hey guys I am facing terrible errors in manajro xfce
bluetooth connectivity is very poor
I am not able to connect to my bluetooth speaker very easily
i have to try it more than 10 times to connect my bluetooth speaker to manjaro xfce
if it gets connected the bluetooth all of a sudden gets deactivated and gets switched off
then again I have to try to connect it by turning on the bluetooth in system
after my speaker gets connected to manjaro the youtube videos starts lagging
even in half screen on 720p videos are lagging
but after disconnecting the speaker and then playing the video the videos doesn’t lag then
i have faced many temporary bluetooth errors in manjaro xfce previously
a restart was fine for them
but this time it’s just terrible and frustrating
here is my system info
[ayushk@ayush-inspiron3541 ~]$ inxi -F
Host: ayush-inspiron3541 Kernel: 5.10.56-1-MANJARO x86_64 bits: 64
Desktop: Xfce 4.16.0 Distro: Manjaro Linux
Type: Portable System: Dell product: Inspiron 3541 v: N/A
serial: <superuser required>
Mobo: Dell model: Inspiron 3541 v: A07 serial: <superuser required>
BIOS: Dell v: A07 date: 11/27/2015
Info: Quad Core model: AMD A6-6310 APU with AMD Radeon R4 Graphics
bits: 64 type: MCP cache: L2: 2 MiB
Speed: 998 MHz min/max: 1000/1800 MHz Core speeds (MHz): 1: 998 2: 998
3: 998 4: 998
Device-1: AMD Mullins [Radeon R4/R5 Graphics] driver: radeon v: kernel
Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
Display: x11 server: X.Org 1.20.13 driver: loaded: ati,radeon
unloaded: modesetting resolution: 1366x768~60Hz
OpenGL: renderer: AMD KABINI (DRM 2.50.0 5.10.56-1-MANJARO LLVM 12.0.1)
v: 4.5 Mesa 21.1.6
Device-1: AMD Kabini HDMI/DP Audio driver: snd_hda_intel
Device-2: AMD FCH Azalia driver: snd_hda_intel
Sound Server-1: ALSA v: k5.10.56-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 15.0 running: yes
Sound Server-3: PipeWire v: 0.3.33 running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169
IF: enp2s0 state: down mac: 20:47:47:53:db:2d
Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
driver: ath9k
IF: wlp3s0 state: up mac: b0:c0:90:62:24:ff
Device-1: Qualcomm Atheros AR9462 Bluetooth type: USB driver: btusb
Local Storage: total: 465.76 GiB used: 41.82 GiB (9.0%)
ID-1: /dev/sda vendor: Seagate model: ST500LT012-1DG142 size: 465.76 GiB
ID-1: / size: 450.28 GiB used: 41.77 GiB (9.3%) fs: ext4 dev: /dev/sda1
ID-1: swap-1 type: partition size: 7.21 GiB used: 44.5 MiB (0.6%)
dev: /dev/sda2
System Temperatures: cpu: 61.0 C mobo: 55.0 C gpu: radeon temp: 61.0 C
Fan Speeds (RPM): cpu: 4780
Processes: 200 Uptime: 2h 2m Memory: 3.28 GiB used: 2.26 GiB (69.1%)
Shell: Bash inxi: 3.3.06
