Hi, I recently installed manjaro with awesome wm, and it has worked great, apart from the brightness and volume keys. I did a lazy fix for the volume keys by adding a custom key shortcut to my rc.lua:
awful.key({ modkey }, "=" function ()
awful.util.spawn("amixer -q sset Master 5%+") end,
{description = "volume up (%5)", group = "volume"}
This works for volume, but i wanted to do the same for Brghtness, i found that i can adjust brightness with xrandr --brightness so i can adjust via the terminal with xrandr --output eDP1 --brightness #brightness 0.1-1 and change brightness, i want to do this in a increase of 10% and not to a fixed value so +10% or -10%, how can i do this?
–brightness brightness
Multiply the gamma values on the crtc currently attached to the output to specified floating value. Useful for
overly bright or overly dim outputs. However, this is a software only modification, if your hardware has support
to actually change the brightness, you will probably prefer to use xbacklight.
> pamac search xbacklight
intelbacklight-git r3.4ec8dfd-1 AUR
A tool that mimics the xbacklight functionality for intel_backlight.
gbacklight r5.6c053a2-1 AUR
Graphical frontend to xbacklight for adjusting the display brightness
acpilight-git v1.1.r9.gf54865e-1 AUR
A backward-compatibile xbacklight replacement
acpilight 1.2-2 community
a backward-compatible xbacklight replacement based on ACPI
xorg-xbacklight-lxhillwind-patch 1.2.1-1 AUR
RandR-based backlight control application, with brightness represented as an integer.
xorg-xbacklight 1.2.3-2 extra
xfce4-power-manager-xbacklight 1.4.4-1 AUR
Power manager for Xfce desktop using xbacklight for setting brightness
gmuxbacklight-git r9.9df3036-1 AUR
Deepin gmux backlight fix
