The title is pretty self explanatory; I have ~50-60 mbps download speeds on speedtest.net, but YouTube takes ridiculously long to load a video. I’m dualbooting Manjaro KDE with Windows 10, and on Windows I’m getting similar speedtest.net values, but YouTube is way better. I use Firefox on Manjaro and MS Edge on Windows. I have fast startup disabled on Windows. My network card is Intel Dual Band Wireless-AC 3168NGW.
inxi -Fazy:
Kernel: 5.15.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=d40977fe-d7fc-4898-8ffe-20fc21fab037 rw quiet apparmor=1
security=apparmor resume=UUID=4dccc5d9-cde4-4fc2-bc59-bb1706b53a7c
udev.log_priority=3
Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Convertible System: HP product: HP Pavilion x360 Convertible 14-ba1xx
v: Type1ProductConfigId serial: <superuser required> Chassis: type: 31
Mobo: HP model: 83C4 v: 31.61 serial: <superuser required> UEFI: Insyde
v: F.53 date: 05/16/2019
ID-1: BAT0 charge: 21.9 Wh (100.0%) condition: 21.9/21.9 Wh (100.0%)
volts: 12.8 min: 11.6 model: 333-54-5D-A BK03041XL type: Li-ion
serial: <filter> status: Full
Device-1: hid-0018:04F3:251C.0002-battery model: ELAN0732:00 04F3:251C
serial: N/A charge: N/A status: N/A
Info: model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xEA
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 800 min/max: 400/3400 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 bogomips: 28808
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: Chicony HP Wide Vision HD Camera type: USB driver: uvcvideo
bus-ID: 1-4:3 chip-ID: 04f2:b5d6 class-ID: 0e02
Display: x11 server: X.org 1.21.1.3 compositor: kwin_x11 driver:
loaded: modesetting alternate: fbdev,vesa resolution: <missing: xdpyinfo>
Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.15.16-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.43 running: yes
Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel bus-ID: 02:00.0 chip-ID: 8086:24fb class-ID: 0280
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-5:4 chip-ID: 8087:0aa7 class-ID: e001
Local Storage: total: 931.51 GiB used: 401.77 GiB (43.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
type: HDD rpm: 5400 serial: <filter> rev: 1C scheme: GPT
ID-1: / raw-size: 29.3 GiB size: 28.67 GiB (97.86%) used: 16.56 GiB (57.8%)
fs: ext4 dev: /dev/sda6 maj-min: 8:6
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 65.9 MiB (25.7%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 58.59 GiB size: 57.37 GiB (97.92%)
used: 3.94 GiB (6.9%) fs: ext4 dev: /dev/sda8 maj-min: 8:8
ID-1: swap-1 type: partition size: 7.81 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda7 maj-min: 8:7
System Temperatures: cpu: 40.0 C pch: 37.5 C mobo: 37.0 C
Processes: 249 Uptime: 35m wakeups: 3 Memory: 15.5 GiB
used: 4.14 GiB (26.7%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: 1297 pacman: 1285 lib: 342 flatpak: 4
snap: 8 Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.12
(I hope I posted this in the right spot, I’m new to Manjaro, these forums, and Linux itself).
