leifb
16 September 2022 18:35
21
I couldn’t find anything interesting in the UEFI / BIOS. Secure boot is disabled.
The grub parameters didn’t help (as long as I did the right thing; I added a set ...
line for every parameter.).
While it wasn’t manjaro, I had a pop os live usb which worked without problems. I even did a benchmark and could see the gpu being used in radeontop
I’m flashing a Manjaro ISO right now to see if this is a problem with my setup or Manjaro in general, but I assume the problem is on my end.
If there is nothing else I can try I guess I will just have to reinstall Manjaro
leifb
16 September 2022 18:38
22
While writing my reply I realized that the grub parameters probably belong to the linux
command in the grub config. I tried that but had no luck as well.
brahma
23
if it worked in popos it will hopefully work in manjaro usb …
no you dont add any set, this is how it should look like - using your cmdline from above:
GRUB_CMDLINE_LINUX_DEFAULT="quiet cryptdevice=UUID=cb6c2345-4354-45e0-a7d7-ac1bab050703:luks-cb6c2345-4354-45e0-a7d7-ac1bab050703 root=/dev/mapper/luks-cb6c2345-4354-45e0-a7d7-ac1bab050703 splash apparmor=1 security=apparmor resume=/dev/mapper/luks-14dfa0a3-eee1-41f3-a442-c46618244862 udev.log_priority=3 radeon.si_support=0 radeon.cik_support=0 amdgpu.si_support=1 amdgpu.cik_support=1"
if it works in manjaro, check the cmdline in the live usb …
leifb
16 September 2022 19:12
24
The Manjaro Live USB worked without problems as well.
Applying the grub parameters in the correct way did not make any difference. I’m quite certain I did it right this time.
The live USB had a few extra parameters, they did not help as well unfortunately.
Thanks for the help nevertheless.
brahma
16 September 2022 19:16
25
maybe try with different kernel … also check logs, maybe there is something:
journalctl -b0 -p4 --no-pager
omano
16 September 2022 19:19
26
There was (probably still is) a minimum requirement for kernel for these new AMD cards. Install kernel 5.15 without any extra Grub parameter, and see if it works. You didn’t provide an inxi -Fazy
you should always provide one when opening a support thread.
leifb
16 September 2022 19:28
27
@brahma
I looked at the logs quite a lot but could not find anything.
I tried and older kernel, which didn’t work.
@omano
I will try the newer kernel right away.
Here is the inxi -Fazy
(I was on tty2):
Kernel: 5.10.141-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=0998ba73-ac0d-4e66-b11f-ebbdd497717d rw quiet
udev.log_priority=3
Console: tty 2 DM: GDM v: 42.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: Z170 PRO GAMING v: Rev X.0x
serial: <filter> UEFI: American Megatrends v: 0803 date: 09/24/2015
Info: model: Intel Core i5-6600K socket: LGA1151 bits: 64 type: MCP
arch: Skylake-S gen: core 6 level: v3 built: 2015 process: Intel 14nm
family: 6 model-id: 0x5E (94) stepping: 3 microcode: 0xF0
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 800 min/max: 800/3900 base/boost: 3500/3900 scaling:
driver: intel_pstate governor: powersave volts: 1.1 V ext-clock: 100 MHz
cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 28009
disabled
prctl and seccomp
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT disabled
Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M]
vendor: Sapphire driver: N/A arch: RDNA-2 code: Navi-2x process: TSMC n7
(7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.0
chip-ID: 1002:73df class-ID: 0300
Display: server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3 driver: X:
loaded: radeon unloaded: modesetting alternate: fbdev,vesa gpu: N/A
tty: 128x48
Message: GL data unavailable in console for root.
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
class-ID: 0403
Device-2: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
class-ID: 0403
Sound Server-1: ALSA v: k5.10.141-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 16.1 running: no
Sound Server-4: PipeWire v: 0.3.57 running: no
Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 4.34 TiB used: 703.85 GiB (15.9%)
model: WDS100T3X0C-00SJG0 size: 931.51 GiB block-size: physical: 512 B
rev: 111110WD temp: 41.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 500GB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD30EZRZ-00Z5HB0 size: 2.73 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 0A80 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
ID-5: /dev/sdd maj-min: 8:48 type: USB vendor: SanDisk model: Cruzer Blade
size: 14.59 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.00 scheme: MBR
ID-1: / raw-size: 448.35 GiB size: 440.24 GiB (98.19%) used: 250.22 GiB
(56.8%) fs: ext4 block-size: 4096 B dev: /dev/dm-0 maj-min: 254:0
mapped: luks-cb6c2345-4354-45e0-a7d7-ac1bab050703
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 440 KiB
(0.1%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: partition size: 17.11 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/dm-1 maj-min: 254:1
mapped: luks-14dfa0a3-eee1-41f3-a442-c46618244862
System Temperatures: cpu: 26.0 C mobo: N/A
Processes: 160 Uptime: 0m wakeups: 0 Memory: 15.55 GiB used: 433.8 MiB
(2.7%) Init: systemd v: 251 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 clang: 14.0.6 Packages: 1630 pm: pacman pkgs: 1600 libs: 435
tools: gnome-software,pamac pm: flatpak pkgs: 30 Shell: Zsh (sudo) v: 5.9
default: Bash v: 5.1.16 running-in: tty 2 inxi: 3.3.21
brahma
16 September 2022 19:33
28
you are having intel cpu, which has integrated gpu:
Intel® HD Graphics 530
so you should be able to boot with it …however its not being detected with inxi nor with mhwd …
leifb
16 September 2022 19:35
29
Good news, using the 5.15 kernel just works!
leifb
16 September 2022 19:36
30
Before I do anything else: Is there something I have to keep in mind? Or can I just use my PC like this?
omano
16 September 2022 19:39
31
Check basics like starting graphical program (game) or use command line tools (like glxinfo) to check if the video card works as intended.
maybe disabled in the BIOS, that’s what I would do on a desktop with dedicated GPU, I would disable the low end integrated one.
leifb
16 September 2022 19:44
32
The graphics card working and I can see it being used.
There is an option in my BIOS where I could force either one and it is set to AUTO
. I guess it decided that it would be stupid to use the integrated graphics for me.
Thank you two very much, i appreciate the help!
omano
16 September 2022 23:42
33
Nice. Keep in mind if for whatever reason you want to enable the integrated graphics, you probably would/should then install the hybrid driver available in MHWD GUI (Manjaro Setings Manager → Hardware), it should configure some things here and there to be able to use the dedicated card on demand by starting programs with specific environment variable, and use Intel for everything else.
If it works good for you like that, I guess keep it like that and enjoy
Also inxi
should now tell you it is using amdgpu
, but you already know it now works properly
PS: don’t forget to remove kernel 5.10 as it is no good for you I guess.
system
Closed
19 September 2022 13:42
34
