Output of inxi -zv8:
Kernel: 6.12.28-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
parameters: BOOT_IMAGE=/vmlinuz-6.12-x86_64
root=UUID=97179447-34f4-4f42-b0d3-a3156b893d8e rw quiet usbhid.kbpoll=1
usbhid.mousepoll=1
Desktop: i3 v: 4.24 with: i3bar tools: avail: cinnamon-screensaver,
i3lock, light-locker, xss-lock vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro
base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: TUF H370-PRO GAMING (WI-FI) v: Rev 1.xx
serial: <superuser required> part-nu: ASUS_MB_CNL uuid: <superuser required>
UEFI: American Megatrends v: 2301 date: 07/10/2020
System RAM: total: 32 GiB available: 31.19 GiB used: 2.41 GiB (7.7%)
Array-1: capacity: 64 GiB slots: 4 modules: 4 EC: None
Device-1: ChannelA-DIMM1 type: DDR4 detail: synchronous size: 8 GiB
speed: 2133 MT/s volts: curr: 1 width (bits): data: 64 total: 64
manufacturer: Corsair part-no: CMK16GX4M2A2666C16 serial: N/A
Device-2: ChannelA-DIMM2 type: DDR4 detail: synchronous size: 8 GiB
Device-3: ChannelB-DIMM1 type: DDR4 detail: synchronous size: 8 GiB
Device-4: ChannelB-DIMM2 type: DDR4 detail: synchronous size: 8 GiB
Info: model: Intel Core i5-8400 bits: 64 type: MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xFA
Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 smt: <unsupported> cache:
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 800 min/max: 800/4000 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800
bogomips: 33613
smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
disabled
Type: spectre_v2 mitigation: IBRS; IBPB: conditional; STIBP: disabled;
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: ASUSTeK
ports: active: DP-1 empty: DP-2,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:3e92 class-ID: 0300
Device-2: NVIDIA GP107 [GeForce GTX 1050 Ti] driver: nvidia v: 570.144
alternate: nouveau,nvidia_drm non-free: 550-570.xx+ status: current (as of
2025-04; EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1c82 class-ID: 0300
Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.65x15.00")
s-diag: 777mm (30.58")
Monitor-1: DP-1 model: BenQ LCD serial: <filter> built: 2021 res:
mode: 2560x1440 hz: 60 scale: 100% (1) dpi: 123 gamma: 1.2 chroma: red:
x: 0.663 y: 0.333 green: x: 0.298 y: 0.631 blue: x: 0.145 y: 0.051 white:
x: 0.314 y: 0.329 size: 527x296mm (20.75x11.65") diag: 604mm (23.8")
ratio: 16:9 modes: 2560x1440, 1920x1080, 1920x1080i, 1680x1050, 1600x900,
1280x1024, 1280x800, 1152x864, 1280x720, 1024x768, 832x624, 800x600,
720x576, 720x480, 640x480, 720x400
drv: nvidia device: 1 drv: iris device: 2 drv: swrast gbm: drv: iris
surfaceless: drv: nvidia x11: drv: iris inactive: wayland
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.0.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) device-ID: 8086:3e92 memory: 15.23 GiB unified: yes
API: Vulkan v: 1.4.313 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1050 Ti driver: nvidia v: 570.144 device-ID: 10de:1c82
surfaces: N/A device: 1 type: integrated-gpu name: Intel UHD Graphics 630
(CFL GT2) driver: mesa intel v: 25.0.5-arch1.1 device-ID: 8086:3e92
surfaces: N/A
gpu: nvidia-settings,nvidia-smi x11: xdriinfo, xdpyinfo, xprop, xrandr
Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
API: ALSA v: k6.12.28-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
IF: wlo1 state: down mac: <filter>
Device-2: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
IF: eno2 state: up speed: 1000 Mbps duplex: full mac: <filter>
Info: services: NetworkManager, sshd, systemd-timesyncd
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:6
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.1
lmp-v: 10 status: discoverable: yes pairing: yes class-ID: 6c0104
Local Storage: total: 465.76 GiB used: 206.66 GiB (44.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 34.9 C
scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE BH16NS55 rev: 1.03
dev-links: cdrom
ID-1: / raw-size: 128 GiB size: 125.43 GiB (97.99%) used: 57.08 GiB (45.5%)
fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
uuid: 97179447-34f4-4f42-b0d3-a3156b893d8e
ID-2: /boot raw-size: 1024 MiB size: 1006.7 MiB (98.31%)
used: 332.4 MiB (33.0%) fs: ext2 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: d3098810-c648-480a-9806-025aa914b5bc
ID-3: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%)
used: 15.2 MiB (1.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: CBF7-0AD4
ID-4: /home raw-size: 238.76 GiB size: 233.95 GiB (97.99%)
used: 149.24 GiB (63.8%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
label: N/A uuid: 4b9523f9-de89-426e-b67d-1ddc2dd640d5
Kernel: swappiness: 20 (default 60) cache-pressure: 100 (default) zswap: no
ID-1: swap-1 type: partition size: 1024 MiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: 78c046f2-c046-4cd6-8f50-63c10053473e
ID-1: /dev/nvme0n1p5 maj-min: 259:5 size: 96 GiB fs: ext4 label: N/A
uuid: 384d6d8f-1a36-4bd2-b9c5-949f550c7c65
Device-1: 1-4:2 info: Holtek Wireless Dongle 2.4 GHZ HT82D40REW
type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
chip-ID: 1a81:1004 class-ID: 0301
Hub-2: 1-7:8 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-9:4 info: Logitech Logi Bolt Receiver type: keyboard,mouse,HID
lanes: 1 mode: 1.1 power: 98mA chip-ID: 046d:c548 class-ID: 0300
Device-2: 1-10:5 info: Logitech Logi Bolt Receiver
type: keyboard,mouse,HID driver: hid-generic,hid-multitouch,usbhid
interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
Device-3: 1-14:6 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-3: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
System Temperatures: cpu: 27.5 C mobo: 27.0 C
Fan Speeds (rpm): fan-1: 0 fan-2: 826 fan-3: 0 fan-4: 0 fan-5: 449
fan-6: 0 fan-7: 0
Power: 12v: N/A 5v: N/A 3.3v: 3.33 vbat: 3.10
Packages: pm: pacman pkgs: 2607 libs: 585 tools: pamac,yay pm: flatpak
pkgs: 0
1: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
2: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
3: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
4: https://manjaro.kurdy.org/stable/$repo/$arch
Processes:
CPU top: 5 of 225
1: cpu: 6.7% command: firefox pid: 2291 mem: 708.5 MiB (2.2%)
2: cpu: 4.4% command: firefox pid: 3577 mem: 296.7 MiB (0.9%)
3: cpu: 0.8% command: Xorg pid: 862 mem: 95.6 MiB (0.2%)
4: cpu: 0.2% command: gnome-terminal-server pid: 1415 mem: 58.5 MiB (0.1%)
5: cpu: 0.2% command: firefox pid: 2457 mem: 229.4 MiB (0.7%)
Memory top: 5 of 225
1: mem: 708.5 MiB (2.2%) command: firefox pid: 2291 cpu: 6.7%
2: mem: 296.7 MiB (0.9%) command: firefox pid: 3577 cpu: 4.4%
3: mem: 275.7 MiB (0.8%) command: firefox pid: 2386 cpu: 0.0%
4: mem: 229.4 MiB (0.7%) command: firefox pid: 2457 cpu: 0.2%
5: mem: 217.6 MiB (0.6%) command: firefox pid: 2536 cpu: 0.2%
Processes: 225 Power: uptime: 2h 42m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.44 GiB services: upowerd Init: systemd
v: 257 default: graphical tool: systemctl
Compilers: clang: 19.1.7 gcc: 15.1.1 alt: 14 Shell: Bash v: 5.2.37
running-in: gnome-terminal inxi: 3.3.38
System log:
Jun 04 09:14:00 pc1 systemd[1]: Stopping Session c1 of User lightdm...
Jun 04 09:14:00 pc1 lightdm[889]: pam_unix(lightdm-greeter:session): session closed for user lightdm
Jun 04 09:14:00 pc1 systemd[1]: session-c1.scope: Deactivated successfully.
Jun 04 09:14:00 pc1 systemd[1]: Stopped Session c1 of User lightdm.
Jun 04 09:14:00 pc1 systemd[1]: session-c1.scope: Consumed 1.037s CPU time, 143.1M memory peak.
Jun 04 09:14:00 pc1 systemd-logind[731]: Removed session c1.
Jun 04 09:14:00 pc1 lightdm[981]: pam_unix(lightdm:session): session opened for user user1(uid=1000) by user1(uid=0)
Jun 04 09:14:00 pc1 systemd-logind[731]: New session 2 of user user1.
Jun 04 09:14:00 pc1 systemd[1]: Created slice User Slice of UID 1000.
Jun 04 09:14:00 pc1 systemd[1]: Starting User Runtime Directory /run/user/1000...
Jun 04 09:14:00 pc1 systemd[1]: Finished User Runtime Directory /run/user/1000.
Jun 04 09:14:00 pc1 systemd[1]: Starting User Manager for UID 1000...
Jun 04 09:14:00 pc1 (systemd)[1160]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[user1] ruser=[<unknown>] rhost=[<unknown>]
Jun 04 09:14:00 pc1 (systemd)[1160]: pam_unix(systemd-user:session): session opened for user user1(uid=1000) by user1(uid=0)
Jun 04 09:14:00 pc1 systemd-logind[731]: New session 3 of user user1.
Jun 04 09:14:00 pc1 systemd[1160]: Queued start job for default target Main User Target.
Jun 04 09:14:00 pc1 systemd[1160]: Created slice User Application Slice.
Jun 04 09:14:00 pc1 systemd[1160]: Created slice User Core Session Slice.
Jun 04 09:14:00 pc1 systemd[1160]: Reached target Paths.
Jun 04 09:14:00 pc1 systemd[1160]: Reached target Timers.
Jun 04 09:14:00 pc1 systemd[1160]: Starting D-Bus User Message Bus Socket...
Jun 04 09:14:00 pc1 systemd[1160]: Listening on GnuPG network certificate management daemon.
Jun 04 09:14:00 pc1 systemd[1160]: Starting GCR ssh-agent wrapper...
Jun 04 09:14:00 pc1 systemd[1160]: Listening on GNOME Keyring daemon.
Jun 04 09:14:00 pc1 systemd[1160]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
Jun 04 09:14:00 pc1 systemd[1160]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Jun 04 09:14:00 pc1 systemd[1160]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Jun 04 09:14:00 pc1 systemd[1160]: Listening on GnuPG cryptographic agent and passphrase cache.
Jun 04 09:14:00 pc1 systemd[1160]: Listening on GnuPG public key management service.
Jun 04 09:14:00 pc1 systemd[1160]: Listening on p11-kit server.
Jun 04 09:14:00 pc1 systemd[1160]: Listening on PipeWire PulseAudio.
Jun 04 09:14:00 pc1 systemd[1160]: Listening on PipeWire Multimedia System Sockets.
Jun 04 09:14:00 pc1 systemd[1160]: Listening on D-Bus User Message Bus Socket.
Jun 04 09:14:00 pc1 systemd[1160]: Listening on GCR ssh-agent wrapper.
Jun 04 09:14:00 pc1 systemd[1160]: Reached target Sockets.
Jun 04 09:14:00 pc1 systemd[1160]: Starting D-Bus User Message Bus...
Jun 04 09:14:00 pc1 dbus-broker-launch[1173]: Service file '/usr/share//dbus-1/services/nemo.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Jun 04 09:14:00 pc1 dbus-broker-launch[1173]: Service file '/usr/share//dbus-1/services/nemo.service' is not named after the D-Bus name 'org.Nemo'.
Jun 04 09:14:00 pc1 dbus-broker-launch[1173]: Service file '/usr/share//dbus-1/services/org.gnome.Caribou.Antler.service' is not named after the D-Bus name 'org.gnome.Caribou.Keyboard'.
Jun 04 09:14:00 pc1 dbus-broker-launch[1173]: Service file '/usr/share//dbus-1/services/org.knopwob.dunst.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Jun 04 09:14:00 pc1 dbus-broker-launch[1173]: Service file '/usr/share//dbus-1/services/org.xfce.Thunar.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Jun 04 09:14:00 pc1 dbus-broker-launch[1173]: Ignoring duplicate name 'org.freedesktop.FileManager1' in service file '/usr/share//dbus-1/services/org.xfce.Thunar.FileManager1.service'
Jun 04 09:14:00 pc1 dbus-broker-launch[1173]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Cache1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Cache1'.
Jun 04 09:14:00 pc1 dbus-broker-launch[1173]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Manager1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Manager1'.
Jun 04 09:14:00 pc1 dbus-broker-launch[1173]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Thumbnailer1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Thumbnailer1'.
Jun 04 09:14:00 pc1 dbus-broker-launch[1173]: Policy to allow eavesdropping in /usr/share/dbus-1/session.conf +31: Eavesdropping is deprecated and ignored
Jun 04 09:14:00 pc1 dbus-broker-launch[1173]: Policy to allow eavesdropping in /usr/share/dbus-1/session.conf +33: Eavesdropping is deprecated and ignored
Jun 04 09:14:00 pc1 dbus-broker-launch[1173]: Service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Jun 04 09:14:00 pc1 dbus-broker-launch[1173]: Ignoring duplicate name 'org.freedesktop.Notifications' in service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service'
Jun 04 09:14:00 pc1 dbus-broker-launch[1173]: Service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifyd.service' is not named after the D-Bus name 'org.xfce.Notifyd'.
Jun 04 09:14:00 pc1 systemd[1160]: Started D-Bus User Message Bus.
Jun 04 09:14:00 pc1 systemd[1160]: Reached target Basic System.
Jun 04 09:14:00 pc1 systemd[1]: Started User Manager for UID 1000.
Jun 04 09:14:00 pc1 systemd[1160]: Started PipeWire Multimedia Service.
Jun 04 09:14:00 pc1 systemd[1]: Started Session 2 of User user1.
Jun 04 09:14:00 pc1 systemd[1160]: Started Multimedia Service Session Manager.
Jun 04 09:14:00 pc1 dbus-broker-launch[1173]: Ready
Jun 04 09:14:00 pc1 systemd[1160]: Starting Update XDG user dir configuration...
Jun 04 09:14:00 pc1 systemd[1160]: Started GNOME Keyring daemon.
Jun 04 09:14:01 pc1 systemd[1160]: Finished Update XDG user dir configuration.
Jun 04 09:14:01 pc1 systemd[1160]: Reached target Main User Target.
Jun 04 09:14:01 pc1 systemd[1160]: Startup finished in 198ms.
Jun 04 09:14:01 pc1 gnome-keyring-daemon[1179]: gnome-keyring-daemon: no process capabilities, insecure memory might get used
Jun 04 09:14:01 pc1 gnome-keyring-daemon[1179]: GNOME_KEYRING_CONTROL=/run/user/1000/keyring
Jun 04 09:14:01 pc1 lightdm[981]: gkr-pam: unlocked login keyring
Jun 04 09:14:01 pc1 systemd[1]: Starting RealtimeKit Scheduling Policy Service...
Jun 04 09:14:01 pc1 wireplumber[1176]: wp-internal-comp-loader: Loading profile 'main'
Jun 04 09:14:01 pc1 systemd[1]: Started RealtimeKit Scheduling Policy Service.
Jun 04 09:14:01 pc1 rtkit-daemon[1188]: Successfully called chroot.
Jun 04 09:14:01 pc1 rtkit-daemon[1188]: Successfully dropped privileges.
Jun 04 09:14:01 pc1 rtkit-daemon[1188]: Successfully limited resources.
Jun 04 09:14:01 pc1 rtkit-daemon[1188]: Canary thread running.
Jun 04 09:14:01 pc1 rtkit-daemon[1188]: Running.
Jun 04 09:14:01 pc1 rtkit-daemon[1188]: Watchdog thread running.
Jun 04 09:14:01 pc1 rtkit-daemon[1188]: Supervising 0 threads of 0 processes of 0 users.
Jun 04 09:14:01 pc1 rtkit-daemon[1188]: Successfully made thread 1176 of process 1176 owned by '1000' high priority at nice level -11.
Jun 04 09:14:01 pc1 rtkit-daemon[1188]: Supervising 1 threads of 1 processes of 1 users.
Jun 04 09:14:01 pc1 rtkit-daemon[1188]: Successfully made thread 1189 of process 1175 owned by '1000' RT at priority 20.
Jun 04 09:14:01 pc1 rtkit-daemon[1188]: Supervising 2 threads of 2 processes of 1 users.
Jun 04 09:14:01 pc1 rtkit-daemon[1188]: Successfully made thread 1209 of process 1176 owned by '1000' RT at priority 20.
Jun 04 09:14:01 pc1 rtkit-daemon[1188]: Supervising 3 threads of 2 processes of 1 users.
Jun 04 09:14:01 pc1 wireplumber[1176]: wp-device: SPA handle 'api.libcamera.enum.manager' could not be loaded; is it installed?
Jun 04 09:14:01 pc1 wireplumber[1176]: s-monitors-libcamera: PipeWire's libcamera SPA plugin is missing or broken. Some camera types may not be supported.
Jun 04 09:14:01 pc1 kernel: Bluetooth: RFCOMM TTY layer initialized
Jun 04 09:14:01 pc1 kernel: Bluetooth: RFCOMM socket layer initialized
Jun 04 09:14:01 pc1 kernel: Bluetooth: RFCOMM ver 1.11
Jun 04 09:14:01 pc1 bluetoothd[720]: Endpoint registered: sender=:1.42 path=/MediaEndpoint/A2DPSource/ldac
Jun 04 09:14:01 pc1 bluetoothd[720]: Endpoint registered: sender=:1.42 path=/MediaEndpoint/A2DPSink/aptx_hd
Jun 04 09:14:01 pc1 bluetoothd[720]: Endpoint registered: sender=:1.42 path=/MediaEndpoint/A2DPSource/aptx_hd
Jun 04 09:14:01 pc1 bluetoothd[720]: Endpoint registered: sender=:1.42 path=/MediaEndpoint/A2DPSink/aac
Jun 04 09:14:01 pc1 bluetoothd[720]: Endpoint registered: sender=:1.42 path=/MediaEndpoint/A2DPSource/aac
Jun 04 09:14:01 pc1 bluetoothd[720]: Endpoint registered: sender=:1.42 path=/MediaEndpoint/A2DPSink/opus_g
Jun 04 09:14:01 pc1 bluetoothd[720]: Endpoint registered: sender=:1.42 path=/MediaEndpoint/A2DPSource/opus_g
Jun 04 09:14:01 pc1 bluetoothd[720]: Endpoint registered: sender=:1.42 path=/MediaEndpoint/A2DPSink/sbc
Jun 04 09:14:01 pc1 bluetoothd[720]: Endpoint registered: sender=:1.42 path=/MediaEndpoint/A2DPSource/sbc
Jun 04 09:14:01 pc1 bluetoothd[720]: Endpoint registered: sender=:1.42 path=/MediaEndpoint/A2DPSource/aptx_ll_1
Jun 04 09:14:01 pc1 bluetoothd[720]: Endpoint registered: sender=:1.42 path=/MediaEndpoint/A2DPSource/aptx_ll_0
Jun 04 09:14:01 pc1 bluetoothd[720]: Endpoint registered: sender=:1.42 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
Jun 04 09:14:01 pc1 bluetoothd[720]: Endpoint registered: sender=:1.42 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
Jun 04 09:14:01 pc1 bluetoothd[720]: Endpoint registered: sender=:1.42 path=/MediaEndpoint/A2DPSource/faststream
Jun 04 09:14:01 pc1 bluetoothd[720]: Endpoint registered: sender=:1.42 path=/MediaEndpoint/A2DPSource/faststream_duplex
Jun 04 09:14:01 pc1 bluetoothd[720]: Endpoint registered: sender=:1.42 path=/MediaEndpoint/A2DPSink/opus_05
Jun 04 09:14:01 pc1 bluetoothd[720]: Endpoint registered: sender=:1.42 path=/MediaEndpoint/A2DPSource/opus_05
Jun 04 09:14:01 pc1 bluetoothd[720]: Endpoint registered: sender=:1.42 path=/MediaEndpoint/A2DPSink/opus_05_duplex
Jun 04 09:14:01 pc1 bluetoothd[720]: Endpoint registered: sender=:1.42 path=/MediaEndpoint/A2DPSource/opus_05_duplex
Jun 04 09:14:10 pc1 systemd[1]: Stopping User Manager for UID 620...
Jun 04 09:14:10 pc1 systemd[896]: Activating special unit Exit the Session...
Jun 04 09:14:10 pc1 systemd[896]: Stopped target Main User Target.
Jun 04 09:14:10 pc1 dbus-broker[948]: Dispatched 20 messages @ 9(±13)μs / message.
Jun 04 09:14:10 pc1 systemd[896]: Stopping Accessibility services bus...
Jun 04 09:14:10 pc1 systemd[896]: Stopping dbus-:1.6-org.a11y.atspi.Registry@0.service...
Jun 04 09:14:10 pc1 systemd[896]: Stopping User preferences database...
Jun 04 09:14:10 pc1 systemd[896]: Stopping Virtual filesystem service...
Jun 04 09:14:10 pc1 systemd[896]: Stopped Accessibility services bus.
Jun 04 09:14:10 pc1 systemd[1]: run-user-620-gvfs.mount: Deactivated successfully.
Jun 04 09:14:10 pc1 systemd[896]: Stopped User preferences database.
Jun 04 09:14:10 pc1 systemd[896]: gvfs-daemon.service: Failed to kill control group /user.slice/user-620.slice/user@620.service/session.slice/gvfs-daemon.service, ignoring: Operation not permitted
Jun 04 09:14:10 pc1 systemd[896]: gvfs-daemon.service: Killing process 955 (gvfsd-fuse) with signal SIGKILL.
Jun 04 09:14:10 pc1 systemd[896]: gvfs-daemon.service: Killing process 1248 (fusermount3) with signal SIGKILL.
Jun 04 09:14:10 pc1 systemd[896]: gvfs-daemon.service: Killing process 1251 (umount) with signal SIGKILL.
Jun 04 09:14:10 pc1 systemd[896]: gvfs-daemon.service: Unit process 1251 (umount) remains running after unit stopped.
Jun 04 09:14:10 pc1 systemd[896]: Stopped Virtual filesystem service.
Jun 04 09:14:10 pc1 systemd[896]: Stopped dbus-:1.6-org.a11y.atspi.Registry@0.service.
Jun 04 09:14:10 pc1 systemd[896]: Removed slice Slice /app/dbus-:1.6-org.a11y.atspi.Registry.
Jun 04 09:14:10 pc1 systemd[896]: Stopped target Basic System.
Jun 04 09:14:10 pc1 systemd[896]: Stopped target Paths.
Jun 04 09:14:10 pc1 systemd[896]: Stopped target Sockets.
Jun 04 09:14:10 pc1 systemd[896]: Stopped target Timers.
Jun 04 09:14:10 pc1 systemd[896]: Closed GnuPG network certificate management daemon.
Jun 04 09:14:10 pc1 systemd[896]: Closed GCR ssh-agent wrapper.
Jun 04 09:14:10 pc1 systemd[896]: Closed GNOME Keyring daemon.
Jun 04 09:14:10 pc1 systemd[896]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Jun 04 09:14:10 pc1 systemd[896]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Jun 04 09:14:10 pc1 systemd[896]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Jun 04 09:14:10 pc1 systemd[896]: Closed GnuPG cryptographic agent and passphrase cache.
Jun 04 09:14:10 pc1 systemd[896]: Closed GnuPG public key management service.
Jun 04 09:14:10 pc1 systemd[896]: Closed p11-kit server.
Jun 04 09:14:10 pc1 systemd[896]: Closed PipeWire PulseAudio.
Jun 04 09:14:10 pc1 systemd[896]: Closed PipeWire Multimedia System Sockets.
Jun 04 09:14:10 pc1 dbus-broker[916]: Dispatched 635 messages @ 3(±6)μs / message.
Jun 04 09:14:10 pc1 systemd[896]: Stopping D-Bus User Message Bus...
Jun 04 09:14:10 pc1 systemd[896]: Stopped D-Bus User Message Bus.
Jun 04 09:14:10 pc1 systemd[896]: Removed slice User Core Session Slice.
Jun 04 09:14:10 pc1 systemd[896]: Closed D-Bus User Message Bus Socket.
Jun 04 09:14:10 pc1 systemd[896]: Removed slice User Application Slice.
Jun 04 09:14:10 pc1 systemd[896]: Reached target Shutdown.
Jun 04 09:14:10 pc1 systemd[896]: Finished Exit the Session.
Jun 04 09:14:10 pc1 systemd[896]: Reached target Exit the Session.
Jun 04 09:14:10 pc1 systemd-logind[731]: Removed session 1.
Jun 04 09:14:10 pc1 (sd-pam)[898]: pam_unix(systemd-user:session): session closed for user lightdm
Jun 04 09:14:10 pc1 systemd[1]: user@620.service: Deactivated successfully.
Jun 04 09:14:10 pc1 systemd[1]: Stopped User Manager for UID 620.
Jun 04 09:14:10 pc1 systemd[1]: Stopping User Runtime Directory /run/user/620...
Jun 04 09:14:10 pc1 systemd[1]: run-user-620.mount: Deactivated successfully.
Jun 04 09:14:10 pc1 systemd[1]: user-runtime-dir@620.service: Deactivated successfully.
Jun 04 09:14:10 pc1 systemd[1]: Stopped User Runtime Directory /run/user/620.
Jun 04 09:14:10 pc1 systemd[1]: Removed slice User Slice of UID 620.
Jun 04 09:14:10 pc1 systemd[1]: user-620.slice: Consumed 1.487s CPU time, 161.2M memory peak.
Jun 04 09:16:14 pc1 gnome-keyring-daemon[1281]: discover_other_daemon: 1
Jun 04 09:16:14 pc1 systemd[1160]: Starting Virtual filesystem service...
Jun 04 09:16:14 pc1 systemd[1160]: Starting Xfce configuration service...
Jun 04 09:16:14 pc1 systemd[1160]: Started Xfce configuration service.
Jun 04 09:16:14 pc1 systemd[1160]: Started Virtual filesystem service.
Jun 04 09:16:14 pc1 systemd[1160]: Starting Accessibility services bus...
Jun 04 09:16:14 pc1 systemd[1160]: Started Accessibility services bus.
Jun 04 09:16:14 pc1 dbus-broker-launch[1328]: Ready
Jun 04 09:16:14 pc1 polkitd[728]: Registered Authentication Agent for unix-session:2 (system bus name :1.44 [/usr/lib/polkit-gnome/polkit-gnome-authentication-agent-1], object path /org/gnome/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8)
Jun 04 09:16:14 pc1 systemd[1160]: Created slice Slice /app/dbus-:1.20-org.a11y.atspi.Registry.
Jun 04 09:16:14 pc1 systemd[1160]: Started dbus-:1.20-org.a11y.atspi.Registry@0.service.
Jun 04 09:16:14 pc1 systemd[1160]: Starting Portal service...
Jun 04 09:16:14 pc1 at-spi2-registryd[1332]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
Jun 04 09:16:14 pc1 systemd[1160]: Starting sandboxed app permission store...
Jun 04 09:16:14 pc1 systemd[1160]: Started sandboxed app permission store.
Jun 04 09:16:14 pc1 systemd[1160]: Starting flatpak document portal service...
Jun 04 09:16:14 pc1 systemd[1160]: Started flatpak document portal service.
Jun 04 09:16:14 pc1 xdg-desktop-por[1333]: Choosing gtk.portal for org.freedesktop.impl.portal.Lockdown as a last-resort fallback
Jun 04 09:16:14 pc1 systemd[1160]: Starting Portal service (GTK/GNOME implementation)...
Jun 04 09:16:14 pc1 systemd[1160]: Started Portal service (GTK/GNOME implementation).
Jun 04 09:16:14 pc1 rtkit-daemon[1188]: Supervising 3 threads of 2 processes of 1 users.
Jun 04 09:16:14 pc1 xdg-desktop-por[1333]: Choosing gtk.portal for org.freedesktop.impl.portal.Settings as a last-resort fallback
Jun 04 09:16:14 pc1 xdg-desktop-por[1333]: Choosing gtk.portal for org.freedesktop.impl.portal.FileChooser as a last-resort fallback
Jun 04 09:16:14 pc1 xdg-desktop-por[1333]: Choosing gtk.portal for org.freedesktop.impl.portal.AppChooser as a last-resort fallback
Jun 04 09:16:14 pc1 xdg-desktop-por[1333]: Choosing gtk.portal for org.freedesktop.impl.portal.Print as a last-resort fallback
Jun 04 09:16:14 pc1 xdg-desktop-por[1333]: Choosing gtk.portal for org.freedesktop.impl.portal.Notification as a last-resort fallback
Jun 04 09:16:14 pc1 xdg-desktop-por[1333]: Choosing gtk.portal for org.freedesktop.impl.portal.Inhibit as a last-resort fallback
Jun 04 09:16:14 pc1 xdg-desktop-por[1333]: Choosing gtk.portal for org.freedesktop.impl.portal.Access as a last-resort fallback
Jun 04 09:16:14 pc1 xdg-desktop-por[1333]: Choosing gtk.portal for org.freedesktop.impl.portal.Account as a last-resort fallback
Jun 04 09:16:14 pc1 xdg-desktop-por[1333]: Choosing gtk.portal for org.freedesktop.impl.portal.Email as a last-resort fallback
Jun 04 09:16:14 pc1 xdg-desktop-por[1333]: Choosing gtk.portal for org.freedesktop.impl.portal.DynamicLauncher as a last-resort fallback
Jun 04 09:16:14 pc1 systemd[1160]: Started Portal service.
Jun 04 09:16:14 pc1 NetworkManager[818]: <info> [1749021374.5106] agent-manager: agent[9b701bddf60a4d77,:1.45/org.freedesktop.nm-applet/1000]: agent registered
Jun 04 09:16:14 pc1 systemd[1160]: Starting Dunst notification daemon...
Jun 04 09:16:14 pc1 systemd[1160]: Started Dunst notification daemon.
Jun 04 09:16:23 pc1 systemd[1160]: Created slice Slice /app/org.gnome.Terminal.
Jun 04 09:16:23 pc1 systemd[1160]: Starting GNOME Terminal Server...
Jun 04 09:16:24 pc1 systemd[1160]: Started GNOME Terminal Server.
Jun 04 09:16:24 pc1 systemd[1160]: Started VTE child process 1424 launched by org.gnome.Terminal process 1415.
Jun 04 09:16:44 pc1 systemd[1]: Starting Pamac Daemon...
Jun 04 09:16:44 pc1 systemd[1]: Started Pamac Daemon.
Jun 04 09:16:46 pc1 systemd[1]: pamac-daemon.service: Deactivated successfully.
