00:12 warbler kernel: i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
Aug 15 15:00:12 warbler kernel: i8042: Warning: Keylock active
Aug 15 15:00:12 warbler kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
Aug 15 15:00:12 warbler kernel: serio: i8042 AUX port at 0x60,0x64 irq 12
Aug 15 15:00:12 warbler kernel: rtc_cmos 00:01: RTC can wake from S4
Aug 15 15:00:12 warbler kernel: rtc_cmos 00:01: registered as rtc0
Aug 15 15:00:12 warbler kernel: rtc_cmos 00:01: setting system clock to 2025-08-15T19:00:08 UTC (1755284408)
Aug 15 15:00:12 warbler kernel: rtc_cmos 00:01: alarms up to one month, y3k, 242 bytes nvram
Aug 15 15:00:12 warbler kernel: intel_pstate: Intel P-state driver initializing
Aug 15 15:00:12 warbler kernel: intel_pstate: HWP enabled
Aug 15 15:00:12 warbler kernel: simple-framebuffer simple-framebuffer.0: [drm] Registered 1 planes with drm panic
Aug 15 15:00:12 warbler kernel: [drm] Initialized simpledrm 1.0.0 for simple-framebuffer.0 on minor 0
Aug 15 15:00:12 warbler kernel: fbcon: Deferring console take-over
Aug 15 15:00:12 warbler kernel: simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
Aug 15 15:00:12 warbler kernel: hid: raw HID events driver (C) Jiri Kosina
Aug 15 15:00:12 warbler kernel: usbcore: registered new interface driver usbhid
Aug 15 15:00:12 warbler kernel: usbhid: USB HID core driver
Aug 15 15:00:12 warbler kernel: drop_monitor: Initializing network drop monitor service
Aug 15 15:00:12 warbler kernel: NET: Registered PF_INET6 protocol family
Aug 15 15:00:12 warbler kernel: input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
Aug 15 15:00:12 warbler kernel: Segment Routing with IPv6
Aug 15 15:00:12 warbler kernel: RPL Segment Routing with IPv6
Aug 15 15:00:12 warbler kernel: In-situ OAM (IOAM) with IPv6
Aug 15 15:00:12 warbler kernel: NET: Registered PF_PACKET protocol family
Aug 15 15:00:12 warbler kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Aug 15 15:00:12 warbler kernel: microcode: Current revision: 0x000000f0
Aug 15 15:00:12 warbler kernel: IPI shorthand broadcast: enabled
Aug 15 15:00:12 warbler kernel: sched_clock: Marking stable (712001717, 3600968)->(734503807, -18901122)
Aug 15 15:00:12 warbler kernel: registered taskstats version 1
Aug 15 15:00:12 warbler kernel: Loading compiled-in X.509 certificates
Aug 15 15:00:12 warbler kernel: Loaded X.509 cert 'Build time autogenerated kernel key: 72741cd9cc42c7a419e3e5fecbca7aeef3fef51e'
Aug 15 15:00:12 warbler kernel: zswap: loaded using pool zstd/zsmalloc
Aug 15 15:00:12 warbler kernel: Demotion targets for Node 0: null
Aug 15 15:00:12 warbler kernel: Key type .fscrypt registered
Aug 15 15:00:12 warbler kernel: Key type fscrypt-provisioning registered
Aug 15 15:00:12 warbler kernel: Btrfs loaded, zoned=yes, fsverity=yes
Aug 15 15:00:12 warbler kernel: Key type big_key registered
Aug 15 15:00:12 warbler kernel: PM:   Magic number: 5:118:41
Aug 15 15:00:12 warbler kernel: PM:   hash matches drivers/base/power/main.c:1611
Aug 15 15:00:12 warbler kernel: memory memory77: hash matches
Aug 15 15:00:12 warbler kernel: RAS: Correctable Errors collector initialized.
Aug 15 15:00:12 warbler kernel: usb 1-2: new high-speed USB device number 2 using xhci_hcd
Aug 15 15:00:12 warbler kernel: ata1: SATA link down (SStatus 4 SControl 300)
Aug 15 15:00:12 warbler kernel: usb 1-2: New USB device found, idVendor=0bda, idProduct=5765, bcdDevice=57.31
Aug 15 15:00:12 warbler kernel: usb 1-2: New USB device strings: Mfr=3, Product=1, SerialNumber=2
Aug 15 15:00:12 warbler kernel: usb 1-2: Product: Integrated_Webcam_FHD
Aug 15 15:00:12 warbler kernel: usb 1-2: Manufacturer: CN0MYWHV7248765KB4J3A00
Aug 15 15:00:12 warbler kernel: usb 1-2: SerialNumber: 200901010001
Aug 15 15:00:12 warbler kernel: usb 1-4: new full-speed USB device number 3 using xhci_hcd
Aug 15 15:00:12 warbler kernel: ata2: SATA link down (SStatus 0 SControl 300)
Aug 15 15:00:12 warbler kernel: clk: Disabling unused clocks
Aug 15 15:00:12 warbler kernel: PM: genpd: Disabling unused power domains
Aug 15 15:00:12 warbler kernel: Freeing unused decrypted memory: 2028K
Aug 15 15:00:12 warbler kernel: Freeing unused kernel image (initmem) memory: 4664K
Aug 15 15:00:12 warbler kernel: Write protecting the kernel read-only data: 38912k
Aug 15 15:00:12 warbler kernel: Freeing unused kernel image (text/rodata gap) memory: 644K
Aug 15 15:00:12 warbler kernel: Freeing unused kernel image (rodata/data gap) memory: 1780K
Aug 15 15:00:12 warbler kernel: usb 1-4: New USB device found, idVendor=05e3, idProduct=0606, bcdDevice= 7.02
Aug 15 15:00:12 warbler kernel: usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Aug 15 15:00:12 warbler kernel: usb 1-4: Product: USB Hub 2.0
Aug 15 15:00:12 warbler kernel: usb 1-4: Manufacturer: ALCOR
Aug 15 15:00:12 warbler kernel: hub 1-4:1.0: USB hub found
Aug 15 15:00:12 warbler kernel: hub 1-4:1.0: 4 ports detected
Aug 15 15:00:12 warbler kernel: x86/mm: Checked W+X mappings: passed, no W+X pages found.
Aug 15 15:00:12 warbler kernel: rodata_test: all tests were successful
Aug 15 15:00:12 warbler kernel: x86/mm: Checking user space page tables
Aug 15 15:00:12 warbler kernel: Run /init as init process
Aug 15 15:00:12 warbler kernel:   with arguments:
Aug 15 15:00:12 warbler kernel:     /init
Aug 15 15:00:12 warbler kernel:   with environment:
Aug 15 15:00:12 warbler kernel:     HOME=/
Aug 15 15:00:12 warbler kernel:     TERM=linux
Aug 15 15:00:12 warbler kernel:     BOOT_IMAGE=/@/boot/vmlinuz-6.16-x86_64
Aug 15 15:00:12 warbler kernel: usb 1-8: new full-speed USB device number 4 using xhci_hcd
Aug 15 15:00:12 warbler kernel: tsc: Refined TSC clocksource calibration: 2495.999 MHz
Aug 15 15:00:12 warbler kernel: clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x23fa763a3d1, max_idle_ns: 440795313647 ns
Aug 15 15:00:12 warbler kernel: usb 1-8: New USB device found, idVendor=8087, idProduct=0a2b, bcdDevice= 0.01
Aug 15 15:00:12 warbler kernel: usb 1-8: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Aug 15 15:00:12 warbler kernel: wmi_bus wmi_bus-PNP0C14:00: [Firmware Bug]: WQBC data block query control method not found
Aug 15 15:00:12 warbler kernel: usb 1-4.1: new low-speed USB device number 5 using xhci_hcd
Aug 15 15:00:12 warbler kernel: Key type psk registered
Aug 15 15:00:12 warbler kernel: nvme nvme0: pci function 0000:02:00.0
Aug 15 15:00:12 warbler kernel: nvme nvme0: missing or invalid SUBNQN field.
Aug 15 15:00:12 warbler kernel: usb 1-4.1: New USB device found, idVendor=046d, idProduct=c077, bcdDevice=72.00
Aug 15 15:00:12 warbler kernel: usb 1-4.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Aug 15 15:00:12 warbler kernel: usb 1-4.1: Product: USB Optical Mouse
Aug 15 15:00:12 warbler kernel: usb 1-4.1: Manufacturer: Logitech
Aug 15 15:00:12 warbler kernel: input: Logitech USB Optical Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.1/1-4.1:1.0/0003:046D:C077.0001/input/input6
Aug 15 15:00:12 warbler kernel: hid-generic 0003:046D:C077.0001: input,hidraw0: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-0000:00:14.0-4.1/input0
Aug 15 15:00:12 warbler kernel: nvme nvme0: allocated 64 MiB host memory buffer (16 segments).
Aug 15 15:00:12 warbler kernel: nvme nvme0: 4/0/0 default/read/poll queues
Aug 15 15:00:12 warbler kernel: nvme nvme0: Ignoring bogus Namespace Identifiers
Aug 15 15:00:12 warbler kernel:  nvme0n1: p1 p2
Aug 15 15:00:12 warbler kernel: usb 1-9: new full-speed USB device number 6 using xhci_hcd
Aug 15 15:00:12 warbler kernel: usb 1-9: New USB device found, idVendor=04f3, idProduct=21e3, bcdDevice=11.14
Aug 15 15:00:12 warbler kernel: usb 1-9: New USB device strings: Mfr=4, Product=14, SerialNumber=0
Aug 15 15:00:12 warbler kernel: usb 1-9: Product: Touchscreen
Aug 15 15:00:12 warbler kernel: usb 1-9: Manufacturer: ELAN
Aug 15 15:00:12 warbler kernel: input: ELAN Touchscreen as /devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/0003:04F3:21E3.0002/input/input7
Aug 15 15:00:12 warbler kernel: input: ELAN Touchscreen as /devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/0003:04F3:21E3.0002/input/input8
Aug 15 15:00:12 warbler kernel: input: ELAN Touchscreen as /devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/0003:04F3:21E3.0002/input/input9
Aug 15 15:00:12 warbler kernel: hid-generic 0003:04F3:21E3.0002: input,hiddev96,hidraw1: USB HID v1.10 Device [ELAN Touchscreen] on usb-0000:00:14.0-9/input0
Aug 15 15:00:12 warbler kernel: usb 1-4.2: new low-speed USB device number 7 using xhci_hcd
Aug 15 15:00:12 warbler kernel: usb 1-4.2: New USB device found, idVendor=046d, idProduct=c31c, bcdDevice=64.00
Aug 15 15:00:12 warbler kernel: usb 1-4.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Aug 15 15:00:12 warbler kernel: usb 1-4.2: Product: USB Keyboard
Aug 15 15:00:12 warbler kernel: usb 1-4.2: Manufacturer: Logitech
Aug 15 15:00:12 warbler kernel: input: Logitech USB Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.2/1-4.2:1.0/0003:046D:C31C.0003/input/input11
Aug 15 15:00:12 warbler kernel: i915 0000:00:02.0: [drm] Found skylake/ult (device ID 1916) integrated display version 9.00 stepping H0
Aug 15 15:00:12 warbler kernel: hid-generic 0003:046D:C31C.0003: input,hidraw2: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-0000:00:14.0-4.2/input0
Aug 15 15:00:12 warbler kernel: input: Logitech USB Keyboard Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.2/1-4.2:1.1/0003:046D:C31C.0004/input/inp>
Aug 15 15:00:12 warbler kernel: i915 0000:00:02.0: vgaarb: deactivate vga console
Aug 15 15:00:12 warbler kernel: i915 0000:00:02.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=io+mem:owns=io+mem
Aug 15 15:00:12 warbler kernel: i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/skl_dmc_ver1_27.bin (v1.27)
Aug 15 15:00:12 warbler kernel: input: Logitech USB Keyboard System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.2/1-4.2:1.1/0003:046D:C31C.0004/input/input>
Aug 15 15:00:12 warbler kernel: [drm] Initialized i915 1.6.0 for 0000:00:02.0 on minor 1
Aug 15 15:00:12 warbler kernel: ACPI: video: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
Aug 15 15:00:12 warbler kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input14
Aug 15 15:00:12 warbler kernel: hid-generic 0003:046D:C31C.0004: input,hidraw3: USB HID v1.10 Device [Logitech USB Keyboard] on usb-0000:00:14.0-4.2/input1
Aug 15 15:00:12 warbler kernel: input: ELAN Touchscreen as /devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/0003:04F3:21E3.0002/input/input15
Aug 15 15:00:12 warbler kernel: input: ELAN Touchscreen UNKNOWN as /devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/0003:04F3:21E3.0002/input/input16
Aug 15 15:00:12 warbler kernel: input: ELAN Touchscreen UNKNOWN as /devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/0003:04F3:21E3.0002/input/input17
Aug 15 15:00:12 warbler kernel: hid-multitouch 0003:04F3:21E3.0002: input,hiddev96,hidraw1: USB HID v1.10 Device [ELAN Touchscreen] on usb-0000:00:14.0-9/input0
Aug 15 15:00:12 warbler kernel: fbcon: i915drmfb (fb0) is primary device
Aug 15 15:00:12 warbler kernel: i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
Aug 15 15:00:12 warbler kernel: fbcon: Taking over console
Aug 15 15:00:12 warbler kernel: i915 0000:00:02.0: [drm] Reducing the compressed framebuffer size. This may lead to less power savings than a non-reduced-size. Try to i>
Aug 15 15:00:12 warbler kernel: Console: switching to colour frame buffer device 160x45
Aug 15 15:00:12 warbler kernel: BTRFS: device fsid c0742a37-0fbc-40a4-8f94-e208c0606e5c devid 1 transid 892446 /dev/nvme0n1p1 (259:1) scanned by mount (231)
Aug 15 15:00:12 warbler kernel: BTRFS info (device nvme0n1p1): first mount of filesystem c0742a37-0fbc-40a4-8f94-e208c0606e5c
Aug 15 15:00:12 warbler kernel: BTRFS info (device nvme0n1p1): using crc32c (crc32c-x86) checksum algorithm
Aug 15 15:00:12 warbler kernel: BTRFS info (device nvme0n1p1): using free-space-tree
Aug 15 15:00:12 warbler systemd[1]: systemd 257.8-4-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +IPE +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +A>
Aug 15 15:00:12 warbler systemd[1]: Detected architecture x86-64.
Aug 15 15:00:12 warbler systemd[1]: Hostname set to <warbler>.
Aug 15 15:00:12 warbler systemd[1]: bpf-restrict-fs: LSM BPF program attached
Aug 15 15:00:12 warbler systemd[1]: Queued start job for default target Graphical Interface.
Aug 15 15:00:12 warbler systemd[1]: Created slice Virtual Machine and Container Slice.
Aug 15 15:00:12 warbler systemd[1]: Created slice CUPS Slice.
Aug 15 15:00:12 warbler systemd[1]: Created slice Slice /system/dirmngr.
Aug 15 15:00:12 warbler systemd[1]: Created slice Slice /system/getty.
Aug 15 15:00:12 warbler systemd[1]: Created slice Slice /system/gpg-agent.
Aug 15 15:00:12 warbler systemd[1]: Created slice Slice /system/gpg-agent-browser.
Aug 15 15:00:12 warbler systemd[1]: Created slice Slice /system/gpg-agent-extra.
Aug 15 15:00:12 warbler systemd[1]: Created slice Slice /system/gpg-agent-ssh.
Aug 15 15:00:12 warbler systemd[1]: Created slice Slice /system/keyboxd.
Aug 15 15:00:12 warbler systemd[1]: Created slice Slice /system/modprobe.
Aug 15 15:00:12 warbler systemd[1]: Created slice User and Session Slice.
Aug 15 15:00:12 warbler systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
Aug 15 15:00:12 warbler systemd[1]: Started Forward Password Requests to Wall Directory Watch.
Aug 15 15:00:12 warbler systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
Aug 15 15:00:12 warbler systemd[1]: Expecting device /dev/disk/by-uuid/809319f8-dca1-47de-9b9f-0942b6628eeb...
Aug 15 15:00:12 warbler systemd[1]: Expecting device /dev/disk/by-uuid/c0742a37-0fbc-40a4-8f94-e208c0606e5c...
Aug 15 15:00:12 warbler systemd[1]: Reached target Local Encrypted Volumes.
Aug 15 15:00:12 warbler systemd[1]: Reached target Login Prompts.
Aug 15 15:00:12 warbler systemd[1]: Reached target Local Integrity Protected Volumes.
Aug 15 15:00:12 warbler systemd[1]: Reached target Remote File Systems.
Aug 15 15:00:12 warbler systemd[1]: Reached target Slice Units.
Aug 15 15:00:12 warbler systemd[1]: Reached target Mounting snaps.
Aug 15 15:00:12 warbler systemd[1]: Reached target Mounted snaps.
Aug 15 15:00:12 warbler systemd[1]: Reached target Local Verity Protected Volumes.
Aug 15 15:00:12 warbler systemd[1]: Listening on Device-mapper event daemon FIFOs.
Aug 15 15:00:12 warbler systemd[1]: Listening on LVM2 poll daemon socket.
Aug 15 15:00:12 warbler systemd[1]: Listening on Process Core Dump Socket.
Aug 15 15:00:12 warbler systemd[1]: Listening on Credential Encryption/Decryption.
Aug 15 15:00:12 warbler systemd[1]: Listening on Journal Socket (/dev/log).
Aug 15 15:00:12 warbler systemd[1]: Listening on Journal Sockets.
Aug 15 15:00:12 warbler systemd[1]: TPM PCR Measurements was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
Aug 15 15:00:12 warbler systemd[1]: Make TPM PCR Policy was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
Aug 15 15:00:12 warbler systemd[1]: Listening on udev Control Socket.
Aug 15 15:00:12 warbler systemd[1]: Listening on udev Kernel Socket.
Aug 15 15:00:12 warbler systemd[1]: Mounting Huge Pages File System...
Aug 15 15:00:12 warbler systemd[1]: Mounting POSIX Message Queue File System...
Aug 15 15:00:12 warbler systemd[1]: Mounting Kernel Debug File System...
Aug 15 15:00:12 warbler systemd[1]: Mounting Kernel Trace File System...
Aug 15 15:00:12 warbler systemd[1]: Starting Create List of Static Device Nodes...
Aug 15 15:00:12 warbler systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
Aug 15 15:00:12 warbler systemd[1]: Starting Load Kernel Module configfs...
Aug 15 15:00:12 warbler systemd[1]: Starting Load Kernel Module dm_mod...
Aug 15 15:00:12 warbler systemd[1]: Starting Load Kernel Module drm...
Aug 15 15:00:12 warbler systemd[1]: Starting Load Kernel Module fuse...
Aug 15 15:00:12 warbler systemd[1]: Starting Load Kernel Module loop...
Aug 15 15:00:12 warbler systemd[1]: Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/Hi>
Aug 15 15:00:12 warbler systemd[1]: Starting Load Kernel Modules...
Aug 15 15:00:12 warbler systemd[1]: TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
Aug 15 15:00:12 warbler systemd[1]: Starting Remount Root and Kernel File Systems...
Aug 15 15:00:12 warbler systemd[1]: Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
Aug 15 15:00:12 warbler systemd[1]: Starting Load udev Rules from Credentials...
Aug 15 15:00:12 warbler systemd[1]: Starting Coldplug All udev Devices...
Aug 15 15:00:12 warbler systemd[1]: Mounted Huge Pages File System.
Aug 15 15:00:12 warbler systemd[1]: Mounted POSIX Message Queue File System.
Aug 15 15:00:12 warbler systemd[1]: Mounted Kernel Debug File System.
Aug 15 15:00:12 warbler systemd[1]: Mounted Kernel Trace File System.
Aug 15 15:00:12 warbler systemd[1]: Finished Create List of Static Device Nodes.
Aug 15 15:00:12 warbler systemd[1]: modprobe@configfs.service: Deactivated successfully.
Aug 15 15:00:12 warbler systemd[1]: Finished Load Kernel Module configfs.
Aug 15 15:00:12 warbler systemd[1]: modprobe@drm.service: Deactivated successfully.
Aug 15 15:00:12 warbler systemd[1]: Finished Load Kernel Module drm.
Aug 15 15:00:12 warbler systemd[1]: modprobe@fuse.service: Deactivated successfully.
Aug 15 15:00:12 warbler systemd[1]: Finished Load Kernel Module fuse.
Aug 15 15:00:12 warbler systemd[1]: Mounting FUSE Control File System...
Aug 15 15:00:12 warbler systemd[1]: Mounting Kernel Configuration File System...
Aug 15 15:00:12 warbler systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
Aug 15 15:00:12 warbler systemd[1]: Mounted Kernel Configuration File System.
Aug 15 15:00:12 warbler systemd[1]: Finished Remount Root and Kernel File Systems.
Aug 15 15:00:12 warbler systemd[1]: Mounted FUSE Control File System.
Aug 15 15:00:12 warbler systemd[1]: Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
Aug 15 15:00:12 warbler kernel: loop: module loaded
Aug 15 15:00:12 warbler kernel: device-mapper: uevent: version 1.0.3
Aug 15 15:00:12 warbler kernel: device-mapper: ioctl: 4.50.0-ioctl (2025-04-28) initialised: dm-devel@lists.linux.dev
Aug 15 15:00:12 warbler systemd[1]: Starting Load/Save OS Random Seed...
Aug 15 15:00:12 warbler systemd[1]: TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
Aug 15 15:00:12 warbler systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
Aug 15 15:00:12 warbler systemd[1]: Finished Load Kernel Module dm_mod.
Aug 15 15:00:12 warbler systemd[1]: modprobe@loop.service: Deactivated successfully.
Aug 15 15:00:12 warbler systemd[1]: Finished Load Kernel Module loop.
Aug 15 15:00:12 warbler systemd[1]: Finished Load udev Rules from Credentials.
Aug 15 15:00:12 warbler systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
Aug 15 15:00:12 warbler systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
Aug 15 15:00:12 warbler kernel: i2c_dev: i2c /dev entries driver
Aug 15 15:00:12 warbler systemd[1]: Finished Load Kernel Modules.
Aug 15 15:00:12 warbler systemd[1]: Starting Apply Kernel Variables...
Aug 15 15:00:12 warbler systemd[1]: Finished Load/Save OS Random Seed.
Aug 15 15:00:12 warbler systemd[1]: Finished Apply Kernel Variables.
Aug 15 15:00:12 warbler systemd[1]: Finished Create Static Device Nodes in /dev gracefully.
Aug 15 15:00:12 warbler systemd[1]: Create System Users was skipped because no trigger condition checks were met.
Aug 15 15:00:12 warbler systemd[1]: Starting Network Name Resolution...
Aug 15 15:00:12 warbler systemd[1]: Starting Network Time Synchronization...
Aug 15 15:00:12 warbler systemd[1]: Starting Create Static Device Nodes in /dev...
Aug 15 15:00:12 warbler systemd[1]: Finished Create Static Device Nodes in /dev.
Aug 15 15:00:12 warbler systemd[1]: Reached target Preparation for Local File Systems.
Aug 15 15:00:12 warbler systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped because of an unmet condition check (ConditionKernelVersion=<5.6).
Aug 15 15:00:12 warbler systemd[1]: Starting Journal Service...
Aug 15 15:00:12 warbler systemd[1]: Starting Rule-based Manager for Device Events and Files...
Aug 15 15:00:12 warbler systemd[1]: Started Network Time Synchronization.
Aug 15 15:00:12 warbler systemd[1]: Reached target System Time Set.
Aug 15 15:00:12 warbler systemd-journald[321]: Collecting audit messages is disabled.
Aug 15 15:00:12 warbler systemd[1]: Started Network Name Resolution.
Aug 15 15:00:12 warbler systemd[1]: Reached target Host and Network Name Lookups.
Aug 15 15:00:12 warbler systemd[1]: Finished Coldplug All udev Devices.
Aug 15 15:00:12 warbler systemd[1]: Started Journal Service.
Aug 15 15:00:12 warbler kernel: Adding 17804616k swap on /dev/nvme0n1p2.  Priority:-2 extents:1 across:17804616k SS
Aug 15 15:00:12 warbler kernel: input: DELL Wireless hotkeys as /devices/virtual/input/input19
Aug 15 15:00:12 warbler kernel: parport_pc 00:04: [io  0x0378-0x037b]
Aug 15 15:00:12 warbler kernel: parport_pc 00:04: activated
Aug 15 15:00:12 warbler kernel: parport_pc 00:04: reported by Plug and Play ACPI
Aug 15 15:00:12 warbler kernel: intel_pmc_core INT33A1:00:  initialized
Aug 15 15:00:12 warbler kernel: mei_me 0000:00:16.0: enabling device (0000 -> 0002)
Aug 15 15:00:12 warbler kernel: pps_core: LinuxPPS API ver. 1 registered
Aug 15 15:00:12 warbler kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
Aug 15 15:00:12 warbler kernel: input: PC Speaker as /devices/platform/pcspkr/input/input21
Aug 15 15:00:12 warbler kernel: PTP clock support registered
Aug 15 15:00:13 warbler kernel: i801_smbus 0000:00:1f.4: SPD Write Disable is set
Aug 15 15:00:13 warbler kernel: i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
Aug 15 15:00:13 warbler kernel: i2c i2c-5: Successfully instantiated SPD at 0x50
Aug 15 15:00:13 warbler kernel: e1000e: Intel(R) PRO/1000 Network Driver
Aug 15 15:00:13 warbler kernel: e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
Aug 15 15:00:13 warbler kernel: e1000e 0000:00:1f.6: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
Aug 15 15:00:13 warbler kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
Aug 15 15:00:13 warbler kernel: dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.4)
Aug 15 15:00:13 warbler kernel: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
Aug 15 15:00:13 warbler kernel: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
Aug 15 15:00:13 warbler kernel: input: Dell WMI hotkeys as /devices/platform/PNP0C14:00/wmi_bus/wmi_bus-PNP0C14:00/9DBB5994-A997-11DA-B012-B622A1EF5492/input/input22
Aug 15 15:00:13 warbler systemd-journald[321]: Received client request to flush runtime journal.
Aug 15 15:00:13 warbler kernel: RAPL PMU: API unit is 2^-32 Joules, 5 fixed counters, 655360 ms ovfl timer
Aug 15 15:00:13 warbler kernel: RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
Aug 15 15:00:13 warbler kernel: RAPL PMU: hw unit of domain package 2^-14 Joules
Aug 15 15:00:13 warbler kernel: RAPL PMU: hw unit of domain dram 2^-14 Joules
Aug 15 15:00:13 warbler kernel: RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
Aug 15 15:00:13 warbler kernel: RAPL PMU: hw unit of domain psys 2^-14 Joules
Aug 15 15:00:13 warbler kernel: ppdev: user-space parallel port driver
Aug 15 15:00:13 warbler kernel: Intel(R) Wireless WiFi driver for Linux
Aug 15 15:00:13 warbler kernel: iwlwifi 0000:01:00.0: Detected crf-id 0xbadcafe, cnv-id 0x3000000 wfpm id 0x80000000
Aug 15 15:00:13 warbler kernel: iwlwifi 0000:01:00.0: PCI dev 24f3/0050, rev=0x201, rfid=0xd55555d5
Aug 15 15:00:13 warbler kernel: iwlwifi 0000:01:00.0: Detected Intel(R) Dual Band Wireless-AC 8260
Aug 15 15:00:13 warbler kernel: dell_laptop: Using i8042 filter function for receiving events
Aug 15 15:00:13 warbler kernel: iwlwifi 0000:01:00.0: loaded firmware version 36.c8e8e144.0 8000C-36.ucode op_mode iwlmvm
Aug 15 15:00:13 warbler kernel: snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops intel_audio_component_bind_ops [i915])
Aug 15 15:00:13 warbler kernel: e1000e 0000:00:1f.6 0000:00:1f.6 (uninitialized): registered PHC clock
Aug 15 15:00:13 warbler kernel: intel_rapl_common: Found RAPL domain package
Aug 15 15:00:13 warbler kernel: intel_rapl_common: Found RAPL domain core
Aug 15 15:00:13 warbler kernel: intel_rapl_common: Found RAPL domain uncore
Aug 15 15:00:13 warbler kernel: intel_rapl_common: Found RAPL domain dram
Aug 15 15:00:13 warbler kernel: intel_rapl_common: Found RAPL domain psys
Aug 15 15:00:13 warbler kernel: ACPI: battery: new hook: Dell Primary Battery Extension
Aug 15 15:00:13 warbler kernel: e1000e 0000:00:1f.6 eth0: (PCI Express:2.5GT/s:Width x1) 28:f1:0e:21:12:50
Aug 15 15:00:13 warbler kernel: e1000e 0000:00:1f.6 eth0: Intel(R) PRO/1000 Network Connection
Aug 15 15:00:13 warbler kernel: e1000e 0000:00:1f.6 eth0: MAC: 12, PHY: 12, PBA No: FFFFFF-0FF
Aug 15 15:00:13 warbler kernel: iTCO_vendor_support: vendor-support=0
Aug 15 15:00:13 warbler kernel: snd_hda_codec_realtek hdaudioC0D0: ALC3235: picked fixup  (pin match)
Aug 15 15:00:13 warbler kernel: snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC3235: line_outs=1 (0x16/0x0/0x0/0x0/0x0) type:line
Aug 15 15:00:13 warbler kernel: snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=1 (0x14/0x0/0x0/0x0/0x0)
Aug 15 15:00:13 warbler kernel: snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x15/0x0/0x0/0x0/0x0)
Aug 15 15:00:13 warbler kernel: snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
Aug 15 15:00:13 warbler kernel: snd_hda_codec_realtek hdaudioC0D0:    inputs:
Aug 15 15:00:13 warbler kernel: snd_hda_codec_realtek hdaudioC0D0:      Internal Mic=0x13
Aug 15 15:00:13 warbler kernel: snd_hda_codec_realtek hdaudioC0D0:      Headset Mic=0x1a
Aug 15 15:00:13 warbler kernel: snd_hda_codec_realtek hdaudioC0D0:      Headphone Mic=0x18
Aug 15 15:00:13 warbler kernel: snd_hda_codec_realtek hdaudioC0D0:      Dock Mic=0x19
Aug 15 15:00:13 warbler kernel: ee1004 5-0050: 512 byte EE1004-compliant SPD EEPROM, read-only
Aug 15 15:00:13 warbler kernel: input: HDA Intel PCH Headphone Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input23
Aug 15 15:00:13 warbler kernel: input: HDA Intel PCH Dock Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input24
Aug 15 15:00:13 warbler kernel: input: HDA Intel PCH Dock Line Out as /devices/pci0000:00/0000:00:1f.3/sound/card0/input25
Aug 15 15:00:13 warbler kernel: input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input26
Aug 15 15:00:13 warbler kernel: input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input27
Aug 15 15:00:13 warbler kernel: input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input28
Aug 15 15:00:13 warbler kernel: iTCO_wdt iTCO_wdt: Found a Intel PCH TCO device (Version=4, TCOBASE=0x0400)
Aug 15 15:00:13 warbler kernel: iTCO_wdt iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
Aug 15 15:00:13 warbler kernel: iwlwifi 0000:01:00.0: base HW address: e4:a4:71:a2:e0:27, OTP minor version: 0x4
Aug 15 15:00:13 warbler kernel: e1000e 0000:00:1f.6 enp0s31f6: renamed from eth0
Aug 15 15:00:13 warbler kernel: ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
Aug 15 15:00:13 warbler kernel: iwlwifi 0000:01:00.0 wlp1s0: renamed from wlan0
Aug 15 15:00:14 warbler kernel: intel_tcc_cooling: Programmable TCC Offset detected
Aug 15 15:00:14 warbler kernel: loop0: detected capacity change from 0 to 8
Aug 15 15:00:14 warbler kernel: squashfs: version 4.0 (2009/01/31) Phillip Lougher
Aug 15 15:00:14 warbler kernel: mousedev: PS/2 mouse device common for all mice
Aug 15 15:00:14 warbler kernel: Bluetooth: Core ver 2.22
Aug 15 15:00:14 warbler kernel: NET: Registered PF_BLUETOOTH protocol family
Aug 15 15:00:14 warbler kernel: Bluetooth: HCI device and connection manager initialized
Aug 15 15:00:14 warbler kernel: Bluetooth: HCI socket layer initialized
Aug 15 15:00:14 warbler kernel: Bluetooth: L2CAP socket layer initialized
Aug 15 15:00:14 warbler kernel: Bluetooth: SCO socket layer initialized
Aug 15 15:00:14 warbler kernel: mc: Linux media interface: v0.10
Aug 15 15:00:14 warbler kernel: NET: Registered PF_QIPCRTR protocol family
Aug 15 15:00:14 warbler kernel: videodev: Linux video capture interface: v2.00
Aug 15 15:00:15 warbler kernel: usbcore: registered new interface driver btusb
Aug 15 15:00:15 warbler kernel: Bluetooth: hci0: Firmware revision 0.0 build 14 week 44 2021
Aug 15 15:00:15 warbler kernel: Bluetooth: hci0: Reading supported features failed (-16)
Aug 15 15:00:15 warbler kernel: Bluetooth: hci0: Error reading debug features
Aug 15 15:00:15 warbler kernel: Bluetooth: hci0: HCI LE Coded PHY feature bit is set, but its usage is not supported.
Aug 15 15:00:15 warbler kernel: usb 1-2: Found UVC 1.00 device Integrated_Webcam_FHD (0bda:5765)
Aug 15 15:00:15 warbler kernel: usbcore: registered new interface driver uvcvideo
Aug 15 15:00:15 warbler kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Aug 15 15:00:15 warbler kernel: Bluetooth: BNEP filters: protocol multicast
Aug 15 15:00:15 warbler kernel: Bluetooth: BNEP socket layer initialized
Aug 15 15:00:15 warbler kernel: Bluetooth: MGMT ver 1.23
Aug 15 15:00:15 warbler kernel: NET: Registered PF_ALG protocol family
Aug 15 15:00:15 warbler kernel: iwlwifi 0000:01:00.0: Registered PHC clock: iwlwifi-PTP, with index: 1
Aug 15 15:00:15 warbler kernel: bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
Aug 15 15:00:16 warbler kernel: u32 classifier
Aug 15 15:00:16 warbler kernel:     Performance counters on
Aug 15 15:00:16 warbler kernel:     input device check on
Aug 15 15:00:16 warbler kernel:     Actions configured
Aug 15 15:00:16 warbler kernel: kvm_intel: L1TF CPU bug present and SMT on, data leak possible. See CVE-2018-3646 and https://www.kernel.org/doc/html/latest/admin-guide>
Aug 15 15:00:21 warbler kernel: NET: Registered PF_VSOCK protocol family
Aug 15 15:00:24 warbler kernel: nvme nvme0: using unchecked data buffer
Aug 15 15:00:27 warbler kernel: Bluetooth: RFCOMM TTY layer initialized
Aug 15 15:00:27 warbler kernel: Bluetooth: RFCOMM socket layer initialized
Aug 15 15:00:27 warbler kernel: Bluetooth: RFCOMM ver 1.11
Aug 15 15:00:28 warbler kernel: wlp1s0: authenticate with 04:d9:f5:c1:e0:d4 (local address=e4:a4:71:a2:e0:27)
Aug 15 15:00:28 warbler kernel: wlp1s0: send auth to 04:d9:f5:c1:e0:d4 (try 1/3)
Aug 15 15:00:28 warbler kernel: wlp1s0: authenticated
Aug 15 15:00:28 warbler kernel: wlp1s0: associate with 04:d9:f5:c1:e0:d4 (try 1/3)
Aug 15 15:00:28 warbler kernel: wlp1s0: RX AssocResp from 04:d9:f5:c1:e0:d4 (capab=0x511 status=0 aid=4)
Aug 15 15:00:28 warbler kernel: wlp1s0: associated
Aug 15 15:00:28 warbler kernel: wlp1s0: Limiting TX power to 30 (30 - 0) dBm as advertised by 04:d9:f5:c1:e0:d4
Aug 15 15:00:30 warbler kernel: warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
Aug 15 15:17:10 warbler kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=1873 end=1874) time 227 us, min 1431, max 1439, scanline start 1>
Aug 15 19:18:02 warbler kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=103454 end=103455) time 232 us, min 1431, max 1439, scanline sta>
That returns
Call to Hibernate failed: Specified resume device is missing or is not an active swap device
So, okay, I put the hibernate device on the kernel command line. I tried using the label for the partition, and when that failed the UUID for the partition. Both seem to fail.
Should I be doing something additional or instead?
with an current systemd/mkinitcpio the resume device will be stored in an uefi variable. Setting the kernel parameter is not needed anymore.
so just check if ‘resume’ is in etc/mkinitcpio.conf in HOOKS. and if your swap partition/file is active and the size is approximately your RAM+VRAM.
(If you have an swap file, make shure it’s not in /home)
BTW inxi would be nice [HowTo] Request support
doas inxi
CPU: dual core Intel Core i5-6300U (-MT MCP-) speed/min/max: 500/400/3000 MHz
Kernel: 6.16.0-5-MANJARO x86_64 Up: 10h 2m Mem: 3.71/15.43 GiB (24.1%)
Storage: 476.94 GiB (83.8% used) Procs: 230 Shell: Bash inxi: 3.3.38
 free
               total        used        free      shared  buff/cache   available
Mem:           15797        3700        1618         925       11733       12096
Swap:          17387           5       17381
If that helps.
I use a swap partition.
hooks line in mkinitcpio.conf is
HOOKS=(base udev autodetect microcode modconf kms keyboard keymap consolefont block filesystems resume fsck)
I corrected the format of the above. Not quite sure what is going on. Maybe the full inxi -zv8 or cat /etc/fstab will help. I see at the beginning of the systemd log 2 partitions are expected, the question is are those found an mounted successfully and what are those. May be fully unrelated.
From the last post, it seems like you are hibernating 16 GB RAM in 17GB swap…that might be a little too little. I am not familiar in such depths with the systemd hibernation - according to the arch wiki it should work :man_shrugging:
Storing in uefi only works on an EFI system. I am running traditional BIOS, EFI turned off.
# <file system>             <mount point>  <type>  <options>  <dump>  <pass>
UUID=c0742a37-0fbc-40a4-8f94-e208c0606e5c /              btrfs   subvol=/@,defaults,discard=async,ssd 0 0
UUID=c0742a37-0fbc-40a4-8f94-e208c0606e5c /home          btrfs   subvol=/@home,defaults,discard=async,ssd 0 0
UUID=c0742a37-0fbc-40a4-8f94-e208c0606e5c /var/cache     btrfs   subvol=/@cache,defaults,discard=async,ssd 0 0
UUID=c0742a37-0fbc-40a4-8f94-e208c0606e5c /var/log       btrfs   subvol=/@log,defaults,discard=async,ssd 0 0
UUID=809319f8-dca1-47de-9b9f-0942b6628eeb swap           swap    defaults,noatime 0 0
tmpfs                                     /tmp           tmpfs   defaults,noatime,mode=1777 0 0
Okay, update. I got it working. But this is ODD.
Changed the /etc/default/grub after rereading ALL of those pages and documents.
I took the resume= out of the GRUB_CMDLINE_LINUX_DEFAULT=
line and put it into the GRUB_CMDLINE_LINUX line all by itself.
Then did all of the udpates (grub, mkinitcpio, etc) again.
Rebooted, and the option came back.
From my understanding that should have made NO difference whatever!
So I may have had a typo and fixed it in the redoing? I cannot be sure.
I only pray it never breaks again on this installation.
I may enable EFI for my next install and just use the EFI hibernate methods, because that (despite being problematic from a stability and security standpoint) is far more simple.
In any case: THANK YOU for the links, pointers, and suggestions. They helped. And in the end they brought me to a successful conclusion. :slight_smile:
