Hey I’m new to the forum, new to Linux and a recent Windows convert. I signed up to hopefully get some help with my issue.
Problem:
I use a dual monitor setup, so the ‘switch display’ Meta+P shortcut from KDE daemon is really useful to me. The problem is it always resets my external monitors refresh rate to default 60hz when I want to always keep it at 144hz.
I’ve checked xorg’s log and each change the refresh rate is set to “auto” rather than what I specify in my nvidia.conf.
How to repeat:
Simply change display config with Meta+P
What’s expected:
For each monitor to select my correct refresh rate set in my nvidia.conf
What actually happens:
(See log) xorg loads 2560x1440 Auto mode rather than 144hz.
What I’ve tried to fix:
- Originally had my .conf in: /etc/X11/Xorg.conf but read FAQ that it needs instead to be /etc/X11/mhwd.d/nvidia.conf instead. Moving it here its still not being applied correctly.
- In KDE display manager, set resolution and apply.
What I suspect is the problem:
Either something is being done by KDE itself to override my .conf and switch my display to the default of 60hz, or my Xorg isn’t being read correctly.
A quick and dirty fix may be to edit what my default refresh rate is so it resets to 144hz instead of 60hz each time. But more preferably I’d like to figure out why my config doesn’t seem to be loading. Does anyone know how I can make 144hz the default refresh rate, or preferably how I can debug why my nvidia.conf isn’t being used on a display change?
Xorg log:
[tim@BEAST ~]$ cat /var/log/Xorg.0.log | grep DP-1
[ 12.659] (II) NVIDIA(0): Setting mode "DP-1: nvidia
-auto-select @2560x1440 +1920+0 {ViewPortIn=2560x1440,
ViewPortOut=2560x1440+0+0}"
[ 13.538] (II) NVIDIA(0): Setting mode "DP-1: nvidia
-auto-select @2560x1440 +0+0 {ViewPortIn=2560x1440, Vie
[ 72.390] (II) NVIDIA(0): Setting mode "DP-1: nvidia
[ 72.484] (II) NVIDIA(0): Setting mode "DP-0: nvidia
-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, Vie
wPortOut=1920x1080+0+0}, DP-1: nvidia-auto-select @2560
x1440 +1920+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1
440+0+0}
nvidia.conf in /etc/X11/mhwd.d:
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 460.73.01
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
# HorizSync source: edid, VertRefresh source: edid
Identifier "Monitor0"
VendorName "Unknown"
ModelName "LG Electronics 32GK650G"
HorizSync 88.0 - 222.0
VertRefresh 30.0 - 144.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "GeForce GTX 1060"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-2"
Option "metamodes" "DP-1: 2560x1440_144 +0+0"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
SubSection "Display"
Depth 24
EndSubSection
EndSection
[tim@BEAST ~]$ inxi -G
Device-1: NVIDIA GP106BM [GeForce GTX 1060 Mobile
6GB]
driver: nvidia v: 460.73.01
Device-2: Chicony HP Wide Vision FHD Camera
type: USB driver: uvcvideo
Display: x11 server: X.Org 1.20.11 driver:
loaded: nvidia resolution: 1: 1920x1080~120Hz
2: 2560x1440~60Hz
OpenGL: renderer: GeForce GTX 1060/PCIe/SSE2
v: 4.6.0 NVIDIA 460.73.01
[tim@BEAST ~]$ xrandr
Screen 0: minimum 8 x 8, current 4480 x 1440, maximum 32767 x 32767
HDMI-0 disconnected (normal left inverted right x axis y axis)
DP-0 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 381mm x 214mm
1920x1080 120.15*+ 60.13
DP-1 connected 2560x1440+1920+0 (normal left inverted right x axis y axis) 697mm x 392mm
2560x1440 59.95*+ 144.00 120.00 99.95 84.98
1024x768 60.00
800x600 60.32
640x480 59.94
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
KDE Plasma Version: 5.21.4
KDE Frameworks Version: 5.81.0
Qt Version: 5.15.2
Kernel Version: 5.10.34-1-MANJARO
OS Type: 64-bit
Graphics Platform: X11
Processors: 12 × Intel® Core™ i7-8750H CPU @ 2.20GHz
Memory: 15.5 GiB of RAM
Graphics Processor: GeForce GTX 1060/PCIe/SSE2
System is a HP Omen 17" laptop using integrated 120hz display and external 144hz LG 32GK650G 144hz gsync monitor connected via display port.
