Hi there.
Some days ago i do a fresh Manjaro install with ext4 filesystem, i checked the box in “encrypt disk”
Now i have a boot partition unencrypted, and / encrypted, i have noticed that before start grub it asks for the encrypt password
I have using the Yubikey to use PAM, sudo, sddm etc, this is OK.
The question is, can i use the Yubikey to login before GRUB without enter the decrypt password pressing the button of Yubikey?
Thanks all!
