what? post output from:
ls /etc/X11/*
/etc/X11/mhwd.d:
nvidia.conf
nvidia.conf.nvidia-xconfig-original
nvidia.conf.old
/etc/X11/xinit:
xinitrc
xinitrc.d (it was in dark blue)
xserverrc
/etc/X11/xorg.conf.d:
00-keyboard.conf
30-touchpad.conf
90-mhwd.conf (it was in light blue)
remove these:
nvidia.conf
nvidia.conf.old
90-mhwd.conf
reboot and see if it helped
and your intel cpu has its own gpu, so why it is not detected?
is it disabled in bios?
Removed all the these files and no change, and I have no idea why the intel cpu is not detected. I’ll check in BIOS but I don’t think I saw anything like it in it.
yes check bios for graphics related options …
were you installing some gpu switching packages/widgets?
also from tty install the 5.15 kernel:
sudo mhwd-kernel -i linux515
open this:
sudo nano /etc/default/grub
and edit this line to look like this:
GRUB_TIMEOUT_STYLE=menu
save it with: ctrl+x
, update grub:
sudo update-grub
reboot and select it in the grub menu/advanced options - dont select the fallback one…
I tried to move from the free drivers to the Nvidia one to solve crashes for XORG. I had these crashes ever since I’ve installed this machine.
I’ve installed the new kernel and edited the the grub file, but don’t understand what am I supposed to choose? Under advanced options to choose Manjaro Linux (Kernel: 5.15.74-3-Manjaro)?
There are two over there, and both of them get stuck at
[ OK ] Reached target Graphical Interface
I’m going over the BIOS, but I don’t think I’ll see anything new.
in the advanced options you should select the non fallback entry for the 5.15 kernel…
so provide logs, there may be some hint whats happening:
journalctl -b0 -p4 --no-pager
sudo dmesg -l err,warn,emerg,alert,crit
sudo dmesg | grep nvidia
yes you had issues because you were running on the open source drivers…
and how is the nvidia connected? directly plugged into the motherboard or via riser cable?
I’ve decided to try and check if the live enviroment with Nvidia’s drivers and after adding the ibt=off it worked for the live enviroment. I have bad news, normal 5.15 still doesn’t load all the way, but I got few bluetooth errors, might be random, but I’ve wanted to write it down either way. Sometimes it get stuck on Reached Sound Card insteead on Graphical Interface. Got a little happy for a moment that there was any kind of change so I’ve decided to write it here.
Currently it stay there. Now for your requests:
Oct 26 21:24:39 guym-tobefilledbyoem kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Oct 26 21:24:39 guym-tobefilledbyoem kernel: ata2.01: failed to resume link (SControl 0)
Oct 26 21:24:39 guym-tobefilledbyoem kernel: ata1.01: failed to resume link (SControl 0)
Oct 26 21:24:39 guym-tobefilledbyoem kernel: vboxdrv: loading out-of-tree module taints kernel.
Oct 26 21:24:39 guym-tobefilledbyoem kernel: VBoxNetAdp: Successfully started.
Oct 26 21:24:39 guym-tobefilledbyoem kernel: VBoxNetFlt: Successfully started.
Oct 26 21:24:40 guym-tobefilledbyoem kernel: ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20210730/utaddress-204)
Oct 26 21:24:40 guym-tobefilledbyoem kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
Oct 26 21:24:40 guym-tobefilledbyoem kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
Oct 26 21:24:40 guym-tobefilledbyoem kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000051F (\LED) (20210730/utaddress-204)
Oct 26 21:24:40 guym-tobefilledbyoem kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
Oct 26 21:24:40 guym-tobefilledbyoem kernel: lpc_ich: Resource conflict(s) found affecting gpio_ich
Oct 26 21:24:40 guym-tobefilledbyoem kernel: r8169 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
Oct 26 21:24:41 guym-tobefilledbyoem kernel: iwlwifi 0000:02:00.0: api flags index 2 larger than supported by driver
Oct 26 21:24:41 guym-tobefilledbyoem kernel: at24 0-0050: supply vcc not found, using dummy regulator
Oct 26 21:24:41 guym-tobefilledbyoem kernel: thermal thermal_zone2: failed to read out thermal zone (-61)
Oct 26 21:24:41 guym-tobefilledbyoem systemd[441]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Oct 26 21:24:46 guym-tobefilledbyoem kernel: kauditd_printk_skb: 16 callbacks suppressed
Oct 26 21:25:56 guym-tobefilledbyoem systemd-xdg-autostart-generator[494]: /home/guym/.config/autostart/org.kde.latte-dock.desktop:106: Unknown key name 'InitialPreference' in section 'Desktop Entry', ignoring.
Oct 26 21:26:07 guym-tobefilledbyoem kernel: kauditd_printk_skb: 15 callbacks suppressed
[ 0.129112] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 2.337710] ata1.01: failed to resume link (SControl 0)
[ 2.364369] ata2.01: failed to resume link (SControl 0)
[ 4.426793] vboxdrv: loading out-of-tree module taints kernel.
[ 4.461527] VBoxNetAdp: Successfully started.
[ 4.470740] VBoxNetFlt: Successfully started.
[ 5.306064] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20210730/utaddress-204)
[ 5.306074] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
[ 5.306079] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
[ 5.306083] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000051F (\LED) (20210730/utaddress-204)
[ 5.306085] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
[ 5.306088] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 5.658652] r8169 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 5.890062] at24 0-0050: supply vcc not found, using dummy regulator
[ 6.312541] iwlwifi 0000:02:00.0: api flags index 2 larger than supported by driver
[ 6.562460] thermal thermal_zone3: failed to read out thermal zone (-61)
[ 11.783616] kauditd_printk_skb: 17 callbacks suppressed
[ 533.974765] kauditd_printk_skb: 11 callbacks suppressed
and
returned nothing
Also, just so we’ll be on the same page, to copy the results of the diffrent commands I use tty only and pip the results into a file on usb, move the usb to a computer that works next to me (windows) and copy paste the file.
so you are saying that you booted with proprietary drivers into live usb, and the nvidia drivers were loaded? did you verify it in the live usb with: inxi -G
for example?
the nvidia is not even detected, there are no logs to nvidia, and there should be!
but you have this:
so lets fix it right away:
and in this line: GRUB_CMDLINE_LINUX_DEFAULT inside the quotes add this parameter:
pcie_aspm=off
dont remove anything from there!, just add it to existing parameters, save the file: ctrl+x
, update grub:
sudo update-grub
reboot and see if it helped…
also this?:
Now that I’ve ran it again it too get stuck at Reached target Graphical Interface.
I’ve done it and nothing changed, still the same results
The GTX960 is connected directly into a PCIEX16 port of GA-H61M-S2PV
so now when you selected to boot with proprietart drivers it got stuck?
check logs:
journalctl -b0 --no-pager | grep nvidia
can you unplug it and then plug it back and see if it helped
I’m trying to run it again without the ibt=off and see if it works. But it got stuck too.
The journalctl -b0 --no-pager | grep nvidia
from the live enviroment return this
Oct 26 19:27:36 manjaro kernel: nvidia: loading out-of-tree module taints kernel.
Oct 26 19:27:36 manjaro kernel: nvidia: module license 'NVIDIA' taints kernel.
Oct 26 19:27:36 manjaro kernel: nvidia: module verification failed: signature and/or required key missing - tainting kernel
Oct 26 19:27:36 manjaro kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 511
Oct 26 19:27:36 manjaro kernel: nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
NVRM: Please visit http://www.nvidia.com/object/unix.html
Oct 26 19:27:36 manjaro kernel: nvidia: probe of 0000:01:00.0 failed with error -1
Oct 26 19:27:36 manjaro kernel: nvidia-nvlink: Unregistered Nvlink Core, major device number 511
Oct 26 19:27:36 manjaro systemd-udevd[4399]: nvidia: Process '/usr/bin/bash -c '/usr/bin/mknod -Z -m 666 /dev/nvidiactl c $(grep nvidia-frontend /proc/devices | cut -d \ -f 1) 255'' failed with exit code 1.
Oct 26 19:27:36 manjaro systemd-udevd[4409]: nvidia: Process '/usr/bin/bash -c '/usr/bin/mknod -Z -m 666 /dev/nvidiactl c $(grep nvidia-frontend /proc/devices | cut -d \ -f 1) 255'' failed with exit code 1.
Oct 26 19:27:37 manjaro kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 511
Oct 26 19:27:37 manjaro kernel: nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=io+mem
Oct 26 19:27:37 manjaro kernel: nvidia: probe of 0000:01:00.0 failed with error -1
Oct 26 19:27:37 manjaro systemd-udevd[4409]: nvidia: Process '/usr/bin/bash -c '/usr/bin/mknod -Z -m 666 /dev/nvidiactl c $(grep nvidia-frontend /proc/devices | cut -d \ -f 1) 255'' failed with exit code 1.
Oct 26 19:27:37 manjaro kernel: nvidia-nvlink: Unregistered Nvlink Core, major device number 511
While the normal version return
Oct 26 22:39:00 guym-tobefilledbyoem systemd-modules-load[218]: Module 'nvidia' is deny-listed
Oct 26 22:39:00 guym-tobefilledbyoem systemd-modules-load[218]: Module 'nvidia_drm' is deny-listed
Oct 26 22:39:00 guym-tobefilledbyoem systemd-modules-load[218]: Module 'nvidia_uvm' is deny-listed
Oct 26 22:39:02 guym-tobefilledbyoem python3[427]: [87] INFO: Available modules: ['nouveau', 'nvidia', 'nvidia_drm', 'nvidia_modeset', 'nvidia_uvm']
Oct 26 22:39:02 guym-tobefilledbyoem python3[427]: [87] INFO: Unloading modules ['nvidia_drm', 'nvidia_modeset', 'nvidia_uvm', 'nvidia'] (if loaded)
Removing the card and returning it did nothing
By the way, I have to go so sorry if I won’t answer as fast as possible
you have these, which looks like the nvidia is being blacklisted…
post output from:
pacman -Qs 'bumblebee|bbswitch|nvidia|prime|acpi|envycontrol|gpu'
pamac list -qm
local/egl-wayland 2:1.1.11-2
EGLStream-based Wayland external platform
local/lib32-nvidia-utils 520.56.06-1
NVIDIA drivers utilities (32-bit)
local/libplacebo 4.208.0-1
Reusable library for GPU-accelerated video/image rendering primitives
local/libvdpau 1.5-1
Nvidia VDPAU library
local/libxnvctrl 520.56.06-1
NVIDIA NV-CONTROL X extension
local/linux515-nvidia 520.56.06-3 (linux515-extramodules)
NVIDIA drivers for linux
local/linux60-nvidia 520.56.06-4 (linux60-extramodules)
local/mhwd-amdgpu 19.1.0-1
MHWD module-ids for amdgpu
local/mhwd-nvidia 520.56.06-2
MHWD module-ids for nvidia 520.56.06
local/mhwd-nvidia-390xx 390.154-2
MHWD module-ids for nvidia 390.154
local/mhwd-nvidia-470xx 470.141.03-3
MHWD module-ids for nvidia 470.141.03
local/nvidia-utils 520.56.06-2
local/optimus-manager 1.4+r12-2
Management utility to handle GPU switching for Optimus laptops (Git version)
pamac list -qm
anydesk-bin
heroic-games-launcher-bin
manjaro-documentation-en
manjaro-firmware
plasma5-applets-window-buttons-git
visual-studio-code-bin
these packages were dropped, so you should remove them…
and you have installed optimus, which is blacklisting the nvidia drivers, so remove it:
sudo pacman -Rns optimus-manager manjaro-documentation-en manjaro-firmware
Still not working, because we’ve changed few important thing I (and I’m going to sleep, I’ll reply first thing tommorow morning) I’ve decided to run few tests to check what’s wrong. These were the last 4 tests you’ve sent me.
local/acpi 1.7-3
Client for battery, power, and thermal readings
local/acpid 2.0.34-1
A daemon for delivering ACPI power management events with netlink support
pamac list -qm
anydesk-bin
Oct 27 02:14:38 guym-tobefilledbyoem kernel: nvidia: module license 'NVIDIA' taints kernel.
Oct 27 02:14:38 guym-tobefilledbyoem kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 511
Oct 27 02:14:38 guym-tobefilledbyoem kernel: nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
Oct 27 02:14:38 guym-tobefilledbyoem kernel: nvidia: probe of 0000:01:00.0 failed with error -1
Oct 27 02:14:38 guym-tobefilledbyoem kernel: nvidia-nvlink: Unregistered Nvlink Core, major device number 511
Oct 27 02:14:38 guym-tobefilledbyoem systemd-modules-load[214]: Failed to insert module 'nvidia': No such device
Oct 27 02:14:40 guym-tobefilledbyoem kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 511
Oct 27 02:14:40 guym-tobefilledbyoem kernel: nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=io+mem
Oct 27 02:14:40 guym-tobefilledbyoem kernel: nvidia: probe of 0000:01:00.0 failed with error -1
Oct 27 02:14:40 guym-tobefilledbyoem kernel: nvidia-nvlink: Unregistered Nvlink Core, major device number 511
Oct 27 02:14:40 guym-tobefilledbyoem systemd-modules-load[214]: Failed to insert module 'nvidia_drm': No such device
Oct 27 02:14:41 guym-tobefilledbyoem kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 511
Oct 27 02:14:41 guym-tobefilledbyoem kernel: nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=io+mem
Oct 27 02:14:41 guym-tobefilledbyoem kernel: nvidia: probe of 0000:01:00.0 failed with error -1
Oct 27 02:14:41 guym-tobefilledbyoem kernel: nvidia-nvlink: Unregistered Nvlink Core, major device number 511
Oct 27 02:14:41 guym-tobefilledbyoem systemd-modules-load[214]: Failed to insert module 'nvidia_uvm': No such device
[ 0.111003] x86/cpu: VMX (outside TXT) disabled by BIOS
[ 0.128673] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 2.317259] ata2.01: failed to resume link (SControl 0)
[ 2.337255] ata1.01: failed to resume link (SControl 0)
[ 4.275627] vboxdrv: loading out-of-tree module taints kernel.
[ 4.309324] VBoxNetAdp: Successfully started.
[ 4.318572] VBoxNetFlt: Successfully started.
[ 5.349059] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20210730/utaddress-204)
[ 5.349069] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
[ 5.349073] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
[ 5.349077] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000051F (\LED) (20210730/utaddress-204)
[ 5.349080] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
[ 5.349083] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 6.420369] at24 0-0050: supply vcc not found, using dummy regulator
[ 6.450510] r8169 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 6.519476] nvidia: module license 'NVIDIA' taints kernel.
[ 6.519480] Disabling lock debugging due to kernel taint
[ 6.560599] NVRM: The Unknown NVIDIA GF1xx Series GPU installed in this
NVRM: system is not supported through the 515.76 NVIDIA
NVRM: driver. You can try the NVIDIA 390.xx Legacy drivers.
NVRM: for download information. The 515.76 NVIDIA driver
NVRM: will ignore this GPU. Continuing probe...
[ 6.560675] nvidia: probe of 0000:01:00.0 failed with error -1
[ 6.560701] NVRM: The NVIDIA probe routine failed for 1 device(s).
[ 6.560702] NVRM: None of the NVIDIA devices were initialized.
[ 7.184112] iwlwifi 0000:02:00.0: api flags index 2 larger than supported by driver
[ 7.433080] thermal thermal_zone3: failed to read out thermal zone (-61)
[ 7.938286] NVRM: The Unknown NVIDIA GF1xx Series GPU installed in this
[ 7.938338] nvidia: probe of 0000:01:00.0 failed with error -1
[ 7.938439] NVRM: The NVIDIA probe routine failed for 1 device(s).
[ 7.938441] NVRM: None of the NVIDIA devices were initialized.
[ 8.005703] NVRM: The Unknown NVIDIA GF1xx Series GPU installed in this
[ 8.005749] nvidia: probe of 0000:01:00.0 failed with error -1
[ 8.005773] NVRM: The NVIDIA probe routine failed for 1 device(s).
[ 8.005774] NVRM: None of the NVIDIA devices were initialized.
[ 9.184559] NVRM: The Unknown NVIDIA GF1xx Series GPU installed in this
[ 9.184613] nvidia: probe of 0000:01:00.0 failed with error -1
[ 9.184640] NVRM: The NVIDIA probe routine failed for 1 device(s).
[ 9.184641] NVRM: None of the NVIDIA devices were initialized.
[ 9.313260] NVRM: The Unknown NVIDIA GF1xx Series GPU installed in this
[ 9.313297] nvidia: probe of 0000:01:00.0 failed with error -1
[ 9.313317] NVRM: The NVIDIA probe routine failed for 1 device(s).
[ 9.313318] NVRM: None of the NVIDIA devices were initialized.
[ 10.617705] kauditd_printk_skb: 20 callbacks suppressed
[ 36.386093] kauditd_printk_skb: 14 callbacks suppressed
ok so there is some progress here:
so uninstall the latest nvidia:
sudo mhwd -r pci video-nvidia
and install the 470 series:
sudo mhwd -i pci video-nvidia-470xx
if not remove the 470 series:
sudo mhwd -r pci video-nvidia-470xx
and install the 390:
sudo mhwd -i pci video-nvidia-390xx
reboot
Sadly neither worked, I had recorded the journalctl of the 470xx
Oct 27 10:19:14 guym-tobefilledbyoem kernel: nvidia: loading out-of-tree module taints kernel.
Oct 27 10:19:14 guym-tobefilledbyoem kernel: nvidia: module license 'NVIDIA' taints kernel.
Oct 27 10:19:14 guym-tobefilledbyoem kernel: nvidia: module verification failed: signature and/or required key missing - tainting kernel
Oct 27 10:19:14 guym-tobefilledbyoem kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 234
Oct 27 10:19:14 guym-tobefilledbyoem kernel: nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
Oct 27 10:19:14 guym-tobefilledbyoem kernel: nvidia: probe of 0000:01:00.0 failed with error -1
Oct 27 10:19:14 guym-tobefilledbyoem kernel: nvidia-nvlink: Unregistered Nvlink Core, major device number 234
Oct 27 10:19:14 guym-tobefilledbyoem kernel: nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=io+mem
Oct 27 10:19:16 guym-tobefilledbyoem kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 511
Oct 27 10:19:16 guym-tobefilledbyoem kernel: nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=io+mem
Oct 27 10:19:16 guym-tobefilledbyoem kernel: nvidia: probe of 0000:01:00.0 failed with error -1
Oct 27 10:19:16 guym-tobefilledbyoem kernel: nvidia-nvlink: Unregistered Nvlink Core, major device number 511
Oct 27 10:19:16 guym-tobefilledbyoem systemd-modules-load[230]: Failed to insert module 'nvidia': No such device
Oct 27 10:19:18 guym-tobefilledbyoem kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 511
Oct 27 10:19:18 guym-tobefilledbyoem kernel: nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=io+mem
Oct 27 10:19:18 guym-tobefilledbyoem kernel: nvidia: probe of 0000:01:00.0 failed with error -1
Oct 27 10:19:18 guym-tobefilledbyoem kernel: nvidia-nvlink: Unregistered Nvlink Core, major device number 511
Oct 27 10:19:18 guym-tobefilledbyoem systemd-modules-load[230]: Failed to insert module 'nvidia_drm': No such device
Oct 27 10:19:19 guym-tobefilledbyoem kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 511
Oct 27 10:19:19 guym-tobefilledbyoem kernel: nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=io+mem
Oct 27 10:19:19 guym-tobefilledbyoem kernel: nvidia: probe of 0000:01:00.0 failed with error -1
Oct 27 10:19:19 guym-tobefilledbyoem kernel: nvidia-nvlink: Unregistered Nvlink Core, major device number 511
Oct 27 10:19:19 guym-tobefilledbyoem systemd-modules-load[230]: Failed to insert module 'nvidia_uvm': No such device
and dmesgof it
[ 0.898522] nvidia: loading out-of-tree module taints kernel.
[ 0.898533] nvidia: module license 'NVIDIA' taints kernel.
[ 0.909862] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 0.941293] nvidia-nvlink: Nvlink Core is being initialized, major device number 234
[ 0.942295] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
[ 0.942447] nvidia: probe of 0000:01:00.0 failed with error -1
[ 0.942590] nvidia-nvlink: Unregistered Nvlink Core, major device number 234
[ 1.212988] nvidia-nvlink: Nvlink Core is being initialized, major device number 234
[ 1.214197] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=io+mem
[ 1.214348] nvidia: probe of 0000:01:00.0 failed with error -1
[ 1.214675] nvidia-nvlink: Unregistered Nvlink Core, major device number 234
[ 1.493523] nvidia-nvlink: Nvlink Core is being initialized, major device number 234
[ 1.494695] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=io+mem
[ 1.494847] nvidia: probe of 0000:01:00.0 failed with error -1
[ 1.495518] nvidia-nvlink: Unregistered Nvlink Core, major device number 234
[ 1.773263] nvidia-nvlink: Nvlink Core is being initialized, major device number 234
[ 1.774470] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=io+mem
[ 1.774623] nvidia: probe of 0000:01:00.0 failed with error -1
[ 1.775295] nvidia-nvlink: Unregistered Nvlink Core, major device number 234
[ 2.199825] nvidia-nvlink: Nvlink Core is being initialized, major device number 234
[ 2.200865] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=io+mem
[ 2.201018] nvidia: probe of 0000:01:00.0 failed with error -1
[ 2.201329] nvidia-nvlink: Unregistered Nvlink Core, major device number 234
[ 2.469329] nvidia-nvlink: Nvlink Core is being initialized, major device number 234
[ 2.470448] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=io+mem
[ 2.470601] nvidia: probe of 0000:01:00.0 failed with error -1
[ 2.471101] nvidia-nvlink: Unregistered Nvlink Core, major device number 234
[ 7.401409] nvidia-nvlink: Nvlink Core is being initialized, major device number 511
[ 7.417925] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=io+mem
[ 7.417983] nvidia: probe of 0000:01:00.0 failed with error -1
[ 7.418166] nvidia-nvlink: Unregistered Nvlink Core, major device number 511
[ 8.807365] nvidia-nvlink: Nvlink Core is being initialized, major device number 511
[ 8.808674] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=io+mem
[ 8.816491] nvidia: probe of 0000:01:00.0 failed with error -1
[ 8.823731] nvidia-nvlink: Unregistered Nvlink Core, major device number 511
[ 8.863443] nvidia-nvlink: Nvlink Core is being initialized, major device number 511
[ 8.866083] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=io+mem
[ 8.873404] nvidia: probe of 0000:01:00.0 failed with error -1
[ 8.886284] nvidia-nvlink: Unregistered Nvlink Core, major device number 511
[ 9.987989] nvidia-nvlink: Nvlink Core is being initialized, major device number 511
[ 9.989148] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=io+mem
[ 9.996420] nvidia: probe of 0000:01:00.0 failed with error -1
[ 10.000991] nvidia-nvlink: Unregistered Nvlink Core, major device number 511
[ 10.111917] nvidia-nvlink: Nvlink Core is being initialized, major device number 511
[ 10.113595] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=io+mem
[ 10.113651] nvidia: probe of 0000:01:00.0 failed with error -1
[ 10.116348] nvidia-nvlink: Unregistered Nvlink Core, major device number 511
and installation of the 390
e[1me[31m> e[mInstalling video-nvidia-390xx...
e[0;32mSourcing /etc/mhwd-x86_64.conf
e[me[0;32mHas lib32 support: true
e[me[0;32mSourcing /var/lib/mhwd/db/pci/graphic_drivers/nvidia-390xx/MHWDCONFIG
e[me[0;32mProcessing classid: 0300
e[me[0;32mSourcing /var/lib/mhwd/scripts/include/0300
e[me[0;32mProcessing classid: 0302
e[me[0;32m:: Synchronizing package databases...
e[me[0;32m core downloading...
e[me[0;32m extra downloading...
e[me[0;32m community downloading...
e[me[0;32m multilib downloading...
e[me[0;32mresolving dependencies...
e[me[0;32mlooking for conflicting packages...
e[me[0;32mwarning: dependency cycle detected:
e[me[0;32mwarning: eglexternalplatform will be installed before its nvidia-390xx-utils dependency
e[me[0;32m
e[me[0;32mPackages (7) egl-wayland-2:1.1.11-2 eglexternalplatform-1.1-2 libxnvctrl-390xx-390.154-1 lib32-nvidia-390xx-utils-390.154-1 linux515-nvidia-390xx-390.154-18 linux60-nvidia-390xx-390.154-3 nvidia-390xx-utils-390.154-2
e[me[0;32m
e[me[0;32mTotal Download Size: 33.26 MiB
e[me[0;32mTotal Installed Size: 226.81 MiB
e[me[0;32m
e[me[0;32m:: Proceed with installation? [Y/n]
e[me[0;32m:: Retrieving packages...
e[me[0;32m lib32-nvidia-390xx-utils-390.154-1-x86_64 downloading...
e[me[0;32m linux60-nvidia-390xx-390.154-3-x86_64 downloading...
e[me[0;32m linux515-nvidia-390xx-390.154-18-x86_64 downloading...
e[me[0;32m libxnvctrl-390xx-390.154-1-x86_64 downloading...
e[me[0;32mchecking keyring...
e[me[0;32mchecking package integrity...
e[me[0;32mloading package files...
e[me[0;32mchecking for file conflicts...
e[me[0;32mchecking available disk space...
e[me[0;32m:: Processing package changes...
e[me[0;32minstalling eglexternalplatform...
e[me[0;32minstalling egl-wayland...
e[me[0;32minstalling libxnvctrl-390xx...
e[me[0;32minstalling nvidia-390xx-utils...
e[me[0;32me[1;1me[1;32m==>e[1;0me[1;1m If you run into trouble with CUDA not being available, run nvidia-modprobe first.e[1;0m
e[me[0;32mOptional dependencies for nvidia-390xx-utils
e[me[0;32m xorg-server-devel: nvidia-xconfig [installed]
e[me[0;32m opencl-nvidia-390xx: OpenCL support
e[me[0;32minstalling lib32-nvidia-390xx-utils...
e[me[0;32mOptional dependencies for lib32-nvidia-390xx-utils
e[me[0;32m lib32-opencl-nvidia
e[me[0;32minstalling linux515-nvidia-390xx...
e[me[0;32minstalling linux60-nvidia-390xx...
e[me[0;32mcat: /usr/lib/modules/extramodules-6.0-MANJARO/version: No such file or directory
e[me[0;32mdepmod: ERROR: Bad version passed
e[me[0;32merror: command failed to execute correctly
e[me[0;32m:: Running post-transaction hooks...
e[me[0;32m(1/7) Creating system user accounts...
e[me[0;32m(2/7) Reloading system manager configuration...
e[me[0;32m(3/7) Reloading device manager configuration...
e[me[0;32m(4/7) Arming ConditionNeedsUpdate...
e[me[0;32m(5/7) Updating module dependencies...
e[me[0;32m(6/7) Refreshing PackageKit...
e[me[0;32m(7/7) Updating the desktop file MIME type cache...
e[me[0;32mnvidia-390xx-utils: install reason has been set to 'explicitly installed'
e[me[0;32mlib32-nvidia-390xx-utils: install reason has been set to 'explicitly installed'
e[me[0;32mlinux515-nvidia-390xx: install reason has been set to 'explicitly installed'
e[me[0;32mlinux60-nvidia-390xx: install reason has been set to 'explicitly installed'
e[me[0;32mrmmod: ERROR: could not remove 'nouveau': No such file or directory
e[me[0;32mrmmod: ERROR: could not remove module nouveau: No such file or directory
e[me[0;32mrmmod: ERROR: could not remove 'ttm': No such file or directory
e[me[0;32mrmmod: ERROR: could not remove module ttm: No such file or directory
e[me[0;32mrmmod: ERROR: could not remove 'drm_kms_helper': No such file or directory
e[me[0;32mrmmod: ERROR: could not remove module drm_kms_helper: No such file or directory
e[me[0;32mrmmod: ERROR: could not remove 'drm': No such file or directory
e[me[0;32mrmmod: ERROR: could not remove module drm: No such file or directory
e[me[0;32mmodprobe: ERROR: could not insert 'nvidia': No such device
e[me[0;32mxorg configuration file: '/etc/X11/mhwd.d/nvidia.conf'
e[me[0;32mmodprobe: ERROR: could not insert 'nvidia_drm': No such device
e[me[1me[31m> e[mSuccessfully installed video-nvidia-390xx
and again journalctl and dmesg
Oct 27 10:28:21 guym-tobefilledbyoem kernel: nvidia: loading out-of-tree module taints kernel.
Oct 27 10:28:21 guym-tobefilledbyoem kernel: nvidia: module license 'NVIDIA' taints kernel.
Oct 27 10:28:21 guym-tobefilledbyoem kernel: nvidia: module verification failed: signature and/or required key missing - tainting kernel
Oct 27 10:28:21 guym-tobefilledbyoem kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 234
Oct 27 10:28:21 guym-tobefilledbyoem kernel: nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
Oct 27 10:28:21 guym-tobefilledbyoem kernel: nvidia: probe of 0000:01:00.0 failed with error -1
Oct 27 10:28:21 guym-tobefilledbyoem kernel: nvidia-nvlink: Unregistered Nvlink Core, major device number 234
Oct 27 10:28:21 guym-tobefilledbyoem kernel: nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=io+mem
Oct 27 10:28:23 guym-tobefilledbyoem kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 511
Oct 27 10:28:23 guym-tobefilledbyoem kernel: nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=io+mem
Oct 27 10:28:23 guym-tobefilledbyoem kernel: nvidia: probe of 0000:01:00.0 failed with error -1
Oct 27 10:28:23 guym-tobefilledbyoem kernel: nvidia-nvlink: Unregistered Nvlink Core, major device number 511
Oct 27 10:28:23 guym-tobefilledbyoem systemd-modules-load[229]: Failed to insert module 'nvidia': No such device
Oct 27 10:28:24 guym-tobefilledbyoem kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 511
Oct 27 10:28:24 guym-tobefilledbyoem kernel: nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=io+mem
Oct 27 10:28:24 guym-tobefilledbyoem kernel: nvidia: probe of 0000:01:00.0 failed with error -1
Oct 27 10:28:24 guym-tobefilledbyoem kernel: nvidia-nvlink: Unregistered Nvlink Core, major device number 511
Oct 27 10:28:24 guym-tobefilledbyoem systemd-modules-load[229]: Failed to insert module 'nvidia_drm': No such device
Oct 27 10:28:25 guym-tobefilledbyoem kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 511
Oct 27 10:28:25 guym-tobefilledbyoem kernel: nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=io+mem
Oct 27 10:28:25 guym-tobefilledbyoem kernel: nvidia: probe of 0000:01:00.0 failed with error -1
Oct 27 10:28:25 guym-tobefilledbyoem kernel: nvidia-nvlink: Unregistered Nvlink Core, major device number 511
Oct 27 10:28:25 guym-tobefilledbyoem systemd-modules-load[229]: Failed to insert module 'nvidia_uvm': No such device
Oct 27 10:29:02 guym-tobefilledbyoem kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 511
Oct 27 10:29:02 guym-tobefilledbyoem kernel: nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=io+mem
Oct 27 10:29:02 guym-tobefilledbyoem kernel: nvidia: probe of 0000:01:00.0 failed with error -1
Oct 27 10:29:02 guym-tobefilledbyoem kernel: nvidia-nvlink: Unregistered Nvlink Core, major device number 511
[ 0.904562] nvidia: loading out-of-tree module taints kernel.
[ 0.904574] nvidia: module license 'NVIDIA' taints kernel.
[ 0.916109] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 0.947746] nvidia-nvlink: Nvlink Core is being initialized, major device number 234
[ 0.948757] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
[ 0.948909] nvidia: probe of 0000:01:00.0 failed with error -1
[ 0.949048] nvidia-nvlink: Unregistered Nvlink Core, major device number 234
[ 1.219772] nvidia-nvlink: Nvlink Core is being initialized, major device number 234
[ 1.220933] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=io+mem
[ 1.221085] nvidia: probe of 0000:01:00.0 failed with error -1
[ 1.221222] nvidia-nvlink: Unregistered Nvlink Core, major device number 234
[ 1.493657] nvidia-nvlink: Nvlink Core is being initialized, major device number 234
[ 1.494793] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=io+mem
[ 1.494947] nvidia: probe of 0000:01:00.0 failed with error -1
[ 1.495715] nvidia-nvlink: Unregistered Nvlink Core, major device number 234
[ 1.790047] nvidia-nvlink: Nvlink Core is being initialized, major device number 234
[ 1.791146] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=io+mem
[ 1.791301] nvidia: probe of 0000:01:00.0 failed with error -1
[ 1.792171] nvidia-nvlink: Unregistered Nvlink Core, major device number 234
[ 2.173991] nvidia-nvlink: Nvlink Core is being initialized, major device number 234
[ 2.175019] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=io+mem
[ 2.175172] nvidia: probe of 0000:01:00.0 failed with error -1
[ 2.175312] nvidia-nvlink: Unregistered Nvlink Core, major device number 234
[ 2.451661] nvidia-nvlink: Nvlink Core is being initialized, major device number 234
[ 2.452714] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=io+mem
[ 2.452868] nvidia: probe of 0000:01:00.0 failed with error -1
[ 2.453013] nvidia-nvlink: Unregistered Nvlink Core, major device number 234
[ 7.848159] nvidia-nvlink: Nvlink Core is being initialized, major device number 511
[ 7.867027] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=io+mem
[ 7.867089] nvidia: probe of 0000:01:00.0 failed with error -1
[ 7.867253] nvidia-nvlink: Unregistered Nvlink Core, major device number 511
[ 9.120068] nvidia-nvlink: Nvlink Core is being initialized, major device number 511
[ 9.122317] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=io+mem
[ 9.130504] nvidia: probe of 0000:01:00.0 failed with error -1
[ 9.141105] nvidia-nvlink: Unregistered Nvlink Core, major device number 511
[ 9.182090] nvidia-nvlink: Nvlink Core is being initialized, major device number 511
[ 9.184343] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=io+mem
[ 9.191440] nvidia: probe of 0000:01:00.0 failed with error -1
[ 9.197701] nvidia-nvlink: Unregistered Nvlink Core, major device number 511
[ 10.367638] nvidia-nvlink: Nvlink Core is being initialized, major device number 511
[ 10.369389] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=io+mem
[ 10.377063] nvidia: probe of 0000:01:00.0 failed with error -1
[ 10.382694] nvidia-nvlink: Unregistered Nvlink Core, major device number 511
[ 10.545382] nvidia-nvlink: Nvlink Core is being initialized, major device number 511
[ 10.548343] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=io+mem
[ 10.554488] nvidia: probe of 0000:01:00.0 failed with error -1
[ 10.571200] nvidia-nvlink: Unregistered Nvlink Core, major device number 511
[ 47.061214] nvidia-nvlink: Nvlink Core is being initialized, major device number 511
[ 47.062236] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=io+mem
[ 47.062297] nvidia: probe of 0000:01:00.0 failed with error -1
[ 47.062448] nvidia-nvlink: Unregistered Nvlink Core, major device number 511
I see the struggle here and … well, i’ll mention it again: i have the same GPU and there are no issues with it regardless the Nvidia version drivers i use, but i go with the video-nvidia
aka 520.56.06 … and works on all supported kernels.
Please boot from the Live Media latest ISO, using proprietary drivers and let us know if there are any issues. By the way, this is normal to see in journal and should not concern you:
oct 27 08:29:36 manjaro kernel: nvidia: loading out-of-tree module taints kernel.
oct 27 08:29:36 manjaro kernel: nvidia: module license 'NVIDIA' taints kernel.
oct 27 08:29:36 manjaro kernel: nvidia: module verification failed: signature and/or required key missing - tainting kernel
My suggestion, based on what i witnessed so far here, is to change the port where the GPU is connected on your motherboard, test with Live Media proprietary drivers and the installed system.
do what bogdan suggest by trying a different port on your motherboard if you have them…
also try booting into a live enviroment with a non arch distro, like linux mint for example, and if you are able to boot, check with:
inxi -G
to see if the nvidia drivers are being loaded and not the nouveau one…
