Hi,
I have xscreensaver installed and it works as I want it, EXCEPT in regards to full screen mode.
Xscreensaver engages when I am in full screen mode. This is very annoying when watching videos.
Looking over the web, this seems to happen to others. I found some scripts that were supposed to fix the problem, but they did not.
Any suggestions?
[eric@ibox ~]$ inxi -Fzxi
System: Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 compiler: N/A Desktop: Xfce 4.14.2 Distro: Manjaro Linux
Machine: Type: Desktop Mobo: ASRock model: 4X4-V1000 serial: UEFI: American Megatrends v: P1.20
date: 01/06/2020
CPU: Topology: Quad Core model: AMD Ryzen Embedded V1605B with Radeon Vega Gfx bits: 64 type: MT MCP arch: Zen
L2 cache: 2048 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 31949
Speed: 1397 MHz min/max: 1600/2000 MHz Core speeds (MHz): 1: 1397 2: 1374 3: 1555 4: 1577 5: 1529 6: 1544
7: 1481 8: 1580
Graphics: Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series] vendor: ASRock driver: amdgpu
v: kernel bus ID: 04:00.0
Display: x11 server: X.Org 1.20.8 driver: amdgpu,ati unloaded: modesetting resolution: 1920x1080~60Hz
OpenGL:
renderer: AMD Ryzen Embedded V1605B with Radeon Vega Gfx (RAVEN DRM 3.38.0 5.8.6-1-MANJARO LLVM 10.0.1)
v: 4.6 Mesa 20.1.7 direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP Audio vendor: ASRock
driver: snd_hda_intel v: kernel bus ID: 04:00.1
Device-2: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor vendor: ASRock
driver: snd_rn_pci_acp3x v: kernel bus ID: 04:00.5
Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASRock driver: snd_hda_intel v: kernel
bus ID: 04:00.6
Sound Server: ALSA v: k5.8.6-1-MANJARO
Network: Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus ID: 01:00.0
IF: wlp1s0 state: down mac:
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASRock driver: r8169 v: kernel
port: f000 bus ID: 02:00.0
IF: enp2s0 state: down mac:
Device-3: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASRock driver: r8169 v: kernel
port: e000 bus ID: 03:00.0
IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac:
IP v4: type: dynamic noprefixroute scope: global
IP v6: type: dynamic noprefixroute scope: global
IP v6: type: noprefixroute scope: link
WAN IP:
Drives: Local Storage: total: 3.64 TiB used: 538.11 GiB (14.4%)
ID-1: /dev/sda vendor: Crucial model: CT1000BX500SSD1 size: 931.51 GiB
ID-2: /dev/sdb type: USB vendor: Western Digital model: WD20SMZM-59H3FS1 size: 1.82 TiB
ID-3: /dev/sdc type: USB model: G-DRIVE mobile USB-C size: 931.48 GiB
Partition: ID-1: / size: 915.60 GiB used: 167.11 GiB (18.3%) fs: ext4 dev: /dev/sda2
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 40.2 C mobo: N/A gpu: amdgpu temp: 40 C
Info: Processes: 286 Uptime: 1d 9h 24m Memory: 6.80 GiB used: 2.39 GiB (35.1%) Init: systemd Compilers:
gcc: 10.2.0 Packages: 1172 Shell: Bash v: 5.0.18 inxi: 3.1.05
