Moved from 515 to 510.
ITS SOLVED: Turns out using 5.10 kernel was the issue. Using kernel 5.14 and reinstalling drivers with mhwd worked.
X will not start, tried a bunch of different things
Followed this guide archlinux(dot)org/title/AMDGPU
- Make sure you have the latest linux-firmware package installed. This driver requires the latest firmware for each model to successfully boot.
- Make sure you do not have
nomodeset
orvga=
as a kernel parameter - Check that you have not disabled
amdgpu
by using any [kernel module blacklisting]
but now i feel I’ve screwed thing up pretty bad. Details below:
inxi -Fazy
Kernel: 5.10.70-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=3391bcbf-f73a-40bc-a811-485871c59f39 rw quiet apparmor=1
Console: tty 2 Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: Gigabyte product: Z390 AORUS ELITE v: N/A
serial: <filter>
Mobo: Gigabyte model: Z390 AORUS ELITE-CF v: x.x serial: <filter>
UEFI: American Megatrends v: F10c date: 12/18/2019
Device-1: hidpp_battery_0
model: Logitech G305 Lightspeed Wireless Gaming Mouse serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
Info: 6-Core model: Intel Core i5-9600K bits: 64 type: MCP arch: Kaby Lake
note: check family: 6 model-id: 9E (158) stepping: D (13) microcode: EA
cache: L2: 9 MiB
bogomips: 44412
Speed: 800 MHz min/max: 800/4600 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800
Type: srbds mitigation: TSX disabled
Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT / 6800M] driver: N/A
bus-ID: 03:00.0 chip-ID: 1002:73df class-ID: 0300
Display: server: X.org 1.20.13 driver: loaded: ati,vesa
unloaded: fbdev,modesetting,radeon tty: 160x45
Message: Advanced graphics data unavailable in console. Try -G --display
Device-1: Intel Cannon Lake PCH cAVS vendor: Gigabyte driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
Device-2: AMD Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT]
driver: snd_hda_intel v: kernel bus-ID: 03:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-3: Logitech [G533 Wireless Headset Dongle] type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-13.4:10
chip-ID: 046d:0a66 class-ID: 0300
Sound Server-1: ALSA v: k5.10.70-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.38 running: no
Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 06:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlp6s0 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-11.1:8 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 1.82 TiB used: 305.94 GiB (16.4%)
model: WDS500G3X0C-00SJG0 size: 465.76 GiB block-size: physical: 512 B
rev: 111110WD temp: 36.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WDS100T2B0A-00SM50 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 20WD
scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WDS500G2B0A-00SM50 size: 465.76 GiB block-size: physical: 512 B
scheme: GPT
ID-1: / raw-size: 47.83 GiB size: 46.78 GiB (97.80%) used: 38.55 GiB (82.4%)
fs: ext4 dev: /dev/sdb5 maj-min: 8:21
used: 292 KiB (0.1%) fs: vfat dev: /dev/sdb4 maj-min: 8:20
System Temperatures: cpu: 34.0 C mobo: 27.8 C
Processes: 174 Uptime: 4m wakeups: 2 Memory: 31.29 GiB used: 753 MiB (2.3%)
Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 Packages:
pacman: 1308 lib: 338 flatpak: 0 Shell: Zsh (login) v: 5.8 running-in: tty 2
inxi: 3.3.08
uname -a
Linux pc 5.10.70-1-MANJARO #1 SMP PREEMPT Thu Sep 30 15:29:01 UTC 2021 x86_64 GNU/Linux
lspci -k
00:00.0 Host bridge: Intel Corporation 8th Gen Core Processor Host Bridge/DRAM Registers (rev 0d)
DeviceName: Onboard - Other
Subsystem: Gigabyte Technology Co., Ltd Device 5000
Kernel driver in use: skl_uncore
Kernel modules: ie31200_edac
00:01.0 PCI bridge: Intel Corporation 6th-10th Gen Core Processor PCIe Controller (x16) (rev 0d)
Kernel driver in use: pcieport
00:12.0 Signal processing controller: Intel Corporation Cannon Lake PCH Thermal Controller (rev 10)
Subsystem: Gigabyte Technology Co., Ltd Device 8888
Kernel driver in use: intel_pch_thermal
Kernel modules: intel_pch_thermal
00:14.0 USB controller: Intel Corporation Cannon Lake PCH USB 3.1 xHCI Host Controller (rev 10)
Subsystem: Gigabyte Technology Co., Ltd Device 5007
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
00:14.2 RAM memory: Intel Corporation Cannon Lake PCH Shared SRAM (rev 10)
Subsystem: Intel Corporation Device 7270
00:16.0 Communication controller: Intel Corporation Cannon Lake PCH HECI Controller (rev 10)
Subsystem: Gigabyte Technology Co., Ltd Device 1c3a
Kernel driver in use: mei_me
Kernel modules: mei_me
00:17.0 SATA controller: Intel Corporation Cannon Lake PCH SATA AHCI Controller (rev 10)
DeviceName: Onboard - SATA
Subsystem: Gigabyte Technology Co., Ltd Device b005
Kernel driver in use: ahci
00:1b.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #17 (rev f0)
00:1c.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #1 (rev f0)
00:1c.7 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #8 (rev f0)
00:1d.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #9 (rev f0)
00:1f.0 ISA bridge: Intel Corporation Z390 Chipset LPC/eSPI Controller (rev 10)
Subsystem: Gigabyte Technology Co., Ltd Device 5001
00:1f.3 Audio device: Intel Corporation Cannon Lake PCH cAVS (rev 10)
DeviceName: Onboard - Sound
Subsystem: Gigabyte Technology Co., Ltd Device a0c3
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel, snd_soc_skl, snd_sof_pci
00:1f.4 SMBus: Intel Corporation Cannon Lake PCH SMBus Controller (rev 10)
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
00:1f.5 Serial bus controller [0c80]: Intel Corporation Cannon Lake PCH SPI Controller (rev 10)
Kernel driver in use: intel-spi
Kernel modules: intel_spi_pci
00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (7) I219-V (rev 10)
DeviceName: Onboard - Ethernet
Subsystem: Gigabyte Technology Co., Ltd Device e000
Kernel driver in use: e1000e
Kernel modules: e1000e
01:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] Navi 10 XL Upstream Port of PCI Express Switch (rev c1)
02:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] Navi 10 XL Downstream Port of PCI Express Switch
03:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Navi 22 [Radeon RX 6700/6700 XT / 6800M] (rev c1)
Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] Device 0e36
03:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT]
Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT]
06:00.0 Network controller: Intel Corporation Wi-Fi 6 AX200 (rev 1a)
Subsystem: Intel Corporation Wi-Fi 6 AX200NGW
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
07:00.0 Non-Volatile memory controller: Sandisk Corp WD Black SN750 / PC SN730 NVMe SSD
Subsystem: Sandisk Corp WD Black SN750 / PC SN730 NVMe SSD
Kernel driver in use: nvme
xorg logs
[ 50.120] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[ 50.123]
X.Org X Server 1.20.13
[ 50.130] Build Operating System: Linux Manjaro Linux
[ 50.133] Current Operating System: Linux pc 5.10.70-1-MANJARO #1 SMP PREEMPT Thu Sep 30 15:29:01 UTC 2021 x86_64
[ 50.133] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=3391bcbf-f73a-40bc-a811-485871c59f39 rw quiet apparmor=1 security=apparmor udev.log_priority=3
[ 50.142] Build Date: 24 August 2021 10:21:29AM
[ 50.144]
[ 50.146] Current version of pixman: 0.40.0
[ 50.151] Before reporting problems, check http://wiki.x.org
[ 50.151] Markers: (--) probed, (**) from config file, (==) default setting,
[ 50.158] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Nov 16 14:15:29 2021
[ 50.160] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 50.160] (==) No Layout section. Using the first Screen section.
[ 50.160] (==) No screen section available. Using defaults.
[ 50.160] (**) |-->Screen "Default Screen Section" (0)
[ 50.160] (**) | |-->Monitor "<default monitor>"
[ 50.161] (==) No monitor specified for screen "Default Screen Section".
[ 50.161] (==) Automatically adding devices
[ 50.161] (==) Automatically enabling devices
[ 50.161] (==) Automatically adding GPU devices
[ 50.161] (==) Automatically binding GPU devices
[ 50.161] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 50.163] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 50.163] Entry deleted from font path.
[ 50.163] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 50.163] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 50.163] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 50.163] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 50.163] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 50.163] (II) The server relies on udev to provide the list of input devices.
[ 50.163] (II) Module ABI versions:
[ 50.163] X.Org ANSI C Emulation: 0.4
[ 50.163] X.Org Video Driver: 24.1
[ 50.163] X.Org XInput driver : 24.1
[ 50.163] X.Org Server Extension : 10.0
[ 50.163] (++) using VT number 2
[ 50.164] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_32
[ 50.166] (--) PCI:*(3@0:0:0) 1002:73df:1002:0e36 rev 193, Mem @ 0x40000000/268435456, 0x50000000/2097152, 0x50300000/1048576, I/O @ 0x00003000/256, BIOS @ 0x????????/131072
[ 50.166] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 50.166] (II) LoadModule: "glx"
[ 50.167] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 50.175] (II) Module glx: vendor="X.Org Foundation"
[ 50.175] compiled for 1.20.13, module version = 1.0.0
[ 50.175] ABI class: X.Org Server Extension, version 10.0
[ 50.175] (==) Matched ati as autoconfigured driver 0
[ 50.175] (==) Matched modesetting as autoconfigured driver 1
[ 50.175] (==) Matched fbdev as autoconfigured driver 2
[ 50.175] (==) Matched vesa as autoconfigured driver 3
[ 50.175] (==) Assigned the driver to the xf86ConfigLayout
[ 50.175] (II) LoadModule: "ati"
[ 50.175] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[ 50.175] (II) Module ati: vendor="X.Org Foundation"
[ 50.175] compiled for 1.20.8, module version = 19.1.0
[ 50.175] Module class: X.Org Video Driver
[ 50.175] ABI class: X.Org Video Driver, version 24.1
[ 50.176] (II) LoadModule: "radeon"
[ 50.176] (II) Loading /usr/lib/xorg/modules/drivers/radeon_drv.so
[ 50.180] (II) Module radeon: vendor="X.Org Foundation"
[ 50.180] compiled for 1.20.8, module version = 19.1.0
[ 50.180] Module class: X.Org Video Driver
[ 50.180] ABI class: X.Org Video Driver, version 24.1
[ 50.180] (II) LoadModule: "modesetting"
[ 50.180] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 50.181] (II) Module modesetting: vendor="X.Org Foundation"
[ 50.181] compiled for 1.20.13, module version = 1.20.13
[ 50.181] Module class: X.Org Video Driver
[ 50.181] ABI class: X.Org Video Driver, version 24.1
[ 50.181] (II) LoadModule: "fbdev"
[ 50.181] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 50.182] (II) Module fbdev: vendor="X.Org Foundation"
[ 50.182] compiled for 1.20.8, module version = 0.5.0
[ 50.182] Module class: X.Org Video Driver
[ 50.182] ABI class: X.Org Video Driver, version 24.1
[ 50.182] (II) LoadModule: "vesa"
[ 50.182] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 50.183] (II) Module vesa: vendor="X.Org Foundation"
[ 50.183] compiled for 1.20.9, module version = 2.5.0
[ 50.183] Module class: X.Org Video Driver
[ 50.183] ABI class: X.Org Video Driver, version 24.1
[ 50.183] (II) RADEON: Driver for ATI/AMD Radeon chipsets:
ATI Radeon Mobility X600 (M24), ATI FireMV 2400,
ATI Radeon Mobility X300 (M24), ATI FireGL M24 GL,
ATI Radeon X600 (RV380), ATI FireGL V3200 (RV380),
ATI Radeon IGP320 (A3), ATI Radeon IGP330/340/350 (A4),
ATI Radeon 9500, ATI Radeon 9600TX, ATI FireGL Z1, ATI Radeon 9800SE,
ATI Radeon 9800, ATI FireGL X2, ATI Radeon 9600, ATI Radeon 9600SE,
ATI Radeon 9600XT, ATI FireGL T2, ATI Radeon 9650, ATI FireGL RV360,
ATI Radeon 7000 IGP (A4+), ATI Radeon 8500 AIW,
ATI Radeon IGP320M (U1), ATI Radeon IGP330M/340M/350M (U2),
ATI Radeon Mobility 7000 IGP, ATI Radeon 9000/PRO, ATI Radeon 9000,
ATI Radeon X800 (R420), ATI Radeon X800PRO (R420),
ATI Radeon X800SE (R420), ATI FireGL X3 (R420),
ATI Radeon Mobility 9800 (M18), ATI Radeon X800 SE (R420),
ATI Radeon X800XT (R420), ATI Radeon X800 VE (R420),
ATI Radeon X850 (R480), ATI Radeon X850 XT (R480),
ATI Radeon X850 SE (R480), ATI Radeon X850 PRO (R480),
ATI Radeon X850 XT PE (R480), ATI Radeon Mobility M7,
ATI Mobility FireGL 7800 M7, ATI Radeon Mobility M6,
ATI FireGL Mobility 9000 (M9), ATI Radeon Mobility 9000 (M9),
ATI Radeon 9700 Pro, ATI Radeon 9700/9500Pro, ATI FireGL X1,
ATI Radeon 9800PRO, ATI Radeon 9800XT,
ATI Radeon Mobility 9600/9700 (M10/M11),
ATI Radeon Mobility 9600 (M10), ATI Radeon Mobility 9600 (M11),
ATI FireGL Mobility T2 (M10), ATI FireGL Mobility T2e (M11),
ATI Radeon, ATI FireGL 8700/8800, ATI Radeon 8500, ATI Radeon 9100,
ATI Radeon 7500, ATI Radeon VE/7000, ATI ES1000,
ATI Radeon Mobility X300 (M22), ATI Radeon Mobility X600 SE (M24C),
ATI FireGL M22 GL, ATI Radeon X800 (R423), ATI Radeon X800PRO (R423),
ATI Radeon X800LE (R423), ATI Radeon X800SE (R423),
ATI Radeon X800 XTP (R430), ATI Radeon X800 XL (R430),
ATI Radeon X800 SE (R430), ATI Radeon X800 (R430),
ATI FireGL V7100 (R423), ATI FireGL V5100 (R423),
ATI FireGL unknown (R423), ATI Mobility FireGL V5000 (M26),
ATI Mobility Radeon X700 XL (M26), ATI Mobility Radeon X700 (M26),
ATI Radeon X550XTX, ATI Radeon 9100 IGP (A5),
ATI Radeon Mobility 9100 IGP (U3), ATI Radeon XPRESS 200,
ATI Radeon XPRESS 200M, ATI Radeon 9250, ATI Radeon 9200,
ATI Radeon 9200SE, ATI FireMV 2200, ATI Radeon X300 (RV370),
ATI Radeon X600 (RV370), ATI Radeon X550 (RV370),
ATI FireGL V3100 (RV370), ATI FireMV 2200 PCIE (RV370),
ATI Radeon Mobility 9200 (M9+), ATI Mobility Radeon X800 XT (M28),
ATI Mobility FireGL V5100 (M28), ATI Mobility Radeon X800 (M28),
ATI Radeon X850, ATI unknown Radeon / FireGL (R480),
ATI Radeon X800XT (R423), ATI FireGL V5000 (RV410),
ATI Radeon X700 XT (RV410), ATI Radeon X700 PRO (RV410),
ATI Radeon X700 SE (RV410), ATI Radeon X700 (RV410),
ATI Radeon X1800, ATI Mobility Radeon X1800 XT,
ATI Mobility Radeon X1800, ATI Mobility FireGL V7200,
ATI FireGL V7200, ATI FireGL V5300, ATI Mobility FireGL V7100,
ATI FireGL V7300, ATI FireGL V7350, ATI Radeon X1600, ATI RV505,
ATI Radeon X1300/X1550, ATI Radeon X1550, ATI M54-GL,
ATI Mobility Radeon X1400, ATI Radeon X1550 64-bit,
ATI Mobility Radeon X1300, ATI Radeon X1300, ATI FireGL V3300,
ATI FireGL V3350, ATI Mobility Radeon X1450,
ATI Mobility Radeon X2300, ATI Mobility Radeon X1350,
ATI FireMV 2250, ATI Radeon X1650, ATI Mobility FireGL V5200,
ATI Mobility Radeon X1600, ATI Radeon X1300 XT/X1600 Pro,
ATI FireGL V3400, ATI Mobility FireGL V5250,
ATI Mobility Radeon X1700, ATI Mobility Radeon X1700 XT,
ATI FireGL V5200, ATI Radeon X2300HD, ATI Mobility Radeon HD 2300,
ATI Radeon X1950, ATI Radeon X1900, ATI AMD Stream Processor,
ATI RV560, ATI Mobility Radeon X1900, ATI Radeon X1950 GT, ATI RV570,
ATI FireGL V7400, ATI Radeon 9100 PRO IGP,
ATI Radeon Mobility 9200 IGP, ATI Radeon X1200, ATI RS740,
ATI RS740M, ATI Radeon HD 2900 XT, ATI Radeon HD 2900 Pro,
ATI Radeon HD 2900 GT, ATI FireGL V8650, ATI FireGL V8600,
ATI FireGL V7600, ATI Radeon 4800 Series, ATI Radeon HD 4870 x2,
ATI Radeon HD 4850 x2, ATI FirePro V8750 (FireGL),
ATI FirePro V7760 (FireGL), ATI Mobility RADEON HD 4850,
ATI Mobility RADEON HD 4850 X2, ATI FirePro RV770,
AMD FireStream 9270, AMD FireStream 9250, ATI FirePro V8700 (FireGL),
ATI Mobility RADEON HD 4870, ATI Mobility RADEON M98,
ATI FirePro M7750, ATI M98, ATI Mobility Radeon HD 4650,
ATI Radeon RV730 (AGP), ATI Mobility Radeon HD 4670,
ATI FirePro M5750, ATI RV730XT [Radeon HD 4670], ATI RADEON E4600,
ATI Radeon HD 4600 Series, ATI RV730 PRO [Radeon HD 4650],
ATI FirePro V7750 (FireGL), ATI FirePro V5700 (FireGL),
ATI FirePro V3750 (FireGL), ATI Mobility Radeon HD 4830,
ATI Mobility Radeon HD 4850, ATI FirePro M7740, ATI RV740,
ATI Radeon HD 4770, ATI Radeon HD 4700 Series, ATI RV610,
ATI Radeon HD 2400 XT, ATI Radeon HD 2400 Pro,
ATI Radeon HD 2400 PRO AGP, ATI FireGL V4000, ATI Radeon HD 2350,
ATI Mobility Radeon HD 2400 XT, ATI Mobility Radeon HD 2400,
ATI RADEON E2400, ATI FireMV 2260, ATI RV670, ATI Radeon HD3870,
ATI Mobility Radeon HD 3850, ATI Radeon HD3850,
ATI Mobility Radeon HD 3850 X2, ATI Mobility Radeon HD 3870,
ATI Mobility Radeon HD 3870 X2, ATI Radeon HD3870 X2,
ATI FireGL V7700, ATI Radeon HD3690, AMD Firestream 9170,
ATI Radeon HD 4550, ATI Radeon RV710, ATI Radeon HD 4350,
ATI Mobility Radeon 4300 Series, ATI Mobility Radeon 4500 Series,
ATI FirePro RG220, ATI Mobility Radeon 4330, ATI RV630,
ATI Mobility Radeon HD 2600, ATI Mobility Radeon HD 2600 XT,
ATI Radeon HD 2600 XT AGP, ATI Radeon HD 2600 Pro AGP,
ATI Radeon HD 2600 XT, ATI Radeon HD 2600 Pro, ATI Gemini RV630,
ATI Gemini Mobility Radeon HD 2600 XT, ATI FireGL V5600,
ATI FireGL V3600, ATI Radeon HD 2600 LE,
ATI Mobility FireGL Graphics Processor, ATI Radeon HD 3470,
ATI Mobility Radeon HD 3430, ATI Mobility Radeon HD 3400 Series,
ATI Radeon HD 3450, ATI Radeon HD 3430, ATI FirePro V3700,
ATI FireMV 2450, ATI Radeon HD 3600 Series, ATI Radeon HD 3650 AGP,
ATI Radeon HD 3600 PRO, ATI Radeon HD 3600 XT,
ATI Mobility Radeon HD 3650, ATI Mobility Radeon HD 3670,
ATI Mobility FireGL V5700, ATI Mobility FireGL V5725,
ATI Radeon HD 3200 Graphics, ATI Radeon 3100 Graphics,
ATI Radeon HD 3300 Graphics, ATI Radeon 3000 Graphics, SUMO, SUMO2,
ATI Radeon HD 4200, ATI Radeon 4100, ATI Mobility Radeon HD 4200,
ATI Mobility Radeon 4100, ATI Radeon HD 4290, ATI Radeon HD 4250,
AMD Radeon HD 6310 Graphics, AMD Radeon HD 6250 Graphics,
AMD Radeon HD 6300 Series Graphics,
AMD Radeon HD 6200 Series Graphics, PALM, CYPRESS,
ATI FirePro (FireGL) Graphics Adapter, AMD Firestream 9370,
AMD Firestream 9350, ATI Radeon HD 5800 Series,
ATI Radeon HD 5900 Series, ATI Mobility Radeon HD 5800 Series,
ATI Radeon HD 5700 Series, ATI Radeon HD 6700 Series,
ATI Mobility Radeon HD 5000 Series, ATI Mobility Radeon HD 5570,
ATI Radeon HD 5670, ATI Radeon HD 5570, ATI Radeon HD 5500 Series,
REDWOOD, ATI Mobility Radeon Graphics, CEDAR, ATI FirePro 2270,
ATI Radeon HD 5450, CAYMAN, AMD Radeon HD 6900 Series,
AMD Radeon HD 6900M Series, Mobility Radeon HD 6000 Series, BARTS,
AMD Radeon HD 6800 Series, AMD Radeon HD 6700 Series, TURKS, CAICOS,
ARUBA, TAHITI, PITCAIRN, VERDE, OLAND, HAINAN, BONAIRE, KABINI,
MULLINS, KAVERI, HAWAII
[ 50.183] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 50.183] (II) FBDEV: driver for framebuffer: fbdev
[ 50.183] (II) VESA: driver for VESA chipsets: vesa
[ 50.183] (EE) open /dev/dri/card0: No such file or directory
[ 50.183] (WW) Falling back to old probe method for modesetting
[ 50.183] (II) Loading sub module "fbdevhw"
[ 50.183] (II) LoadModule: "fbdevhw"
[ 50.184] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 50.184] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 50.184] compiled for 1.20.13, module version = 0.0.2
[ 50.184] ABI class: X.Org Video Driver, version 24.1
[ 50.184] (EE) Unable to find a valid framebuffer device
[ 50.184] (WW) Falling back to old probe method for fbdev
[ 50.184] (II) Loading sub module "fbdevhw"
[ 50.184] (II) LoadModule: "fbdevhw"
[ 50.184] (II) FBDEV(2): using default device
[ 50.184] vesa: Refusing to run on UEFI
[ 50.184] (EE) Screen 0 deleted because of no matching config section.
[ 50.184] (II) UnloadModule: "modesetting"
[ 50.184] (II) UnloadModule: "fbdev"
[ 50.184] (II) UnloadSubModule: "fbdevhw"
[ 50.184] (II) FBDEV(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 50.184] (==) FBDEV(0): Depth 24, (==) framebuffer bpp 32
[ 50.184] (==) FBDEV(0): RGB weight 888
[ 50.184] (==) FBDEV(0): Default visual is TrueColor
[ 50.184] (==) FBDEV(0): Using gamma correction (1.0, 1.0, 1.0)
[ 50.184] (II) FBDEV(0): hardware: EFI VGA (video memory: 14400kB)
[ 50.184] (DB) xf86MergeOutputClassOptions unsupported bus type 0
[ 50.184] (II) FBDEV(0): checking modes against framebuffer device...
[ 50.184] (II) FBDEV(0): checking modes against monitor...
[ 50.184] (II) FBDEV(0): Virtual size is 2560x1440 (pitch 2560)
[ 50.184] (**) FBDEV(0): Built-in mode "current": 368.7 MHz, 135.6 kHz, 92.6 Hz
[ 50.184] (II) FBDEV(0): Modeline "current"x0.0 368.73 2560 2592 2656 2720 1440 1444 1448 1464 -hsync -vsync -csync (135.6 kHz b)
[ 50.184] (==) FBDEV(0): DPI set to (96, 96)
[ 50.184] (II) Loading sub module "fb"
[ 50.184] (II) LoadModule: "fb"
[ 50.184] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 50.185] (II) Module fb: vendor="X.Org Foundation"
[ 50.185] compiled for 1.20.13, module version = 1.0.0
[ 50.185] ABI class: X.Org ANSI C Emulation, version 0.4
[ 50.185] (**) FBDEV(0): using shadow framebuffer
[ 50.185] (II) Loading sub module "shadow"
[ 50.185] (II) LoadModule: "shadow"
[ 50.185] (II) Loading /usr/lib/xorg/modules/libshadow.so
[ 50.186] (II) Module shadow: vendor="X.Org Foundation"
[ 50.186] compiled for 1.20.13, module version = 1.1.0
[ 50.186] ABI class: X.Org ANSI C Emulation, version 0.4
[ 50.186] (II) UnloadModule: "radeon"
[ 50.186] (II) Unloading radeon
[ 50.186] (II) FBDEV(0): FBIOBLANK: Invalid argument (Screen blanking not supported by kernel - disabling)
[ 50.187] (==) FBDEV(0): Backing store enabled
[ 50.187] (==) FBDEV(0): DPMS enabled
[ 50.187] (II) Initializing extension Generic Event Extension
[ 50.187] (II) Initializing extension SHAPE
[ 50.187] (II) Initializing extension MIT-SHM
[ 50.187] (II) Initializing extension XInputExtension
[ 50.188] (II) Initializing extension XTEST
[ 50.188] (II) Initializing extension BIG-REQUESTS
[ 50.188] (II) Initializing extension SYNC
[ 50.188] (II) Initializing extension XKEYBOARD
[ 50.188] (II) Initializing extension XC-MISC
[ 50.188] (II) Initializing extension SECURITY
[ 50.188] (II) Initializing extension XFIXES
[ 50.188] (II) Initializing extension RENDER
[ 50.188] (II) Initializing extension RANDR
[ 50.188] (II) Initializing extension COMPOSITE
[ 50.188] (II) Initializing extension DAMAGE
[ 50.188] (II) Initializing extension MIT-SCREEN-SAVER
[ 50.188] (II) Initializing extension DOUBLE-BUFFER
[ 50.188] (II) Initializing extension RECORD
[ 50.188] (II) Initializing extension DPMS
[ 50.188] (II) Initializing extension Present
[ 50.188] (II) Initializing extension DRI3
[ 50.188] (II) Initializing extension X-Resource
[ 50.188] (II) Initializing extension XVideo
[ 50.188] (II) Initializing extension XVideo-MotionCompensation
[ 50.188] (II) Initializing extension GLX
[ 50.188] (II) AIGLX: Screen 0 is not DRI2 capable
[ 50.406] (II) IGLX: Loaded and initialized swrast
[ 50.406] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 50.406] (II) Initializing extension XFree86-VidModeExtension
[ 50.406] (II) Initializing extension XFree86-DGA
[ 50.406] (II) Initializing extension XFree86-DRI
[ 50.406] (II) Initializing extension DRI2
[ 50.428] (EE) XKB: Couldn't open rules file /usr/share/X11/xkb/rules/evdev
[ 50.428] (EE) XKB: Failed to load keymap. Loading default keymap instead.
[ 50.428] XKB: Failed to compile keymap
[ 50.428] Keyboard initialization failed. This could be a missing or incorrect setup of xkeyboard-config.
[ 50.428] (EE)
Fatal server error:
[ 50.428] (EE) Failed to activate virtual core keyboard: 2(EE)
[ 50.428] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 50.428] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 50.428] (EE)
[ 50.436] (EE) Server terminated with error (1). Closing log file.
sudo journalctl --boot -p4
-- Journal begins at Mon 2021-11-15 14:52:03 CST, ends at Tue 2021-11-16 14:36:35 CST. --
Nov 16 14:14:42 pc kernel: efifb: Ignoring BGRT: unexpected or invalid BMP data
Nov 16 14:14:42 pc kernel: ACPI: Invalid passive threshold
Nov 16 14:14:42 pc systemd[1]: Configuration file /etc/systemd/system/piavpn.service is marked executable. Please remove executable permission bits. Proceeding anyway.
Nov 16 14:14:42 pc kernel: acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
Nov 16 14:14:42 pc kernel: acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
Nov 16 14:14:43 pc kernel: iwlwifi 0000:06:00.0: api flags index 2 larger than supported by driver
Nov 16 14:14:43 pc systemd-xdg-autostart-generator[436]: Configuration file /home/nathan/.config/autostart/org.kde.yakuake.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Nov 16 14:14:43 pc systemd[387]: default.target: Wants dependency dropin /home/nathan/.config/systemd/user/default.target.wants/pia.service is not a symlink, ignoring.
Nov 16 14:14:43 pc kernel: thermal thermal_zone4: failed to read out thermal zone (-61)
Nov 16 14:14:44 pc kernel: kauditd_printk_skb: 56 callbacks suppressed
Nov 16 14:14:50 pc kernel: kauditd_printk_skb: 355 callbacks suppressed
Nov 16 14:15:01 pc kernel: kauditd_printk_skb: 11 callbacks suppressed
Please let me know what i can do to recover, Ideally, I’d like to learn from this and not reformat. I’ve also updated and messed up all the configs in /etx/x11/xorg.conf.d/*
I’ve also tried using the manjaro mhwd tool to install the correct drivers, but that doesnt seem to work either.
cheers
