please can someone help me i want to install eclipse 2020-09 version but currently i m on 2020-03 edge release version cant find a way to install the latest version.
You need this package from AUR
https://aur.archlinux.org/packages/eclipse-java/
pamac build eclipse-java
You will have to remove eclipse-common
before that, if you have it installed.
You can use this AUR package instead if you don’t want to spend much time on compiling
https://aur.archlinux.org/packages/eclipse-java-bin
pamac build eclipse-java-bin
thank sir have a great day
