.zshrc line to give suggestions based on previous commands typed in a prompt
What is the command to .zshrc file to zsh give me suggestions based on a previous commands I have already typed?
For example when I start typing
echo "
I get this:
Screenshot_20230719_205758
and then I can move my up/down arrows to get suggestions of the commands that I had already typed?
I cannot find out what line do I need to add to .zshrc I hope someone here will know!
Here:
https://wiki.archlinux.org/title/Zsh#Command_completion
But what manjaro does is
source /usr/share/zsh/plugins/zsh-autosuggestions/zsh-autosuggestions.zsh
With that file being provided by zsh-autosuggestions:
You already get suggestions.
What else do you want?
Normally it is just a matter of hitting TAB once or twice
In Bash you can utilize the history by starting with:
CTRL + R … and then start to type - it’ll show matches from your history of previous commands that you issued
Should be similar in zsh - but I don’t use that so I don’t know.
