hi, guys, I wanna know what is the default power management software? is it TLP ? if I wanna improve the efficiency of my laptop, is TLP conflict with the default power management software?
Default power management depends on desktop environment, e.g. Gnome uses upower
. KDE uses powerdevil
Which DE do you use?
Manjaro Xfce includes tlp
for power management
thanks zesko, I’m using Gnome, so, will TLP and upower works together happy without conflict?
If you want to use the official Gnome power management, then not use TLP that is in the conflict.
- Uninstall
tlp
and disable all tlp service. - Install the optional dependency
power-profile-daemon
for gnome-control-center - Enable
sudo systemctl enable --now power-profile-daemon
, Power Profiles will be displayed - You can check
powerprofilesctl
See the example:
thanks a lot
