Hi there! I have Manjaro 21 w/Gnome 40, in a desktop PC with Ryzen 5900 and NVidia 1660 ti. I use 3 monitors, one of which I watch using a mirror (technically a beamglass, part of a teleprompter). In order to look at the correct image, I need to horizontally flip the image for this display.
Through the command line, I successfully achieve the effect by typing: xrandr --output DP-2 --reflect x
I tried to make the changes permanent following this procedure. I created the file /etc/X11/xorg.conf.d/10-monitor.conf with the following contents:
Section "Monitor"
Identifier "DP-2"
Option "reflect" "x"
EndSection
but to no avail. Nothing happens after boot. Do you know if I mistyped anything? Is there a log file I could check to find out what the problem might be?
you would see that there is not such an option like “reflection” at the monitor section. Instead you have to do something like this, if I understood correctly:
I had found the “reflect” option from this page, which seems to describe a specific version of xorg.conf, so no luck there. Sadly “rotate” does not flip the display, but rather rotates it, which is not satisfactory in my particular case.
I have also tried creating an ~/.xprofile and /etc/xprofile which the command line statement that does work ( xrandr --output DP-2 --reflect x), but also no luck. According to this wiki entry, GDM should source .xprofile and /etc/xprofile, but nothing happens and I am not sure where to look for any kind of associated logging.
Thanks, but luckily performing mirroring through xandr in the command line already works. My problem is I can’t find a way of performing the mirroring automatically after booting. Right now I run it manually every time I boot or turn off/on a display.
Since gnome has zsh by default, try to add it to this file: ~/.zshrc.
Or another thing: ~/.config/autostart ← there you can add *.desktop files which should start at the beginning. Create a script, make it executable, add it to /bin or ~/bin/ (in this case also add export PATH=$HOME/bin:$PATH to this file ~/.zshrc). Then create a desktop file, which will execute the script at the autostart directory.
gnome-tweaks has also an option to manage autostarts.
