I have some severe issues with my machine and finding a fix feels like out of my depth.
The symptoms are slightly different depending on which kernel I run.
Kernel 6.1:
If I update past…
lib32-nvidia-utils 530.41.03-1
linux61 6.1.29-1
linux61-nvidia 530.41.03-10
mhwd-nvidia 530.41.03-4
…both my monitors repeatedly starts turning off (for a second) and on (and I see the desktop again for a second).
With the above versions the machine is rock solid.
Kernel 6.6:
After updating all packages and changing kernel to 6.6 it all works, until I turn off my secondary monitor. When I turn it back on it behaves just as before but it only affects the secondary monitor.
I’m not sure how to go about finding a fix for this, and at this point I’m just hoping one of you guys have an idea what to look at.
I have tried different distributions that comes with newer nvidia drivers and they all behave identically as does newer install media for Manjaro.
Kernel: 6.1.29-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.1-x86_64
root=UUID=f9a8ff97-2266-4030-8565-cb28e84ab37c rw rootflags=subvol=@ quiet
splash resume=UUID=55ecb89d-ea57-4566-a732-f9f1663ec709
udev.log_priority=3
Console: pty pts/2 DM: SDDM Distro: Manjaro base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: PRIME X570-P v: Rev X.0x serial: <filter>
part-nu: SKU uuid: 2eca0f7f-b1c1-943e-8f3e-a036bc0a73b2
UEFI: American Megatrends v: 4403 date: 04/28/2022
System RAM: total: 64 GiB available: 62.7 GiB used: 7 GiB (11.2%)
Device-1: DIMM_A1 type: no module installed
Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 32 GiB speed: 2133 MT/s volts: curr: 1.2 min: 1.2 max: 1.2
width (bits): data: 64 total: 64 manufacturer: Corsair
part-no: CMK64GX4M2E3200C16 serial: N/A
Device-3: DIMM_B1 type: no module installed
Device-4: DIMM_B2 type: DDR4 detail: synchronous unbuffered (unregistered)
Slot: 0 type: PCIe lanes: 16 status: in use length: long volts: 3.3
bus-ID: 00:03.1 children: 1: 08:00.0 class-ID: 0300 type: display 2: 08:00.1
class-ID: 0403 type: audio 3: 08:00.2 class-ID: 0c03 type: serialbus
4: 08:00.3 class-ID: 0c80 type: serialbus
Slot: 1 type: PCIe lanes: 4 status: available length: long volts: 3.3
bus-ID: 00:1f.7
Slot: 2 type: PCIe lanes: 1 status: available length: short volts: 3.3
bus-ID: 00:1f.7
Slot: 3 type: PCIe lanes: 1 status: available length: short volts: 3.3
bus-ID: 00:1f.7
Slot: 4 type: PCIe lanes: 1 status: available length: short volts: 3.3
bus-ID: 00:1f.7
Info: model: AMD Ryzen 9 3950X socket: AM4 bits: 64 type: MT MCP arch: Zen 2
gen: 3 level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 2340 high: 3700 min/max: 2200/5033 boost: disabled
base/boost: 3700/4725 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.1 V ext-clock: 100 MHz cores: 1: 3700 2: 2200 3: 2200 4: 2200
5: 2200 6: 2200 7: 2200 8: 2200 9: 3700 10: 2200 11: 2200 12: 2200 13: 2200
14: 2200 15: 2200 16: 2200 17: 2200 18: 3700 19: 2200 20: 2200 21: 2200
22: 2200 23: 2200 24: 2200 25: 2200 26: 2200 27: 2200 28: 2200 29: 2200
30: 2200 31: 2200 32: 2200 bogomips: 236898
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA TU104 [GeForce RTX 2070 SUPER] vendor: ASUSTeK
driver: nvidia v: 530.41.03 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-02; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 08:00.0 chip-ID: 10de:1e84 class-ID: 0300
Display: server: X.org v: 1.21.1.11 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia tty: 139x72
API: EGL Message: No EGL data available.
API: OpenGL Message: GL data unavailable in console for root.
API: Vulkan v: 1.3.279 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 2070 SUPER driver: nvidia v: 530.41.03 device-ID: 10de:1e84
surfaces: N/A
Device-1: NVIDIA TU104 HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 08:00.1
chip-ID: 10de:10f8 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0a:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: SteelSeries ApS Arctis 7 driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 7-4:2
chip-ID: 1038:12ad class-ID: 0300
API: ALSA v: k6.1.29-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: n/a (root, process) with: wireplumber
status: active tools: pw-cli,wpctl
Server-3: PulseAudio v: 17.0 status: active (root, process)
with: pulseaudio-alsa type: plugin tools: pacat,pactl
vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 931.51 GiB used: 164.87 GiB (17.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Corsair model: Force MP600
lanes: 4 tech: SSD serial: <filter> fw-rev: EGFM11.3 temp: 44.9 C
scheme: GPT
SMART: yes health: PASSED on: 3y 269d 10h cycles: 145
read-units: 430,744,387 [220 TB] written-units: 441,846,514 [226 TB]
ID-1: / raw-size: 862.25 GiB size: 862.25 GiB (100.00%)
used: 164.86 GiB (19.1%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2 label: N/A uuid: f9a8ff97-2266-4030-8565-cb28e84ab37c
used: 608 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: N/A uuid: 79B0-122A
ID-3: /home raw-size: 862.25 GiB size: 862.25 GiB (100.00%)
ID-4: /local raw-size: 862.25 GiB size: 862.25 GiB (100.00%)
ID-5: /remote/Google Drive raw-size: N/A size: 14.42 TiB
used: 14.03 TiB (97.2%) fs: nfs4 remote: 192.168.0.50:/volume1/Google Drive
ID-6: /remote/Temp raw-size: N/A size: 14.42 TiB used: 14.03 TiB (97.2%)
fs: nfs4 remote: 192.168.0.50:/volume1/Temp
ID-7: /var/cache raw-size: 862.25 GiB size: 862.25 GiB (100.00%)
ID-8: /var/log raw-size: 862.25 GiB size: 862.25 GiB (100.00%)
ID-1: swap-1 type: partition size: 68.97 GiB used: 9.5 MiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: 55ecb89d-ea57-4566-a732-f9f1663ec709
Device-1: 1-1:2 info: ASUSTek ROG CHAKRAM type: HID,mouse
driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 500mA chip-ID: 0b05:18e3 class-ID: 0300
Device-2: 1-2:3 info: Razer USA BlackWidow V3 type: keyboard,mouse,HID
driver: hid-generic,usbhid interfaces: 5 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1532:024e class-ID: 0300
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 3-6:2 info: ASUSTek AURA LED Controller type: HID
lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:18f3 class-ID: 0300
serial: <filter>
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-6: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-7: 7-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 7-4:2 info: SteelSeries ApS Arctis 7 type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 6 rev: 1.1
Hub-8: 8-0:1 info: super-speed hub ports: 4 rev: 3.1
System Temperatures: cpu: 46.5 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1372 libs: 432 tools: pamac pm: flatpak pkgs: 0
1: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 534
1: cpu: 19.4% command: chrome pid: 229626 mem: 659.3 MiB (1.0%)
2: cpu: 12.8% command: chrome pid: 234277 mem: 484.2 MiB (0.7%)
3: cpu: 2.1% command: chrome pid: 217831 mem: 297.6 MiB (0.4%)
4: cpu: 1.4% command: kwin_x11 pid: 1193 mem: 316.8 MiB (0.4%)
5: cpu: 1.4% command: thumbnail.so started-by: kioslave5 pid: 236645
mem: 149.0 MiB (0.2%)
Memory top: 5 of 534
1: mem: 744.5 MiB (1.1%) command: plasmashell pid: 1222 cpu: 0.5%
2: mem: 659.3 MiB (1.0%) command: chrome pid: 229626 cpu: 19.4%
3: mem: 588.5 MiB (0.9%) command: teams pid: 109882 cpu: 0.7%
4: mem: 487.9 MiB (0.7%) command: chrome pid: 217786 cpu: 0.7%
5: mem: 484.2 MiB (0.7%) command: chrome pid: 234277 cpu: 12.8%
Processes: 534 Power: uptime: 6d 10h 11m states: freeze,mem,disk
suspend: deep avail: s2idle wakeups: 0 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 25.07 GiB
services: org_kde_powerdevil,upowerd Init: systemd v: 255
Compilers: clang: 16.0.6 gcc: 13.2.1 alt: 12 Shell: Bash (su) v: 5.2.26
running-in: pty pts/2 inxi: 3.3.33
// Fredrik
