"pamac-manager" received signal SIGSEGV, Segmentation fault
Scenario:
I just type “net” in the search box an hit enter
Result: segmentation fault, core dumped
Core dumps: https://file.io/k3aRkhrvgzCL
Last will and testament:
(pamac-manager:26159): GLib-CRITICAL **: 05:16:18.866: g_str_has_prefix: assertion 'str != NULL' failed
** (pamac-manager:26159): CRITICAL **: 05:16:18.866: string_contains: assertion 'self != NULL' failed
Thread 1 "pamac-manager" received signal SIGSEGV, Segmentation fault.
0x00007ffff731a5c4 in g_str_hash () from /usr/lib/libglib-2.0.so.0
(gdb) bt
#0  0x00007ffff731a5c4 in g_str_hash () at /usr/lib/libglib-2.0.so.0
#1  0x00007ffff731b63a in g_hash_table_contains () at /usr/lib/libglib-2.0.so.0
#2  0x00005555555694d9 in  ()
#3  0x00007ffff733ed9d in  () at /usr/lib/libglib-2.0.so.0
#4  0x00007ffff733ed37 in  () at /usr/lib/libglib-2.0.so.0
#5  0x00007ffff733ed37 in  () at /usr/lib/libglib-2.0.so.0
#6  0x00007ffff733ed37 in  () at /usr/lib/libglib-2.0.so.0
#7  0x00007ffff733ed29 in  () at /usr/lib/libglib-2.0.so.0
#8  0x00007ffff733ed29 in  () at /usr/lib/libglib-2.0.so.0
#9  0x00007ffff733ed29 in  () at /usr/lib/libglib-2.0.so.0
#10 0x00007ffff733ed37 in  () at /usr/lib/libglib-2.0.so.0
#11 0x00007ffff733ed37 in  () at /usr/lib/libglib-2.0.so.0
#12 0x00007ffff733ed37 in  () at /usr/lib/libglib-2.0.so.0
#13 0x00007ffff733ed37 in  () at /usr/lib/libglib-2.0.so.0
#14 0x00007ffff7342f10 in  () at /usr/lib/libglib-2.0.so.0
#15 0x000055555556c34a in  ()
#16 0x0000555555573cfd in  ()
#17 0x000055555557677b in  ()
#18 0x00007ffff74d2644 in  () at /usr/lib/libgio-2.0.so.0
#19 0x00007ffff74d66ad in  () at /usr/lib/libgio-2.0.so.0
#20 0x0000555555584340 in  ()
#21 0x000055555556d6a6 in  ()
#22 0x00007ffff74d2644 in  () at /usr/lib/libgio-2.0.so.0
#23 0x00007ffff74d66ad in  () at /usr/lib/libgio-2.0.so.0
#24 0x00007ffff7e5a60e in  () at /usr/lib/libpamac.so.11
#25 0x00007ffff7339a31 in g_main_context_dispatch () at /usr/lib/libglib-2.0.so.0
#26 0x00007ffff7396cc9 in  () at /usr/lib/libglib-2.0.so.0
#27 0x00007ffff73370e2 in g_main_context_iteration () at /usr/lib/libglib-2.0.so.0
#28 0x00007ffff7507ed6 in g_application_run () at /usr/lib/libgio-2.0.so.0
#29 0x0000555555561416 in  ()
#30 0x00007ffff6e27cd0 in __libc_start_call_main (main=main@entry=0x555555561090, argc=argc@entry=1, argv=argv@entry=0x7fffffffdaf8) at ../sysdeps/nptl/libc_start_call_main.h:58
#31 0x00007ffff6e27d8a in __libc_start_main_impl
    (main=0x555555561090, argc=1, argv=0x7fffffffdaf8, init=<optimized out>, fini=<optimized out>, rtld_fini=<optimized out>, stack_end=0x7fffffffdae8) at ../csu/libc-start.c:360
#32 0x0000555555561545 in  ()
Why i am posting it here and not on gitlab: there is a wall of jericho around it, i don’t get password reset emails, i can’t create a new account without administrator approval
Providing some info about the system you have this issue on would help in determining the cause and possible solution.
I’ve just tried to recreate the behavior and I do not experience this on a gnome system in testing & stable branch.
Same here. No issue on Plasma 5.27.7.
Also no issue on XFCE stable, kernel 6.1.
I can reproduce it on the unstable branch.
It seems it may be related to the recent glib2 2.76.5-1 update.
The file has been deleted.
Due to an influx of spam, we have had to approve account registrations. Please write an email to support@manjaro.org, with your username, if you want to get access faster. Sorry for the inconvenience.
fixed: fix a flatpak issue (52f2eb3a) · Commits · Applications / libpamac · GitLab
