Hi all, I just did an upgrade, and (as to be expected) there is something to learn…
I use Yoshimi quite extensively (softsynth)…it segfaults
I use Linux 6.6 on that particular box…
Thanks a lot for meditating with me
Melissa ![]()
Melissa ![]()
I’ll check it out on my Media Computer later. At the moment I have an old 32 bit clamshell providing Yoshimi for my MIDI keyboard, so no issues there.
Thanks…
I use an Intel NUC, here…if I could help by providing info, let me know, thanks
inxi -zv8
would be useful.
Here it comes:
Kernel: 6.6.119-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=eea67e57-392c-47e1-b80f-8a6225ab811d rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.5.3 tk: Qt v: N/A info: frameworks v: 6.20.0
Type: Desktop Mobo: Intel model: NUC5i5RYB v: H40999-504
serial: uuid: Firmware: UEFI
vendor: Intel v: RYBDWi35.86A.0350.2015.0812.1722 date: 08/12/2015
System RAM: total: 8 GiB available: 7.65 GiB used: 2.7 GiB (35.3%)
Array-1: capacity: 16 GiB slots: 2 modules: 1 EC: None
Device-1: CHANNEL A DIMM0 type: DDR3 detail: synchronous size: 8 GiB
speed: 1600 MT/s volts: N/A width (bits): data: 64 total: 64
manufacturer: Crucial part-no: CT102464BF160B.C16 serial:
Device-2: CHANNEL B DIMM0 type: no module installed
Info: model: Intel Core i5-5250U bits: 64 type: MT MCP arch: Broadwell
gen: core 5 level: v3 note: check built: 2015-18 process: Intel 14nm
family: 6 model-id: 0x3D (61) stepping: 4 microcode: 0x2F
Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 798 min/max: 500/2700 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 798 2: 798 3: 798 4: 798 bogomips: 12774
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
avx avx2 bmi1 bmi2 bts clflush cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fxsr ht ibpb ibpb_exit_to_user ibrs ida
intel_pt invpcid lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt
xtopology xtpr
vulnerable
Type: spectre_v1 mitigation: usercopy/swapgs barriers and \__user pointer
STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
affected
Device-1: Intel HD Graphics 6000 driver: i915 v: kernel arch: Gen-8
process: Intel 14nm built: 2014-15 ports: active: HDMI-A-1
empty: DP-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1626 class-ID: 0300
alternate: fbdev,vesa dri: iris gpu: i915 display-ID: 0
Monitor-1: HDMI-A-1 model: Philips PHL 234E5 serial: built: 2015
res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 96 gamma: 1.2 chroma: red:
x: 0.639 y: 0.333 green: x: 0.310 y: 0.627 blue: x: 0.153 y: 0.071 white:
x: 0.314 y: 0.329 size: 509x286mm (20.04x11.26") diag: 584mm (23")
ratio: 16:9 modes: 1920x1080, 1920x1080i, 1680x1050, 1280x1024, 1440x900,
1280x720, 1024x768, 800x600, 720x576, 720x576i, 720x480, 720x480i,
640x480, 720x400
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.3.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 6000 (BDW
GT3) device-ID: 8086:1626 memory: 7.47 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.328 layers: 2 device: 0 type: integrated-gpu name: Intel
HD Graphics 6000 (BDW GT3) driver: mesa intel v: 25.3.1-arch1.2
device-ID: 8086:1626 surfaces: N/A
Device-1: Intel Broadwell-U Audio driver: snd_hda_intel v: kernel
bus-ID: 00:03.0 chip-ID: 8086:160c class-ID: 0403
Device-2: Intel Wildcat Point-LP High Definition Audio
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9ca0
class-ID: 0403
Device-3: KORG X50 driver: snd-usb-audio type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 2-1.1:4 chip-ID: 0944:0106 class-ID: 0103
Device-4: M-Audio Keystation 61 MK3 driver: snd-usb-audio type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-1.2:6
chip-ID: 0763:3109 class-ID: 0103
Device-5: M-Audio Keystation 61 MK3 driver: snd-usb-audio type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-1.3.1:10
Device-6: KORG monologue driver: snd-usb-audio type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-1.3.2:11 chip-ID: 0944:0139
class-ID: 0103
Device-7: KORG padKONTROL driver: snd-usb-audio type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-1.3.4:15 chip-ID: 0944:0105
class-ID: 0103
Device-8: iConnectivity mio driver: snd-usb-audio type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-1.4.1:12 chip-ID: 2321:000a
class-ID: 0103 serial:
Device-9: KORG microKEY-37 driver: snd-usb-audio type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-1.4.2.4:18 chip-ID: 0944:0111
class-ID: 0103
Device-10: Midiplus Co Origin25 driver: snd-usb-audio type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-1.4.3:16 chip-ID: 1acc:1a04
Device-11: QinHeng CH345 MIDI adapter driver: snd-usb-audio type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-1.4.4:19
chip-ID: 1a86:752d class-ID: 0103
Device-12: PreSonus Audio AudioBox iTwo driver: snd-usb-audio type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-2:3 chip-ID: 194f:0403
class-ID: fe01 serial:
Device-13: Roland BOSS DR-880 driver: snd-usb-audio type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-4:5 chip-ID: 0582:0075
class-ID: ff00
API: ALSA v: k6.6.119-1-MANJARO status: kernel-api with: aoss
Server-2: JACK v: 1.9.22 status: off with: nsmd status: off
tools: jack_control,jack_mixer,qjackctl
Server-3: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I218-V driver: e1000e v: kernel port: 3080
bus-ID: 00:19.0 chip-ID: 8086:15a3 class-ID: 0200
IF: enp0s25 state: up speed: 100 Mbps duplex: full mac:
IP v4: type: dynamic noprefixroute scope: global
broadcast:
IP v6: type: dynamic noprefixroute scope: global
IP v6: type: noprefixroute scope: link
Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:095a class-ID: 0280
IF: wlp2s0 state: down mac:
WAN IP:
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-7:7 chip-ID: 8087:0a2a
class-ID: e001
Local Storage: total: 238.47 GiB used: 28.89 GiB (12.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: SK Hynix model: SC311 SATA 256GB
size: 238.47 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: fw-rev: 0P10 scheme: GPT
ID-1: / raw-size: 27.94 GiB size: 27.33 GiB (97.83%) used: 21.07 GiB (77.1%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: eea67e57-392c-47e1-b80f-8a6225ab811d
used: 6.1 MiB (1.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 68B4-E0B4
ID-3: /home raw-size: 209.08 GiB size: 204.74 GiB (97.92%)
used: 7.82 GiB (3.8%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: 1a5bfa2b-3b0b-4fd2-a4a5-5594f93ecdfe
ID-1: swap-1 type: partition size: 977 MiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 6d2a9eac-bfab-48df-a833-3422f53078e8
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-2: 1-1:2 info: Intel Integrated Hub ports: 8 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8001
Hub-3: 2-0:1 info: hi-speed hub with single TT ports: 11 rev: 2.0
Hub-4: 2-1:2 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
Device-1: 2-1.1:4 info: KORG X50 type: audio driver: snd-usb-audio
interfaces: 1 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
Device-2: 2-1.2:6 info: M-Audio Keystation 61 MK3 type: audio
driver: snd-usb-audio interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 0763:3109 class-ID: 0103
Hub-5: 2-1.3:8 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
Device-1: 2-1.3.1:10 info: M-Audio Keystation 61 MK3 type: audio
Device-2: 2-1.3.2:11 info: KORG monologue type: audio
driver: snd-usb-audio interfaces: 1 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 chip-ID: 0944:0139 class-ID: 0103
Hub-6: 2-1.3.3:13 info: Dell Keyboard Hub ports: 3 rev: 1.1
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 90mA chip-ID: 413c:1002
Device-1: 2-1.3.3.1:17 info: Dell SK-8125 Keyboard type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 chip-ID: 413c:2002 class-ID: 0300
Device-2: 2-1.3.3.3:20 info: Microsoft Wheel Mouse Optical type: mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1
chip-ID: 045e:0040 class-ID: 0301
Device-3: 2-1.3.4:15 info: KORG padKONTROL type: audio
lanes: 1 mode: 1.1 power: 500mA chip-ID: 0944:0105 class-ID: 0103
Hub-7: 2-1.4:9 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
Device-1: 2-1.4.1:12 info: iConnectivity mio type: audio
lanes: 1 mode: 1.1 power: 40mA chip-ID: 2321:000a class-ID: 0103
serial:
Hub-8: 2-1.4.2:14 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 2-1.4.2.4:18 info: KORG microKEY-37 type: audio
lanes: 1 mode: 1.1 power: 100mA chip-ID: 0944:0111 class-ID: 0103
Device-2: 2-1.4.3:16 info: Midiplus Co Origin25 type: audio
driver: snd-usb-audio interfaces: 2 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 1acc:1a04 class-ID: 0103
serial:
Device-3: 2-1.4.4:19 info: QinHeng CH345 MIDI adapter type: audio
lanes: 1 mode: 1.1 power: 96mA chip-ID: 1a86:752d class-ID: 0103
Device-4: 2-2:3 info: PreSonus Audio AudioBox iTwo type: audio
driver: snd-usb-audio interfaces: 6 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 194f:0403 class-ID: fe01
serial:
Device-5: 2-4:5 info: Roland BOSS DR-880 type:
lanes: 1 mode: 1.1 chip-ID: 0582:0075 class-ID: ff00
Device-6: 2-7:7 info: Intel Bluetooth wireless interface type: bluetooth
mode: 1.1 power: 100mA chip-ID: 8087:0a2a class-ID: e001
Hub-9: 3-0:1 info: super-speed hub ports: 4 rev: 3.0
Hub-10: 3-1:2 info: Realtek Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0411
Hub-11: 3-1.3:3 info: Realtek Hub ports: 4 rev: 3.2
Hub-12: 3-1.4:4 info: Realtek Hub ports: 4 rev: 3.2
System Temperatures: cpu: 74.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: 1621 pm: pacman pkgs: 1614 libs: 409 tools: pamac,yay pm: flatpak
pkgs: 7
1: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
2: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
3: https://manjaro.grena.ge/stable/$repo/$arch
4: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
5: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
6: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
7: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
8: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 202
1: cpu: 23.2% command: firefox pid: 1680 mem: 539.9 MiB (6.8%)
2: cpu: 13.5% command: firefox pid: 2003 mem: 281.6 MiB (3.5%)
3: cpu: 12.7% command: jack_mixer started-by: python3 pid: 1506
mem: 78.7 MiB (1.0%)
4: cpu: 6.5% command: kwin_wayland pid: 724 mem: 189.0 MiB (2.4%)
5: cpu: 4.4% command: zyn-fusion pid: 1626 mem: 132.4 MiB (1.6%)
Memory top: 5 of 202
1: mem: 539.9 MiB (6.8%) command: firefox pid: 1680 cpu: 23.2%
2: mem: 351.3 MiB (4.4%) command: plasmashell pid: 949 cpu: 1.4%
3: mem: 281.6 MiB (3.5%) command: firefox pid: 2003 cpu: 13.5%
4: mem: 222.8 MiB (2.8%) command: firefox pid: 1991 cpu: 3.0%
5: mem: 211.1 MiB (2.6%) command: konsole pid: 2272 cpu: 3.6%
Processes: 202 Power: uptime: 12m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 3.04 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
tool: systemctl
Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.3.8 running-in: konsole inxi: 3.3.40
thanks
MOD EDIT: placed inxi output inside triple backticks using the </> button, for you.
Could you be helped with the startup messages? I start yoshimi from the terminal just for these instances…
That might help too. use the </> button for posting cli output.
Thought so, here they come ![]()
yoshimi 2.3.5.2 is starting...
Start-up Synth-Instance(0)...
-----Connect-attempt----(jack_audio/alsa_midi)----
finding manual
Cannot lock down 107341340 byte memory area (Cannot allocate memory)
-----Connect-SUCCESS-------------------
Using jack_audio for audio and alsa_midi for midi
manual found
Found 4448 instruments in 112 banks
Root 5. Bank set to 115 "Will_Godfrey_Companion"
Alsa midi priority is 1
Build Number 2410
Clientname: yoshimi
Audio: jack -> 'default'
Midi: alsa -> 'default'
Oscilsize: 512
Samplerate: 48000
Period size: 256
Yay! We're up and running :-)
yoshimi> Failed to load plugin 'libdecor-gtk.so': failed to init
Main Engine initialised
zsh: segmentation fault (core dumped) yoshimi
That would most likely be the problem.
okay, I’ll try to install it now and get beck to you, gimme a sec… ![]()
…still the same…
This is the kernel:
Linux caliope 6.6.119-1-MANJARO #1 SMP PREEMPT_DYNAMIC Sun Dec 7 08:34:08 UTC 2025 x86_64 GNU/Linux
I haven’t gone to the old Caravan where I keep my Music stuff, yet, but I’m running 6.17.x RT on my media machine. I’'ve been doing breakfast. I’m not sure that would make a difference, though.
Well, I’ll install that kernel and try…thanks…hang on…
dash…still the same. Yoshimi is usefull for its interface…Zynaddsubfx had the same interface once…it’s basically just that…
Yes I get the same error as you do. At the moment I have no idea. I’ll have to make time to try to chase it down, but that won’t be until this afternoon.
dont give it priority…maybe go upstream. but…take time when you can, this is a mere annoyance as I have to learn Zyn’s interface now…and it’s not the best design… ![]()
I’ll leave things as they are, maybe some next upgrade will fix it…we’ll see…
Enjoy your day, please…do have a great day… ![]()
I didn’t.
I found this… #1112199 - yoshimi: Segment violation launching in Wayland (with labwc window composer) - Debian Bug report logs
from that, above this seems to work
FLTK_BACKEND=x11 yoshimi
edit the yoshimi launcher in the menu, and replace
yoshimi
with the above
The issue appears to be related to FLTK, which the UI of Yoshimi is built from.
yoshimi now loads correctly on my testing machine. I expect it will on my Media machine (running stable), as well.
wow…and there is light…it works🏆. I’m…stunned by your insight. Thank you so much…
I owe you a lot. I make Ambient music, so this machine is a workhorse.
Again: thank you very very much…![]()
