Hello,
XnView MP (1.3.1-1), Okular (22.08.2-1), and Flameshot (12.1.0-1) all freeze upon calling up for “save as” dialog. Except freezing up, XnView MP and Okular rapidly increase RAM usage, and then I have to either kill the process or to wait for automatic termination.
For example, I open a 3-4 Mb picture in XnView MP and do some editing (resize, crop etc.), everything is good, at this moment the app takes 151 MiB. But then, once I call for “Save As”, the app quickly increases RAM usage up to 4.1 GiB and freezes up.
So does the Okular, and what’s interesting, Okular eats up the same 4.1 GiB after calling up Save As dialog, or Print as PDF (I wanted to affix screenshots to demonstrate, but cannot do this, probably because it is my first post here). Flameshot just freezes up, its RAM usage doesn’t changed; and if I use Save (to predefined location), i.e. without calling up for file browser window, it works normally, no freeze.
During those issues, despite to increase RAM usage, I still have about of 8 GiB free RAM, so I guess it’s not the case of not enough RAM.
I suspect this might be related to the fact that all those apps are Qt5 depended ones. However, in the near past they were operating normally, perhaps something went wrong after recent updates. Unfortunately, I do not know where to see exactly, that’s why I hope for your help and advice.
My other apps (Thunderbird, LibreOffice, Firefox, TeX Studio, Inkscape) behave properly whenever I want to save as or to print to a file.
Here is the basic information of my system:
Kernel: 5.15.76-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
Desktop: Xfce v: 4.16.1 tk: Gtk v: 3.24.34 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: LENOVO product: 20TA002ERT v: ThinkPad E14 Gen 2
Mobo: LENOVO model: 20TA002ERT serial: <superuser required> UEFI: LENOVO
v: R1EET28W(1.28 ) date: 11/09/2020
ID-1: BAT0 charge: 46.3 Wh (100.0%) condition: 46.3/45.0 Wh (102.8%)
volts: 12.3 min: 11.1 model: LGC 5B10X026 type: Li-poly serial: <filter>
status: full cycles: 183
RAM: total: 15.34 GiB used: 2.06 GiB (13.4%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: quad core model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
smt: enabled arch: Tiger Lake rev: 1 cache: L1: 320 KiB L2: 5 MiB L3: 8 MiB
Speed (MHz): avg: 1208 high: 1262 min/max: 400/4200 cores: 1: 1262 2: 1201
3: 1201 4: 1202 5: 1201 6: 1201 7: 1200 8: 1201 bogomips: 38720
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq
pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand
rdseed rdt_a rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect
ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
xtpr
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo
driver: i915 v: kernel arch: Gen-12.1 ports: active: HDMI-A-1 off: eDP-1
empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 00:02.0 chip-ID: 8086:9a49
class-ID: 0300
Device-2: Luxvisions Innotech Integrated Camera type: USB driver: uvcvideo
bus-ID: 3-8:4 chip-ID: 30c9:0014 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary model: Philips PHL 273V7
serial: <filter> res: 1920x1080 hz: 60 dpi: 82
size: 598x336mm (23.54x13.23") diag: 686mm (27") modes: max: 1920x1080
min: 720x400
Monitor-2: eDP-1 note: disabled model: AU Optronics 0x403d res: 1920x1080
dpi: 158 size: 309x174mm (12.17x6.85") diag: 355mm (14") modes: 1920x1080
API: OpenGL Message: Unable to show GL data. Required tool glxinfo
missing.
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Lenovo
driver: sof-audio-pci-intel-tgl bus-ID: 00:1f.3 chip-ID: 8086:a0c8
class-ID: 0401
Sound API: ALSA v: k5.15.76-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.59 running: no
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
vendor: Lenovo driver: r8169 v: kernel pcie: speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: down mac: <filter>
bus-ID: 3-10:8 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 296.91 GiB used: 149.86 GiB (50.5%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZALQ256HAJD-000L1
size: 238.47 GiB speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter>
rev: BL1QFXV7 temp: 27.9 C scheme: GPT
ID-2: /dev/sda type: USB vendor: SanDisk model: USB 3.2Gen1
size: 58.44 GiB type: N/A serial: <filter> rev: 1.00 scheme: GPT
ID-1: / size: 74.62 GiB used: 34.11 GiB (45.7%) fs: ext4 dev: /dev/nvme0n1p3
label: N/A uuid: 18965959-9320-46bf-831c-c1327c6541ef
ID-2: /boot/efi size: 499 MiB used: 312 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p1 label: N/A uuid: 72AB-0BF9
ID-3: /home size: 154.55 GiB used: 115.75 GiB (74.9%) fs: ext4
dev: /dev/nvme0n1p4 label: N/A uuid: 45aea03b-ea4e-48ba-8dc5-06b8384b4c4b
ID-1: swap-1 type: partition size: 3.91 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p2 label: N/A uuid: 69d8f401-46a0-4a63-9f3c-2b10e819123f
ID-1: /dev/sda1 size: 58.44 GiB fs: exfat label: N/A uuid: ACA8-3126
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Hub-4: 3-3:2 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2817 class-ID: 0900
Device-1: 3-3.2:5 info: Logitech Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 046d:c077 class-ID: 0301
Device-2: 3-3.3:7 info: Logitech LogiG MKeyboard type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 046d:c349 class-ID: 0300
Device-3: 3-5:3 info: SanDisk 3.2Gen1 type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 224mA
chip-ID: 0781:558b class-ID: 0806 serial: <filter>
Device-4: 3-8:4 info: Luxvisions Innotech Integrated Camera type: Video
Device-5: 3-9:6 info: Synaptics type: <vendor specific> driver: N/A
interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 06cb:00da
class-ID: ff00 serial: <filter>
Device-6: 3-10:8 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-5: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-6: 4-1:2 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.2 speed: 5 Gb/s
chip-ID: 2109:0817 class-ID: 0900
System Temperatures: cpu: 48.0 C mobo: N/A
Fan Speeds (RPM): fan-1: 0
Processes: 269 Uptime: 4m wakeups: 3 Init: systemd v: 251 default: graphical
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1624
Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.23
