Kvantum theme is not being applied in Qt5 applications
In IceWM session, kvantum theme is not being applied in qt5 application (i.e pcmanfm-qt) after the update. It seems qt5ct settings are not being applied at all.
In “unstable” I needed to install kvantum-qt5 (repository “extra”). Its in testing too…
The above pinned solution worked for me. Creating a symlink .xprofile of .profile.
$ ln -s .profile .xprofile
Most of the users have default zsh shell so this is most likely going to be the solution for us. Also if they could mention the issue and solution in stable announcement that would be helpful for other users as most of us likely to check that topic at first hand.
