I just got a brand new laptop with the 12th gen i7-1255U and slapped Manjaro with i3 on it (as was the case with my old laptop using an AMD processor). With the default installation (using the xf86-video-intel driver) the laptop was unusable due to the amount of flickering, artifacts and in general epilepsy-inducing shenanigans from the integrated GPU. After removing the driver the system works fine but refuses to handle two displays at the same time. When using mons -e right
or xrandr --output DP-3 --auto --right-of eDP-1
the primary display works fine but the secondary display just remains black and only appears to show the mouse (I can open new windows in the second workspace but they only show when I move them back to primary monitor).
Also as the tearing is quite annoying I would like to use the intel driver in order to use the TearFree
option.
As it is my first time posting in this forum I am quite unsure about which logs might be useful but I will be glad to provide them.
Thank you very much in advance for any help.
