W1sE
July 13, 2021, 8:35pm
1
Immediately after today’s stable update, I noticed Yakuake leaving behind a green flash on being minimised. I have a screen capture of this, but idk how to upload it here.
System: Host: w1sebox Kernel: 5.11.4-1-rt11-MANJARO x86_64 bits: 64 Desktop: KDE Plasma 5.22.3 Distro: Manjaro Linux
Machine: Type: Laptop System: HP product: OMEN by HP Laptop 15-dc1xxx v: N/A serial: <superuser required>
Mobo: HP model: 8575 v: 21.17 serial: <superuser required> UEFI: AMI v: F.22 date: 05/03/2021
Battery: ID-1: BAT0 charge: 35.3 Wh (79.9%) condition: 44.2/44.2 Wh (100.0%)
CPU: Info: 6-Core Intel Core i7-9750H [MT MCP] speed: 800 MHz min/max: 800/4500 MHz
Graphics: Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] driver: i915 v: kernel
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] driver: nvidia v: 470.42.01
Device-3: Quanta HP Wide Vision HD Camera type: USB driver: uvcvideo
Display: x11 server: X.Org 1.20.11 driver: loaded: modesetting,nvidia resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.1.4
Network: Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
Drives: Local Storage: total: 1.14 TiB used: 52.79 GiB (4.5%)
Info: Processes: 282 Uptime: 13m Memory: 7.58 GiB used: 1.84 GiB (24.3%) Shell: Bash inxi: 3.3.05
Alfy
July 13, 2021, 8:37pm
2
Are you both using some custom Global Theme?
Alfy
July 13, 2021, 8:43pm
4
Global is Breeze dark for me with Oxygen plasma and window decoration
What happens if you change those back to default Breeze too ? And more importantly, do you have that issue with our Breath2 ?
linub
July 13, 2021, 8:53pm
6
same here,green screen on close.(breeze dark)
Alfy
July 13, 2021, 8:56pm
7
Yes issue remains, tried a mixture of other Appearance settings too.
Login out and back doesn’t help?
Deleting cache, apply theme, log out and back in doesn’t help?
Alfy
July 13, 2021, 9:22pm
9
I logged in/out.
anything specific i should remove from cache?
I usually clean it entirely from time to time … is just my thing.
Also, do you have the .compose-cache
in your home directory ?
Alfy
July 13, 2021, 9:28pm
11
Cleared cache, flash remains.
no i dont have .compose-cache
Create it and reboot. It should then have some binary/binaries file/files with unique ID … Not sure why some installs have it and some don’t, but on my end i noticed slight improvement overall.
Alfy
July 13, 2021, 9:39pm
13
thanks I added that and indeed have a new file.
So i had a play in workspace behaviour>desktop effects and it seems that Sliding popups causes the flash.
Goof catch, let me see if i can reproduce so then we call it a bug …
linub
July 13, 2021, 9:48pm
15
you all saw that the person reporting it on KDE provided a work around?
Alfy
July 13, 2021, 9:51pm
16
you mean remove an animation? you monster!
confirming the workaround also works (with animation)
My workaround was to untick the Ask the window manager to perform the animation
checkbox.
W1sE
July 14, 2021, 6:14am
18
This is a better solution as the previous one causes the system tray popups to fade, which is not desirable (for me).
system
Closed
July 29, 2021, 6:14am
19
