Hi, I am a new GNU/Linux user and installed Manjaro KDE a few days ago. The problem I have is that I have a very old 19 inch monitor with 1366x768 resolution that only supports VGA output and is connected to my Radeon graphics card via VGA-to-DVI-1 adapter (might be relevant, I dont know).
The maximum resolution in settings by default is 1024x768. After a few searches I found a solution and created a bash script to autostart
#!/bin/sh
xrandr --newmode "1368x768_60.00" 85.25 1368 1440 1576 1784 768 771 781 798 -hsync +vsync
xrandr --addmode DVI-1 1368x768_60.00
xrandr --output DVI-1 --mode 1368x768_60.00
But the problem is that the resolution here is 1368x768 and NOT the 1366x768 . I got the values from the cvt 1366 768 60
command which for some reason gives the output for 1368x768
# 1368x768 59.88 Hz (CVT) hsync: 47.79 kHz; pclk: 85.25 MHz
Modeline "1368x768_60.00" 85.25 1368 1440 1576 1784 768 771 781 798 -hsync +vsync
What should the values be for the correct 1366x768 resolution? I calculated the PPI for my monitor to be 82.48 based on the fact it is 19 inch. I tried calculating other values based on the aspect ratio but when I applied the mode monitor was unable to process the output and I had to restart, not sure if I made a mistake somewhere. What are the other values for screen resolutions should be?
As it is, on the current resolution the edges of applications in fullscreen are cut off by a few pixels which is workable but not great. I had mostly no issues with screen resolution on windows 10 after initial drivers install and update.
Also, when I use the script, on each reboot the first login screen is in 1024x768 resolution (obviously because the script haven’t ran yet), is there a way to apply the resolution before that?
moson
19 June 2021 10:00
2
Try this one:
Modeline "1366x768" 85.500 1366 1494 1624 1798 768 770 776 795 +hsync -vsync
Have a look here:
https://wiki.archlinux.org/title/xrandr#Permanently_adding_undetected_resolutions
Thank you for your help, your parameters worked perfectly.
Another question is what do I put in the Device -> Driver
section in the /etc/X11/xorg.conf.d/
config from the archwiki you mentioned xrandr - ArchWiki ?
I use amd open source drivers
Should I put
video-linux
amdgpu
or
radeon
in the
Device -> Driver
section of the config file?
moson
19 June 2021 11:03
4
amdgpu
Also check if you don’t already have a config file in the conf.d folder…
(Don’t know if mhwd is doing anything in that respect)
btw. In case you mess up and get a black screen or so, switch to TTY (CTRL+ALT+F3 for example), log in and fix / remove the config file…
When I tried to use the full /etc/X11/xorg.conf.d/
config, system didn’t want to boot
Section "Monitor"
Identifier "DVI-1"
Modeline "1366x768_60.00" 85.50 1366 1494 1624 1798 768 770 776 795 -hsync +vsync
Option "PreferredMode" "1366x768_60.00"
EndSection
Section "Screen"
Identifier "Screen0"
Monitor "DVI-1"
DefaultDepth 24
SubSection "Display"
Modes "1366x768_60.00"
EndSubSection
EndSection
Section "Device"
Identifier "Device0"
Driver "amdgpu"
EndSection
Thanks for the tip on ctrl+alt+f3
When I removed the Screen
and Device
sections, system booted but with default resolution of 1024x768
moson
19 June 2021 11:37
6
Check the logs and try to figure out what goes wrong /var/log/Xorg...
Can you post the output of inxi -Fazy
inxi -Fazy
output:
ystem:
Kernel: 5.10.42-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=c8b2b200-dc93-47c7-b794-4352bf238d18 rw quiet udev.log_priority=3
Console: tty pts/2 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
base: Arch Linux
Type: Desktop Mobo: MSI model: H81M-P33 (MS-7817) v: 1.0 serial: N/A
UEFI: American Megatrends v: 1.4 date: 02/20/2014
Info: Quad Core model: Intel Core i5-4570 socket: BGA1155 bits: 64 type: MCP
arch: Haswell family: 6 model-id: 3C (60) stepping: 3 microcode: 28 cache:
L1: 256 KiB L2: 6 MiB L3: 6 MiB
bogomips: 25608
Speed: 2073 MHz min/max: 800/3600 MHz base/boost: 3200/3800 volts: 1.2 V
ext-clock: 100 MHz Core speeds (MHz): 1: 2073 2: 3004 3: 1739 4: 2212
Type: l1tf
Device-1: AMD Tahiti XT [Radeon HD 7970/8970 OEM / R9 280X]
vendor: PC Partner Limited driver: radeon v: kernel alternate: amdgpu
bus-ID: 01:00.0 chip-ID: 1002:6798 class-ID: 0300
Display: server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: ati,radeon unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: DVI-1 res: 1366x768 hz: 60
OpenGL: renderer: AMD TAHITI (DRM 2.50.0 5.10.42-1-MANJARO LLVM 12.0.0)
v: 4.5 Mesa 21.1.2 direct render: Yes
Device-1: Intel 8 Series/C220 Series High Definition Audio
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:8c20 class-ID: 0403
Device-2: AMD Tahiti HDMI Audio [Radeon HD 7870 XT / 7950/7970]
vendor: PC Partner Limited driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 1002:aaa0 class-ID: 0403
Device-3: C-Media Storm Pro type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-4:3 chip-ID: 0d8c:0012
class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.10.42-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.30 running: no
vendor: Micro-Star MSI driver: r8169 v: kernel port: d000 bus-ID: 03:00.0
Local Storage: total: 1.82 TiB used: 715.29 GiB (38.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G
family: Driven SSDs size: 223.57 GiB block-size: physical: 512 B
logical: 512 B sata: 3.2 speed: 6.0 Gb/s rotation: SSD serial: <filter>
rev: J4.3 temp: 32 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 68 hrs cycles: 30 read: 50 GiB
written: 177 GiB
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD10EZRX-00D8PB0
family: Green size: 931.51 GiB block-size: physical: 4096 B logical: 512 B
sata: 3.0 speed: 3.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 0A80
temp: 38 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 5y 214d 8h cycles: 1806
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: SanDisk model: Cruzer Fit
size: 14.91 GiB block-size: physical: 512 B logical: 512 B serial: <filter>
rev: 1.00 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: Western Digital
model: WD Elements 1042 drive model: WD7500BMVW-11S5XS0
family: Elements / My Passport (USB, AF) size: 698.63 GiB block-size:
physical: 4096 B logical: 512 B sata: 3.0 speed: 3.0 Gb/s rotation: 5400 rpm
serial: <filter> drive serial: <filter> rev: 1007 drive rev: 01.01A01
temp: 38 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 1y 300d 1h cycles: 2987
ID-1: / raw-size: 223.27 GiB size: 218.71 GiB (97.96%)
used: 20.84 GiB (9.5%) fs: ext4 block-size: 4096 B dev: /dev/sda2
maj-min: 8:2
used: 288 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: radeon temp: 40.0 C
Processes: 200 Uptime: 29m wakeups: 0 Memory: 7.72 GiB
used: 2.72 GiB (35.2%) Init: systemd v: 248 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1424 lib: 441 flatpak: 0 Shell: Bash (sudo)
v: 5.1.8 running-in: konsole inxi: 3.3.04
moson
19 June 2021 12:05
8
Then try radeon
instead of amdgpu
in the device / driver section.
Or you might want to try using amdgpu instead of radeon:
Enable Southern Islands (SI) and Sea Islands (CIK) support
radeon
option for Driver worked. Thank you for your help
system
Closed
4 July 2021 12:17
10
