Hey
So I am trying to install Manjaro KDE on my pc. I torrented using the official torrent, verified hash, used both balena etcher and the DD command, but when I try and open calamares, I get an error saying 1 module remaining (it might not be an error), and the module is partition. Here is the log:
Any help would be appreciated
Thanks
A guess - your filesystem cannot be read.
so do you mean the usb I’m booting from or my HDD?
Yes - the system’s internal disk - it is a guess but from the log your internal cannot be read.
A disk which fails as serious as it appears easily be flawed - but it is impossible to say.
I would open a terminal - then list the devices - check if it is present and take it from there.
Most likely I would - in case of ssd - try to reset flash cells - or try a wipe of the disk - but that is speculative at best.
I already have an OS on the hard drive, so it is definitely working
boot a live iso - open a terminal an run the command
sudo fdisk -l
Create a code fence like this
Then copy the text and paste it inside the fence like this
The result should be looking like this
Disk /dev/sda: 2.73 TiB, 3000592982016 bytes, 5860533168 sectors
Disk model: Hitachi HDS5C303
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: FFA21A60-3E6C-E74D-92A6-C5BF4705D93C
Device Start End Sectors Size Type
/dev/sda1 2048 1128447 1126400 550M EFI System
/dev/sda2 1128448 5322751 4194304 2G Linux swap
/dev/sda3 5322752 5860533134 5855210383 2.7T Linux filesystem
Disk /dev/loop0: 71.03 MiB, 74477568 bytes, 145464 sectors
Disk /dev/loop1: 583.29 MiB, 611622912 bytes, 1194576 sectors
Disk /dev/loop2: 1.8 GiB, 1932173312 bytes, 3773776 sectors
Disk /dev/loop3: 743.34 MiB, 779452416 bytes, 1522368 sectors
Disk /dev/sdb: 14.59 GiB, 15669919744 bytes, 30605312 sectors
Disk model: Cruzer Blade
Disklabel type: dos
Disk identifier: 0x00000000
Device Boot Start End Sectors Size Id Type
/dev/sdb1 * 64 6788171 6788108 3.2G 0 Empty
/dev/sdb2 6788172 6796363 8192 4M ef EFI (FAT-12/16/32)
sondeno:
Hitachi HDS5C303
Nothing looks out of the ordinary - I have no idea why it is stubborn.
If you don’t have data worth saving you could try wiping using either
sgdisk --zap-all /dev/sda
or
wipefs --all /dev/sda
