My display is half broken and so i thought making my tab a second display would help me able to see things at full color. I tried achieving this using vdl-monitor and deskcreen. As expected it did work but i soon found out that the screen recorder stopped working. I figured out it was because of the 20-intel.conf file in /usr/share/X11/xorg.conf.d/
. I removed it and that did fix the problem but then i wasn’t able to use vdl-monitor. I dont know the reason for the 20-intel.conf glitching out my screen recorder. Heres the content written inside the file:
Section "Device"
Identifier "intelgpu0"
Driver "intel"
Option "VirtualHeads" "2"
EndSection
And heres my inxi:
Kernel: 5.15.65-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=875edbad-ad77-49d2-ac56-e609bdfda3a8 rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.5 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Portable System: Dell product: Inspiron N5010 v: A02
serial: <superuser required>
Mobo: Dell model: 0WXY9J v: A02 serial: <superuser required>
UEFI-[Legacy]: Dell v: A02 date: 04/09/2010
Device-1: Intel Core Processor Integrated Graphics vendor: Dell driver: i915
v: kernel arch: Gen-5.75 process: Intel 45nm built: 2010 ports:
active: LVDS-1 empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0046 class-ID: 0300
Device-2: Microdia Laptop_Integrated_Webcam_1.3M type: USB
driver: uvcvideo bus-ID: 1-1.6:3 chip-ID: 0c45:6461 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915
resolution: 1366x768~60Hz
OpenGL: renderer: Mesa Intel HD Graphics (ILK) v: 2.1 Mesa 22.1.7
direct render: Yes
