24 pin dot matrix printer for manjaro
Hello all Linux friends
I am looking for a 24 pin dot matrix printer USB or network connection.
Does anyone know a good Pinter model that work with linux natively!!
Best regards
Hi @Sjostrand ,
Please, take a look at the following link:
Printer List | OpenPrinting - The Linux Foundation
Did you search the Internet and saw what printer you want to buy? Maybe, I could help you a little more.
I do not know which DE/WM are you actually using. I wonder whether you could tell me about it, in order to help you.
Hope this help, regards
Hello an Thanks for answering
Ye I was looking at Oki Ml 3390eco or Epson LQ-350
I use latest Manjaro native no WM here
Hi @Sjostrand ,
I searched on the link posted above and found that the Epson printer is supported.
Printer: Epson LQ-350 | OpenPrinting - The Linux Foundation
Regards,
Does any one successfully make any oki dot matrix printer work with Manjaro??
Anyone have Oki Ml 3390eco series dot matrix printer working with Manjaro?? Why better print dpi then Epson
