I don’t know why there is strange lines like this on the bash window, whatever my KDE Theme chosen.
Computer: Surface Pro 6
OS: Manjaro 20.1 Mikah
Kernel: x86_64 Linux 5.8.0-2-MANJARO
DE: KDE 5.73.0 / Plasma 5.19.4
WM: KWin
WM: KWin
This is not a an issue with zsh itself but a window manager issue.
This usually happens when you are using fractional scaling e.g. 1.5 and I have only seen it on KDE.
I tend to agree with @linux-aarhus. This is a graphical issue and has nothing to do with the shell.
You could also try to use a different fonts and see if that helps.
actually I am using 125% scaling on my 2736*1824 screen. maybe we can fix it in the next KDE version?
another font doesn’t work
I recommend you experiment with the scaling - initially start by remove scaling - to see if you can make it disappear.
The issue has been coming and going - I believe it is an upstream issue.
When you make it disappear - then reproduce the issue making notes of the steps to reproduce. Then check bugs.kde.org to see if something similar is reported and add to that report - or you could create a new issue.
yes when I changed the 125% to 100% they are gone. but I still love 125%. maybe years later I should buy a 1920*1080 screen, will that be better?
