Under 5.15 kernel zfs works but 5.14 not. What to try?
$ uname -r
5.14.18-1-MANJARO
zpool command:
The ZFS modules are not loaded.
Try running '/sbin/modprobe zfs' as root to load them.
$ sudo /sbin/modprobe zfs
modprobe: FATAL: Module zfs not found in directory /lib/modules/5.14.18-1-MANJARO
$ pamac install linux514-zfs
Preparing...
Resolving dependencies...
Checking inter-conflicts...
To install (5):
linux514-zfs 2.1.1-13 extra 26,5 MB
linux510-zfs 2.1.1-13 extra 26,1 MB
linux513-zfs 2.1.1-1 extra 27,0 MB
linux515-zfs 2.1.1-6 extra 27,2 MB
linux54-zfs 2.1.1-13 extra 23,4 MB
To remove (1):
zfs-dkms 2.1.1-1 (Conflicts With: zfs) extra
Total download size: 130,2 MB
Total installed size: 132,8 MB
Total removed size: 67,5 MB
Apply transaction ? [y/N] N
Transaction cancelled.
