Hello forum,
Occasionally at around 21:30, my system completely freezes and REISUB, while activated, does not work.
I have the journalctl for the last seconds before 21:30. There is an error (first three lines), but I’m unsure what it means.
Mar 24 21:29:27 lee-pc kernel: BUG: unable to handle page fault for address: 000000040001f38a
Mar 24 21:29:28 lee-pc kernel: #PF: supervisor read access in kernel mode
Mar 24 21:29:28 lee-pc kernel: #PF: error_code(0x0000) - not-present page
Mar 24 21:29:28 lee-pc kernel: PGD 402656067 P4D 402656067 PUD 0
Mar 24 21:29:28 lee-pc kernel: Oops: 0000 [#1] PREEMPT SMP NOPTI
Mar 24 21:29:28 lee-pc kernel: CPU: 7 PID: 162 Comm: kswapd0 Tainted: P OE 5.4.105-1-MANJARO #1
Mar 24 21:29:28 lee-pc kernel: Hardware name: System manufacturer System Product Name/PRIME B450M-K, BIOS 2202 07/14/2020
Mar 24 21:29:28 lee-pc kernel: RIP: 0010:workingset_eviction+0x38/0xe0
Mar 24 21:29:28 lee-pc kernel: Code: 04 c5 a0 3e b4 a2 48 8b 47 38 0f 1f 44 00 00 0f b7 b0 f0 00 00 00 0f 1f 44 00 00 49 63 90 00 31 00 00 48 8b 94 d0 28 0b 00 00 <4c> 3b 82 80 00 00 00 75 7f b8 01 00 00 00 f0 48 0f c1 42 70 48 8b
Mar 24 21:29:28 lee-pc kernel: RSP: 0018:ffffbd234056fac8 EFLAGS: 00010056
Mar 24 21:29:28 lee-pc kernel: RAX: ffff9c0480651000 RBX: ffff9c02698fee30 RCX: 0000000000000000
Mar 24 21:29:28 lee-pc kernel: RDX: 000000040001f30a RSI: 0000000000000000 RDI: fffff27a0630ed40
Mar 24 21:29:28 lee-pc kernel: RBP: fffff27a0630ed40 R08: ffff9c049f37c000 R09: 0000000000000002
Mar 24 21:29:28 lee-pc kernel: R10: ffff9c02698fee30 R11: 000000000015359c R12: 0000000000000001
Mar 24 21:29:28 lee-pc kernel: R13: 0000000000000246 R14: ffff9c02698fee38 R15: 0000000000000000
Mar 24 21:29:28 lee-pc kernel: FS: 0000000000000000(0000) GS:ffff9c048e9c0000(0000) knlGS:0000000000000000
Mar 24 21:29:28 lee-pc kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Mar 24 21:29:28 lee-pc kernel: CR2: 000000040001f38a CR3: 000000013f590000 CR4: 00000000003406e0
Mar 24 21:29:28 lee-pc kernel: Call Trace:
Mar 24 21:29:28 lee-pc kernel: __remove_mapping+0x1ae/0x1e0
Mar 24 21:29:28 lee-pc kernel: shrink_page_list+0x837/0xbd0
Mar 24 21:29:28 lee-pc kernel: shrink_inactive_list+0x17e/0x410
Mar 24 21:29:28 lee-pc kernel: shrink_node_memcg+0x2c4/0x820
Mar 24 21:29:28 lee-pc kernel: shrink_node.isra.0+0xc3/0x440
Mar 24 21:29:28 lee-pc kernel: balance_pgdat+0x2e7/0x530
Mar 24 21:29:28 lee-pc kernel: kswapd+0x1fd/0x3e0
Mar 24 21:29:28 lee-pc kernel: ? wait_woken+0x80/0x80
Mar 24 21:29:28 lee-pc kernel: ? balance_pgdat+0x530/0x530
Mar 24 21:29:28 lee-pc kernel: kthread+0x13e/0x160
Mar 24 21:29:28 lee-pc kernel: ? __kthread_bind_mask+0x60/0x60
Mar 24 21:29:28 lee-pc kernel: ret_from_fork+0x22/0x40
Mar 24 21:29:28 lee-pc kernel: Modules linked in: nft_fib_ipv4 nft_fib nft_ct nf_tables nfnetlink wireguard(E) ip6_udp_tunnel udp_tunnel rfcomm cmac algif_hash algif_skcipher af_alg bnep nf_log_ipv6 ip6t_REJECT nf_reject_ipv6 xt_h>
Mar 24 21:29:28 lee-pc kernel: nf_defrag_ipv6 nf_defrag_ipv4 libcrc32c iptable_filter uinput nvidia_drm(POE) nvidia_modeset(POE) drm_kms_helper drm agpgart syscopyarea sysfillrect sysimgblt fb_sys_fops nvidia(POE) vboxnetflt(OE) >
Mar 24 21:29:28 lee-pc kernel: ---[ end trace 7f19da0840d251cb ]---
Mar 24 21:29:28 lee-pc kernel: note: kswapd0[162] exited with preempt_count 1
Mar 24 21:29:39 lee-pc kernel: [UFW BLOCK] IN=enp7s0 OUT= MAC=01:00:5e:00:00:01:48:7d:2e:f9:3a:fe:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
Here’s inixi:
Kernel: 5.4.105-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=2da13361-3914-4269-a8f9-cf1731568275 rw quiet
sysrq_always_enabled=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4 vt: 1
Type: Desktop Mobo: ASUSTeK model: PRIME B450M-K v: Rev X.0x
serial: <filter> UEFI-[Legacy]: American Megatrends v: 2202 date: 07/14/2020
Info: 6-Core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+
family: 17 (23) model-id: 8 stepping: 2 microcode: 800820D cache: L2: 3 MiB
bogomips: 81456
Speed: 2350 MHz min/max: 1550/3400 MHz boost: enabled Core speeds (MHz):
1: 2350 2: 2405 3: 1375 4: 1374 5: 1331 6: 1374 7: 1373 8: 1373 9: 2188
10: 2733 11: 1533 12: 1374
disabled, RSB filling
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: ASUSTeK PH-GTX1050TI-4G
driver: nvidia v: 460.56 alternate: nouveau,nvidia_drm bus-ID: 08:00.0
chip-ID: 10de:1c82 class-ID: 0300
Display: x11 server: X.Org 1.20.10 driver: loaded: nvidia display-ID: :0.0
screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3")
s-diag: 583mm (23")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 93 size: 527x296mm (20.7x11.7")
diag: 604mm (23.8")
OpenGL: renderer: GeForce GTX 1050 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 460.56
direct render: Yes
Device-1: NVIDIA GP107GL High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 08:00.1 chip-ID: 10de:0fb9
class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 0a:00.3 chip-ID: 1022:1457 class-ID: 0403
Sound Server-1: ALSA v: k5.4.105-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.17 running: no
Sound Server-4: PulseAudio v: 14.2 running: yes
vendor: ASUSTeK driver: r8168 v: 8.048.03-NAPI modules: r8169 port: f000
bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-3:3 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 4.55 TiB used: 1.02 TiB (22.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM003-1ER162
rotation: 7200 rpm serial: <filter> rev: CC45 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Seagate model: BUP Slim BK
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B
serial: <filter> rev: 0304 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Seagate model: BUP Slim RD
ID-4: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST2000DM005-2CW102
rotation: 5425 rpm serial: <filter> rev: 0001 scheme: GPT
ID-1: / raw-size: 166.26 GiB size: 162.65 GiB (97.83%)
used: 86.93 GiB (53.4%) fs: ext4 dev: /dev/sdc4 maj-min: 8:36
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 9.95 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdc3 maj-min: 8:35
System Temperatures: cpu: 39.0 C mobo: N/A gpu: nvidia temp: 46 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 30%
Processes: 291 Uptime: 37m wakeups: 0 Memory: 15.64 GiB
used: 3.52 GiB (22.5%) Init: systemd v: 247 tool: systemctl Compilers:
gcc: 10.2.0 alt: 8/9 clang: 11.1.0 Packages: pacman: 1833 lib: 455
Shell: Bash v: 5.1.0 running-in: xfce4-terminal inxi: 3.3.03
Thank you.
