So I am running a AMD R7 250E GPU which is a GCN 1.0 card that has support for the amdgpu kernel module, but for some reason it’s not using this kernel, so I was wondering how I could set it up so it uses the amdgpu kernel instead.
However I heard that blacklisting the kernel or changing the config file no longer works on modern
kernels, I even heard about cases where the system was bricked by changing this configuration.
If anyone can help it would be greatly appreciated.
Thank you all for the help, I would not be able to do it without it (I know it’s a bit generic but it’s true )
For the complete solution also run: sudo nano /etc/mkinitcpio.conf
Then add MODULES=(amdgpu radeon) to the file
At last run: sudo mkinitcpio -P
Reboot and it should be good
Does experimental support for amdgpu means that the kernel is quite possibly unstable?
And also how to I access the kernel command line to set the module parameters like described in the link you sent?
Ok. thanks this is a bit more cleaner, but the problem now is that I don’t have any files on my modprobe.d folder or at least it doesn’t seems to be any.
Maybe I am interpreting things wrong, this commands are supposed to be imputed on the terminal?
With only the MODULES=(amdgpu radeon) that has to be on the mkinitcpio.conf file.
Is that right?
Ok just one more question before I try this:
If I execute this commands without creating the files, will it create them for me, or I have to create them first?
Wait there’s one more thing on the modules there is one that is empty with only this MODULES=" ", is this the one where I have to put this MODULES=(amdgpu radeon) on?
There was 2 errors that were about kernel 5.7 maybe because I don’t have them installed.
==> Building image from preset: /etc/mkinitcpio.d/linux57.preset: 'default'
-> -k /boot/vmlinuz-5.7-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.7-x86_64.img
==> ERROR: '/lib/modules/5.7.19-2-MANJARO' is not a valid kernel module directory
==> Building image from preset: /etc/mkinitcpio.d/linux57.preset: 'fallback'
-> -k /boot/vmlinuz-5.7-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.7-x86_64-fallback.img -S autodetect
If sudo nano /etc/mkinitcpio.conf only shows MODULES=(amdgpu radeon) then this is a problem
It should look like this:
# vim:set ft=sh
# MODULES
# The following modules are loaded before any boot hooks are
# run. Advanced users may wish to specify all system modules
# in this array. For instance:
# MODULES=(piix ide_disk reiserfs)
# BINARIES
# This setting includes any additional binaries a given user may
# wish into the CPIO image. This is run last, so it may be used to
# override the actual binaries included by a given hook
# BINARIES are dependency parsed, so you may safely ignore libraries
BINARIES=()
# FILES
# This setting is similar to BINARIES above, however, files are added
# as-is and are not parsed in any way. This is useful for config files.
FILES=""
# HOOKS
# This is the most important setting in this file. The HOOKS control the
# modules and scripts added to the image, and what happens at boot time.
# Order is important, and it is recommended that you do not change the
# order in which HOOKS are added. Run 'mkinitcpio -H <hook name>' for
# help on a given hook.
# 'base' is _required_ unless you know precisely what you are doing.
# 'udev' is _required_ in order to automatically load modules
# 'filesystems' is _required_ unless you specify your fs modules in MODULES
# Examples:
## This setup specifies all modules in the MODULES setting above.
## No raid, lvm2, or encrypted root is needed.
# HOOKS=(base)
## This setup will autodetect all modules for your system and should
## work as a sane default
# HOOKS=(base udev autodetect block filesystems)
## This setup will generate a 'full' image which supports most systems.
## No autodetection is done.
# HOOKS=(base udev block filesystems)
## This setup assembles a pata mdadm array with an encrypted root FS.
## Note: See 'mkinitcpio -H mdadm' for more information on raid devices.
# HOOKS=(base udev block mdadm encrypt filesystems)
## This setup loads an lvm2 volume group on a usb device.
# HOOKS=(base udev block lvm2 filesystems)
## NOTE: If you have /usr on a separate partition, you MUST include the
# usr, fsck and shutdown hooks.
HOOKS="base udev resume autodetect modconf block keyboard keymap mdadm_udev lvm2 filesystems fsck"
# COMPRESSION
# Use this to compress the initramfs image. By default, gzip compression
# is used. Use 'cat' to create an uncompressed image.
#COMPRESSION="cat"
#COMPRESSION="pigz"
#COMPRESSION="gzip"
#COMPRESSION="bzip2"
#COMPRESSION="lzma"
COMPRESSION="xz"
#COMPRESSION="lzop"
#COMPRESSION="lz4"
# COMPRESSION_OPTIONS
# Additional options for the compressor
COMPRESSION_OPTIONS=(-T0)
