Xorg error libneettle.so.6 after Update 2019-07-17
/usr/lib/Xorg: error while loading shared libraries: libneettle.so.6: cannot open shared object file: No such file or directory
xinit: giving up
xinit: unable to connect to X server: connection refused
xinit: server error
Did you reboot after your update?
last time I update system went smoothly, and the I shut down the PC
After I turn on again my PC I got GRUB option: manjaro and advanced option
I go to TTY2 try startx and got that error, Sir
Can you get an up-to-date mirror and try updating again from the TTY?
sudo pacman-mirrors -f 5 && sudo pacman -Syyu
It looks like your x server is older than the nettle package which shouldn't happen in normal circumstances.
If that doesn't work can we see the output of:
cat /etc/pacman.conf | grep -i ignorepkg
I got error: faiied retrieving file 'corelib.db' 'multilib.db, etc from all mirrors
error: failed to synchronied all database
output:
#pacman won't upgrade packages listed in IgnorePkg and members of IgnoreGroup
#IgnorePkg =
Is your connection wired or wireless?
wired, Sir.
when I try with live manjaro usb, It can connect to internet
From the TTY run:
sudo systemctl start dhcpcd.service
Wait a minute or so to get an IP address, then try this again:
sudo: systemtcl: command not found
that should be systemctl not systemtcl
Sorry Sir,
still cannot connect to internet
Try running nmtui and activating your wired connection.
I'm setting up ethernet in edit a connection automatically, but I can not found in activate a connection.
Now i failed to start dhcpd.service: unit dhcpd.service not found.
Can I try using live USB Manjaro to fix it?
Sure, you can use sudo manjaro-chroot -a from a terminal on the live cd. That should give a chroot.
Then run:
pacman-mirrors -f 5 && pacman -Syyu
Thank you Mr. Dalto, you're the best...
