I’m trying to hook up my spare laptop running Manjaro KDE to my living room tv. It’s an older Toshiba satellite amd-a6. When I plug it into the avr or tv directly via hdmi, display manager sees it but nothing displays on the tv. I tried with Linux Mint and its working fine, same with my other laptop running Win10.
Can be anything
could you first provide the output of
inxi -Fazy
can be you need to install it first.
pamac install inxi
copy the output and paste it here
select the text and click </> on the topbar
Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=078e2227-1315-4af2-87f7-770ca464845c rw quiet apparmor=1
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: TOSHIBA product: Satellite C40D-A v: PSCDSC-008003
serial: <filter>
Mobo: AMD model: Larne serial: <filter> UEFI: Insyde v: 1.20
date: 05/31/2013
ID-1: BAT1 charge: 53.1 Wh condition: 53.1/47.5 Wh (112%) volts: 12.5/10.8
model: Panasonic PA5109U-1BRS type: Li-ion serial: N/A status: Full
cycles: 28
Device-1: hidpp_battery_0 model: Logitech Wireless Touch Keyboard K400 Plus
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: Discharging
Topology: Quad Core model: AMD A6-5200 APU with Radeon HD Graphics bits: 64
type: MCP arch: Jaguar family: 16 (22) model-id: N/A stepping: 1
microcode: 700010F L2 cache: 2048 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 15979
Speed: 1996 MHz min/max: 800/2000 MHz Core speeds (MHz): 1: 1996 2: 1996
3: 1996 4: 1996
Type: spectre_v2
mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Device-1: AMD Kabini [Radeon HD 8400 / R3 Series] vendor: Toshiba
driver: radeon v: kernel alternate: amdgpu bus ID: 00:01.0
chip ID: 1002:9830
Device-2: Suyin TOSHIBA Web Camera - HD type: USB driver: uvcvideo
bus ID: 2-3:2 chip ID: 064e:e375 serial: <filter>
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: radeon
FAILED: ati unloaded: modesetting alternate: fbdev,vesa display ID: :0
screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 507x285mm (20.0x11.2")
s-diag: 582mm (22.9")
Monitor-1: HDMI-0 res: 1920x1080 dpi: 30 size: 1650x928mm (65.0x36.5")
diag: 1893mm (74.5")
OpenGL: renderer: AMD KABINI (DRM 2.50.0 5.8.6-1-MANJARO LLVM 10.0.1)
v: 4.5 Mesa 20.1.7 direct render: Yes
Device-1: AMD Kabini HDMI/DP Audio driver: snd_hda_intel v: kernel
bus ID: 00:01.1 chip ID: 1002:9840
Device-2: AMD FCH Azalia vendor: Toshiba driver: snd_hda_intel v: kernel
bus ID: 00:14.2 chip ID: 1022:780d
Sound Server: ALSA v: k5.8.6-1-MANJARO
Device-1: Qualcomm Atheros AR8162 Fast Ethernet vendor: Toshiba driver: alx
v: kernel port: 3000 bus ID: 01:00.0 chip ID: 1969:1090
IF: enp1s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL8188EE Wireless Network Adapter driver: rtl8188ee
v: kernel port: 2000 bus ID: 05:00.0 chip ID: 10ec:8179
IF: wlp5s0 state: down mac: <filter>
Local Storage: total: 698.64 GiB used: 7.64 GiB (1.1%)
ID-1: /dev/sda vendor: Toshiba model: MQ01ABD075 size: 698.64 GiB
block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: 4M scheme: GPT
ID-1: / raw size: 698.34 GiB size: 686.38 GiB (98.29%) used: 7.64 GiB (1.1%)
fs: ext4 dev: /dev/sda2
System Temperatures: cpu: 61.2 C mobo: N/A gpu: radeon temp: 59 C
Processes: 168 Uptime: 6m Memory: 5.25 GiB used: 1.16 GiB (22.0%)
Init: systemd v: 246 Compilers: gcc: N/A Packages: pacman: 1156 lib: 315
flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
So it seems to work when I have the laptop lid closed and only the tv on. Its a 4k tv but i use 1080p but it only allows 30fps. On mint I was able to use 120hz.
As you can see in the dispay section it says that it failes to load you display driver
FAILED: ati unloaded: modesetting alternate: fbdev,vesa display ID: :0 screens:1
I guess your running with amdgpu now but I think you need to set a few thing to get it in its best.
Since it is a sea island classified card I think you could modify the kernel parameters in the kernel command line as.
radeon.cik_support=0 amdgpu.cik_support=1
This way you force the amdgpu drivers to load.
The way to do that is open /etc/default/grub
with your favorite editor with sudo.
For instance:
sudo vim /etc/default/grub
find the line that starts with
GRUB_CMDLINE_LINUX_DEFAULT="quiet udev.log_priority=3"
modify it to
GRUB_CMDLINE_LINUX_DEFAULT="quiet radeon.cik_support=0 amdgpu.cik_support=1 udev.log_priority=3"
safe the new config en rebuild grub with
sudo grub-mkconfig -o /boot/grub/grub.cfg
reboot
check how it goes now
Note: It can be you also need to tune some xorg settings.
