qt-webengine appears to require libavcodec 59 which ordinary ffmpeg contains, but the rk version is behind. If I use ordinary ffmpeg I don’t have hardware video acceleration but if I use rk, my webengine-based browser doesn’t work
I would to take this opportunity to thank the Manjaro-Arm team great support.
Just an example, yesterday I highlighted an issue to @spikerguy that I could perform system updates Manjaro-Arm-KDE Unstable branch because of dependencies issues:
resolving dependencies...
:: installing libvpx (1.13.0-1) breaks dependency 'libvpx.so=7-64' required by ffmpeg-m2m
[jfl@jfl-mnjro ~]$ sudo pacman -Syu
core is up to date
extra is up to date
community is up to date
[jfl@jfl-mnjro ~]$
Within a few hours @spikerguy uploaded the new ffmpeg-m2m and other related packages to Unstable repo and it resolved the system updates issue. This is just one example there are many instances before.
How am I supposed to install the ffmpeg-m2m package?
Everything seems to rely on the normal ffmpeg package, and trying to uninstall that one is (nearly?) impossible?
For example, it starts with:
- removing ffmpeg breaks dependency 'libavcodec.so=59-64' required by chromaprint
- removing ffmpeg breaks dependency 'libavformat.so=59-64' required by chromaprint
- removing ffmpeg breaks dependency 'libavutil.so=57-64' required by chromaprint
- removing ffmpeg breaks dependency 'libswresample.so=4-64' required by chromaprint
- removing ffmpeg breaks dependency 'libswscale.so=6-64' required by freerdp
- removing ffmpeg breaks dependency 'libavdevice.so=59-64' required by mpv
- removing ffmpeg breaks dependency 'libavfilter.so=8-64' required by mpv
But then it grows quickly, chromaprint → grilo-plugins → … → GTK and at that point…
