Since updating yesterday my Manjaro-plus-awesome installation has become extremely laggy, and htop shows Xorg consistently over 25%, but mostly 50-90%.
For 13 years I’ve been using ArchLinux and usually tried to solve all problems myself with minimum forum use, but currently I have 12-hour-days at work plus studying for exams plus a sick parent, so any help to keep my laptop usable in the short run would be extremely welcome.
Below a few info pastes. Thank you very much in advance.
System info:
> inxi -Fxxxazc0 --no-host
Kernel: 5.14.0-0-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=0af7bfc3-6459-4120-8926-d232ed4462f0 rw quiet apparmor=1
security=apparmor resume=UUID=529c403d-51e9-4833-92a9-d2b4d0333419
udev.log_priority=3
Desktop: Xfce 4.16.3 wm: awesome 4.3 vt: 7 dm: LightDM 1.30.0
Type: Laptop System: LENOVO product: 20L70053GE v: ThinkPad T480s
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 20L70053GE v: SDK0J40697 WIN serial: <filter>
UEFI: LENOVO v: N22ET66W (1.43 ) date: 10/12/2020
ID-1: BAT0 charge: 51.0 Wh (98.3%) condition: 51.9/57.0 Wh (91.1%)
volts: 12.8 min: 11.6 model: LGC 01AV478 type: Li-poly serial: <filter>
status: Unknown cycles: 175
Info: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142)
stepping: A (10) microcode: EA cache: L2: 8 MiB
bogomips: 32012
Speed: 2379 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 2379 2: 2188
3: 1713 4: 918 5: 800 6: 2343 7: 800 8: 1487
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: Chicony Integrated IR Camera type: USB driver: uvcvideo
bus-ID: 1-5:3 chip-ID: 04f2:b615 class-ID: 0e02
Device-3: Chicony Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-8:9 chip-ID: 04f2:b614 class-ID: 0e02
Display: x11 server: X.Org 1.20.13 compositor: compton driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 2048x1152 s-dpi: 96 s-size: 542x305mm (21.3x12.0")
s-diag: 622mm (24.5")
Monitor-1: eDP-1 res: 2048x1152 dpi: 168 size: 309x174mm (12.2x6.9")
diag: 355mm (14")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2)
v: 4.6 Mesa 21.2.1 direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.14.0-0-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.34 running: yes
Device-1: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel
port: efa0 bus-ID: 00:1f.6 chip-ID: 8086:15d8 class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel
port: efa0 bus-ID: 3d:00.0 chip-ID: 8086:24fd class-ID: 0280
IF: wlp61s0 state: up mac: <filter>
Device-1: Intel Bluetooth wireless interface type: USB driver: btusb
v: 0.8 bus-ID: 1-7:8 chip-ID: 8087:0a2b class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 953.87 GiB used: 698.41 GiB (73.2%)
model: MZVLB1T0HALR-000L7 size: 953.87 GiB block-size: physical: 512 B
rev: 5L2QEXA7 temp: 35.9 C scheme: GPT
ID-1: / raw-size: 54.19 GiB size: 53.09 GiB (97.97%)
used: 21.68 GiB (40.8%) fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8
used: 316 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p9 maj-min: 259:9
ID-3: /home raw-size: 36.68 GiB size: 35.86 GiB (97.75%)
used: 19.44 GiB (54.2%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
ID-1: swap-1 type: partition size: 8.7 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p7 maj-min: 259:7
System Temperatures: cpu: 47.0 C mobo: N/A
Fan Speeds (RPM): fan-1: 3092
Processes: 233 Uptime: 33m wakeups: 65441 Memory: 15.4 GiB
used: 2.13 GiB (13.8%) Init: systemd v: 248 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1463 lib: 430 flatpak: 0 Shell: Zsh v: 5.8
running-in: xfce4-terminal inxi: 3.3.06
> glxinfo | grep OpenGL
OpenGL vendor string: Intel
OpenGL renderer string: Mesa Intel(R) UHD Graphics 620 (KBL GT2)
OpenGL core profile version string: 4.6 (Core Profile) Mesa 21.2.1
OpenGL core profile shading language version string: 4.60
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
OpenGL version string: 4.6 (Compatibility Profile) Mesa 21.2.1
OpenGL shading language version string: 4.60
OpenGL context flags: (none)
OpenGL profile mask: compatibility profile
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.2 Mesa 21.2.1
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
OpenGL ES profile extensions:
> mhwd -li
> mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
Video-related packages
> pacman -Ss nvidia | grep install
> [sudo] password for surus:
core/mhwd-nvidia 470.63.01-1 [installed]
core/mhwd-nvidia-390xx 390.144-1 [installed]
extra/libvdpau 1.4-1 [installed]
extra/xf86-video-nouveau 1.0.17-1 (xorg-drivers) [installed]
multilib/lib32-libvdpau 1.4-1 [installed]
